Dekodowanie numeru VIN VSSZZZ1MZ2R075920 na www.automo.pl
Vehicle Identification No.: VSSZZZ1MZ2R075920
Date of production: 22.01.2002
Model year: 2002
Sales type: 1M1324
Engine code: ASV
Engine parameters: 4-cylinder, 81 kW (110 p.s.), 1.9 l
Transmission code: EGS
Interior trim code: KG
Roof color: Z4
Exterior color / paint code: Z4 / C9Z
1E0: Without activated charcoal canister
6EA: Without additional side body covers (stone guard)
3B0: Without additional child seat anchor
2WA: Without additional tires
4J1: Floor tray, extension center console
9TD: Door warning lights front and reflectorsrear
4UE: Air bag for driver and front seat passenger
8L3: Roof antenna
7AA: Electronic vehicle immobilization device
1C1: Antifreeze up to -25 degree celsius tolerance up to -30 degree C
9FA: Without automatic transmission indicator light
9M0: Without auxiliary/parking heater
3H0: Without backrest release for front seats
T8U: 4-cylinder diesel engine 1.9 L unit 038.G
J0L: Battery 340 A (70 Ah)
5C0: Without special body measures
K8G: Hatchback
3P1: Bracket for first aid kit and warning triangle
9U1: Brake pad wear indicator
1LS: Front disc brakes with integrated adapter
1KK: Disc brakes, rear
1AC: Anti-lock brake system (ABS)
4L2: Dipping breakaway interior rear view mirror
2JS: Body-colored bumpers with protective moldings
7QA: Without CD/DVD for navigation
7A0: Without CD changer/CD player
5D1: Carrier frequency 433.92 MHz-434.42 Mhz
4W0: Without cassette and CD storage unit
8KA: W/o catalytic converter warning light
2D1: Complete cd enhancing underbody panel
6E0: Without center armrest front
3C7: 3-point seat belt for center rear seat
B0X: Component parts set, complying with vehicle type for Germany, various parts
6FB: Body-colored exterior mirror housings
4LA: Without controls
8T0: Without cruise control system (CCS)
6Y0: Without cruise control warning system
4M5: Cup holder
4N1: Padded dashboard
4K3: Radio remote controlled central locking operated from inside and safe securing
4AF: Door and side trim panel in foam film and woven fabric
3YQ: Door pockets without insert mats
0A2: 4 doors
1X0: Front wheel drive
QS0: Without electronic map cooling system
0GE: Emission standard EU3
8Z5: Not hot country
MN0: 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3 base engine is T8U
A8D: Luxury equipment
6XB: Exterior mirrors: adjustable from inside
2B3: Additional exterior noise suppression (hood, capsule and dash panel)
6A0: Without fire extinguisher
1T0: Without first aid kit and warning triangle
4Q1: Flame retardent materials
0TA: Without floor mats
2V1: Dust and pollen filter
8WD: Integrated front fog light
6W0: Without license plate bracket front
0AE: Front stabilizer
1SA: Without additional engine guard
2W0: Fuel filler cap
1Z0: Initial standard fuel filling
0F3: Fuel system for diesel engine
2LB: Fuel tank with special material treatment
6R2: Leather gearshift boot
6Q2: Leather gearshift knob/handle
C15: Operating permit, alteration
8GL: Alternator 120 A
5N6: Folding grab handles at roof frame soft fold-away
6PA: Plastic hand brake lever handle
8BB: Halogen headlight for driving on the right
8K0: Without special headlight activation
8X0: Without headlight washer system
8Q1: Headlight-range adjustment
8MA: Without headphone port rear
3J7: Articulated and height-adjustable headrests for front seats
7E3: Sheathed type glow plug heater
9X0: Without heated door lock cylinder
8P1: Heated rear window
9T0: Without heated washer nozzles
9AB: Manually controlled air conditioning
8Y0: Single-tone horn
1EX: Special identification plate for EC for M1 passenger vehicle
0RA: Without ignition/starter switch locking system
2G8: Filler neck module 2 without insert
5TC: Without decorative inserts
0EJ: Installation differentiation for transmission MQ 250 vehicle components
U0C: Instrument insert with tachometer clock and km/h speedometer
