Activated carbon canister:
 | Activated carbon canister |
Additional body covers, side:
 | Without additional side body covers(stone guard) |
 | Without additional child seat anchor |
Additional dust seals:
 | Without additional seals outside |
 | Without additional tires |
Additional tunnel cover:
 | Floor tray, extension center console |
Additional warning lights:
 | Additional warning lights (door area) |
Air bag:
 | Air bag for driver and front seatpassenger |
Antennas:
 | Roof antenna |
Anti-theft protection system:
 | Electronic vehicle immobilization device |
Antifreeze:
 | Antifreeze up to -25 degree celsiustolerance up to -30 degree C |
Automatic transmission indicator light:
 | Without automatic transmissionindicator light |
Auxiliary heating:
Backrest release:
 | Without backrest release for front seats |
Base engine:
 | 4-cylinder gasoline engine 1.8 Lunit 06A.A |
Batteries:
 | Battery 280 A (60 Ah) |
Body measures:
 | Without special body measures |
Body style:
 | Notchback |
Brackets:
 | Bracket for first aid kit and warningtriangle |
Brake pad wear indicator:
 | Without brake pad wear indicator |
Brake type, front:
 | Front disc brakes with integratedadapter |
Brake type, rear:
 | Disc brakes, rear |
Braking systems:
 | Electronic differential lock (EDL) |
Breakaway interior mirror:
 | Dipping breakaway interior rear viewmirror |
Bumper:
 | Standard bumpers |
CD ROM/DVD/SD card:
 | Without CD/DVD for navigation |
CD changer/CD player:
 | CD changer preparation |
 | Carrier frequency 433.92 MHz-434.42 Mhz |
Cassette and CD storage unit:
 | Without cassette and CD storage unit |
Catalytic converter control:
 | W/o catalytic converter warning light |
Cd enhancing underbody panel:
 | Complete cd enhancing underbody panel |
Center armrest:
 | Front center armrest |
Center rear seat belts:
 | Static lap belt, center rear |
Child seats:
 | Without child seat |
 | Component parts set, complying withvehicle type for the Netherlandsvarious parts |
 | Body-colored exterior mirror housings |
Controls (steering wheels/steering column):
 | Without controls |
Cruise control:
 | Without cruise control system (CCS) |
Cruise control warning and speed limit system:
 | Without cruise control warning system |
Cup holder:
 | Cup holder |
Dashboard:
 | Padded dashboard |
Dashboard illumination:
 | Standard dashboard illumination |
Door and lid locking system:
 | Radio remote controlled central lockingoperated from inside and safe securing |
Door and side trim panels:
 | Door and side trim panel in foam filmand woven fabric |
Door pockets, front:
 | Door pockets without insert mats |
Doors:
 | 4 doors |
Drive layout:
 | Front wheel drive |
Electronic map cooling system:
 | Without electronic map cooling system |
Emission standard:
 | Emission standard D3 EU3D |
Engine compartment lighting:
 | Without engine compartment lighting |
Engine cooling system:
 | Not hot country |
Engine specifications:
 | 4-cyl. gasoline engine 1.8 L/92 kW 20VEU 3Dbase engine is T0V |
Equipment levels:
 | Luxury equipment |
Exterior mirror setting:
 | Exterior mirrors  electrically foldableand electrically adjustable/heated |
Exterior noise suppression measures:
 | Additional exterior noise suppression |
Fire extinguisher:
 | Without fire extinguisher |
 | Without first aid kit and warningtriangle |
Flame retardent materials:
 | Flame retardent materials |
Floor mats:
 | Without floor mats |
Fresh air intake for passenger compartment (with particulate filter):
 | Dust and pollen filter |
 | Integrated front fog light |
Front license plate carrier:
 | Without license plate carrier front |
Front seats:
 | Standard front seats |
Front stabilizer:
 | Front stabilizer |
Front underbody guard:
 | Without additional front underbody guard |
Fuel filler cap/door, locking option:
