| INJECTION XU10J4R |
| LEAD FREE PETROL |
| EEC 95 DEPOLL (ENGINE) |
PRE-FILTER:
| ASSEMBLY WITHOUT PRE-FILTER |
SPEED SENSOR SIGNAL:
| SENSOR HALL EFFECT |
| XU/XUD |
CATALYTIC CONVERTER:
| 3 PARTS CATALYST |
| WITHOUT OIL-WATER DISTR CHAMB |
FUEL TANK INSULATION:
| FUEL TANK INTERIOR INSULATION |
FUEL SUPPLY CUTOFF:
| FUEL FEED CUT-OFF |
RHEOSTAT:
| 2 FANS , 2 RATES , IMPROVED |
FUEL VAPOUR RETRIEVAL:
| CONTROLLED PETROL VAPOUR RECUPERATION |
| W/O INJECTION VARIANT |
| BVM5 |
| BE3 S |
| REAR AXLE HYPOID GEARSET 19 X 79 |
SPEEDOMETER DRIVE:
| TACHO TORQUE 22X18 |
| ALLOY WHEEL |
CLUTCH:
| CABLE CLUTCH |
GEARBOX SAFETY LOCK:
| W/O G/BOX SECURITY LOCKING |
| 205X60X15 V TYRES |
WHEELS FITTED:
| 6,5" RIM ROAD WHEELS |
| ALLOY WHEELS |
| BE3 |
ABS:
| WITH ABS BRAKES |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 22 |
ANTI-THEFT DEVICE:
| STANDARD ANTI-THEFT |
STEERING:
| UNVARIABLE POWER STEERING |
| FRONT ANTI ROLL BAR DIAM 24 |
TRACTION CONTROL:
| WITHOUT ANTISLIPPING |
SERVICE BRAKE:
| WITH COMPENSATOR SLAVE |
BRAKE TYPE:
| VENTILATED FRONT DISCS/REAR DISCS |
POWER STEERING FLUID COOLING SYSTEM:
| WITH COOLING |
| NORMAL SUSPENSION |
ACTIVE SUSPENSION:
| WITHOUT VARIABLE SUSPENSION |
HORNS:
| HORNS-HARMONY |
AERIAL:
| AMPLIFIED ROOF AERIAL |
WIPER ARM:
| FRONT BLADE WITH DEFLECTOR |
| PROTECTOR W/O CHROME RING |
SIDE MOULDINGS (DIMENSION):
| LATERAL PROTECTORS L=34 + SIDE SILL |
| SMALL DIAMETER HUB CAP |
SIDE REPEATER INDICATORS:
| SIDE FLASH-UNIT ASSEMBLY |
INDICATORS:
| WITHOUT SIGNALING LIGHTS |
THIRD BRAKE LAMP:
| WITH EYE LEVEL REAR LIGHTS |
SILL ILLUMINATION LAMP:
| SILL ILLUMINATION |
| W/O ENGINE UNDERSHELDING |
WASHER JET:
| WINDSHIELD WASHER JET W/O DEFROST |
| WITHOUT FULLER FUNCTION |
EXHAUST TAILPIPE TRIM:
| SINGLE OUTLET |
ENGINE BAY SOUNDPROOFING:
| BONNET SOUND-PROOFING |
WINDSCREEN GLASS (TYPE):
| NO HEATING WINDSCREEN |
| INTERMITTENT WINDSCREEN WIPER W/O WATER LEVEL INDI |
REAR SCREEN WIPER:
| W/O REAR SCREEN WASH WIPE |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
BUMPER:
| BUMPERS WITHOUT EMBELLISHER |
MUDFLAP:
| WITHOUT MUDGUARD |
LUGGAGE RACK:
| WITHOUT ROOF BARS |
| FRONT FOG LIGHTS |
| HT EXT RRVW MIRROR EL INT CONTR |
| OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL |
| ALLOY WHEEL + STANDARD TYRE |
| UNCOLOURED DOOR MIRROR/COLOURED DOOR HANDLE |
| ELECTR/SEQUEN CTRL SUN ROOF |
GLASS (APPEARANCE):
| TINTED |
REAR QUARTER WINDOW (TYPE):
| PIVOTING REAR QTR GLASS |
| LAMINATED QUALITY 2 |
| NIL CLOTH "EM" |
| ALARM ULTRASONIC+PERIMETER STD |
REAR HEAD RESTRAINT:
| REAR HEADREST INTEGRAL |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| REAR BENCH SEAT SINGLE CUSHION SEPARATE SEAT BACKS |
SUPPLEMENTARY SEAT:
| WITHOUT SUPPLEMENTARY SEAT POSITN |
REAR SEAT ARMREST:
| WITH REAR ARMREST |
INTERIOR ALARM:
| ALARM FORGET LIGHTS |
LOAD FLOOR MOULDING:
| WITHOUT LOAD FLOOR STRIP |
RADIO TELEPHONE:
| WITHOUT TELEPHONE PRE-EQUIPMENT |
LUGGAGE COVER:
| WITHOUT LUGGAGE COVER |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITHOUT ALARM |
AIR CONDITIONING:
| MANUAL CONTROL CAR HEATER |
| GRADUATION MPH |
TACHOMETER:
| REV COUNTER WITH NEEDLE |
