Dekodowanie numeru VIN WVWZZZ6NZWY267063 na www.automo.pl
Vehicle Identification No.: WVWZZZ6NZWY267063
Model Designation: polo
Model: PO
Date of production: 18.04.1998
Model year: 1998
Sales type: 6N10P4
Engine code: AFH
Transmission code: CWX
Axle drive: 5S
Interior trim code: 65
Roof color: Z4
Exterior color/Paint Code: Z4/C9Z
Activated carbon canister: [1E1] : Activated carbon canister
Additional body covers, side: [6EA] : Without additional side body covers(stone guard)
Additional child seat anchors: [3B0] : Without additional child seat anchor
Backrest release: [3H3] : Backrest release for front seat(s)
Batteries: [J1L] : Battery 280 A (60 Ah)
Body measures: [5C0] : Without special body measures
Body style: [K8G] : Hatchback
Brake type, front: [1LF] : Disc brakes, front
Brake type, rear: [1KD] : Disc brakes, rear
Braking systems: [1AC] : Anti-lock brake system (ABS)
Bumper: [2JG] : Body-colored bumpers
Catalytic converter control: [8KA] : W/o catalytic converter warning light
Center high-mounted stop light: [8R1] : Center high-mounted stop light
Center rear seat belts: [3C1] : Static lap belt, center rear
Clutch actuation: [1K1] : Mechanical clutch actuation
Cruise control warning and speed limit system: [6Y0] : Without cruise control warning system
Cup holder: [4M0] : Without cup holder
Dashboard: [4N2] : Standard dashboard
Door and lid locking system: [4F4] : Central locking system
Door and side trim panels: [4AX] : Door and side trim panel partially inleather with special color trim
Doors: [0A1] : 2 doors
Duty-free tires: [1V0] : Without duty-free and cost-free tires
Engine specifications: [M64] : 4-cyl. gasoline engine 1.4 L/74 kW 16Vwith multi-point injection and MVEG 2base engine is T1N/T5G
Equipment levels: [A8C] : Comfort equipment
Exterior noise suppression measures: [2B7] : Additional exterior noise suppression
First aid kit / warning triangle: [1T0] : Without first aid kit and warningtriangle
Flame retardent materials: [4Q0] : No flame retardent materials
Floor mats: [0TL] : Front and rear floor mats (leatherettebinding)
Front cargo area: [5VA] : Without cargo area front
Front fog light/additional headlight: [8WA] : Without front fog light
Front stabilizer: [0AD] : Front stabilizer
Front turn signal lights: [6Z2] : White turn signal lights
Fuel systems: [0F2] : Fuel system for carburetor gasolineengine
Fuel tank treatment: [2LB] : Fuel tank with special materialtreatment
Gearshift boot/cover: [6R2] : Leather gearshift boot
Gearshift knob/handle: [6Q2] : Leather gearshift knob/handle
General operating permit, alterations: [C02] : Operating permit, alteration
Generators: [8GD] : Alternator 90A
Hand brake lever handle: [6PC] : Leather hand brake lever handle
Headlight: [8BB] : Halogen headlightfor driving on the right
Headlight washer system: [8X0] : Without headlight washer system
Headlight-range adjustment: [8Q1] : Headlight-range adjustment
Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating
Heated washer nozzles: [9T0] : Without heated washer nozzles
Heating and air conditioning system: [9AB] : Manually controlled air conditioning
Identification plates: [1EY] : Special identification platewith weight data, but without generaloperating permit (ROW)
Insert for the filling up of unleaded fuel/fuel type: [2G1] : Insert for the filling up of unleadedfuel
Interference suppression: [8E2] : Local interference suppression for FM/AMradio reception
Key for locking system: [8QA] : Key without LED
Left exterior mirror: [3BR] : Left exterior mirror: non-speherical,adjustable from inside
Luggage compartment cover: [3U1] : Foldable trunk cover
Luggage compartment floor covering: [6SE] : Flat needle-punched trunk floor covering
Manufacturing sequence differentiation: [0FB] : Pamplona manufacturing sequence
Mud flap: [6N0] : Without mud flaps
Nameplate set: [1RY] : Nameplate set "16V"for special color trim
Outer rear seat belts: [3ZB] : 3-point seat belts, outer rear with ECElabel
Paint preservative/transit coating: [5K1] : Paint preservative (wax)
Partition: [3CA] : Without partition
Protective side molding: [4B1] : Protective side molding
Radios: [8AA] : Without radio
Rear cargo area: [3GA] : Without cargo area
Rear headrests: [3Q1] : Rear headrests
Rear seats: [3NC] : Rear seat bench/backrest, split folding
Rear spoiler: [5J1] : Rear spoiler
Rear stabilizer: [0BB] : Rear stabilizer
Right exterior mirror: [3AD] : Right exterior mirror: convex,adjustable from inside
Seat covering: [N4M] : Partially leather seat covering
Second battery/battery installation: [8FA] : Without second battery
Side air bag: [4X0] : Without side air bag
Side lights: [8F6] : Dark colored side turn signal lights
Spare wheel/breakdown set: [1G6] : Space-saving spare wheel
Speaker installation: [8RE] : 4 speakers (passive)
Special color trim: [0UB] : Special color trim
Special labels/plates: [0SB] : Labels/plates in German
Start/stop system/regenerative braking: [7L0] : Without inertia benefit system/deceleration fuel cut-off/idle stopvalve
Steering: [1N1] : Power steering
Steering wheels: [2PZ] : Leather steering wheel for air bagsystem (rest-of-the-world)(lightweight design)
Sticker (customized or special edition): [0KA] : Without stickers and badges
Taillight assemblies: [8SB] : Taillight assembly w/ dark colored lens
Tires: [H2Y] : Tires 225/35 R18 87Y xl
Transmission specifications: [G0C] : 5-speed manual transmission
Type approval countries/countries with special requirements: [B13] : Type approval Switzerland
Vehicle class differentiation units/platform components: [0DH] : Vehicle class differentiation 6N0
Wheel covers: [1NL] : Covers for alloy wheels
Wheels: [C3Y] : Alloy wheels 6J x 14Offset 43
Window regulator: [4R1] : Power windows
Windshield glass type: [4GF] : Windshield in heat-insulating glass
Base engine: [T5G] : 4-cylinder gasoline engine 1.4 Lunit 030.J
Front seats: [Q2Q] : RECARO sports seats, front
Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer
