Dekodowanie numeru VIN VSSZZZ6LZ2R008872 na www.automo.pl
Vehicle Identification No.: VSSZZZ6LZ2R008872
Date of production: 29.01.2002
Model year: 2002
Sales type: 6L1324
Engine code: ATD
Engine parameters: 4-cylinder, 74 kW (100 p.s.), 1.9 l
Transmission code: EWT
Interior trim code: CY
Roof color: H2
Exterior color / paint code: H2 / S7U
1E0: Without activated charcoal canister
6EA: Without additional side body covers (stone guard)
3B0: Without additional child seat anchor
6U0: Without additional seals outside
8LA: Without additional instruments/switches
2WA: Without additional tires
9TA: Without additional warning lights
4UF: Driver`s and front passenger air bag with front passenger air bag deactivation
1L0: Standard air cleaner
VK1: Air duct, type 1
8L3: Roof antenna
7AA: Electronic vehicle immobilization device
1C1: Antifreeze up to -25 degree celsius tolerance up to -30 degree C
9FA: Without automatic transmission indicator light
5B0: Backrest release for left front seat right front seat w/ "Easy Entry" funct.
T5X: 4-cylinder diesel engine 1.9 L unit 038.L
J0L: Battery 340 A (70 Ah)
5C7: Additional body measures
K8G: Hatchback
6J1: Special body treatment
3P0: Without bracket for first aid kit and warning triangle
9U0: Without brake pad wear indicator
1LQ: Front disc brakes with integrated adapter
1KD: Disc brakes, rear
1AP: Anti-spin regulation (ASR) with electronic differential lock (EDL), lightweight design
4L2: Dipping breakaway interior rear view mirror
2JG: Body-colored bumpers
7QA: Without CD/DVD for navigation
7A0: Without CD changer/CD player
5D1: Carrier frequency 433.92 MHz-434.42 Mhz
8R1: Center high-mounted stop light
3C1: Static lap belt, center rear
GA0: Without center sun visor
QA0: Without child seat
QJ0: Without aluminum/chrome work package
0Y1: Standard climatic zones
B0A: Component parts set without country-specific design requirement
6FF: Body-colored exterior mirror housings and various add-on parts
S0C: Introductory volume
8T0: Without cruise control system (CCS)
6Y0: Without cruise control warning system
4M5: Cup holder
4N2: Standard dashboard
4K3: Radio remote controlled central locking operated from inside and safe securing
3LD: Door and side trim panel
0A1: 2 doors
QN2: Drawer under right front seat
1X0: Front wheel drive
QS0: Without electronic map cooling system
0GE: Emission standard EU3
MS7: 4-cyl. turbo diesel eng. 1.9 L/74 kW TDIpump-jet injection system Base engine is T5X/T21/T71
A8D: Luxury equipment
0P0: Rear exhaust tailpipe (standard)
6XE: Exterior mirrors: electrically foldable and electrically adjustable/heated
2B3: Additional exterior noise suppression (hood, capsule and dash panel)
6A0: Without fire extinguisher
1T0: Without first aid kit and warning triangle
0TA: Without floor mats
QM1: Foot area lining with cover
AC1: Long frame forestructure
2V1: Dust and pollen filter
8WD: Integrated front fog light
6W0: Without license plate bracket front
0AQ: Front stabilizer
1SA: Without additional engine guard
2W0: Fuel filler cap
1Z0: Initial standard fuel filling
0F9: Cooled fuel system for diesel engine
2LB: Fuel tank with special material treatment
6R1: Leatherette gearshift boot
6Q4: Comfort gearshift knob/handle
C02: Operating permit, alteration
8GL: Alternator 120 A
4Z5: Glove compartment door with light
5N3: Folding grab handles
6PA: Plastic hand brake lever handle
8BG: Twin-headlight for driving on the right,with integrated high beam
8K0: Without special headlight activation
8X0: Without headlight washer system
8Q1: Headlight-range adjustment
3J7: Articulated and height-adjustable headrests for front seats
7E0: W/o heat accumulator/auxiliary heating
9X0: Without heated door lock cylinder
8P1: Heated rear window
9T0: Without heated washer nozzles
