na to wygląda że to nie 2006r
Numer VIN - 1GNEC16K6PJ316154
Region - United states
Fabryka / Producent - Janesville, WI
Marka - Chevrolet
Model - Suburban\nRok - 1993
Nadwozie - 4 DOOR WAGON/SPORT UTILITY
Drzwi - 2-door
Silnik - 3800 cm3
Rodzaj paliwa - Petrol
Numer seryjny - 316154
A364 - Abs brakes
F21E - Full size spare tire
C3E4 - Cigarette lighter with illum ashtray
1DAA - 10" rearview mirror
C314 - Color-keyed molded plastic door trim panels
REF2 - Rh/lh padded armrests
AFE0 - Assist handles for outboard front/2nd seat passengers
FD84 - Full-length, color-keyed, cloth headliner with matching molding
DBFE - Dual padded color-keyed cloth sunshades
FCB9 - Front/rear dome lamps with front door-actuated switches
L0C7 - Lh rear side spare tire carrier
FDBA - Front/rear coat hooks
{292 - {v__1} 3-passenger front bench seat with outboard head restraints
EA88 - Embossed 2-piece black vinyl floor mat
CC73 - Color-keyed door sill plates
4231 - 4-spoke custom urethane steering wheel
G3A7 - Gauges-inc:speedometer,odometer,trip odometer,engine temperature/oil pressure/ fuel level gauges, voltmeter and additional telltale lights
HA48 - Headlamp-on warning buzzer
HFE4 - Hd deluxe heater/defogger with side window defogger
E44D - Etr am radio with digital clock/dual speakers, fixed mast antenna
43E2 - 4-wheel anti-lock brakes
M8D4 - Manual lap/shoulder safety belts for outboard front seat positions
M667 - Manual lap safety belt for center front seat position
EE8B - Energy absorbing steering column
F317 - Front seat head restraints
{39D - {zy1} solid paint
F57F - Front/rear chromed bumpers with black rub strips, rear black step pad
B085 - Black body-side molding
M54C - Molded grille painted argent
SEFF - Single rectangular halogen headlamps
D09B - Dual black below-eye-line type adjustable 9" x 6.5" mirrors
SA90 - Solar-ray tinted glass (all windows)
I20A - Intermittent windshield wiper system
UF82 - Upper windshield shade band
P3D6 - Panel rear doors
IC46 - Insulation on headliner/dash/doors/under cowl top & sides
E3B9 - Epa mileage - 13 city/17 hwy
(D33 - (5) 15" x 7" steel wheels
A8F7 - Argent painted wheels-inc: black hubcaps
5411 - 5.7l (350) efi v8 engine
P9BC - Power front disc/rear drum brakes with 4-wheel anti-lock system
{3F9 - {mx0} 4-speed electronically-controlled automatic transmission with od
T0F7 - Tools-inc: mechanical jack, wheel wrench
{D9A - {gu6} 3.42 rear axle ratio
HF85 - Hd 630 cca battery
1DF8 - 100 amp alternator
61BA - 6800# gvwr (2950 front/3968 rear), springs (2950 front/4000 rear), axles (3400 front/4000 rear)
I738 - Integral pwr steering
IA4F - Independent coil spring front suspension
S80E - Semi-floating hypoid rear axle with semi-elliptic 2-stage multi-leaf suspension
173B - 1.25" diameter front stabilizer bar
32BF - 32mm front/rear shock absorbers
{24E - {qha} (5) p235/75r15x all-season sbr bsw tires
4490 - 42 gallon fuel tank
P5ED - Power door locks
AFD8 - Air conditioning
C469 - Cruise control
TA7F - Tachometer
T008 - Tilt steering
CA40 - Cassette player
AA42 - Alloy wheels
P38E - Power windows
RE3B - Rear window defogger
3F4 - must select one of the following body codes
131 - panel doors (std) n/c
3A7 - tailgate-inc: lift glass w/drop gate, pwr release
480 - must select the following gvwr
6331 - 6800 gvwr (2950 front/3968 rear), springs (2950 front/4000 rear),axles (3400 front/4000 rear) (std) n/c
F05 - must select one of the following emission systems
6FF - std emission equipment n/c
BE1 - high altitude emission requirement n/c
A0A - california emission equipment
D1C - must select the following engine
052 - 5.7l (350) efi v8 engine (std) n/c
3F2 - must select the following transmission
805 - 4-speed electronically-controlled automatic transmission w/od (std) n/c
41D - must select one of the following axle ratios
16A - 3.42 rear axle ratio (std) n/c
CC5 - 3.73 rear axle ratio (req: kc4 v02 cooling)
LED5 - Locking differential rear axle
F2E - must select one of the following tires
B60 - p235/75r15x all-season sbr bsw tires (std) n/c
9AA - p235/75r15x all-season sbr wsw tires
9CD - must select one of the following decors
D58 - cheyenne decor-inc: base vehicle only (std) (req: n1a1 preferred equipment group) n/c