 | Fuel filler cap |
 | Initial standard fuel filling |
Fuel systems:
 | Fuel system for carburetor gasolineengine |
Fuel tank treatment:
 | Fuel tank with special materialtreatment |
Gearshift boot/cover:
 | Leatherette gearshift boot |
Gearshift knob/handle:
 | Comfort gearshift knob/handle |
 | Operating permit, alteration |
Generators:
 | Alternator 90A |
Grab handles at roof frame:
 | Folding grab handles at roof framesoft fold-away |
Hand brake lever handle:
 | Plastic hand brake lever handle |
Headlight:
 | Halogen headlightfor driving on the right |
Headlight activation:
 | Without special headlightactivation |
Headlight washer system:
 | Without headlight washer system |
Headlight-range adjustment:
 | Headlight-range adjustment |
Headphone port, rear:
 | Headphone port rear |
Headrests:
 | Articulated and height-adjustableheadrests for front seats |
 | W/o heat accumulator/auxiliary heating |
Heated door lock cylinder:
 | Without heated door lock cylinder |
Heated rear window:
 | Heated rear window |
Heated washer nozzles:
 | Without heated washer nozzles |
 | Climatronic with impact pressurecontrol free of cfc |
Horns:
 | Two-tone horn |
Identification plates:
 | Special identification plate for ECfor M1 passenger vehicle |
 | Without ignition/starter switch lockingsystem |
 | Filler neck module 2 with insert |
Inserts:
 | Without decorative inserts |
Installation differentiation for vehicle components:
 | Installation differentiation fortransmission MQ 250vehicle components |
Instrument inserts:
 | Instrument insert with tachometerclock and km/h speedometer |
Interference suppression:
 | Local interference suppression for FM/AMradio reception |
Interior light in driver compartment:
 | Interior light with switch-off delay anddoor pillar switch |
Key for locking system:
 | Key for locking systemwith remote control |
Label for radio remote control:
 | Without label for radio remote control |
Lashing rings/rails for load restraint:
 | Without lashing rings for load restraint |
Left exterior mirror:
 | Left exterior mirror  aspherical |
Left vanity mirror:
 | Left vanity mirror, illuminated |
 | Tailgate/trunk lid unlockingfrom outside |
Lockable wheel bolts:
 | Standard wheel bolts |
Luggage compartment cover:
 | Luggage compartment cover |
Luggage compartment floor covering:
 | Tufted trunk floor covering |
Luggage compartment lining:
 | Comfort trunk lining |
Luggage net/pocket on backrest(s):
 | Luggage net on backrest, right seat |
Lumbar support:
 | Without lumbar supportin seat backrests |
 | Brussels manufacturing sequence |
Mass damper for steering wheels:
 | Without mass damper for steering wheel |
Molding roof liner:
 | Unsplit molding roof liner |
 | Multi-function display/on-board computer |
Nameplate set:
 | Nameplate set  20V |
Navigation device:
 | Without navigation device |
Outdoor temperature gage:
 | Outdoor temperature gage |
Outer rear seat belts:
 | 3-point seat belts, outer rear |
Owner s manuals:
 | Information kit in Dutch |
 | Paint preservative (wax) |
Park distance control:
 | Without park distance control |
Partition:
 | Without partition |
Pillar lining:
 | Exterior pillar liningdesign 2 |
Platform group class:
 | Platform group class 2 |
Platform module floor pan, rear:
 | Rear floor panel module, type 3 |
Preparation for sound combination for rotating emergency light:
 | Without sound combination for rotatingemergency light and radio antennapreparation |
Preparation for two-way radio installation:
 | Without preparation for two-way radioinstallation |
Proportioning valve:
 | Without proportioning valve |
Protective side molding:
 | Protective side molding |
Radiator grille:
 | Radiator grille |
Radios:
 | Radio for comfort-class vehicle |
Reading light:
 | One reading light front, two readinglights rear |
Rear axle:
