Nie podałeś linku do ogłoszenia, a po samym numerze VIN to raczej nikt wiele więcej nie pomoże.
Poniżej to co wyszło z numeru VIN
Basic Information
Vehicle family: 207 (a7)
Build code: 11488 76 1 0630
Warranty Start Date: 28/10/2008
Engine serial number: 10 jbar 3027991
Gearbox serial number: 20 dp45 2984172
BER: E2*2001/116*0340*09
General information
PRODUCT TYPE: Car
COMMERCIAL MARQUE/COMPONENT TYPE: Peugeot
VEHICLE FAMILY: 207
SILHOUETTE: 3 door saloon
TRIM LEVEL: X line
ENGINE: Diesel turbo dv6ted4 90hp fap
TRANSMISSION: Bvm5
PAINT TYPE: Metallic paintwork
BODY COLOUR: Ezq - paint manitoba grey
INTERIOR TRIM TYPE: Weave pachinko + tavoc2 "wu"
UPHOLSTERY COLOUR: "fx"
GEARBOX (CHARACTERISTICS): Be4-5l manual gearbox
ENGINE (TYPE): Ev/dv
OTHER BADGE, " MISC. ": Without fuller badge
BADGE: Without badge
Vehicle characteristics
TRIM LEVEL: X line
SPEEDOMETER DRIVE: W/o tacho torque
Fuel supply-Engine
DIESEL FILTER WATER DETECTOR: Without diesel filter water detector
FUEL: Diesel fuel
EMISSIONS STANDARD (ENGINE): Anti depollution l5 (engine)
CATALYTIC CONVERTER: 2-component platinum filter catalyser
COOLING MOTOR: Radiator th : 27 - 21 dm2 brazed aluminium
CRANKCASE GAS CIRCUIT HEATING: W/o heater casing gas circuit
EOBD SELF-DIAGNOSIS SYSTEM: "eobd" auto-diagnostic without accelerometer
DEVICE (ANTIPOLLUTION): "egr" exhaust gas recycling
VEHICLE TECHNICAL DEPOLLUTION: L5 vehicle technical depollution
PARTICLE FILTER: Particle filter
FAN: 1 aero 2-speed 140w fan with scoop
FUEL VAPOUR RETRIEVAL: Without petrol vapour recuperation
INJECTION ASSOCIATED VARIANT: Mounting bosch
TANK FILTER: Cithout reservoir filter
STOP AND START: Without stop and start
Gearbox Transmission
TRANSMISSION: Bvm5
FINAL DRIVE RATIO: Rear axle hypoid gearset 19 x 70
WHEEL STYLE: 15 inch monaco wheel
DIFFERENTIAL (GEARBOX): Differential 84
RIM/TYRE SIZE: 15 inch tyre fitment
TYRE (SIZE, TYPE): 185x65x15 h tyres
WHEELS FITTED: 6" rim road wheels
WHEEL (TYPE): Alloy wheels
INFLATION PRESSURE LOSS INDICATOR: Without tyre deflation indicator
GEARBOX TYPE: Gearbox be4r
Suspension-Steering-Brakes
ABS: With abs brakes
FRONT ANTI-ROLL BAR: Front anti-roll bar diam 21
BRAKE TYPE: Ventilated front discs/rear discs
STEERING TRAVEL: Steering mechanism travel 72
SUSPENSION: Normal suspension
DYNAMIC STABILITY CONTROL SYSTEM: Without electronic stability program
BRAKE ASSOCIATED VARIANT: Abs teves mk70
PEDAL BRACKET (TYPE): Pedal standard
Body fittings
HORNS: Horn standard
AERIAL: Short roof aerial
OPENING ROOF (APPEARANCE): Without sun roof
FINISHER (SELF-ADHESIVE): Matt black rear surround trim
REAR SPOILER: Assembly without rear spoiler
SIDE MOULDINGS (TYPE): Lateral protector mass tinted
SIDE MOULDINGS (DIMENSION): Without lateral protectors
WHEEL EMBELLISHER (STYLE): Without wheel cap
