nie dawaj dublowanych tematow bo po co? jak ocena auta to tu tez dostaniesz zdekodowany vin..
| DT17TED4 TURBO DIESEL |
DIESEL FILTER WATER DETECTOR:
| DIESEL FUEL |
| TYPE ENGINE DT |
| MNTG EXCHANGER ON ENG & G/BOX |
POWER VARIATION (ENGINE):
| STANDARD POWER |
| "EOBD" SELF-DIAGNOSIS |
DEVICE (ANTIPOLLUTION):
| "EGR" EXHAUST GAS RECYCLING |
| PARTICLE FILTER |
| 2 ELECTRONIC FANS 33W INTEGRAL CTRL |
| SIEMENS ASSEMBLY |
TANK FILTER:
| CITHOUT RESERVOIR FILTER |
| MOTORISED THROTTLE BODY (ENG AIR INTAKE) |
| BVA AM6 |
| BVA AM6C |
| CP 15 X 53 |
| WHEEL GALAXIE 18 POUCES |
CLUTCH:
| WITHOUT CLUTCH |
DIFFERENTIAL (GEARBOX):
| DIFFERENTIAL 86 |
RIM/TYRE SIZE:
| 18 INCH TYRE FITMENT |
| TYRE 235X45X18 Y REINFORCED |
| ALLOY WHEEL ASSEMBLY 4 |
| TYRE DEFLECTION INDICATOR |
| Auto gearbox AM6 |
STEERING COLUMN:
| MANUALLY ADJUSTED STEERING COLUMN |
STEERING:
| VARIABLE POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 25 |
STEERING TRAVEL:
| TRAVEL MECHANISM STEERING 174 |
| NORMAL SUSPENSION |
ACTIVE SUSPENSION:
| VARIABLE SUSPENSION |
STEERING (OPERATION):
| ASSISTED MANUAL STEERING |
TOWBAR:
| WITHOUT TOWBAR |
| BODY COLOUR LATERAL PROTECTORS |
SIDE MOULDINGS (DIMENSION):
| LATERAL PROTECTORS + SIDE SILL |
| WITHOUT WHEEL CAP |
SILL ILLUMINATION LAMP:
| SILL ILLUMINATION |
| W/O ENGINE UNDERSHELDING |
| ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR |
REAR SCREEN WIPER:
| W/O REAR SCREEN WASH WIPE |
| HEADLAMP WASHWIPE |
| WITHOUT FRONT BUMPER PLUG |
ROOF GLASS:
| WITHOUT ROOF WINDOW |
| ALLOY WHEEL + STANDARD TYRE |
| BODY COLOURED EXT HANDLES + EXT MIRROR |
| FIXED ROOF |
BUMPER TRIM:
| BUMPER STRIP WITH STAINLESS STEEL INSERT |
GLASS (APPEARANCE):
| WINDOW TINTED |
| HEATED & REFLEC W/SCREEN + LAT LAMINATED + RR TOUG |
| NO ACCES AND HANDSFREE STARTING |
| PERFORATED LEATHER + LEATHER CLAUDIA "QD" |
REAR SEAT ARMREST:
| WITH REAR ARMREST |
| REAR 3-POINT 2 INERTIA REEL SEAT BELT |
| COLD COUNTRIES |
CHILD LOCK:
| WITHOUT CHILD LOCK |
| GRADUATION KMS/H |
| LEFT HAND DRIVE |
ADDITIONAL HEATING:
| WITHOUT ADDITIONNAL HEATING |
| METAL DECOR |
| GRADUATION 260 KM/H OR 160 M/H BLACK BACKGROUND |
DOOR TRIM:
| METAL DECOR |
| 4 FR SPKRS (2TW=2SPKRS)+5 RR SPKRS (2TW+2SPKRS+1C |
| REMOTE RADIO CONTROL |
| WITHOUT REAR BLIND |
| PASSENGER BOOSTER PARALLEL + FRONT ADJUSTMENT |
DRIVER SEAT CONTROL:
| MEMORY CTRL DRIVERS FRONT SEAT |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT ELEC CNTRL |
| PASSENGER LUMBAR ADJUSTMENT |
| MOUNTING COMPACT DISC |
| WITH NAVIGATION SYSTEM COLOUR SCREEN |
HEADLAMP BULBS:
| DISCHARGE BULB |
| WITHOUT REAR GLASS LIFT |
| DISPLAY (NAVIGATION+VIDEO+RADIO+CLOCK, TEMP, CD) |
COURTESY MIRROR:
| DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT |
OIL GAUGE:
| TWO-FUNCTIONS INDICATOR OIL LEVEL+TEMPERATURE |
| HEATED SEAT |
| THORAX SIDE + CURTAIN AIRBAG |
FOOTWELL LIGHTING:
| WITHOUT DOOR SILL LIGHTING |
HEADLAMP HEIGHT ADJUSTER:
| AUTOMATIC HEADLAMP ADJUSTMENT |
DIRECTIONAL HEADLAMP:
| WITH DIRECTIONAL LIGHTS |
| "RT3" RADIOTELEPHONE SYSTEM |
| REGULATOR OR SPEED LIMIT |
DRIVER’S SEAT HEIGHT CONTROL:
| ELECTRIC CONTRL DRIVERS HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
AIR CON./TEMPERATURE REGULATION:
| AUTOMATIC AIR CONDITIONNED BI-ZONE |
TUNER RADIO:
| DUAL RADIO TUNER |
INTERIOR PROTECTION:
| WITHOUT INNER PROTECTION |
OBSTACLE DETECTION SYSTEM:
| FRONT-REAR RADAR OBSTACLE SENSOR |
LATERAL BLINDS:
| WITHOUT SIDE BLINDS |
| LEATHER GEAR LEVER KNOB |
EQUALISER AMPLIFIER:
| WITH EQUALISER AMPLIFIER |
| SIMPLE CENTRAL LOCKING |
| LEATHER STEERING WHEEL 3 BRANCHES |
DRIVER’S KNEE AIRBAG:
| DRIVER’S KNEE AIRBAG |
| ALTERNATOR CLASS 18 180 AMP |
| BATTERY L3 600 DEGASSING + |
| STARTER MOTOR CLASS 6+ |
| AUTOMATIC HEADLAMP ILLUMINATION |
RADIO FREQUENCY:
| WESTERN EUROPE RADIO FREQUENCY |
| STANDARD |
| NORMAL ATMOSPHERE |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SLAVE CONTROL UNIT:
| CROSS-RANGE BSI |
