nie mam niestety info z holandi. Ale przebieg moze byc skrecony.
| DV6ATED4 TURBO DIESEL |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE ALUMINIUM |
| DIESEL FUEL |
| EV/DV |
CATALYTIC CONVERTER:
| 2-COMPONENT PLATINUM FILTER CATALYSER |
| MNTG WATER/OIL EXCHANGER ON ENGINE |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| "EGR" EXHAUST GAS RECYCLING |
| WITHOUT PARTICLE FILTER |
| 2 FANS , 2 RATES , IMPROVED 130WAERO |
FUEL VAPOUR RETRIEVAL:
| WITHOUT PETROL VAPOUR RECUPERATION |
| MOUNTING BOSCH |
HYBRID DRIVE TRAIN:
| WITHOUT ALTERNATOR-STARTER |
TANK FILTER:
| RESERVOIR FILTER INTERIOR |
| WITHOUT THROTTLE HOUSING (INTAKE AIR ENGINE) |
| BVM5 |
| BE4-5L MANUAL GEARBOX |
| REAR AXLE HYPOID GEARSET 19 X 72 |
| 15 INCH STEEL WHEEL |
GEARBOX TYPE (TYPE APPROVAL):
| GEARBOX BE4/5 L TYPE |
DIFFERENTIAL (GEARBOX):
| DIFFERENTIAL 84 |
| 195X65X15 H TYRES |
WHEELS FITTED:
| 6" RIM ROAD WHEELS |
| STEEL WHEELS |
| GEARBOX BE4R |
ABS:
| WITH ABS BRAKES |
STEERING:
| VARIABLE POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 22 |
BRAKE TYPE:
| VENTILATED FRONT DISCS/REAR DISCS |
| NORMAL SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT:
| BOSCH ABS 8 0 |
PEDAL BRACKET (TYPE):
| PEDAL STANDARD |
TOWBAR:
| TOWBAR |
HORNS:
| HORN STANDARD |
AERIAL:
| SHORT ROOF AERIAL |
| BODY COLOUR LATERAL PROTECTORS |
SIDE MOULDINGS (DIMENSION):
| STANDARD LATERAL PROTECTORS |
| COLUMBIA STYLE 8 HOLES 15 INCHES |
REVERSING LAMPS:
| WITH 1 REVERSING LAMP |
| W/O ENGINE UNDERSHELDING |
DRAUGHT EXCLUSION:
| BONNET WITHOUT SEAL |
| EXT MIRROR ELECTRIC-FOLD BACK |
EXHAUST TAILPIPE TRIM:
| W/O EXHAUST OUTLET EMBELLISHER |
REAR SCREEN WIPER:
| REAR SCREEN WIPER |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
ROOF GLASS:
| WITHOUT ROOF WINDOW |
BUMPER:
| BODY COLOUR STANDARD FRONT/REAR BUMPER |
MUDFLAP:
| WITHOUT REAR MUDGUARD |
| FRONT FOG LIGHTS |
| DRIVER’S DOOR MIRROR ELECTRIC CONTROL |
| PASS EXT RRVIEW MIRROR NON HEATED ELECT CNTRL |
| STEEL WHEEL + STANDARD TYRE |
| BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR |
REAR SCREEN WASH:
| REAR SCREEN WASH |
| FIXED ROOF |
BUMPER TRIM:
| BODY COLOUR BUMPER STRIP |
GLASS (APPEARANCE):
| TINTED |
REAR QUARTER WINDOW (TYPE):
| FIXED REAR QTR GLASS |
| ACOUSTIC WINDSCREEN EXCEPT SINGAPORE |
| PALASSARI CLOTH + "MU" EFKA |
REAR HEAD RESTRAINT:
| REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| SEPARATE FOLD BACK BENCH SEAT |
SUPPLEMENTARY SEAT:
| WITHOUT SUPPLEMENTARY SEAT POSITN |
REAR SEAT ARMREST:
| WITH REAR ARMREST |
LOAD FLOOR MOULDING:
| WITH LOAD FLOOR STRIP |
LUGGAGE COVER:
| WITH LUGGAGE COVER |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITH ALARM |
| TEMPERATE COUNTRIES |
| GRADUATION KMS/H |
RADIO EQUIPMENT:
| FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
| LEFT HAND DRIVE |
ADDITIONAL HEATING:
| AUTOMATIC ADDITIONAL HEATING |
| STANDARD DASHBOARD + BRIGHT SILVER ALUMINIUM PANEL |
INT. TRIM AND EQUIPMENT VARIATION:
| LEATHER STEERING-WHEEL KNOB BOOT |
| 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| REMOTE RADIO CONTROL WITHOUT CD FUNCTION |
| WITHOUT REAR BLIND |
| FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
DRIVER SEAT ADJUSTMENT:
| WITHOUT DRIVER’S LUMBER AND SIDE SUPPORTS |
| WITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS |
DRIVER’S SEAT FOLDING:
| W/O FOLDING DRIV FRONT SEATING |
FRONT PASSENGER SEAT FOLDING:
| W/O FOLDING PASS FRONT SEATING |
FRONT SEAT ARMREST:
| DRIVER ANT PASSENGER FRONT ARMREST |
EXTERIOR TEMP. INDICATOR:
| EXT TEMP INDICATOR |
| WITHOUT COMPACT DISC |
STOWAGE BIN:
| WITH SETTING BOX |
| WITHOUT NAVIGATION SYSTEM |
| SEQENT CONTR RR WINDOW LIFTER |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY (NAVIGATION+RADIO+CLOCK, TEMP, CD) |
COURTESY MIRROR:
| DRIVER’S + PASSENGER’S CONCEALABLE WITH LIGHT |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
FITTING REAR HEAD RESTRAINT:
| MOUNT 3 REAR HEAD-REST |
| NON HEATED SEAT |
| THORAX SIDE + CURTAIN AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
ON-BOARD COMPUTER:
| COMPUTER |
EQUIPMENT PACK:
| W/O EQUIPMENT PACK |
| HEATED DOOR MIRROR |
| SILVER EFFECT INTERIOR DOOR HANDLE |
FRONT SEAT GUARD:
| WITHOUT CAB PROTECTION PANEL |
STORAGE (DRIVING POSITION):
| ROOF FRONT CONSOLE STORAGE |
| "RD4" RDS COMPACT DISC AUDIO SYSTEM |
| REGULATOR OR SPEED LIMIT |
DRIVER’S SEAT HEIGHT CONTROL:
| PARALLEL DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
DRIVER AIRBAG:
| DRIVERS AIR BAG |
LOAD SPACE STORAGE:
| WITH BOOT TIDY |
TUNER RADIO:
| MONO RADIO TUNER |
OBSTACLE DETECTION SYSTEM:
| WITHOUT OBSTACLE DETECTOR |
| LEATHER GEAR LEVER KNOB + LEATHER GAITER |
FLOOR MAT:
| W/O CARPETMAT |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| SIMPLE + AUTOMATIC CENTRAL LOCKING |
| LEATHER STEERING WHEEL 3 BRANCHES |
DRIVER’S KNEE AIRBAG:
| WITHOUT DRIVER’S KNEE AIRBAG |
| ALTERNATOR 150 AMP |
| BATTERY L2 400 |
| STARTER MOTOR CL 5 |
| AUTOMATIC HEADLAMP ILLUMINATION |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY CAN CAN |
RADIO FREQUENCY:
| WESTERN EUROPE RADIO FREQUENCY |
| NORMAL ATMOSPHERE |
RADIO HEADPHONE SOCKET:
| WITH ACCESSORIES SOCKET |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SET OF KEYS:
| 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
COUNTRY ADAPTATION:
| WITHOUT ADAPTATION COUNTRY |
EMERGENCY EQUIPMENT:
| W/O HELP EQUIPMENT |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SPEED MONITORING:
| WITHOUT SPEED CHECK |
SLAVE CONTROL UNIT:
| BSI COMM 2003 |
