Dekodowanie numeru VIN WVWZZZ3CZ7E142314 na www.automo.pl
Vehicle Identification No.: WVWZZZ3CZ7E142314
Model Designation: passat var. 4motion
Model: PA
Date of production: 20.12.2006
Model year: 2007
Sales type: 3C515M
Engine code: BMP
Transmission code: JLR
Axle drive: 6S
Interior trim code: UP
Roof color: 2T
Exterior color/Paint Code: 2T/C9X
"Multimedia", video/DVD/notebook connection: [9WC] : Without "Multimedia" in vehicle
Activated carbon canister: [1E0] : Without activated charcoal canister
Additional child seat anchors: [3B4] : Child seat anchor forchild seat system ISOFIX
Additional warning lights: [9TC] : Additional reflectors (door area)
Antennas: [8ZG] : Antenna for AM/FM reception
Anti-theft protection system: [7AR] : Electronic vehicle immobilization devicewith alarm system and backup horn
Auxiliary heating: [9M9] : Parking heater with radio remote control
Backrest release: [3H2] : Backrest release for right front seat
Batteries: [J0L] : Battery 340 A (70 Ah)
Battery/alternator capacity: [NY0] : Standard battery/alternator capacity
Body measures: [5C0] : Without special body measures
Body style: [K8D] : Station Wagon Variant/Avant
Brackets: [3P1] : Bracket for first aid kit and warningtriangle
Brake type, front: [1LH] : Disc brakes, front
Brake type, rear: [1KU] : Disc brakes, rear
Braking systems: [1AT] : Electronic stabilization program (ESP)
Breakaway interior mirror: [4L6] : Breakaway interior rear view mirror,automatically dimming
Bumper: [2JC] : Comfort bumpers
CD ROM/DVD/SD card: [7QB] : CD ROM (Germany)
CD changer/CD player: [7A0] : Without CD changer/CD player
Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit
Center console: [3D3] : Center console
Center rear seat belts: [3C7] : 3-point seat belt for center rear seat
Country codes: [FE0] : Without country code (no DVD player invehicle)
Cruise control: [8T2] : Cruise control system (CCS)electronic
Cruise control warning and speed limit system: [6Y9] : W/o cruise control speed limit system
Cup holder: [4M6] : Cup holder
Customized installation: [FC0] : Without customized installation
Delivery equipment: [2A0] : Without delivery equipment
Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing
Door and side trim panels: [3LD] : Door and side trim panel
Drive layout: [1X1] : Four wheel drive
Electric interface for external use: [UF0] : Without electric interface
Electronic map cooling system: [QS0] : Without electronic map cooling system
Emission standard: [7GG] : Emission standard EU4 DPF
Engine specifications: [D7N] : 4-cyl. turbo diesel engine 2.0 L/103 kWTDI with pump-jet injection systembase engine is TM0/TP0/TR0
Equipment levels: [A8C] : Comfort equipment
Exterior mirror setting: [6XN] : Exterior mirrors: electricallyadjustable, separately heated
Exterior noise suppression measures: [2B0] : Without additional exterior noisesuppression
Fire extinguisher: [6A0] : Without fire extinguisher
First aid kit / warning triangle: [1T2] : Warning triangle
Floor mats: [0TD] : Front and rear floor mats
Front fog light/additional headlight: [8WD] : Integrated front fog light
Front license plate bracket: [6W1] : License plate bracket front (large)
Front seat, left: [3TF] : Comfort seat, front left
Front seat, right: [3SF] : Comfort seat, front right
Fuel quantity for initial filling: [1Z6] : Increase in initial standard fuelfilling
Fuel systems: [0F9] : Cooled fuel system for diesel engine
Gearshift knob/handle: [6Q2] : Leather gearshift knob/handle
General operating permit, alterations: [C11] : Operating permit, alteration
Generators: [8GV] : Alternator 180 A
Headlight: [8BV] : Twin headlight, for driving on theright, (gas discharge) with integratedhigh beam
Headlight activation: [8K8] : Low beam assistant with"Coming Home" function
Headlight washer system: [8X1] : Headlight washer system
Headlight-range adjustment: [8Q6] : Headlight-range adjustment, automatic/dynamic with fixed and dynamic bendinglight(AFS 2)
Headphone port, rear: [8MA] : Without headphone port rear
Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating
Heated washer nozzles: [9T1] : Heated washer nozzles, front
Heating and air conditioning system: [9AK] : Climatronic with impact pressurecontrol free of cfc
Insert for the filling up of unleaded fuel/fuel type: [2G0] : Without insert for the filling up offuel
Inserts: [5MA] : Decorative inserts
Installation differentiation for vehicle components: [0EN] : Installation differentiation fortransmission MQ 350vehicle components
Installation parts for engine (engine mount system): [1VG] : Installation parts for four-cylinderengine
Interior light in foot area: [6T0] : Without interior light in footwell
Left vanity mirror: [4SU] : Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid: [4E2] : Tailgate/trunk lid releasefrom inside (electrically)
