typowy poleasing. Koniecznie trzeba zapytac czy jest faktura 23%. Wez rejestracje z dowodu
01A:
| BLACK Seat |
1AB:
| BLACK COLOR FINISH PANEL DOORS |
2BQ:
| COVER INSIDE DOOR, SILVER DUST |
4AA:
| BLACK Interior |
A01:
| Glass, Tinted |
A51:
| FRONT SEAT Bucket |
A64:
| FOR SPLIT SEAT 40/60 |
A69:
| Safety belt, FRONT |
AEF:
| Pwr, SPEED lifting/lowering |
AG5:
| FRONT SEAT, P/S, height adjuster, manually operated |
AH3:
| FRONT SEAT, DRIVER, with manual adjustment |
AJF:
| HEADREST, the front seats, ACTIVE |
ASV:
| HUMIDITY SENSOR |
AXG:
| For reacting one-touch ON WINDOWS |
AYC:
| AIRBAG FOR DRIVER, PASSENGER, SIDE AND Curtains |
B75:
| COVER, ASSEMBLY, BAGGAGE |
BAH:
| An immobilizer electric, OPTION 2 |
BSO:
| OPRED.EFFEKTIVNUYU POINT GUIDE. |
C1R:
| MOLDING INSTRUMENT PANEL INNER, particulate-BLACK |
C25:
| Wiper and washer REAR FOLDING DOORS |
C49:
| REAR WINDOW, fan |
C95:
| LAMP, ASSEMBLY, CEILING, DUAL LAMP FOR READING |
C99:
| SWITCH Passenger Airbag Deactivation |
C9D:
| LIGHT CABIN, scattered light, CONSOLE |
CE1:
| WIPER, FRONT, PULSE SYSTEM |
CJ2:
| CLIMATE CONTROL |
CT5:
| FOR THE NETHERLANDS |
D6I:
| Visor, SUNNY, mirror with light |
D75:
| HANDLE, ASSY, OUTER |
DBU:
| CONSOLE FRONT DOOR WITH sliding armrest |
DD8:
| INTERNAL MIRRORS With increasing C Increased sensitivity to light |
DP6:
| HOUSING |
DVA:
| CLUSTER, BLACK, BLACK RING WITH SILVER RIDING |
DWE:
| USED HAND MIRROR with folding DRIVE |
E17:
| BUMPER 2.5 MPH |
EA1:
| POCKET, front seats, LEFT |
EA2:
| POCKET, front seats, RIGHT |
EBX:
| CLOTH SEAT UPHOLSTERY, SCENE MODIFIED |
FBD:
| Cloth trim DOORS ATLANTIS |
FX1:
| FINAL TRANSFER OF AXIAL 3.94 |
FX3:
GEK:
| EXTERIOR PAINTING, CM. COLOUR CARD In the preface to model catalog |
GNA:
| EQUIPMENT CHASSIS, FRONT STRUT ASSEMBLY |
GNG:
| REAR AXLE, TORSION BEAM AND LEVERS WATT |
J67:
| FOR USE WITH 15 quot;BRAKE SYSTEM |
J71:
| Electric parking brake |
K34:
| PROGRAMMABLE SPEED |
K3L:
| BATTERY, 60AH |
K60:
| Generator, 100AMP. |
KB5:
| ASSISTANT Trogane the hill |
KC5:
| SOCKET, ELECTRICAL ACCESSORIES (12V) |
KCL:
| TUNNEL HEATER, REAR SEAT PASSENGER 2-position |
LDE:
| Z16EXR, A16XER [LDE] GASOLINE ENGINE |
LHD:
| Left-hand DRIVE |
MDB:
| ENVIRONMENT FOR BLACK GLASS MOLDING |
MDG:
| F17 (CR) MANUAL TRANSMISSION CONTROL |
MM3:
| USE OF HAND with transmission |
N37:
| STEERING COLUMN, ADJUSTABLE, REACH AND TILT |
N52:
| STEERING WHEEL, three spokes |
NE9:
| Emission control system 09 EEC |
NJ1:
| Servo STEERING, PERMANENT gear ratio ELECTRIC CO STANDARD COURSE REIKI |
OHA:
| GM LOCAL IN EUROPE FOR OHA |
PWM:
| WHEEL 16X6.5, STEEL, PAINTED |
QVF:
| TYRE, 205/60R16-92H |
T39:
| LIGHTS, TURN SIGNAL, AUXILIARY |
T3N:
| WORKING FOR A SYSTEM OF LIGHTING IN DAYTIME |
T4A:
| LIGHTS, pencil, HALOGEN |
T79:
| FOR REAR FOG LAMPS |
TR0:
| LIGHT CABIN, REAR, DOUBLE A CONVENIENCE AND FOR READING |
TR6:
| Headlight adjustment, with manual transmission |
TS6:
| LAMP BRAKE SIGNAL, HIGH-LEVEL CENTRAL |
TSP:
| LIGHT, COMPLETE, CUSTOM SHOP |
TSQ:
| DELUXE CABIN LIGHT |
TTO:
| RADIO EQUIPMENT, COOLING SYSTEM |
TTW:
| AUTOMATIC HEADLAMPS discovery of tunnels |
TTX:
| AUXILIARY CONNECTOR RADIO INLET |
U04:
| TONE ONE TON |
U18:
| SPEEDOMETER, COMPLETE, KM/H |
U65:
| SPEAKER, 7 |
U68:
| COMPUTER INFORMATION |
UC3:
| Steering wheel, audio controls and PHONE |
UDC:
| For driver information center with a monochrome dot matrix |
UDK:
| GRAPHIC INFO - in color |
UEC:
| LIGHT SENSOR AUTO RECYCLING OF AIR |
UH0:
| WARNING: Seat belts, LEFT |
UH1:
| WARNING: Seat belts, RIGHT |
ULS:
| MANAGEMENT locking STEERING COLUMN |
US3:
| ANTENNA MULTI-FUNCTION |
V3X:
| CENTRAL INSTRUMENT PANEL, SILVER DUST |
V83:
| NOTE CAR - ECE ORGANIZATION |
VD1:
| EUROPEAN EQUIPMENT |
VHY:
| PROTECTOR VEHICLE CORROSION PREVENTION |
VNF:
| BATTERY ISOLATION |
VRG:
| SPECIFICATION OPEL/VAUXHALL - CABIN |
VRH:
| SPECIFICATION OPEL/VAUXHALL - STEERING COLUMN |
VRK:
| SPECIFICATION OPEL/VAUXHALL - Soffits |
VRL:
| SPECIFICATION OPEL/VAUXHALL - FRONT HORIZONTAL SUSPENSION |
VRM:
| SPECIFICATION OPEL/VAUXHALL - FRONT VERTICAL SUSPENSION |
VRN:
| SPECIFICATION OPEL/VAUXHALL - REAR SUSPENSION |
VRR:
| SPECIFICATION OPEL/VAUXHALL - TIRES AND WHEELS |
WGC:
| EQUIPMENT receiving unit, GPS |
WTC:
| SET, tires, tire repair, INTEGRATED EQUIPMENT |
XL8:
| For 433 MHz |
Y67:
| REQUIRED IF DISPLAY SET REMINDER SERVICE |