RADIO EQUIPMENT:
| FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
CONSOLE:
| LONG CONSOLE |
| RIGHT HAND DRIVE |
REMOTE CONTROL:
| REMOTE CONTROL ASSEMBLY |
LOAD SPACE LIGHTING:
| GLOVE-BOX LIGHTING |
| DASHBOARD WITH LARGE GLOVE BOX COVER, PAINTED TRIM |
INTERFERENCE SUPPRESSION:
| RADIO INTERFERENCE SUPPRESSOR |
MISC. INT. LAMPS:
| MAP READING LAMP |
LOAD SPACE TRIM:
| TRIM BOOT + RR TAILGAT FLAP |
DOOR TRIM:
| WITHOUT WOOD EFFECT DECOR WITHOUT LEATHER |
TACHOMETER (SIGNAL CONNECTION):
| REV COUNTER CALC |
CHILD SEAT ANCHORING POINTS:
| WITHOUT CHILD SEAT MOUNTING |
| ASSEMBLY WITH 6 SPEAKERS + 2 TWEETERS |
| REMOTE RADIO CONTROL |
POLLEN FILTER:
| WITH POLLEN FILTER |
| WITHOUT SUN VISOR SCREEN |
| WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
DRIVER SEAT CONTROL:
| DRIVERS FRT SEAT MANUAL CNTROL |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT MANUAL CNTR |
DRIVER SEAT ADJUSTMENT:
| DRIVER’S LUMBAR ADJUSTMENT |
| PASSENGER TILTING BACK |
INT. UPHOLSTERY ELEMENTS:
| WOVEN ROOF LINING |
FRONT SEAT ARMREST:
| ASSEMBLY WITHOUT FRONT ELBOW REST |
EXTERIOR TEMP. INDICATOR:
| EXT TEMP INDICATOR |
| WITHOUT COMPACT DISC |
HANDBRAKE WARNING LAMP:
| WITHOUT PARKING BREAK INDICATOR |
| WITHOUT REAR GLASS LIFT |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY (CLOCK AND OR TEMP) |
CLOCK:
| NUMERIC CLOCK |
COURTESY MIRROR:
| DRIVER+PASSENGER WITHOUT LIGHTING |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
FITTING REAR HEAD RESTRAINT:
| WITHOUT REAR HEAD-REST |
| NON HEATED SEAT |
| WITHOUT FRONT SIDE AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVER + PASSENGER ELECTRIC WINDOW AUTO STOP |
LOUDSPEAKER GRILLE (REAR PASSENGER COMPARTMENT):
| WITH REAR SHELF LOUDSPEAKER GRILLE |
ON-BOARD COMPUTER:
| NO COMPUTER |
COURTESY LAMP:
| FRONT DOORS CONT - FR+RE INTERIOR LAMP |
HEADLAMP HEIGHT ADJUSTER:
| REMOTE MANUAL HEADLAMP ADJUSTMENT |
FRONT SUN VISOR:
| DRIV+PASS SIDE (W/O NOTICE) |
| PERFORMANCE 3 RDS RADIO |
| WITHOUT AIR CONDITIONING |
| WITHOUT SPEED CONTROL |
DRIVER’S SEAT HEIGHT CONTROL:
| PARR+FR DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
AIR CON./TEMPERATURE REGULATION:
| WITHOUT REGULATION AIRCON/TEMP |
STORAGE (OTHERS):
| FRONT SEATS STORAGE |
CARPET COVER:
| W/O CARPETMAT |
DRIVER AIRBAG:
| DRIVERS AIR BAG |
CARPET:
| DILOURS CARPET F330 |
LIGHTING TIMER:
| ADJUSTABLE TIMER |
INTERIOR PROTECTION:
| WITHOUT INNER PROTECTION |
SWITCH:
| ELECTRONIC ANTI-THEFT KEY |
COOLANT LEVEL WARNING LAMP:
| NO WATER LEVEL WARNING |
ANTIPOLLUTION MALFUNCTION WARNING LAMP:
| BAD FUNCTIONING ALARM |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| CENTRAL DEAD LOCKING |
| SPORT LEATHER STEERING WHEEL |
| ALTERNATOR 80 AMP |
| BATTERY L2 300 |
| STARTER MOTOR CL 3 |
| WITHOUT PARTICULAR LIGHT |
| STANDARD |
| NORMAL ATMOSPHERE |
FIRST AID KIT:
| WITH FIRST AID BOX |
TRAFFIC SIDE:
| DRIVING ON THE LEFT-HAND SIDE |
SIDE IMPACTS:
| DOOR WITH REINFORCEMENT |
SET OF KEYS:
| 2 HF PLIP KEYS |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SPEED MONITORING:
| WITHOUT SPEED CHECK |
EMERGENCY WARNING TRIANGLE:
| WITHOUT WARNING TRIANGLE |
