po jego wygladzie od razu wiem ze na 99% bedze przymeczony mlodym rajdowcem z 1.4 8V pod maska
| INJECTION TU3JP |
FUEL FILLER CAP:
| FUEL CAP WITHOUT LOCK |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE ALUMINIUM |
| LEAD FREE PETROL |
| EEC 2000 DEPOLL (ENGINE) |
PRE-FILTER:
| ASSEMBLY WITHOUT PRE-FILTER |
| TU |
CATALYTIC CONVERTER:
| 3-COMPONENT RHODIUM+PLATINUM FILTER CATALYSER |
| WITHOUT OIL-WATER DISTR CHAMB |
OPTIMISATION OF VEHICLE’S CONSUMPTION:
| WITHOUT FUEL CONSUMPTION OPTIMISATION |
COOLING MOTOR:
| RADIATOR TH : 18 - 21 DM2 |
FUEL SUPPLY CUTOFF:
| FUEL FEED CUT-OFF |
RHEOSTAT:
| "EOBD" AUTO-DIAGNOSTIC WITH ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| WITHOUT ANTI-POLLUTION DEVICE |
| L4 VEHICLE TECHNICAL DEPOLLUTION |
| WITHOUT PARTICLE FILTER |
| 2 TWO-SPEED 250W FANS |
FUEL VAPOUR RETRIEVAL:
| CONTROLLED PETROL VAPOUR RECUPERATION |
| MOUNTING SAGEM |
TANK FILTER:
| RESERVOIR FILTER INTERIOR |
| MANUAL THROTTLE BODY (ENGINE AIR INTAKE) |
| BVM5 |
| UP-RATED BVM/MA |
| REAR AXLE HYPOID GEARSET 16 X 65 |
SPEEDOMETER DRIVE:
| TACHO TORQUE 19X17 |
| 14 INCHES OPTIMIZED WHEEL |
GEARBOX SAFETY LOCK:
| W/O G/BOX SECURITY LOCKING |
GEARBOX TYPE (TYPE APPROVAL):
| GEARBOX MA/5 N TYPE |
DIFFERENTIAL (GEARBOX):
| STD GEARBOX DIFF |
| 175X65X14 T TYRES |
WHEELS FITTED:
| 5,5" RIM ROAD WHEELS |
| STEEL WHEELS |
| MA |
ABS:
| W/O ABS BRAKES |
REAR ANTI-ROLL BAR:
| ANTI-ROLL BAR DIAM 18 |
STEERING:
| UNVARIABLE POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 20 |
SERVICE BRAKE:
| WITH COMPENSATOR SLAVE |
BRAKE TYPE:
| NON-VENTILATED FRONT DISCS/REAR DRUMS |
| NORMAL SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT:
| WITHOUT ABS |
PEDAL BRACKET (TYPE):
| PEDAL STANDARD |
HORNS:
| HORN STANDARD |
AERIAL:
| LONG FRONT AERIAL |
FINISHER (SELF-ADHESIVE):
| BLACK DOOR PILLAR WITHOUT DECORATIVE PATTERNS |
| DYED SIDELAMPS |
SIDE MOULDINGS (DIMENSION):
| STANDARD LATERAL PROTECTORS |
| FLORIDA STYLE 6 HOLES 14 INCHES |
| W/O ENGINE UNDERSHELDING |
| EXT MIRROR MANUAL-FOLD BACK |
EXHAUST TAILPIPE TRIM:
| W/O EXHAUST OUTLET EMBELLISHER |
ENGINE BAY SOUNDPROOFING:
| ENGINE SIDE BULKHEAD SOUND PRO |
| FRONT WIPER BLADE W/O RAIN SENSOR |
REAR SCREEN WIPER:
| REAR SCREEN WIPER |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
ROOF GLASS:
| WITHOUT ROOF WINDOW |
BUMPER:
| STANDARD FRONT + BODY COLOUR SPORT REAR BUMPER |
MUDFLAP:
| REAR WHEEL FRONT MUDFLAP |
LUGGAGE RACK:
| MOUNTING WITHOUT ROOF BARS |
| NO FRONT FOG LIGHTS |
SPECIAL HEADLAMP (DOUBLE OPTIC):
| DOUBLE OPTIC LAMPS |
| NON HEATED EXT DRIV RRVIEW MIRROR MAN CNTRL |
| NON HEATED/MANUAL CNTRL PASSENGER OUTER REAR MIRRO |
| STEEL WHEEL + STANDARD TYRE |
| BODY COLOUR DOOR MIRRORS + HANDLES |
| EXT MIRROR ASPHERICAL GLASS |
| FIXED ROOF |
BUMPER TRIM:
| DYED BUMPER STRIP |
REAR WINDOW (TYPE):
| REAR GLASS HEATED |
GLASS (APPEARANCE):
| TINTED |
REAR QUARTER WINDOW (TYPE):
| WITHOUT REAR QUARTER GLASS |
| ATHERMAL WINDSCREEN |
| ANDORRE PLAITED CLOTH + EFKA "PA" |
CIGAR LIGHTER:
| FRONT CIGAR-LIGHTER |
REAR HEAD RESTRAINT:
| REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| SEPARATE FOLD BACK BENCH SEAT |
INTERIOR ALARM:
