200 000 km w 2007 roku
1 0DY L AED installation differentiation for build status of vehicle class B5 (AUDI) unit components
2 0G1 L GES gearshift lever
3 0GE L AGM emissions concept EU 3
4 0JG L GKV weight category front axle weight range 7
5 0K0 L ASY without alternative drive module
6 0L2 L GAB electric throttle actuation
7 0LW L SIZ special plates/stickers/ safety certificates for Germany
8 0ST L SAU labels/plates in German and French
9 0TD L ZFM front and rear floor mats
10 0VC L BTA information kit in German
11 0W1 L AKZ label for central electric German-speaking countries
12 0YE L GKH weight category rear axle weight range 5
13 1AT E BRS electronic stabilization program (ESP)
14 1BA L DAE standard suspension/shock absorption
15 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
16 1D0 L AHV without towing attachment
17 1E0 L AKB without activated charcoal canister
18 1EX L TYP special identification plate for EC
19 1G3 L RER alloy spare wheel with original equipment tires
20 1KD L BAH disc brakes, rear
21 1LB L BAV disc brakes, front
22 1PA L ABR standard wheel bolts
23 1SA L TWU without additional engine guard
24 1T3 L VBK First aid kit with warning triangle
25 1VG L TWL installation parts for four-cylinder engine
26 1WD L GFW transmission shaft for tripod joints
27 1X0 L ATA front wheel drive
28 1YA L GFH without transmission shafts f. rear axle
29 1Z0 L KRM initial standard fuel filling
30 2A5 L UEA delivery equipment (transit coating) with thin seat cover
31 2B1 L GRD additional exterior noise suppression
32 2G0 L EBB without insert for the filling up of fuel
33 2K1 L SFS reinforced bumpers
34 2PG L LRA steering wheel
35 2T0 L DAT without double-sized standard (DIN)
36 2WA L ZBR without additional tires
37 2Z1 L TYZ type sign at rear and "Quattro" nameplates respectively
38 3B0 L ZKV without additional child seat anchor
39 3C7 L SHM 3-point seat belt for center rear seat
40 3CB L TRW removable net partition
41 3FA L DEI without roof insert (standard roof)
42 3L1 L SIE manual height adjustment for left front seat
43 3NZ L HIS rear seat bench unsplit, backrest split folding
44 3Q6 L KOH three rear headrests
45 3S2 E DAR black roof rails
46 3X0 L DLS without load-through provision
47 3Y0 L SSR without roll-up sun screen
48 4A0 L SIH without seat heater
49 4E0 L SDH tailgate/trunk lid unlocking from outside
50 4GH L WSS windshield tinted with windshield sunshield
51 4K4 P TKV radio remote controlled central locking operated from inside and separate trunk release
52 4L2 L IRS dipping breakaway inside rear view mirror
53 4M0 L BEH without cup holder
54 4N0 L INT standard dashboard
55 4P0 L PBH rear floor panel module, type 1
56 4R2 L FEH power windows front, mechanical window regulators rear
57 4SB L MSL vanity mirror left
58 4TB L MSR vanity mirror right
59 4UE L AIB airbag f. driver a. front seat passenger
60 4W0 L KBO without cassette and CD storage unit
61 4X1 L SAB side airbag front
62 4ZE L ZIE black moldings
63 5A5 L GRV trunk lining, with stowage trays
64 5C0 L KSA without special body measures
65 5D1 P TRF carrier frequency 433.92 MHz
66 5E1 L SAA without sill top with door cover
67 5J0 L HES without rear spoiler
68 5K1 L LAC paint preservative (wax)
69 5MY P EIH decorative aluminum inserts "stars graphite"
70 5RQ L ASR outer right rear view mirror: convex
71 5SL L ASL outer left rear view mirror: non-spherical
72 6E3 E MAS center armrest front
73 6FB L BBO body-colored outer rear view mirror housings
74 6M0 L GPS without tie down straps/luggage net
75 6N0 L SZF without mud flaps
76 6PA L HBV plastic hand brake lever handle
77 6Q1 L SAG plastic gearshift knob/handle
78 6R1 L SHV leatherette gearshift boot
79 6RA E FIT dashboard and door trim panel one-piece, single color
80 6U0 L ZTD without additional seals outside
81 6V1 L HEB rear trim panel (ECE)
82 6W5 L KZV front license plate bracket
83 6XD P ASE outer rear view mirrors: powered, heated
84 7A0 L CDW without CD changer/CD player
85 7AA L EDW electronic vehicle immobilization device
86 7CA L AKF without label for radio remote control
87 7K0 L RDK without tire pressure warning light
88 7M1 L EIL scuff plates in door apertures with metal inserts
89 7P0 L LOR without lumbar support in front and rear seats
90 7Q0 L NAV without navigation device
91 7QA L CDR without CD ROM
92 7X0 L EPH without park distance control
93 8GL L GEN alternator 120A
94 8JH L HSW ellipsoidal headlight for driving on the right
95 8K0 L FLS without special low beam mode
96 8KA L KUE w/o catalytic converter warning light
97 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
98 8Q1 L LWR headlight-range adjustment
99 8RN P LSE eight speakers (active)
100 8S4 L LEL two reading lights front, two rear
101 8T0 L GRA without cruise control system (CCS)
102 8TC L NEL rear fog light for driving on the right
103 8UC P RAO radio "chorus"
104 8WB L NES front fog lights
105 8X0 L SWR without headlight washer system
106 8Z5 L MKU engine cooling system, type 1
107 9AK L HKA "Climatronic" with impact pressure control free of cfc
108 9P0 L SGK without seat belt warning light
109 9Q0 L MFA without multi-function indicator/ on-board computer
110 9T1 L BWD heated washer nozzles, front
111 9W0 L VTV w/o car phone preparation/installation
112 9X6 P BTS heated door lock cylinder left with micro switch
113 9Y1 L ATE outdoor temperature gage
114 A00 L SAH no self-collection
115 A8S I AUS standard equipment
116 B0A L BLB component parts set without country-specific design requirement
117 B99 L TPL type approval EC
118 C15 E COC operating permit, alteration 15
119 C8N L RAD alloy wheels 6J x 15 style not designated; 4B0 601 025 L offset 45
120 E0A L AAU no special edition
121 F0A L FZS no special purpose vehicle, standard equipment
122 FA0 L SVO control of standard production
123 FC0 L IND without customized installation
124 G0C I GSP 5-speed manual transmission
125 H6S L REI tires 195/65 R 15 V
126 J0R L BAT battery 380 A (80 Ah)
127 K8D I KAR Station Wagon Variant/Avant
128 L0L L LEA left-hand drive vehicle
129 M3L L MOT 4-cyl. turbo diesel engine 1.9 L/85 kW TDI with pump-jet injection system base engine is T4N
130 N5F P SIB fabric seat covering
131 PFA G remote control for central locking
132 PW1 G winter package I
133 Q1A L VOS standard front seats
134 QH0 L SPR without voice control
135 QV0 L TVE w/o TV reception/digital radio reception
136 RBL G "chorus" radio with active speaker system
137 T4N I GMO 4-cylinder diesel engine 1.9 L unit 038.A
138 U2A L INS instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
139 V0A L REL tires w/o specification of tire brand
140 VC0 L GRT w/o remote-controlled garage door opener
141 WM3 G Ambition, Nautilus fabric
142 X0A G national sales program Germany
