zloty strzal i zdekodowalo ;D
Numer VIN - VSSZZZ6KZ1R061324
Region - Spain
Fabryka / Producent - Martorell
Marka - Seat
Model - Ibiza Stella\nRok - 2000
Silnik - 1.90 [50kW] [68HP] [4cyl.]
Numer seryjny - 061324
Vehicle identification no. - Vsszzz6kz1r061324
Model designation - Ibiza stella
Date of production - 04.07.2000
Model year - 2001
Sales type - 6k12k6
Engine code - AGP
Transmission code - EAY
Axle drive - 5S
Interior trim code - CN
Roof color - L1
Exterior color / paint code - L1 / s7n
Activated carbon canister - Without activated charcoal canister
Additional body covers, side - Without additional side body covers (stone guard)
Additional child seat anchors - Child seat anchor for child seat system isofix
Additional dust seals - Without additional seals outside
Additional instruments - Without additional instruments/switches
Additional tires (winter tires) - Without additional tires
Additional tunnel cover - Floor tray, extension center console
Air bag - Air bag for driver
Air cleaner (engine) - Standard air cleaner
Antennas - Roof antenna
Anti-theft protection system - Electronic vehicle immobilization device
Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c
Backrest release - Backrest release for front seat(s)
Batteries - Battery 340 a (70 ah)
Body style - Hatchback
Brackets - Without bracket for first aid kit and warning triangle
Brake type, front - Disc brakes, front
Brake type, rear - Drum brakes, rear
Braking systems - Anti-lock brake system (abs)
Breakaway interior mirror - Dipping breakaway interior rear view mirror
Bumper - Comfort bumpers
Cd changer/cd player - Without cd changer/cd player
Carrier frequency for radio remote control - Carrier frequency 433.92 mhz-434.42 mhz
Center console - Center console
Center high-mounted stop light - Center high-mounted stop light
Center rear seat belts - Static lap belt, center rear
Cigarette lighter - Cigarette lighter
Climatic zones - Standard climatic zones
Clutch actuation - Hydraulic clutch actuation
Component part sets with country-specific design requirements - Component parts set, complying with vehicle type for france, various parts
Components with special surface appearance - Components without special surface appearance
Cruise control - Without cruise control system (ccs)
Cruise control warning and speed limit system - Without cruise control warning system
Cup holder - Without cup holder
Dashboard - Standard dashboard
Door and lid locking system - Radio remote controlled central locking
Door and side trim panels - Door and side trim panel in foam film and woven fabric
Doors - 2 doors
Emission standard - Emission standard eu2 mveg 2
Engine specifications - 4-cylinder diesel engine 1.9 l/50 kw sdi with mveg 2 base engine is t0x
Equipment levels - Executive comfort equipment
Exterior mirror setting - Exterior mirrors adjustable from inside
Exterior noise suppression measures - Additional exterior noise suppression
First aid kit / warning triangle - Without first aid kit and warning triangle
Floor coverings - Flat needle-punched floor covering
Floor mats - Without floor mats
Fresh air intake for passenger compartment (with particulate filter) - Fresh air intake without air cleaner
Front fog light circuit - Without front fog light circuit
Front fog light/additional headlight - Without front fog light
Front spoiler - Front spoiler (type 2)
Front stabilizer - Front stabilizer
Front turn signal lights - White turn signal lights
Fuel quantity for initial filling - Initial standard fuel filling
Fuel systems - Fuel system for naturally aspirated diesel engine with direct injection (sdi)
Fuel tank treatment - Fuel tank without special material treatment
Gearshift boot/cover - Leatherette gearshift boot
Gearshift knob/handle - Comfort gearshift knob/handle
General operating permit, alterations - Operating permit, alteration
Generators - Alternator 90a
Glove compartment - Glove compartment door without light
Grab handles at roof frame - Folding grab handles
Hand brake lever handle - Plastic hand brake lever handle
Headlight - Halogen headlight for driving on the right
Headlight activation - Without special headlight activation
Headlight washer system - Without headlight washer system
Headlight-range adjustment - Headlight-range adjustment
Headrests - Height-adjustable headrests for front seats
Heat accumulator system/additional heater - without heat accumulator/auxiliary heating
Heated washer nozzles - Without heated washer nozzles
Heating and air conditioning system - Manually controlled air conditioning
Hinged quarter window - Without rear hinged quarter window
Horns - Single-tone horn
Identification plates - Special identification plate for ec for m1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type - Without insert for the filling up of fuel
Interior light in driver compartment - Interior light with door pillar switches
