P5ED:
| Power door locks |
V452:
| Vehicle anti-theft |
A364:
| Abs brakes |
LE14:
| Limited slip differential |
T643:
| Traction control |
V030:
| Vehicle stability control system |
DCC4:
| Driver airbag |
PA4E:
| Passenger airbag |
KA70:
| Keyless entry |
AFD8:
| Air conditioning |
S7E4:
| Separate driver/front passenger climate controls |
C469:
| Cruise control |
TA7F:
| Tachometer |
T008:
| Tilt steering |
TC5A:
| Tilt steering column |
L272:
| Leather steering wheel |
T114:
| Tire pressure monitor |
AC08:
| Am/fm radio |
C354:
| Cd player |
DE19:
| Driver multi-adjustable power seat |
L07A:
| Leather seat |
AAB8:
| Automatic headlights |
D835:
| Daytime running lights |
F98D:
| Fog lights |
HB91:
| High intensity discharge headlights |
F4AE:
| Front air dam |
R9F3:
| Rear spoiler |
S3E8:
| Splash guards |
AA42:
| Alloy wheels |
P38E:
| Power windows |
HC6B:
| Heated exterior mirror |
P673:
| Power adjustable exterior mirror |
IC14:
| Interval wipers |
RE3B:
| Rear window defogger |
S9CE:
| Seat adjuster, power, driver 6-way |
C030:
| Console, floor, lockable, includes 2 covered cupholders, ashtray with cigar lighter, auxiliary power outlet and CD storage |
F00B:
| Floormats, carpeted |
S4F5:
| Steering column, manual, Tilt-Wheel |
SA8E:
| Steering wheel, leather-wrapped, smaller, 3-spoke |
H07E:
| Head-Up Display, includes dot-matrix readouts for street mode, track mode with g-meter, vehicle speed, engine rpm, and readings from key gauges including water temperature and oil pressure |
I109:
| Instrumentation, analog, electronic, includes Driver Information Center with 2 line display |
T508:
| Tire Pressure Monitor System, air pressure sensors in each tire, pressure display in Driver Information Center |
O380:
| Oil life monitoring system |
D709:
| Door locks, power, programmable, includes lockout protection |
W869:
| Windows, power, includes driver and passenger express-down |
C92F:
| Cruise control, electronic with set and resume speed |
TE0A:
| Theft-deterrent system, push button start, immobilizer and audible visual alarm |
KB9D:
| Keyless Access, with push-button start, includes 2 remote transmitters which enable automatic door unlock and open by touching door switch |
HAD8:
| Hatch release, push button open |
DD43:
| Defogger, rear-window, electric |
A6BE:
| Air conditioning, dual-zone, automatic, includes individual climate settings for driver and right front passenger, automatic climate control and outside temperature display |
A036:
| Air filtration, includes pollen filter |
S188:
| Sound system, ETR AM/FM stereo with CD player and MP3 playback, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume, Theftlock and (U66) Sound system feature, 7-speaker system |
A8D8:
| Antenna, integral, hidden |
M9FD:
| Mirror, inside rearview, manual day/night, includes dual reading lights |
VEC6:
| Visors, illuminated vanity mirrors, driver and front passenger |
L9F4:
| Lighting, interior, courtesy, cargo and glovebox |
SD67:
| Storage, includes lockable glovebox, center console and 2 rear compartments with covers (One compartment contains battery on Z06) |
B305:
| Brakes, 4-wheel antilock, 4-wheel disc |
ABC8:
| Air bags, frontal, driver and right front passenger with passenger side suppression (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.) |
TA4D:
| Traction control, all-speed |
D053:
| Daytime running lamps |
HB3C:
| Headlamps, dual projector lamps, xenon high-intensity discharge low-beam, tungsten-halogen high-beam, includes automatic exterior lamp control |
FD31:
| Fog lamps, front, integral in fascia |
MC82:
| Mirrors, outside rearview, power, heated, body-color |
G6F8:
| Glass, Solar-Ray light tinted |
WC86:
| Wipers, intermittent, front |
C532:
| City 16/hwy 26 (7.0L engine/6-speed manual trans) |
EAB0:
| Engine, 7.0L (427 ci) LS7 V8 SFI (505 hp [376.6 kW] @ 6300 rpm, 470 lb.-ft. [634.5 N-m] @ 4800 rpm), includes dry sump oil system |
T3B7:
| Transmission, 6-speed manual, short-throw (Includes (GU6) Axle, 3.42 ratio.) |
A6F1:
| Axle, 3.42 ratio, limited slip |
R323:
| Rear wheel drive |
AF88:
| Active handling, improves traction and enhances vehicle stability |
E82A:
| Engine access, rear opening hood, includes underhood lamp |
ZD62:
| Z06 Performance Package, 4-wheel independent, includes transverse composite springs, power steering, engine oil, axle and transmission coolers, stiffer springs and stabilizer bars, specific shock absorbers, larger brakes with 6 piston front and 4 piston rear cross-drilled rotors and specific tires |
T1DD:
| Tires, front P275/35ZR18, extended mobility, Eagle F1 Supercar |
T3B6:
| Tires, rear P325/30ZR19, extended mobility, Eagle F1 Supercar |
W463:
| Wheels, Z06 silver painted aluminum, 18" x 9.5" (45.7 cm x 24.1 cm), front and 19" x 12" (48.3 cm x 30.48 cm), rear |
S1A9:
| Steering, power, speed-sensitive, rack and pinion |
F86E:
| Fuel capacity, approximate, 18 gallon (68 liters) |
E1F9:
| Exhaust, dual mode, aluminized stainless-steel with polished 4" stainless-steel tips |