8E2: Local interference suppression for FM/AMradio reception
9GA: Interior light with door pillar switches
8QE: Key for locking system with remote control
5SL: Left exterior mirror: aspherical
4SC: Left vanity mirror with cover
4E0: Tailgate/trunk lid unlocking from outside
1PA: Standard wheel bolts
3U1: Foldable trunk cover
6SC: Tufted trunk floor covering
5A2: Comfort trunk lining
4U3: Luggage net on backrest, right seat
7P0: Without lumbar support in seat backrests
0FA: Standard manufacturing sequence
1Q0: Without mass damper for steering wheel
6NA: Unsplit molding roof liner
9Q0: Without multi-function display/ on-board computer
2VP: Nameplate set "TDI" "I"
7Q0: Without navigation device
9Y1: Outdoor temperature gage
3ZM: 3-point seat belts, outer rear
0VC: Information kit in German
5K0: Without surface protection, with additional transit coating
7X0: Without park distance control
3CA: Without partition
4XF: Exterior pillar lining design 2
7PB: Platform group class 2
4P0: Rear floor panel module, type 1
9D0: Without preparation for two-way radio installation
1H0: Without proportioning valve
4B1: Protective side molding
6KA: Radiator grille
8UE: Radio with CD drive
8S1: Reading light front
0N5: Standard rear axle
3GA: Without cargo area
8TF: Rear fog lights, left and right
3Q6: Three rear headrests
6P0: Without license plate bracket rear
6QA: Rear seat catch
3NC: Rear seat bench/backrest, split folding
5J5: Body-colored rear spoiler (version 2)
0BC: Rear stabilizer
8M1: Rear window wiper and washer system with intermittent control
4QU: 3-point seat belts front w/ tensioner (electr.) and height adjustment
5RQ: Right exterior mirror: convex
4TC: Right vanity mirror with cover
3Y0: Without roll-up sun screen
3FA: Without roof insert (standard roof)
3S0: Without roof rails/roof load rack
2UA: Standard design
3L1: Manual height adjustment for left front seat
9P0: Without seat belt reminder
N2Z: Seat covering for special editions
4A0: Without seat heater
QG2: No possibility of activating service interval prolongation
G25: Front shock absorption
UB5: Rear shock absorption for sports design
4X1: Side air bag front
4KC: Side and rear windows in heat-insulatingglass
7R3: Side turn signal lights (white)
5E2: Sill top with door cover
9JB: Smoking package, ashtray front and rear
7B0: Without socket
1G2: Steel spare wheel with original equipment tires
8RM: 8 speakers (passive)
9A0: Without taxi alarm system
0UA: Without special color trim
E82: "Sporty Entry"
0SB: Labels/plates in German
3M0: Without special measures
8CC: Speedometer sensor without seal (electronic speedometer sensor)
1N6: Power steering
2C5: Axial and vertical adjustable steering column
L0L: Left-hand drive vehicle
2PX: Leather trimmed sports steering wheel
0KA: Without stickers and badges
9J0: Without supertone system and tone sequence control
8SA: Taillight assemblies, standard design
9W0: W/o car phone preparation/installation
0L2: Electric throttle actuation
V0A: Tires w/o specification of tire brand
H6S: Tires 195/65 R15 V
1S1: Tool kit and jack
1D3: Preparation for towing attachment with heavy-duty cooling system
G0C: 5-speed manual transmission
0G4: Cable gearshift
B01: Type approval Germany
0CK: Vehicle class differentiation 1M0
F0A: No special purpose vehicle, standard equipment
AZ0: Vehicle with standard production scope
8W1: Washer fluid level indicator
L20: Suspension range 20 installation control only, no requirement forecast
0YZ: Without determination of weight categoryfor rear axle
1NL: Covers for alloy wheels
CU8: Alloy wheels 6J x 15 "Martinet" (1M0 601 025 H)
4R5: Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
4GF: Windshield in heat-insulating glass
8N4: Windshield wiper intermittent control with potentiometer (four speeds)
QA0: Without child seat
Q4H: Comfort sports seats, front