669 - silverado decor-inc: center seat, deluxe molding, steering wheel w/simulated leather, illum visor mirrors,vinyl door panels w/cloth/carpet trim, front door map pockets, appearance pkg, full wheel covers, map/glove box/ashtray/underhood lights, color-keyed carpeting/front-rear floor mats,bumper guards dual chrome mirrors,etr am/fm stereo up:um6, ux1 (n/a w/n1a1 preferred equipment group) n/c
7CE - must select one preferred equipment group no deletions allowed - additional opts may be ordered from following list only - available upgrades are noted as up: opt code
PE73 - Preferred equipment group 1-inc: cheyenne decor n/c
PA1F - Preferred equipment group 2-inc: silverado decor, front air cond up:c69 , tilt wheel, speed control, pwr windows/locks net
P3CD - Preferred equipment group 3-inc: silverado decor, front air cond up:c69 , tilt wheel, speed control, pwr windows/locks, etr am/fm stereo w/cassette up:ux1 , remote control mirrors, aluminum wheels (w/e55 body-inc:rear window wiper up:zp6 ) net
60D - must select one of the following seating options
F41 - additional seats not desired (req: n1a1 preferred equipment group) n/c
922 - center folding seat-inc:manual lap/shoulder safety belts for outboard positions, manual lap safety belt for center position
949 - center/rear seats-inc: folding center seat, removable folding rear seat, manual lap/shoulder safety belts for outboard positions, manual lap safety belts for center positions (w/ye9 decor-inc: third seat floor mats)
7D3 - must select one of the following seat types
F63 - vinyl bench seat (std) (n/a w/ye9 decor) n/c
BFE - custom cloth bench seat-inc: scotchgard fabric protector (req: ye9 decor)
98D - custom cloth reclining split bench seat-inc: scotchgard fabric protector (req: ye9 decor)
C6D - custom cloth reclining high back bucket seats-inc: scotchgard fabric protector, roof/floor console (req: ye9 decor)
B2F - leather reclining high back bucket seats-inc: leather seating areas, black leather-wrapped steering wheel, custom cloth door panels, scotchgard fabric protector on cloth areas, roof/floor console (req: ye9 decor) req: beige interior trim
165 - must select one of the following paint types
5D7 - solid paint (std) n/c
F6D - conventional 2-tone paint
E1A - deluxe 2-tone paint-inc: decal striping
F1D9 - Front all-weather air conditioning
F9B0 - Front/rear all-weather air conditioning-inc: dual controls
ACC1 - Appearance pkg-inc: chrome grille, composite halogen headlamps, dual horns
(851 - (5) roof marker lamps (n/a w/yf5 emissions)
B8EF - Black roof luggage carrier
C531 - Cold-climate pkg-inc: engine block heater
CFDA - Convenience pkg-inc: pwr door locks/side windows (w/zw9 body-inc:pwr panel door locks) (req: ye9 decor) n/c
CF02 - Convenience group-inc: elect spd control, tilt wheel
E7B6 - Engine oil cooler (req: v02 cooling)
HB5A - Hd radiator/trans oil cooling system
D3C3 - Deep tinted glass
A52E - Aux rear passenger heater
F5AF - Front license plate bracket n/c
D8CF - Dual stainless-steel camper-type 7.5 x 10.5 exterior mirrors (n/a w/n1a3 preferred equipment group)
D8B8 - Dual electric remote below-eye-line 8.5 x 5 painted exterior mirrors (req: ye9 decor, zq2 convenience group)
P338 - Priced order acknowledgement n/c
E8EF - Etr am/fm stereo w/seek-scan, digital clock (n/a w/n1a3 preferred equipment group)
E20C - Etr am/fm stereo w/seek-scan,cassette,digital clock
E7CF - Etr am stereo/fm stereo w/seek-scan,cassette, search-repeat,graphic equalizer,digital clock
R7E0 - Radio delete (req: n1a1 preferred equipment group) credit
P99D - Premium speaker system (req: ye9 decor, ux1 radio, zq2 convenience group)
E6CA - Elect rear window defogger (w/o zp6 rear window wiper/defogger req: zw9 body)
R29E - Rear window wiper/washer system (req: e55 body)
R2BE - Rear window wiper/washer system w/defogger (req: e55 body)
P7F4 - Pwr driver seat (req: l__3 or l__6 seat)
T372 - Tachometer
TAEA - Tow hooks
HEFC - Hd trailering special equipment-inc: platform hitch, wiring harness, hd radiator/trans oil cooler, engine oil cooler
R15D - Rally wheel trim (n/a w/n90 wheels, n1a3 preferred equipment group)
C66B - Cast aluminum wheels
R28D - Retail fuel amenity delete avail to qualified fleet buyer only
otomoto.pl/chevrolet-suburban-C27282441.html