UNDERBODY SHIELD: Plastic protectio + foam under engine
ADDITIONAL SHIELD (UNDER ENGINE): W/o engine undershelding
EXT. REARVIEW MIRROR COMP. FUNCTION: Ext mirror manual-fold back
EXHAUST TAILPIPE TRIM: W/o exhaust outlet embellisher
ENGINE BAY SOUNDPROOFING: Bonnet soundproofing + thermal protection
WINDSCREEN WIPER: Front wiper blade w/o rain sensor
HEADLAMP WIPER: W/o headlamp wiper
REAR SCREEN WIPER (OPERATION): Intermittent rear wiper auto operation
FRONT PANEL BLANK: Without front bumper plug
ROOF GLASS: Without roof window
REAR TAILGATE GLASS: Fixed tailgate window
OUTSIDE TEMPERATURE SENSOR: With exterior temperature sensor
BUMPER: Std grl body col sport fr bumper body col std rr
NUMBER PLATE: Without licence plate
LUGGAGE RACK: Without roof bars
FRONT FOGLAMP: Front fog lights
SPECIAL HEADLAMP (DOUBLE OPTIC): Double optic lamps
EXTERIOR REAR VIEW MIRROR (DRIVER SIDE): Driver’s door mirror electric control
EXTERIOR REAR VIEW MIRROR (PASSENGER SIDE): Pass ext rrview mirror non heated elect cntrl
SPARE WHEEL: Emergency wheel
EXTERIOR ACCESSORIES: Body coloured ext handles + ext mirror
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS): Convex exterior mirror glass
SUN ROOF: Fixed roof
BUMPER TRIM: Dyed bumper strip
GLASS (APPEARANCE): Tinted
REAR QUARTER WINDOW (TYPE): Pivoting rear qtr glass
WINDOW (TYPE): Lam w/screen + side + rr toughened
HANDS FREE ACCESS AND STARTING: No acces and handsfree starting
Interior fittings
ANTI-THEFT ALARM: Without theft protection alarm
REAR HEAD RESTRAINT: Rear headrest adjustable
FRONT HEAD RESTRAINT: Front headrest adjustable
REAR SEAT: Separate fold back bench seat
LUGGAGE COVER: Shelf
REAR SEATBELT: 3 reel 3 pt rear safe belt + unbukled warning
FRONT SEATBELT: Driver + passenger seatbelt warning
CLIMATE (AMBIENT TEMP): Cold countries
CHILD LOCK: Without child lock
SPEED GRADUATIONS: Graduation kms/h
GRAB HANDLES: Pass fr handle + rear + hook
RADIO EQUIPMENT: Feed aerial receiv frt speaker twt rear speaker
DRIVING POSITION: Left hand drive
REMOTE CONTROL: Remote control assembly
LOAD SPACE LIGHTING: Glove-box lighting
DASHBOARD EQUIPMENT: Mistral lion grey decor soft fascia
MISC. INT. LAMPS: W/o map reading lamp
INSTRUMENT PANEL (CHARACTERISTICS): 220 kmh or 140 mph graduation white dial backgroud
LOUDSPEAKER: 4 fr speakers (2 tw + 2 fr) + 2 rr speakers
RADIO CONTROLS: Remote radio control
PASSENGER COMPARTMENT SOUNDPROOFING: 5kg bulkhead s’proof+door stop+scuttle+pedal
FRONT PASSENGER SEAT HEIGHT CONTROL: Front passenger seat cushion height adjustment parallel adjustment
DRIVER SEAT CONTROL: Memory ctrl drivers front seat
FRONT PASSENGER SEAT CONTROL: Front passenger seat control with memory
DRIVER SEAT ADJUSTMENT: Reclining driver’s seat back
FRONT PASSENGER SEAT ADJUSTMENT: Passenger tilting back
FRONT SEAT ARMREST: Assembly without front elbow rest