Lockable wheel bolts: [1PA] : Standard wheel bolts
Luggage compartment floor covering: [6SM] : Needle-punched trunk floor covering(Dilours)
Lumbar support: [7P7] : Electrically adjustable lumbar supportfor left front seat
Mass damper for steering wheels: [1Q1] : Mass damper for steering wheel, 26.5Hz
Moldings: [4ZB] : Bright moldings
Multi-function display/trip computer: [9Q5] : Multi-function display with control
Nameplate set: [1DG] : Nameplate set "TDI"
Navigation device: [7Q5] : Navigation system with black-and-whitescreen
Operating voltage 12V plus 100 V inverter: [9Z0] : Operating voltage 12V
Outer rear seat belts: [3ZB] : 3-point seat belts, outer rear with ECElabel
Owner's manuals: [0VC] : Information kit in German
Paint coating: [FB0] : Standard paint coating
Paint preservative/transit coating: [5K0] : Without surface protection, withadditional transit coating
Park distance control: [7X0] : Without park distance control
Parking brake: [UH1] : Parking brake
Partition: [3CA] : Without partition
Pedestrian protection: [VL1] : Extended pedestrian protection measures
Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation
Protective side molding: [4B4] : Protective side molding
Radiator grille: [6KA] : Radiator grille
Radios: [8AY] : Radio/navigation system
Reading light: [8S7] : Two reading lights front
Rear cargo area: [3GA] : Without cargo area
Rear license plate bracket: [6P1] : License plate bracket rear (ECE)
Rear seats: [3NE] : Rear seat bench/backrest, split foldingwith center armrest
Remote-controlled garage door opener: [VC0] : W/o remote-controlled garage door opener
Right exterior mirror: [5RQ] : Right exterior mirror: convex
Right vanity mirror: [4TV] : Right vanity mirror, illuminated
Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen
Roof rails/roof load rack: [3S2] : Black roof rails
Scuff plates: [7M0] : Plastic scuff plates in door apertures
Seat belt check: [9P1] : Seat belt reminder, electriccontact in buckle
Seat covering: [N0U] : Cut pile seat covering
Seat ventilation/massage seat: [4D0] : Without seat ventilation/massage seat
Second battery/battery installation: [8FB] : Second battery
Shock absorption, chassis, front: [G07] : Front shock absorption
Shock absorption, chassis, rear: [1JA] : Rear shock absorption, basic design 1
Side air bag: [4X3] : Side air bag front with curtain air bag
Side lights: [7R3] : Side turn signal lights (white)
Ski bag: [3X2] : Load-through provision
Smoking/non-smoking package: [9JA] : Non-smoking package
Socket: [7B3] : 12-volt socket(s)
Spare wheel/breakdown set: [1G8] : Breakdown set
Speaker installation: [8RM] : 8 speakers (passive)
Special alarm systems: [9A0] : Without taxi alarm system
Special labels/plates: [2KW] : Labels/plates in German, French, andDutch
Steering: [1N3] : Speed-related variable steering assist(Servotronic)
Steering wheels: [1MA] : Steering wheel
TV reception/digital radio reception: [QV0] : W/o TV reception/digital radio reception
Taillight assemblies: [8SK] : Taillight assemblies with diodes (LED)
Telephone/telematics: [9W8] : Car phone preparation
Tie down straps/net/pocket: [6M0] : Without tie down straps/net/pocket
Tire pressure warning light: [7K0] : Without tire pressure warning light
Tires: [HJ7] : Tires 215/55 R16 97W x1
Tool kit and jack: [1S1] : Tool kit and jack
Transit coating: [NT0] : Transit coating (type 1)
Transmission specifications: [G0L] : 6-speed manual transmission forfour-wheel drive vehicle
Transmission types/gearshift mechanisms: [0G4] : Cable gearshift
Trunk sill protection: [2P1] : Plastic trunk sill protection
Type approval countries/countries with special requirements: [B01] : Type approval Germany
Umbrella: [NS0] : Without umbrella(s)
Vehicle class differentiation units/platform components: [0HG] : Vehicle class differentiation 3C0
Weight category front axle: [L30] : Suspension range 30installation control only, norequirement forecast
Weight category rear axle: [0YG] : Weight range 7installation control only, norequirement forecast
Wheel covers: [1NH] : Full wheel covers
Wheels: [C1G] : Steel wheels 6.5J x 16
Window regulator: [4R4] : Power windows with comfort operation andcircuit breaker
Windshield glass type: [4GF] : Windshield in heat-insulating glass
Windshield wiper intermittent control: [8N3] : Windshield wiper intermittent controlwith rain sensor
Audio-response system/voice control: [QH0] : Without voice control
Child seats: [QA0] : Without child seat
Compass/traffic sign display: [QR0] : Without compass/traffic sign display/traffic signs recognition
Service interval prolongation: [QG1] : Service interval prolongation
Tray areas package: [QE2] : Storage box
Base engine: [TP0] : 4-cylinder diesel engine 2.0 Lunit 03G.8
Instrument inserts: [U5A] : Instrument insert, km/h speedometer
