| DW12TED4 TURBO DIESEL |
DIESEL FILTER WATER DETECTOR:
| DIESEL FUEL |
| EEC 2000 DEPOLL (ENGINE) |
PRE-FILTER:
| ASSEMBLY WITHOUT PRE-FILTER |
| EW/DW |
CATALYTIC CONVERTER:
| 3 PARTS CATALYST |
| MNTG EXCHANGER ON ENG & G/BOX |
| L4 VEHICLE TECHNICAL DEPOLLUTION |
| PARTICLE FILTER |
| MOUNTING BOSCH |
| BVA4 |
| HP20 (AG) |
| CP 23 X 66 |
SPEEDOMETER DRIVE:
| W/O TACHO TORQUE |
| 16 INCH MARGUERITE ALLOY WHEEL |
| TYRE 215X60X16 V |
WHEELS FITTED:
| 6,5" RIM ROAD WHEELS |
| ALLOY WHEEL ASSEMBLY 1 |
| TYRE DEFLECTION INDICATOR |
| HP AUTOMATIC GEARBOX |
ABS:
| WITH ABS BRAKES |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 26 |
ANTI-THEFT DEVICE:
| STANDARD ANTI-THEFT |
STEERING COLUMN:
| MANUALLY ADJUSTED STEERING COLUMN |
STEERING:
| UNVARIABLE POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 23 |
| NORMAL SUSPENSION |
ACTIVE SUSPENSION:
| WITHOUT VARIABLE SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT:
| ABS 5-3 |
| WITHOUT WHEEL CAP |
| W/O ENGINE UNDERSHELDING |
| EXT MIRROR ELECTRIC-FOLD BACK |
| W/O HEADLAMP WIPER |
| FRONT BUMPER BLANK - RH SIDE |
| FRONT FOG LIGHTS |
| HT EXT RRVW MIRROR EL INT CONTR |
| OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL |
| STEEL WHEEL + STANDARD TYRE |
EXTERIOR REAR VIEW MIRROR (GLASS APPEARANCE):
| TINTED EXT REAR VIEW MIRROR |
| DOMED DRIVER’S DOOR MIRROR GLASSS |
| FIXED ROOF |
| LAMINATED WINDSCREEN + SIDE REAR TOUGHENED |
| LEATHER L005 + CARPET ARGALI V145 "C9" |
| WITH THEFT PROTECTION ALARM |
| REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS |
REAR SEAT ARMREST:
| WITH REAR ARMREST |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITH ALARM |
| TEMPERATE COUNTRIES |
| GRADUATION KMS/H |
| LEFT HAND DRIVE |
| BACK DIAL PLATE BLACK |
TACHOMETER (SIGNAL CONNECTION):
| REV COUNTER CALC |
CHILD SEAT ANCHORING POINTS:
| WITHOUT CHILD SEAT MOUNTING |
| SPEAKERS ON REAR PARCEL SHELF |
| REMOTE RADIO CONTROL |
POLLEN FILTER:
| WITH POLLEN FILTER |
| ELECTRIC REAR BLIND |
| PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT |
DRIVER SEAT CONTROL:
| MEMORY CTRL DRIVERS FRONT SEAT |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT ELEC CNTRL |
| PASSENGER LUMBAR ADJUSTMENT |
| MOUNTING COMPACT DISC |
| WITHOUT NAVIGATION SYSTEM |
HEADLAMP BULBS:
| HALOGEN BULB |
| SEQENT CONTR RR WINDOW LIFTER |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY (NAVIGATION+RADIO+CLOCK, TEMP, CD) |
| NON HEATED SEAT |
| THORAX SIDE + CURTAIN AIRBAG |
REMOTE CONTROL WINDOW CLOSING:
| REMOTE CONTROL WINDOW CLOSING |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
ON-BOARD COMPUTER:
| COMPUTER |
HEADLAMP HEIGHT ADJUSTER:
| REMOTE MANUAL HEADLAMP ADJUSTMENT |
| "RT2" RADIOTELEPHONE SYSTEM |
| SPEED CONTROL |
DRIVER’S SEAT HEIGHT CONTROL:
| PARR+FR DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
CARPET COVER:
| WITH CARPETMAT |
COOLANT LEVEL WARNING LAMP:
| WATER LEVEL WARNING |
ANTIPOLLUTION MALFUNCTION WARNING LAMP:
| WITHOUT ANTIPOLLUTION MALFUNCTION LED |
OBSTACLE DETECTION SYSTEM:
| OBSTACLE DETECTOR |
LATERAL BLINDS:
| WITHOUT SIDE BLINDS |
FRONT HEAD RESTRAINT (OPERATION):
| ELECTRIC FRONT HEAD REST |
FLOOR MAT:
| WITH CARPETMAT |
DOOR AND REAR PANEL TRIM TYPE:
| WITH LEATHER INSERT |
EQUALISER AMPLIFIER:
| WITH EQUALISER AMPLIFIER |
| CENTRAL DEAD LOCKING |
| 4 SPOKE SMOOTH LEATHER STEERING WHEEL |
FRONT SEAT MODULARITY/ERGONOMY PACK:
| MODULARITY/ERGONOMIC PACK FRONT ERGO 2 CUSHION |
| ALTERNATOR 150 AMP |
| BATTERY L2 400 |
| STARTER MOTOR CL 5 |
| WITHOUT PARTICULAR LIGHT |
SERVICE BATTERY:
| WITHOUT SERVICE BATTERY |
| STANDARD |
| NORMAL ATMOSPHERE |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
EQUIPMENT GROUP:
| BOURGEOIS EQUIPMENT |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SURFACE CONDITIONS:
| GOOD TERRAIN |