ROOF CONSOLE: Without roof console
COMPACT DISC: Without compact disc
SATELLITE NAVIGATION SYSTEM: Without navigation system
HEADLAMP BULBS: Halogen bulb
REAR WINDOW LIFT: Without rear glass lift
DRIVER’S WINDOW LIFT: Sequential driver’s electric window
PASSENGER’S WINDOW LIFT: Elec cntrl pass front window lifter
DISPLAY: Dispay (radio+clock+and or t��, cd) without memory
COURTESY MIRROR: Driver’s concealable+pass non concealable no light
OIL GAUGE: Std oil level indicator
FITTING REAR HEAD RESTRAINT: Mount 3 rear head-rest
HEATING ELEMENT: Non heated seat
FRONT LATERAL AIRBAG: Thorax side + curtain airbag
FOOTWELL LIGHTING: Without door sill lighting
PASSENGER AIRBAG: Passenger airbag
ON-BOARD COMPUTER: Computer
EQUIPMENT PACK: W/o equipment pack
EXTERIOR REAR VIEW MIRROR (HEATED): Heated door mirror
AIRBAG DEACTIVATION: Manual airbag deactivation
INTERIOR DOOR CONTROL (APPEARANCE): Int door handle grey lion
COURTESY LAMP: Doors + fr courtesy light remote control
DIRECTIONAL HEADLAMP: Without directional lights
FRONT SEAT GUARD: Without separation grille
STORAGE (DRIVING POSITION): Lower glovebox with cooling
RADIO RECEIVER: "rd4/mp3" rds compact disc audio system
REFRIGERATION: Single air conditioning
CRUISE CONTROL: Without speed control
DRIVER’S SEAT HEIGHT CONTROL: Parallel drv height adj
INTERIOR REAR VIEW MIRROR: Day -night inner rear mirror - without electrochro
STORAGE (OTHERS): W/o other setting boxes
CARPET COVER: W/o carpetmat
DRIVER AIRBAG: Drivers air bag
LOAD SPACE STORAGE: W/o boot tidy
TUNER RADIO: Mono radio tuner
INTERIOR PROTECTION: Without inner protection
EXTERIOR TEMPERATURE (SCALE): Ext temp indicator celsius
OBSTACLE DETECTION SYSTEM: Without obstacle detector
TRIM ADAPTATION: Gear lever knob chrome insert
FLOOR MAT: W/o carpetmat
EQUALISER AMPLIFIER: Without equaliser amplifier
LOCKING CONTROL: Simple + automatic central locking
STEERING WHEEL: Rubber steering wheel
STORAGE SPACE LOCKS: Glove-box without locking
AMBIENCE PACK: Without ambiance pack
DRIVER’S KNEE AIRBAG: Without driver’s knee airbag
AUDIO PACK AUXILIARY SOCKET: 1 audio rca socket
Electrical
ALTERNATOR: Alternator 150 amp
BATTERY: Battery l2 400
STARTER MOTOR: Class 6 starter motor
SPECIAL LIGHTING: Without particular light
CEN. LOCKING REM CONTROL FREQUENCY: Locking remote control frequency 433.92 mhz heterodyne
MULTIPLEXING: Multiplexing assembly can can
RADIO FREQUENCY: Western europe radio frequency
Component manufacturers
Miscellaneous
ATMOSPHERIC CONDITIONS: Normal atmosphere
RADIO HEADPHONE SOCKET: Without accessories socket
TRAFFIC SIDE: Right hand drive
SET OF KEYS: 1 hf plip key + 1 single main key
EMERGENCY EQUIPMENT: W/o help equipment
SURFACE CONDITIONS: Good terrain
SPEED MONITORING: Without speed check
SLAVE CONTROL UNIT: Bsi + com 2005 4-position ring