9AK: Climatronic with impact pressure control free of cfc
8Y4: High-sounding horn
1EX: Special identification plate for EC for M1 passenger vehicle
0RA: Without ignition/starter switch locking system
2G5: Filler neck module 1 without insert
5TC: Without decorative inserts
0EJ: Installation differentiation for transmission MQ 250 vehicle components
U0C: Instrument insert with tachometer clock and km/h speedometer
9GB: Interior light with switch-off delay anddoor pillar switch
8QE: Key for locking system with remote control
5SL: Left exterior mirror: aspherical
4SK: Left vanity mirror not illuminated with cover and pocket
QQ0: Without add. lights (interior lighting)
4E0: Tailgate/trunk lid unlocking from outside
1PA: Standard wheel bolts
3U1: Foldable trunk cover
6SC: Tufted trunk floor covering
9E1: Luggage compartment lighting
5A6: Full fleece trunk lining
4U3: Luggage net on backrest, right seat
1Q0: Without mass damper for steering wheel
6NA: Unsplit molding roof liner
9Q1: Multi-function display/on-board computer
2VP: Nameplate set "TDI" "I"
7Q0: Without navigation device
3ZB: 3-point seat belts, outer rear with ECE label
0VB: Information kit in French
5K0: Without surface protection, with additional transit coating
7X0: Without park distance control
3CA: Without partition
4XC: Exterior pillar lining
7PB: Platform group class 2
4P2: Rear floor panel module, type 3
4B1: Protective side molding
6KD: Radiator grille
8YE: Radio for comfort-class vehicle
8S1: Reading light front
0N7: Heavy-duty rear axle (design 2)
8TC: Rear fog light for driving on the right
3Q1: Rear headrests
6P0: Without license plate bracket rear
3NC: Rear seat bench/backrest, split folding
8M1: Rear window wiper and washer system with intermittent control
4QV: 3-point seat belts with electric tensioner and height adjustment, front
5RQ: Right exterior mirror: convex
4TC: Right vanity mirror with cover
3FA: Without roof insert (standard roof)
3S0: Without roof rails/roof load rack
3L3: Manual height adjustment for front seats
9P0: Without seat belt reminder
N0H: Woven fabric seat covering
4A0: Without seat heater
QG0: Without service interval prolongation
G17: Front shock absorption
1JJ: Rear shock absorption, basic design
4X1: Side air bag front
4KX: Side and rear windows tinted green hinged quarter window operated manually
7R3: Side turn signal lights (white)
9JD: Smoking package, ashtray front
7B0: Without socket
1G2: Steel spare wheel with original equipment tires
8RM: 8 speakers (passive)
E0A: No special edition
0SG: Labels/plates in French
8CC: Speedometer sensor without seal (electronic speedometer sensor)
1N1: Power steering
2C5: Axial and vertical adjustable steering column
L0L: Left-hand drive vehicle
1MP: Steering wheel for air bag system
0KA: Without stickers and badges
8SA: Taillight assemblies, standard design
9W0: W/o car phone preparation/installation
V0A: Tires w/o specification of tire brand
HA9: Tires 195/55 R 15 85V
1S7: Tool kit and aluminum jack
1D0: Without trailer hitch
G0C: 5-speed manual transmission
0G4: Cable gearshift
2P1: Plastic trunk sill protection
B08: Type approval France
0CY: Vehicle class differentiation 6L0
F0A: No special purpose vehicle, standard equipment
AZ0: Vehicle with standard production scope
8W0: Without washer fluid level indicator
L39: Suspension range 39 installation control only, no requirement forecast
0YA: Weight range 1 installation control only, no requirement forecast
1NL: Covers for alloy wheels
C0F: Alloy wheels 6J x 15
4R1: Power windows
4GF: Windshield in heat-insulating glass
9PB: Windshield wiper arms/blades with additional guide vanes
8N4: Windshield wiper intermittent control with potentiometer (four speeds)
Q1A: Standard front seats
