Proszę o sprawdzenie ibizy: VIN: VSSZZZ6LZ3R136332. Z góry dziękuje. |
Numer VIN - VSSZZZ6LZ3R136332
Region - Spain Fabryka / Producent - Martorell Marka - Seat Model - Ibiza Sport\nRok - 2002 Silnik - 1.90 [96kW] [131HP] [4cyl.] Numer seryjny - 136332 Vehicle identification no. - Vsszzz6lz3r136332 Model designation - Ibiza sport Date of production - 11.12.2002 Model year - 2003 Sales type - 6l1536 Engine code - ASZ Transmission code - FJW Axle drive - 6S Interior trim code - DY Roof color - Z4 Exterior color / paint code - Z4 / c9z Activated carbon canister - Without activated charcoal canister Additional body covers, side - Without additional side body covers (stone guard) Additional child seat anchors - Without additional child seat anchor Additional dust seals - Without additional seals outside Additional instruments - Additional instruments (voltage and oil pressure) Additional tires (winter tires) - Without additional tires Additional warning lights - Without additional warning lights Air bag - Driver s and front passenger air bag with front passenger air bag deactivation Air cleaner (engine) - Standard air cleaner Air duct, front area - Air duct, type 1 Antennas - Roof antenna Anti-theft protection system - Electronic vehicle immobilization device Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c Automatic transmission indicator light - Without automatic transmission indicator light Backrest release - Backrest release for front seat(s) Base engine - 4-cylinder diesel engine 1.9 l unit 038.k Batteries - Battery 340 a (70 ah) Body measures - Additional body measures Body style - Hatchback Body treatment - Special body treatment Brackets - Bracket for first aid kit and warning triangle Brake pad wear indicator - Without brake pad wear indicator Brake type, front - Disc brakes, front Brake type, rear - Disc brakes, rear Braking systems - Electronic stabilization program (esp) Breakaway interior mirror - Dipping breakaway interior rear view mirror Bumper - Body-colored bumpers Cd rom/dvd/sd card - Without cd/dvd for navigation Cd changer/cd player - Without cd changer/cd player Carrier frequency for radio remote control - Carrier frequency 433.92 mhz-434.42 mhz Cd enhancing underbody panel - Without cd enhancing underbody panel Center high-mounted stop light - Center high-mounted stop light Center rear seat belts - Static lap belt, center rear Center sun visor - Without center sun visor Chrome work package - Without aluminum/chrome work package Climatic zones - Standard climatic zones Component part sets with country-specific design requirements - Component parts set, complying with vehicle type for germany, various parts Components with special surface appearance - Components without special surface appearance Cruise control - Cruise control system (ccs) electronic Cruise control warning and speed limit system - Without cruise control warning system Cup holder - Without cup holder Dashboard - Dashboard with deleted option Door and lid locking system - Radio remote controlled central locking operated from inside and safe securing Door and side trim panels - Door and side trim panel Doors - 2 doors Drawers under front seats - Without drawers under front seats Electronic map cooling system - Without electronic map cooling system Emission standard - Emission standard eu3 Engine cover - Engine cover Engine specifications - 4-cyl. turbo diesel engine 1.9 l/96 kw tdi with pump-jet injection system base engine is t9j Equipment levels - Sports equipment Exhaust tailpipe - Rear exhaust tailpipe (standard) Exterior mirror setting - Exterior mirrors electrically foldable and electrically adjustable/heated Exterior noise suppression measures - Additional exterior noise suppression Fire extinguisher - Without fire extinguisher First aid kit / warning triangle - Without first aid kit and warning triangle Floor mats - Without floor mats Foot area lining - Foot area lining with cover Frame forestructure - Long frame forestructure Fresh air intake for passenger compartment (with particulate filter) - Dust and pollen filter Front fog light/additional headlight - Integrated front fog light Front license plate carrier - Without license plate carrier front Front stabilizer - Front stabilizer Front underbody guard - Without additional front underbody guard Fuel filler cap/door, locking option - Fuel filler cap Fuel quantity for initial filling - Initial standard fuel filling Fuel systems - Cooled fuel system for diesel engine Fuel tank treatment - Fuel tank with special material treatment Gearshift boot/cover - Leatherette gearshift boot Gearshift knob/handle - Leather gearshift knob/handle General operating permit, alterations - Operating permit, alteration Generators - Alternator 120 a Glove compartment - Glove compartment door without light Grab handles at roof frame - Folding grab handles Hand brake lever handle - Leather hand brake lever handle Headlight - Headlight with gas discharge lamp and turn signal light for driving on the right Headlight activation - Without special headlight activation Headlight washer system - Headlight washer system Headlight-range adjustment - Automatic headlight-range adjustment static Headrests - Articulated and height-adjustable headrests for front seats Heat accumulator system/additional heater - Electric auxiliary air heater Heated rear window - Heated rear window Heated washer nozzles - Heated washer nozzles, front Heating and air conditioning system - Climatic air-conditioning system (semi-automatic) Horns - High-sounding horn Identification plates - Special identification plate for ec for m1 passenger vehicle Ignition/starter switch locking system - Without ignition/starter switch