seat do 2005 roku = brak historii...
1 0A2 L TUE 4 doors
2 0AE L STV Front stabilizer
3 0BC L STH Rear stabilizer
4 0CK L AED Vehicle class differentiation 1M0
5 0EJ L EDF Installation differentiation for transmission MQ 250 vehicle components
6 0F3 L KRS Fuel system for diesel engine
7 0FA L FAD Standard manufacturing sequence
8 0G4 L GES Cable gearshift
9 0GZ E AGM Emission concept EU3, diesel with EOBD
10 0KA L KAE Without stickers and badges
11 0L2 L GAB Electric throttle actuation
12 0N5 L HIA Standard rear axle
13 0RA L ZSS Without ignition/starter switch locking system
14 0SG L SAU Labels/plates in French
15 0TA L ZFM Without floor mats
16 0UA L BFA Without special color trim
17 0VB L BTA Information kit in French
18 0YZ L GKH Without determination of weight categoryfor rear axle
19 1AJ L BRS Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
20 1C1 L FRO Antifreeze up to -25 degree celsius tolerance up to -30 degree C
21 1D3 L AHV Preparation for towing attachment with heavy-duty cooling system
22 1E0 L AKB Without activated charcoal canister
23 1EX L TYP Special identification plate for EC
24 1G2 L RER Steel spare wheel with original equipment tires
25 1H0 L BRM Without proportioning valve
26 1KK L BAH Disc brakes, rear
27 1LS L BAV Front disc brakes with integrated adapter
28 1MF L LRA Comfort steering wheel for air bag system
29 1N6 L LEN Power steering
30 1NL L RAA Covers for alloy wheels
31 1PC L ABR Wheel bolts with anti-theft protection (unlockable)
32 1Q0 L TGL Without mass damper for steering wheel
33 1S1 L BOW Tool kit and jack
34 1SA L TWU Without additional engine guard
35 1T0 L VBK Without first aid kit and warning triangle
36 1X0 L ATA Front wheel drive
37 1Z0 L KRM Initial standard fuel filling
38 2B3 L GRD Additional exterior noise suppression (hood, capsule and dash panel)
39 2C5 L LSS Axial and vertical adjustable steering column
40 2D1 L CWV Complete cd enhancing underbody panel
41 2G8 L EBB Filler neck module 2 without insert
42 2JG L STF Body-colored bumpers
43 2LB L KRB Fuel tank with special material treatment
44 2UA L SWP Standard design
45 2V1 L FRI Dust and pollen filter
46 2VP L SZU Nameplate set "TDI" "I"
47 2W0 L TDA Fuel filler cap
48 2WA L ZBR Without additional tires
49 3B0 L ZKV Without additional child seat anchor
50 3C7 L SHM 3-point seat belt for center rear seat
51 3CA L TRW Without partition
52 3FA L DEI Without roof insert (standard roof)
53 3GA L LBH Without cargo area
54 3H0 L LER Without backrest release for front seats
55 3J7 L KOV Articulated and height-adjustable headrests for front seats
56 3L1 L SIE Manual height adjustment for left front seat
57 3M0 L SZL Without special measures
58 3NC L HIS Rear seat bench/backrest, split folding
59 3P1 L HAL Bracket for first aid kit and warning triangle
60 3Q6 L KOH Three rear headrests
61 3S0 L DAR Without roof rails/roof load rack
62 3U1 L GPR Foldable trunk cover
63 3Y0 L SSR Without roll-up sun screen
64 3YQ L TAV Door pockets without insert mats
65 3ZM L SHA 3-point seat belts, outer rear
66 4A0 L SIH Without seat heater
67 4AF L TSV Door and side trim panel in foam film and woven fabric
68 4B1 L SSL Protective side molding
69 4E0 L SDH Tailgate/trunk lid unlocking from outside
70 4GF L WSS Windshield in heat-insulating glass
71 4J1 L ZTA Floor tray, extension center console
72 4K3 L TKV Radio remote controlled central locking operated from inside and safe securing
73 4KC L SSH Side and rear windows in heat-insulatingglass
74 4L6 L IRS Breakaway interior mirror, automatically dimming
75 4LA L BED Without controls
76 4M5 L BEH Cup holder
77 4N1 L INT Padded dashboard
78 4P0 L PBH Rear floor panel module, type 1
79 4Q1 L SES Flame retardent materials
80 4QU L RSV 3-point seat belts with tensioner and electric height adjustment front
81 4R4 L FEH Power windows with comfort operation andcircuit breaker
82 4SD L MSL Left vanity mirror, illuminated
83 4TD L MSR Right vanity mirror illuminated
84 4U3 L GNF Luggage net on backrest, right seat
85 4UF L AIB Driver's and front passenger air bag with front passenger air bag deactivation
86 4W0 L KBO Without cassette and CD storage unit
87 4X1 L SAB Side air bag front
88 4XF L DPF Exterior pillar lining design 2
89 5A2 L GRV Comfort trunk lining
90 5C0 L KSA Without special body measures
91 5D1 L TRF Carrier frequency 433.92 MHz-434.42 Mhz
92 5J5 L HES Body-colored rear spoiler (version 2)
93 5K0 L LAC Without paint preservative
94 5N6 L HGD Folding grab handles at roof frame soft fold-away
