straszny golas.
REG: WT6186 Data produkcji: 20070503
z13dtj1989069
W0L:General Motors
0:Pojazd Nie Specjalny
S:Corsa Platform
D:2007 - Platform Generation
L08:3 DRZWIOWY HATCHBACK
7:2007
6:Eisenach
123522:SERIAL NUMBER
18I = WYKOŃCZENIE WNĘTRZA - CIEMNY WĘGIEL DRZEWNY 18X = KOLOR WYKOŃCZENIA SIEDZENIA - CIEMNY WĘGIEL DRZEWNY 18Y = WYKŁADZINA WYKOŃCZENIA DRZWI,W RÓŻNYCH KOLORACH 4CU = FARBA ZEWNĘTRZNA,PATRZ TABELA FARB W PRZEDMOWIE DO KATALOGU A32 = SZYBY STEROWANE ELEKTRYCZNIE,PRZÓD AH3 = SIEDZENIE PRZEDNIE,KIEROWCY,REGULACJA RĘCZNA AK5 = DLA PODUSZKI POWIETRZNEJ KIEROWCY I PASAŻERA AQ6 = SIEDZENIE PRZEDNIE,OPARCIE REGULOWANE AU0 = ZAMEK DRZWI,ZE ZDALNYM STEROWANIEM B76 = DLA PRZYRZĄDÓW Z CZARNYMI TARCZAMI B81 = WYPRASKA,PŁYTA BOKU NADWOZIA,USUNĄĆ BRG = IDENTYFIKACYJNY PUNKT ZWROTNY 2007 1/2 M.Y C60 = KLIMATYZACJA CT1 = DLA BELGII D77 = LUSTERKO,ELEKTRYCZNE,SZEROKOKĄTNE,PRAWE-LEWE DAG DDU = LUSTERKO,ZESP. DP6 = OBUDOWA DT4 = POPIELNICZKA I ZAPALNICZKA ECA = KLUCZYK FY2 = PRZEŁOŻENIE KOŃCOWE PRZEKŁADNI GŁÓWNEJ 3.74 G61 = MOCOWANIE NA 4 ŚRUBY GDI = TKANINA WYKOŃCZENIOWA,PONCZ/ELBA JM4 = SYSTEM HAMULCOWY,TARCZOWE-PRZEDNIE/BĘBNOWE-TYLNE,Z ABS K60 = ALTERNATOR,100A LDP = SILNIKI WYSOKOPRĘŻNE Z13DTJ,A13DTJ LHD = KIEROWNICA PO LEWEJ M26 = RĘCZNA SKRZYNIA BIEGÓW,5 BIEGOWA,TYPU F17 MM3 = UŻYWANY(-A,-E) Z RĘCZNĄ SKRZYNIĄ BIEGÓW N33 = DLA ODCHYLANEJ KOLUMNY KIEROWNICY N45 = KOŁO KIEROWNICY,TRZY SZPRYCHY NC0 = WYPOSAŻENIE,UNIA EUROPEJSKA NT4 = EMISJA SPALIN,EEC 05 OBY OGD OHI = LOKALNY GM W EUROPE OHI PA8 = KOŁA 14X5.5, STALOWE, 18 OKRĄGŁYCH OTWORÓW QBO = OPONY,185/70 R 14-88T QQ5 = DLA KOŁA ZAPASOWEGO O PEŁNYCH WYMIARACH T9M = WYKOŃCZENIE ELBA TN0 = AKUMULATOR,65A TRP = RAMA RADIA U3F UF8 = WYŚWIETLACZ CIEKŁOKRYSTALICZNY TRZECH INFORMACJI - DATA/GODZINA/TEMPERATURA UJ3 UW4 = GŁOŚNIKI,4 UZT = RADIO,AM/FM STEREO,SZUKANIE,CD,ETR,GM-LAN VG2 = WOSK ZABEZPIECZAJĄCY,USUNĄĆ VM9 = PODNOŚNIK MECHANICZNY,RUCHOMA STOPA W2N = LITERNICTWO,BOCZNE,USUNĄĆ W4Y WBE = WYPOSAŻENIE JEDNOSTKI ODBIORNIKA,RADIO XA3 = OPEL XK1 = DLA BELGII XL8 = DLA CZĘSTOTLIWOŚCI 433 MHZ Z0D = DLA BELGII Z1F = CZUJNIK,SYSTEM OGRANICZAJĄCY,LEWY
jesli chodzi o handlarzy z zielonej łąki - to zalecana szczegolna ostrożność
