C11E:
| Child safety door locks |
P5ED:
| Power door locks |
V452:
| Vehicle anti-theft |
A364:
| Abs brakes |
E7CA:
| Electronic brake assistance |
T643:
| Traction control |
V030:
| Vehicle stability control system |
DCC4:
| Driver airbag |
F4FC:
| Front side airbag |
PA4E:
| Passenger airbag |
S710:
| Side head curtain airbag |
F46D:
| First aid kit |
TD1D:
| Trunk anti-trap device |
KA70:
| Keyless entry |
AFD8:
| Air conditioning |
S7E4:
| Separate driver/front passenger climate controls |
C469:
| Cruise control |
TA7F:
| Tachometer |
T008:
| Tilt steering |
TC5A:
| Tilt steering column |
L272:
| Leather steering wheel |
SF2A:
| Steering wheel mounted controls |
TA8A:
| Telescopic steering column |
T114:
| Tire pressure monitor |
T9EA:
| Trip computer |
AC08:
| Am/fm radio |
C354:
| Cd player |
C42A:
| Cd changer |
DE19:
| Driver multi-adjustable power seat |
F3F3:
| Front power lumbar support |
L07A:
| Leather seat |
P5E9:
| Passenger multi-adjustable power seat |
C39A:
| Cargo area tiedowns |
P7AD:
| Power sunroof |
M0DB:
| Manual sunroof |
AAB8:
| Automatic headlights |
D835:
| Daytime running lights |
F98D:
| Fog lights |
F4AE:
| Front air dam |
AA42:
| Alloy wheels |
P38E:
| Power windows |
HC6B:
| Heated exterior mirror |
E49E:
| Electrochromic interior rearview mirror |
P673:
| Power adjustable exterior mirror |
IC14:
| Interval wipers |
RE3B:
| Rear window defogger |
*AD9:
| **ALL STANDARDS ARE 2007 UNLESS OTHERWISE NOTED** |
4E5B:
| 4-wheel anti-lock brake system (ABS) |
D724:
| Driver & front passenger airbag (SRS) |
F279:
| Front/rear side curtain airbags (SRS) |
F0BE:
| Front seat-mounted side airbag (SRS) |
A24C:
| All-position 3-point seat belts |
FCF9:
| Front/rear outboard seat belts w/force-limiting pretensioners |
H249:
| Height-adjustable front shoulder belt anchors |
EB9D:
| Emergency locking retractor (ELR) for all seating positions |
A6C0:
| Automatic locking retractor (ALR) for front/rear passenger seats |
CB5A:
| Child restraint seat (CRS) w/top tether anchor brackets |
T452:
| Traction control (TRAC) |
VE8B:
| Vehicle dynamics integrated management (VDIM) w/cutoff function |
CF8A:
| Collapsible steering column |
I673:
| Impact-dissipating soft upper headliner & pillars |
F86D:
| Front/rear door side-impact beams |
F73B:
| Front/rear crumple zones |
OBA5:
| One-piece color-keyed front/rear bumpers |
L27D:
| Low grille w/color-keyed front airdam |
P017:
| Projector bulb headlamps w/headlamp off delay |
FD85:
| Front fog lamps |
L030:
| LED lights-inc: brake lights, tail lights |
U2C4:
| UV & infrared ray-reducing glass w/acoustic windshield glass |
CBA0:
| Color-keyed heated mirrors w/puddle lamps |
V72E:
| Variable intermittent wipers w/mist cycle |
36CB:
| 3.5L DOHC 24-valve direct injection V6 engine-inc: dual variable valve timing w/intelligence (VVT-i) |
6CC7:
| 6-speed electronically controlled automatic transmission w/intelligence (ECT-i), OD |
R323:
| Rear wheel drive |
D54E:
| Double wishbone front suspension-inc: high-mount upper arms, coil springs |
M6C6:
| Multi-link rear suspension-inc: high-mount upper arms, coil springs |
F6E8:
| Front/rear gas-filled shock absorbers |
FAC2:
| Front/rear stabilizer bars |
P6A4:
| P225/45VR17 all-season front tires |
PA1E:
| P245/45VR17 all-season rear tires |
16B2:
| 17" x 8" 10-spoke aluminum alloy wheels |
T89C:
| Temporary spare tire |
S0CF:
| Speed-sensitive electric pwr steering |
4C15:
| 4-wheel pwr ventilated disc brakes w/tandem brake booster |
E4B7:
| Electronic brake force distribution (EBD) |
B065:
| Brake assist (BA) |
D569:
| Dual stainless steel exhaust |
TE5A:
| Tool kit |
S488:
| Semi-analine leather seat trim |
1751:
| 10-way pwr front bucket seats (2006) |
R7F0:
| Rear bench seat w/trunk pass-through |
CBDA:
| Center console-inc: front armrest, (1) front cupholder, (2) rear cupholders, storage box |
1EE9:
| 1-piece cut pile carpeting |
C39E:
| Carpeted floor mats |
MA13:
| Manual tilt/telescopic steering wheel w/paddle shifters |
OC24:
| Optitron gauges-inc: 160-mph speedometer, 8000-rpm tachometer, fuel level, coolant temp |
W5A6:
| Warning lights-inc: battery, oil level, seat belt, brake, airbags, engine, oil pressure, low fuel, tire slippage (w/TRAC) |
I42E:
| Indicator lights-inc: door ajar, TRAC off, headlamp on, high beam, cruise control, fog lamps on |
T138:
| Tire pressure monitoring system |
SB08:
| Scheduled maintenance indicator light |
D2DB:
| Digital odometer w/(2) trip meters |
O704:
| Outside temp gauge |
DA64:
| Digital clock |
PD6F:
| Pwr windows-inc: auto-up/down, jam protection |
PFA6:
| Pwr door locks-inc: anti-lockout, speed-sensitive auto lock/unlock |
RE99:
| Remote keyless entry-inc: multi-function remote, lock, 2-stage unlock, trunk, panic feature, adjustable volume, rolling code |
IF69:
| Illuminated trunk & fuel filler door release |
RFD0:
| Retained accessory pwr for windows |
L6D5:
| Lexus personalized settings (LPS) |
RAB9:
| Remote keyless entry system-inc: lock, two-stage unlock, trunk open, panic feature, volume-adjustable tone, rolling code |
H117:
| HomeLink programmable garage door opener |
VB5E:
| Vehicle theft-deterrent system w/engine immobilizer |
A20D:
| Automatic climate control-inc: dust filter, pollen filter, speed & air flow indicators |
HED9:
| HD rear window defogger w/timer |
PA16:
| Premium 194-watt sound system-inc: AM/FM stereo, in-dash 6-disc CD changer, automatic sound levelizer (ASL), auxiliary audio input, (13) speakers |
R5A4:
| Rear glass-imprinted antenna w/FM diversity antenna |
C6A5:
| Cigarette lighter w/front ashtray |
(CBC:
| (1) cupholder behind shift lever |
MCA7:
| Metallic-finish interior accents |
EFBF:
| Electrochromic rearview mirror w/compass |
SE29:
| Sun visors w/vanity mirrors |
(7EA:
| (2) front/(2) rear assist grips |
L7EA:
| Lighting-inc: door courtesy, glovebox, trunk, front/rear dome, LED map |
F2B5:
| Front seatback pockets |
RC60:
| Retractable coat hooks |