95 5RQ L ASR Right exterior mirror: convex
96 5SL L ASL Left exterior mirror: aspherical
97 5TC L EIH Without decorative inserts
98 6A0 L FEU Without fire extinguisher
99 6E3 L MAS Front center armrest
100 6EA L ZKS Without additional side body covers (stone guard)
101 6FB L BBO Body-colored exterior mirror housings
102 6KA L KUG Radiator grille
103 6NA L HIM Unsplit molding roof liner
104 6P0 L KZH Without license plate bracket rear
105 6PA L HBV Plastic hand brake lever handle
106 6Q4 L SAG Comfort gearshift knob/handle
107 6QA L VRH Rear seat catch
108 6R1 L SHV Leatherette gearshift boot
109 6SC L KBB Tufted trunk floor covering
110 6W0 L KZV Without license plate bracket front
111 6XD L ASE Exterior mirrors: electrically adjustable/heated
112 6Y0 L GWA Without cruise control warning system
113 7A0 L CDW Without CD changer/CD player
114 7AA L EDW Electronic vehicle immobilization device
115 7B0 L STD Without socket
116 7E0 L WSA W/o heat accumulator/auxiliary heating
117 7P0 L LOR Without lumbar support in seat backrests
118 7PB L PGK Platform group class 2
119 7Q0 L NAV Without navigation device
120 7QA L CDR Without CD/DVD for navigation
121 7R3 L SLE Side turn signal lights (white)
122 7X0 L EPH Without park distance control
123 8BB L HSW Halogen headlight for driving on the right
124 8CC L TWP Speedometer sensor without seal (electronic speedometer sensor)
125 8E2 L ENT Local interference suppression for FM/AMradio reception
126 8GD L GEN Alternator 90A
127 8K0 L FLS Without special low beam mode
128 8KA L KUE W/o catalytic converter warning light
129 8L3 L ANT Roof antenna
130 8M1 L HEW Rear window wiper and washer system with intermittent control
131 8MA L KAH Without headphone port rear
132 8N3 L SWS Windshield wiper intermittent control with rain sensor
133 8P1 L BHS Heated rear window
134 8Q1 L LWR Headlight-range adjustment
135 8QE L SLR Key for locking system with remote control
136 8RM L LSE 8 speakers (passive)
137 8S1 L LEL Reading light front
138 8SA L SBR Taillight assemblies, standard design
139 8T2 L GRA Cruise control system (CCS) electronic
140 8TF L NEL Rear fog lights, left and right
141 8UE L RAO Radio with CD drive
142 8W1 L WWA Washer fluid level indicator
143 8WD L NES Integrated front fog light
144 8X0 L SWR Without headlight washer system
145 8Y1 L SNH Two-tone horn
146 8Z5 L MKU Not hot country
147 9A0 L TAA Without taxi alarm system
148 9AK L HKA Climatronic with impact pressure control free of cfc
149 9D0 L VEF Without preparation for two-way radio installation
150 9FA L AKA Without automatic transmission indicator light
151 9GB L ASI Interior light with switch-off delay anddoor pillar switch
152 9J0 L STA Without supertone system and tone sequence control
153 9JB L RAU Smoking package, ashtray front and rear
154 9M0 L ZUH Without auxiliary/parking heater
155 9P0 L SGK Without seat belt warning light
156 9Q1 L MFA Multi-function display/on-board computer
157 9T0 L BWD Without heated washer nozzles
158 9TB L WAL Additional warning lights (door area)
159 9U1 L BVK Brake pad wear indicator
160 9W0 L VTV W/o car phone preparation/installation
161 9X0 L BTS Without heated door lock cylinder
162 9Y1 L ATE Outdoor temperature gage
163 A8W I AUS Luxury equipment
164 AZ0 L FAF Vehicle with standard production scope
165 B08 L TPL Type approval France
166 B0K L BLB Component parts set, complying with vehicle type for France, various parts
167 C22 E COC Operating permit, alteration 22
168 CT8 L RAD Alloy wheels 6J x 15 "Zumaia", offset 42
169 E0A L AAU No special edition
170 F0A L FZS No special purpose vehicle, standard equipment
171 G0C I GSP 5-speed manual transmission
172 G25 L DFV Front shock absorption
173 H6S L REI Tires 195/65 R15 V
174 J0L L BAT Battery 340 A (70 Ah)
175 K8G I KAR Hatchback
176 L0L L LEA Left-hand drive vehicle
177 L20 L GKV Suspension range 20 installation control only, no requirement forecast
178 MN0 I MOT 4-cyl. turbo diesel eng. 1.9 L/81 kW TDIEU 3 base engine is T8U
179 N7C L SIB Fabric seat covering
180 Q1A L VOS Standard front seats
181 QA0 L KIS Without child seat
182 QG2 L WIV No possibility of activating service interval prolongation
183 QS0 L KFK Without electronic map cooling system
184 T8U I GMO 4-cylinder diesel engine 1.9 L unit 038.G
185 U0C L INS Instrument insert with tachometer clock and km/h speedometer
186 UB5 L DFH Rear shock absorption for sports design
187 V0A L REL Tires w/o specification of tire brand
188 X3A G National sales program France