| DOOR OPEN WARNING (INTERIOR LAMP FLASHING) |
LUGGAGE COVER:
| WITHOUT LUGGAGE COVER |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITHOUT ALARM |
| TEMPERATE COUNTRIES |
AIR CONDITIONING:
| HEATER MATRIX WITH REAR HEATING |
| GRADUATION KMS/H |
GRAB HANDLES:
| FR + RR HANDLES WITH HOOKS |
TACHOMETER:
| REV COUNTER WITH NEEDLE |
RADIO EQUIPMENT:
| FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
CONSOLE:
| CONSOLE WITH REAR HEATING |
| LEFT HAND DRIVE |
REMOTE CONTROL:
| REMOTE CONTROL ASSEMBLY |
ADDITIONAL HEATING:
| WITHOUT ADDITIONNAL HEATING |
LOAD SPACE LIGHTING:
| WITHOUT ARRANGING LIGHTING |
BOOT AND LOAD SPACE LIGHTING:
| AUTO BOOT LIGHT OR LOAD VOL SWITCH |
| GREY CENTRAL PANEL + BLACK DIFFUSER BUTTON |
MISC. INT. LAMPS:
| LESS INTERIOR LIGHT |
| GRADUATION 210 KM/H OR 135 M/H ALUMINIUM LAND |
TACHOMETER (SIGNAL CONNECTION):
| REV COUNTER CALC |
CHILD SEAT ANCHORING POINTS:
| WITHOUT CHILD SEAT MOUNTING |
| MOUNTING 2 LS FR + 2 TWEETERS + 2 LS RR |
| REMOTE RADIO CONTROL WITHOUT CD FUNCTION |
| WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
DRIVER SEAT ADJUSTMENT:
| DRIVERS FIXED LATERAL BEARING |
| PASSENG FIXED LATERAL BEARING |
DRIVER’S SEAT FOLDING:
| W/O FOLDING DRIV FRONT SEATING |
FRONT PASSENGER SEAT FOLDING:
| W/O FOLDING PASS FRONT SEATING |
EXTERIOR TEMP. INDICATOR:
| WITHOUT EXT TEMP INDICATOR |
| WITHOUT COMPACT DISC |
STOWAGE BIN:
| WITHOUT SETTING BOX |
| WITHOUT NAVIGATION SYSTEM |
| MAN CTRL REAR WINDOW LIFTER |
DRIVER’S WINDOW LIFT:
| ELECTR CONTROL DRIVERS FRONT WINDOW LIFTER |
PASSENGER’S WINDOW LIFT:
| ELEC CNTRL PASS FRONT WINDOW LIFTER |
| DISPLAY (CLOCK AND OR TEMP) |
CLOCK:
| NUMERIC CLOCK |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
| NON HEATED SEAT |
| WITHOUT FRONT SIDE AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ON-BOARD COMPUTER:
| NO COMPUTER |
EQUIPMENT PACK:
| W/O EQUIPMENT PACK |
| NON HEATED DOOR MIRROR |
| NEUTRAL FINISH INSIDE DOOR HANDLE |
FRONT SEAT GUARD:
| WITHOUT CAB PROTECTION PANEL |
FRONT SUN VISOR:
| DRIV+PASS SIDE (W/O NOTICE) |
| "RD3" RDS COMPACT DISC AUDIO SYSTEM |
| SINGLE AIR CONDITIONING |
| WITHOUT SPEED CONTROL |
DRIVER’S SEAT HEIGHT CONTROL:
| PARALLEL DRV HEIGHT ADJ |
STORAGE (OTHERS):
| STORAGE COMPARTMENT FR + RR DOORS + WALLET |
CARPET COVER:
| W/O CARPETMAT |
DRIVER AIRBAG:
| DRIVERS AIR BAG |
LOAD SPACE STORAGE:
| W/O BOOT TIDY |
CARPET:
| F550 PILE CARPET |
LIGHTING TIMER:
| NOT ADJUSTABLE TIMER |
SWITCH:
| ELECTRONIC ANTI-THEFT KEY |
| GEAR LEVER KNOB PLASTIC+CHROME INSERT |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| SIMPLE CENTRAL LOCKING |
| RUBBER STEERING WHEEL 3 BRANCH |
STORAGE SPACE LOCKS:
| GLOVE-BOX WITHOUT LOCKING |
| ALTERNATOR 70 AMP |
| BATTERY LO 250 |
| STARTER MOTOR CL 2 |
| WITHOUT PARTICULAR LIGHT |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY |
| STANDARD |
| NORMAL ATMOSPHERE |
FIRST AID KIT:
| WITHOUT FIRST AID BOX |
RADIO HEADPHONE SOCKET:
| WITHOUT ACCESSORIES SOCKET |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SET OF KEYS:
| 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SPEED MONITORING:
| WITHOUT SPEED CHECK |
EMERGENCY WARNING TRIANGLE:
| WITHOUT WARNING TRIANGLE |
