TEMAT: Astra 1.7 CDTI W0L0TGF3548008696
Astra 1.7 CDTI W0L0TGF3548008696 2013/01/22 12:33 #36893
  • venglin
  • venglin Avatar
W imieniu kolegi, który jest zainteresowany kupnem Astry, uprzejmie proszę forumowiczów o ocenę następującego egzemplarza:
otomoto.pl/opel-astra-1-7-cdti-80-koni-n...ladna-C26095466.html
VIN: W0L0TGF3548008696 Sprawdź ten VIN na autobaza.pl ▸
Odp: Astra 1.7 CDTI W0L0TGF3548008696 2013/01/22 14:28 #36910
przebieg mozesz wsadzic miedzy bajki i czytac dzieciom na dobranoc ;)
W0L0TGF3548008696
W0L0TGF3548008696
OPEL
Astra-g Zafira-a
wagon
Z17dtl
ASTRA-G ZAFIRA-A
18.09.2003
MODEL YEAR:
2004
Z17DTL
ENGINE ROOM:
00788736
CODE BODY:
35
CODE GM:
XXNZ
DE
W0L0TGF3548008696
W0L:
General Motors
0:
Normal Vehicle
T:
Astra
G:
Astra
F:
Active (manual) Belts and driver passenger airbag system (frontal) Roof side
F35:
5 Door Estate
3:
2H9 (Z18XE)
5:
4:
2004
8:
Ellesmere Port
AG4:
The front seats, A/C, height adjuster, manually operated
AJ3:
AIRBAG FOR DRIVER
AJ4:
FOR PASSENGER AIRBAG
AP0:
FOR SIDE AIRBAG, A/C
AP1:
FOR SIDE AIRBAG, P/S
AQ6:
The front seats, adjustable backrest
AT0:
HEADREST, REAR, fabric, solid
AU0:
DOOR LOCK WITH REMOTE CONTROL
AY3:
HEADREST, FRONT, fabric, solid
AY5:
A32:
WITH ELECTRIC WINDOWS, FRONT
BB7:
USED with chrome interior door handle
B75:
COVER, ASSEMBLY, BAGGAGE
CT3:
FOR GERMANY
C35:
HEATER, BACK OFFICE
C60:
AIR CONDITIONER
C73:
LAMP REAR DOOR, DARK LENS
C87:
READING LAMP, REAR
DA5:
ARMREST, REAR, CENTRAL
DL8:
MIRROR, WITH ELECTRIC AND HEAT, P/C A/C
DP6:
HOUSING
D18:
CLUSTER, Black, Chrome Ring
D75:
HANDLE, ASSY, OUTER
ELL:
Made in the Ellesmere-PORT
FP9:
Final drive ratio 3.55
G61:
4 wheel bolt
ABS
J65:
FRONT AND REAR DISC BRAKES
K60:
Generator, 100AMP.
LHD:
Left-hand DRIVE
LRB:
Z17DTL [LRB] ENGINE
MM3:
USE OF HAND with transmission
M79:
MANUAL TRANSMISSION CONTROL ,5-SPEED
NP5:
STEERING WHEEL, LEATHER
NT4:
GAS EMISSIONS, EEC 05
N40:
Power steering, unvarying STEP
PAC:
FINISH PIAZZA/ELBA
PCC:
N joy
P34:
WHEEL AND TIRE, SPARE
QED:
TIRES 195/60 R 15-88H
QE7:
WHEEL, ROAD, aluminum, 7-spoke, 6JX15
T67:
BATTERY, 70AH
T9M:
FINISH ELBA
T9P:
DARK ORNAMENTS, BODY headlights
U07:
HORN, fanfare
U91:
SHORT ANTENNA, ROOF, RADIO
U96:
SPEAKER, 6, Option 2
VU3:
PANEL OF THE CENTRAL UNIT, COAL, METALLIC
V22:
GRILLE, RADIATOR, CHROME PROFILE
V55:
HOLDER CAP OFF
W8X:
ADDITIONAL DETAILS SET RADIO
XK5:
EQUIPMENT, JEWEL
XL8:
For 433 MHz
Z0F:
FOR GERMANY
Z1F:
SENSOR SYSTEM LIMITED, A/C
Z1Y:
PAINT, TWO LAYER
2F4:
RADIO, CDR 500
2J1:
4BU:
80I:
INTERIOR-BLACK
80X:
INTERIOR TRIM BODY-BLACK
80Y:
FINISH PANEL DOORS, BLACK
GALERIA # 0