 | Standard rear axle |
Rear cargo area:
 | Without cargo area |
Rear fog light:
 | Rear fog lights, left and right |
Rear headrests:
 | Three rear headrests |
Rear license plate carrier:
 | Without license plate carrier rear |
Rear seat catch:
 | Rear seat catch |
Rear seats:
 | Rear seat bench/backrest, split foldingwith center armrest |
Rear spoiler:
 | Without rear spoiler |
Rear stabilizer:
 | Rear stabilizer |
Rear window wiper and washer system:
 | W/o rear window wiper and washer system |
Restraint systems, front:
 | 3-point seat belts front w/ tensioner(electr.) and height adjustment |
Right exterior mirror:
 | Right exterior mirror  convex(large viewing field) |
Right vanity mirror:
 | Right vanity mirror illuminated |
 | Roll-up sun screen for rear window |
Roof insert/convertible top:
 | Without roof insert (standard roof) |
Roof rails/roof load rack:
 | Without roof rails/roof load rack |
Rough-road/sports version:
 | Standard design |
Seat adjustment:
 | Manual height adjustment for left frontseat |
Seat belt check:
 | Without seat belt reminder |
Seat covering:
 | Fabric seat covering |
Seat heater:
 | Without seat heater |
Service interval prolongation:
 | Without service interval prolongation |
Shock absorption, chassis, front:
 | Front shock absorption |
Shock absorption, chassis, rear:
 | Rear shock absorption, basic design 2 |
Side air bag:
 | Side air bag front |
Side and rear windows:
 | Side and rear windows in heat-insulatingglass |
Side lights:
 | Side turn signal lights (white) |
Sill top/sill cover:
 | Sill top with door cover |
Smoking/non-smoking package:
 | Smoking package, ashtray front and rear |
Socket:
 | 12-volt socket in luggage boot |
Spare wheel/breakdown set:
 | Steel spare wheel with originalequipment tires |
Speaker installation:
 | 8 speakers (passive) |
Special alarm systems:
 | Without taxi alarm system |
Special color trim:
 | Without special color trim |
Special editions:
 | No special edition |
Special labels/plates:
 | Labels/plates in Dutch |
Special registration measures:
 | Without special measures |
Speedometer cable and seal:
 | Speedometer sensor without seal(electronic speedometer sensor) |
Steering:
 | Power steering |
Steering column systems:
 | Axial and vertical adjustable steeringcolumn |
Steering system arrangement:
 | Left-hand drive vehicle |
Steering wheels:
 | Leather trimmed sports steering wheel |
Sticker (customized or special edition):
 | Without stickers and badges |
Supertone system and tone sequence control:
 | Without supertone system and tonesequence control |
Taillight assemblies:
 | Taillight assemblies, standard design |
Telephone/telematics:
 | W/o car phone preparation/installation |
Throttle actuation:
 | Mechanical throttle actuation |
Tire suppliers:
Tires:
 | Tires 195/65 R15 V |
Tool kit and jack:
 | Tool kit and jack |
Trailer hitch:
 | Trailer hitch |
Transmission specifications:
 | 5-speed manual transmission |
Transmission types/gearshift mechanisms:
 | Cable gearshift |
Trunk sill protection:
 | Plastic trunk sill protection |
 | Type approval the Netherlands |
 | Vehicle class differentiation 1M0 |
Vehicle specifications:
 | No special purpose vehicle, standardequipment |
Washer fluid level indicator:
 | Washer fluid level indicator |
Weight category front axle:
 | Suspension range 16installation control only, norequirement forecast |
Weight category rear axle:
 | Without determination of weight categoryfor rear axle |
Wheel covers:
 | Wheel center cover |
Wheels:
 | Steel wheels 6J x 15Offset 38 |
Window regulator:
 | Power windows with comfort operation andcircuit breaker |
Windshield glass type:
 | Windshield in heat-insulating glass |
Windshield wiper intermittent control:
 | Windshield wiper intermittent controlwith potentiometer (four speeds) |