locking system Insert for the filling up of unleaded fuel/fuel type - Filler neck module 1 without insert Inserts - Without decorative inserts Installation differentiation for vehicle components - Installation differentiation for transmission mq 350 vehicle components Instrument inserts - Instrument insert with tachometer clock and km/h speedometer Interior light in driver compartment - Interior light with switch-off delay and door pillar switch Key for locking system - Key for locking system with remote control Left exterior mirror - Left exterior mirror aspherical Left vanity mirror - Without left vanity mirror, but pocket in sun visor Light package (lighting) - Without add. lights (interior lighting) Lock operation for tailgate/trunk lid - Tailgate/trunk lid unlocking from outside Lockable wheel bolts - Wheel bolts with anti-theft protection (unlockable) Luggage compartment cover - Foldable trunk cover Luggage compartment floor covering - Tufted trunk floor covering Luggage compartment lighting - Luggage compartment lighting Luggage compartment lining - Full fleece trunk lining Luggage net/pocket on backrest(s) - Luggage net on backrest, right seat Manufacturing sequence differentiation - Standard manufacturing sequence Mass damper for steering wheels - Without mass damper for steering wheel Molding roof liner - Unsplit molding roof liner Multi-function display/trip computer - Multi-function display/on-board computer Nameplate set - Nameplate set tdi Navigation device - Without navigation device Outer rear seat belts - 3-point seat belts, outer rear with ece label Owner s manuals - Information kit in german Paint preservative/transit coating - Without surface protection, with additional transit coating Partition - Without partition Pillar lining - Exterior pillar lining Platform group class - Platform group class 2 Platform module floor pan, rear - Rear floor panel module, type 3 Protective side molding - Protective side molding Radiator grille - Radiator grille Radios - Radio for comfort-class vehicle Reading light - Without reading light Rear axle - Heavy-duty rear axle (design 2) Rear fog light - Rear fog light for driving on the right Rear headrests - Rear headrests Rear license plate carrier - Without license plate carrier rear Rear seat catch - Rear seat catch Rear seats - Rear seat bench/backrest, split folding Rear window wiper and washer system - Rear window wiper and washer system with intermittent control Restraint systems, front - 3-point seat belts with electric tensioner and height adjustment, front Right exterior mirror - Right exterior mirror convex Right vanity mirror - Right vanity mirror with cover Roof insert/convertible top - Without roof insert (standard roof) Roof rails/roof load rack - Without roof rails/roof load rack Seat adjustment - Manual height adjustment for left front seat Seat belt check - Without seat belt reminder Seat covering - Fabric seat covering Seat heater - Seat heater for front seats separately controlled Service interval prolongation - Without service interval prolongation Shock absorption, chassis, front - Front shock absorption Shock absorption, chassis, rear - Rear sports shock absorption Side air bag - Side air bag front Side and rear windows - Side and rear windows in heat-insulating glass Side lights - Side turn signal lights (white) Smoking/non-smoking package - Smoking package, ashtray front Socket - Without socket Spare wheel/breakdown set - Steel spare wheel with original equipment tires Speaker installation - 8 speakers (passive) Special editions - No special edition Special labels/plates - Labels/plates in german Speedometer cable and seal - Speedometer sensor without seal (electronic speedometer sensor) Steering - Power steering Steering column systems - Axial and vertical adjustable steering column Steering system arrangement - Left-hand drive vehicle Steering wheels - Leather steering wheel Sticker (customized or special edition) - Without stickers and badges Taillight assemblies - Taillight assemblies, standard design Telephone/telematics - without car phone preparation/installation Tire suppliers - Tires with o specification of tire brand Tires - Tires 205/45 r16 83w Tool kit and jack - Tool kit and aluminum jack Trailer hitch - Without trailer hitch Transmission specifications - 6-speed manual transmission Transmission types/gearshift mechanisms - Cable gearshift Trunk sill protection - Plastic trunk sill protection Type approval countries/countries with special requirements - Type approval germany Vehicle class differentiation units/platform components - Vehicle class differentiation 6l0 Vehicle specifications - No special purpose vehicle, standard equipment Vehicle type - Vehicle with standard production scope Washer fluid level indicator - Without washer fluid level indicator Weight category front axle - Suspension range 43 installation control only, no requirement forecast Weight category rear axle - Weight range 1 installation control only, no requirement forecast Wheel covers - Covers for alloy wheels Wheel housing liners - Wheel housing liner front and rear Wheels - Alloy wheels 6.5j x 16 Window regulator - Power windows Windshield glass type - Windshield in heat-insulating glass Windshield wiper arms/blades - Windshield wiper arms/blades with additional guide vanes Windshield wiper intermittent control/ light/rain sensor - Windshield wiper intermittent control with potentiometer (four speeds) Child seats - Without child seat Front seats - Comfort sports seats, front Country-specific product program - National sales program germany |
blazer zapoznales sie z regulaminem dzialu ocena auta?
Brak historii
Data produkcji: 2002-12-11 |