Interior noise suppression measures - Acoustics package for diesel
Key for locking system - Key for locking system with remote control
Label for axle load and gross vehicle weight rating - Without sticker for permissible front and rear axle loads and gross vehicle weight rating
Label for brake-proportioning values - Without label for brake-proportioning values
Labels - Labels for country group 4/b
Lashing rings/rails for load restraint - Without lashing rings for load restraint
Left exterior mirror - Left exterior mirror aspherical
Left vanity mirror - Left vanity mirror with cover
Lockable wheel bolts - Standard wheel bolts
Luggage compartment cover - Luggage compartment cover
Luggage compartment floor covering - Tufted trunk floor covering
Luggage compartment lighting - Luggage compartment lighting
Luggage compartment lining - Trunk lining partially fleece
Marque-specific/class-specific features - Seat marque-specific/class-specific features
Multi-function display/trip computer - Without multi-function display/ on-board computer
Nameplate set - Nameplate set sdi
Outer rear seat belts - 3-point seat belts, outer rear with ece label
Owner s manuals - Information kit in french
Paint preservative/transit coating - Without surface protection, with additional transit coating
Partition - Without partition
Payloads - Standard payload
Pillar lining - Without pillar lining
Proportioning valve - Without proportioning valve
Protective side molding - Without protective side molding
Radios - Without radio, but with preparation for six speakers
Reading light - Without reading light
Rear cargo area - Without cargo area
Rear fog light - Rear fog lights, left and right
Rear gates/tailgate - Standard trunk lid
Rear headrests - Rear headrests
Rear heating system/ventilation system - Rear heating duct
Rear license plate carrier - Without license plate carrier rear
Rear seats - Rear seat bench/backrest, split folding
Rear spoiler - Body-colored rear spoiler (version 3)
Rear stabilizer - Without rear stabilizer
Rear window wiper and washer system - Rear window wiper and washer system with intermittent control
Restraint systems, front - 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror - Right exterior mirror convex
Right vanity mirror - Vanity mirror right
Roof insert/convertible top - Without roof insert (standard roof)
Roof rails/roof load rack - Without roof rails/roof load rack
Seat adjustment - Manual height adjustment for left front seat
Seat belt check - Without seat belt reminder
Seat covering - Woven fabric seat covering
Seat heater - Without seat heater
Shock absorption/suspension, chassis - Standard suspension/shock absorption
Side air bag - Without side air bag
Side and rear windows - Side and rear windows in heat-insulating glass
Side lights - Dark colored side turn signal lights
Socket - Without socket
Spare wheel/breakdown set - Space-saving spare wheel
Speaker installation - 4 speakers (passive)
Special editions - No special edition
Special labels/plates - Labels/plates in french
Steering - Power steering
Steering column systems - Height adjustable steering column
Steering system arrangement - Left-hand drive vehicle
Steering wheels - Comfort steering wheel for air bag system with additional mass
Sticker (customized or special edition) - Without stickers and badges
Taillight assemblies - Taillight assembly with red colored lens
Throttle actuation - Electric throttle actuation
Tires - Tires 175/70 r14 88h
Tool kit and jack - Tool kit and jack
Trailer hitch - Without trailer hitch
Transmission specifications - 5-speed manual transmission
Transmission types/gearshift mechanisms - Gearshift linkage
Tray - Without tray on roof liner
Trunk sill protection - Without trunk sill protection
Type approval countries/countries with special requirements - Type approval france
Upgrading measures - Vehicles with special upgrade measures
Vehicle class differentiation units/platform components - Vehicle class differentiation 6k0
Vehicle specifications - No special purpose vehicle, standard equipment
Weight category front axle - Suspension range 57
Weight category rear axle - Without determination of weight category for rear axle
Wheel covers - Full wheel covers
Wheels - Steel wheels 6j x 14 for seat, black, offset 38
Window regulator - Power windows
Windshield glass type - Windshield in heat-insulating glass
Windshield wiper arms/blades - Windshield wiper arms/blades with additional guide vanes
Windshield wiper intermittent control/ light/rain sensor - Windshield wiper intermittent control
Base engine - 4-cylinder diesel engine 1.9 l unit 038.d
Front seats - Standard front seats with integrated storage trays
Instrument inserts - Instrument insert with tachometer clock and km/h speedometer
Tire suppliers - Tires with o specification of tire brand
Tray areas package - Tray areas package 1
