Dziwne...
The CARFAX database currently contains no records for this vehicle. Please check back again soon, as our database is continually updated.
P5ED:
| Power door locks |
V452:
| Vehicle anti-theft |
A364:
| Abs brakes |
LE14:
| Limited slip differential |
T643:
| Traction control |
DCC4:
| Driver airbag |
PA4E:
| Passenger airbag |
KA70:
| Keyless entry |
AFD8:
| Air conditioning |
S7E4:
| Separate driver/front passenger climate controls |
C469:
| Cruise control |
TA7F:
| Tachometer |
T008:
| Tilt steering |
TC5A:
| Tilt steering column |
L272:
| Leather steering wheel |
T114:
| Tire pressure monitor |
AC08:
| Am/fm radio |
C354:
| Cd player |
DE19:
| Driver multi-adjustable power seat |
L07A:
| Leather seat |
R627:
| Removable top |
AAB8:
| Automatic headlights |
D835:
| Daytime running lights |
F98D:
| Fog lights |
HB91:
| High intensity discharge headlights |
F4AE:
| Front air dam |
PAF7:
| Power trunk lid |
AA42:
| Alloy wheels |
RD9B:
| Run flat tires |
P38E:
| Power windows |
HC6B:
| Heated exterior mirror |
P673:
| Power adjustable exterior mirror |
IC14:
| Interval wipers |
RE3B:
| Rear window defogger |
S9CE:
| Seat adjuster, power, driver 6-way |
C030:
| Console, floor, lockable, includes 2 covered cupholders, ashtray with cigar lighter, auxiliary power outlet and CD storage |
F00B:
| Floormats, carpeted |
S4F5:
| Steering column, manual, Tilt-Wheel |
S338:
| Steering wheel, leather-wrapped |
I109:
| Instrumentation, analog, electronic, includes Driver Information Center with 2 line display |
T8DF:
| Tire Pressure Monitor System, air pressure sensors in each tire pressure display in Driver Information Center |
O380:
| Oil life monitoring system |
D709:
| Door locks, power, programmable, includes lockout protection |
W869:
| Windows, power, includes driver and passenger express-down |
C92F:
| Cruise control, electronic with set and resume speed |
TE0A:
| Theft-deterrent system, push button start, immobilizer and audible visual alarm |
KB9D:
| Keyless Access, with push-button start, includes 2 remote transmitters which enable automatic door unlock and open by touching door switch |
I245:
| Ignition, keyless, engaged with push button start |
H550:
| Hatch release, push button open, includes power hatch pulldown |
DD43:
| Defogger, rear-window, electric |
A6BE:
| Air conditioning, dual-zone, automatic, includes individual climate settings for driver and right front passenger, automatic climate control and outside temperature display |
A036:
| Air filtration, includes pollen filter |
S188:
| Sound system, ETR AM/FM stereo with CD player and MP3 playback, includes Radio Data System, seek-and-scan, digital clock, auto-tone control, automatic volume, Theftlock and (U66) Sound system feature, 7-speaker system |
A8D8:
| Antenna, integral, hidden |
M9FD:
| Mirror, inside rearview, manual day/night, includes dual reading lights |
VEC6:
| Visors, illuminated vanity mirrors, driver and front passenger |
L9F4:
| Lighting, interior, courtesy, cargo and glovebox |
SAB1:
| Storage, includes lockable glovebox, center console and 2 rear compartments with covers |
B305:
| Brakes, 4-wheel antilock, 4-wheel disc |
A62C:
| Air bags, dual-stage, frontal, driver and front passenger (Always use safety belts and proper child restraints, even with air bags. See the Owners Manual for more safety information.) |
ADA7:
| Air bag, shut-off switch, front passenger |
LDE6:
| Lower Anchors for child safety seat |
TA4D:
| Traction control, all-speed |
D053:
| Daytime running lamps |
R243:
| Roof panel, removable, 1-piece, body-color |
H4EC:
| Headlamps, bi-functional, Xenon, high-intensity discharge, includes automatic exterior lamp control |
FD31:
| Fog lamps, front, integral in fascia |
MC82:
| Mirrors, outside rearview, power, heated, body-color |
G6F8:
| Glass, Solar-Ray light tinted |
WC86:
| Wipers, intermittent, front |
C28E:
| City 18/hwy 28 (6.0L engine/6-speed manual trans) |
C152:
| City 18/hwy 26 (6.0L engine/4-speed auto trans) |
E00D:
| Engine, 6.0L LS2 V8 SFI (400 HP [298.3 kW] @ 6000 rpm, 400 lb.-ft. [542.8 N-m @ 4400 rpm) |
T3B7:
| Transmission, 6-speed manual, short-throw (Includes (GU6) Axle, 3.42 ratio.) |
A45D:
| Axle, 3.42 ratio, limited slip (Included and only available with (MN6) Transmission, 6-speed manual.) |
R323:
| Rear wheel drive |
AF88:
| Active handling, improves traction and enhances vehicle stability |
E82A:
| Engine access, rear opening hood, includes underhood lamp |
S581:
| Suspension, 4-wheel independent, includes transverse fiberglass leaf springs |
T844:
| Tires, front P245/40ZR18, extended mobility, Eagle F1 |
TB97:
| Tires, rear P285/35ZR19, extended mobility, Eagle F1 |
W4BE:
| Wheels, 5-spoke painted aluminum, 18" x 8.5" (45.7 cm x 21.6 cm), front and 19" x 10.0" (48.3 cm x 25.4 cm), rear |
S1A9:
| Steering, power, speed-sensitive, rack and pinion |
F86E:
| Fuel capacity, approximate, 18 gallon (68 liters) |
EE92:
| Exhaust, aluminized stainless-steel with polished 3" stainless-steel tips |
