Year:
| 2010 |
Multimedia , video/DVD/notebook connection:
| Multimedia socket for external audio source |
Activated carbon canister:
| Without activated charcoal canister |
Additional body covers, side:
| Without additional side body covers (stone guard) |
| Child seat anchor |
| Without additional tires |
Air bag:
| Driver s and front passenger air bag with front passenger air bag deactivation |
Air cleaner (engine):
| Standard air cleaner |
Air duct, front area:
| Air duct, standard |
Antennas:
| Roof antenna |
Anti-theft protection system:
| Electronic vehicle immobilization device |
Antifreeze:
| Antifreeze up to -25 degree celsius tolerance up to -30 degree C |
Backrest release:
| Backrest release for front seat(s) |
Base engine:
| 3-cylinder diesel engine 1.4 L Unit 045.F |
Batteries:
| Battery 330 A (61 Ah) |
Body measures:
| Without special body measures |
Body style:
| Coupe |
Brackets:
| Without bracket for first aid kit and warning triangle |
Brake pad wear indicator:
| Without brake pad wear indicator |
Brake type, front:
| Disc brakes, front (Geomet D) |
Brake type, rear:
| Drum brakes, rear |
Braking systems:
| Anti-lock brake system (ABS) |
Breakaway interior mirror:
| Dipping breakaway interior rear view mirror |
Bumper:
| Sports bumpers |
| Carrier frequency 433.92 MHz-434.42 Mhz |
CD changer/CD player:
| Without CD changer/CD player |
CD ROM/DVD/SD card:
| Without CD/DVD for navigation |
Center armrest:
| Without center armrest front |
Center rear seat belts:
| 3-point seat belt for center rear seat |
Chrome work package:
| Without aluminum/chrome work package |
Climatic zones:
| Standard climatic zones |
| Component parts set without country-specific design requirement |
| Components without special surface appearance |
Controls (steering wheels/steering column):
| Multi-function module radio control |
Cruise control:
| Without cruise control system (CCS) |
Cruise control warning and speed limit system:
| Without cruise control warning system |
Cup holder:
| Cup holder in center console |
Customized installation:
| Without customized installation |
Dashboard:
| Standard dashboard |
Dashboard illumination:
| Standard dashboard illumination |
Door and lid locking system:
| Radio remote controlled central locking operated from inside and safe securing |
Door and side trim panels:
| Door and side trim panel |
Doors:
| 2 doors |
Doors/trays in trunk:
| Without stowage box in luggage boot |
Drawers under front seats:
| Without drawers under front seats |
Electric interface for external use:
| Without electric interface |
Emission standard:
| Emission standard EU4 DPF |
Engine cooling system:
| Not hot country |
Engine specifications:
| 3-cyl. turbo diesel eng. 1.4 L/59 kW TDI pump-jet injection system Base engine is T0U/TF4 |
Equipment levels:
| Comfort equipment |
Exhaust tailpipe:
| Rear exhaust tailpipe (standard) |
Exterior mirror setting:
| Exterior mirrors adjustable from inside |
Fire extinguisher:
| Without fire extinguisher |
| Without first aid kit and warning triangle |
Floor mats:
| Without floor mats |
Folding table:
| Without table |
Foot area lining:
| Foot area lining without cover |
Fresh air intake for passenger compartment (with particulate filter):
| Dust and pollen filter |
| Without front fog light |
Front license plate carrier:
| Without license plate carrier front |
Front seats:
| Standard front seats |
Front stabilizer:
| Front stabilizer |
Front underbody guard:
| Without additional front underbody guard |
| Initial standard fuel filling |
Fuel systems:
| Fuel system for diesel engine |
Fuel tank treatment:
| Fuel tank with special material treatment |
Gearshift boot/cover:
| Leatherette gearshift boot |
Gearshift knob/handle:
| Plastic gearshift knob/handle |
| Operating permit, alteration |
Generators:
| Alternator 110 A |
Hand brake lever handle:
| Plastic hand brake lever handle |
Handling standard production and pre-production series:
| Internal control |
Headlight:
| Halogen headlight for driving on the right |
Headlight activation:
| Without special headlight activation |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Headlight-range adjustment |
Headrests:
| Height-adjustable headrests for front seats |
| Electric auxiliary air heater |
Heated washer nozzles:
| Without heated washer nozzles |
| Manually controlled heating system |
Hill hold control:
| Without hill hold control / hill descent control / comfort driving assist |
Horns:
| Single-tone horn |
Identification plates:
| Special identification plate for EC for M1 passenger vehicle |
| Without ignition/starter switch locking system |
| Filler neck module 1 without insert |
Installation differentiation for vehicle components:
| Installation differentiation for transmission MQ 250 vehicle components |
Instrument inserts:
| Instrument insert with tachometer clock and km/h speedometer |
Interior noise suppression measures:
| Special interior noise suppression |
Key for locking system:
| Key for locking system with remote control |
Left exterior mirror:
| Left exterior mirror convex |
Left vanity mirror:
| Left vanity mirror not illuminated with cover and pocket |
Lockable wheel bolts:
| Standard wheel bolts |
Luggage compartment cover:
| Foldable trunk cover |
Luggage compartment floor covering:
| Tufted trunk floor covering |
Luggage compartment lighting:
| Luggage compartment lighting |
Luggage compartment lining:
| Full fleece trunk lining |
Luggage net/pocket on backrest(s):
| Without luggage nets/pockets on backrests |
| Standard manufacturing sequence |
Mass damper for steering wheels:
| Without mass damper for steering wheel |
Molding roof liner:
| Unsplit molding roof liner |
| Without multi-function display/ on-board computer |
Nameplate set:
| Nameplate set in base trim |
Navigation device:
| Without navigation device |
Outer rear seat belts:
| 3-point seat belts, outer rear with ECE label |
Owner s manuals:
| Information kit in French |
| Without surface protection, with additional transit coating |
Park distance control:
| Without park distance control |
Pedal cluster:
| Standard pedal cluster |
Pedestrian protection:
| Standard pedestrian protection measures |
Platform group class:
| Platform group class 2 |
Platform module floor pan, rear:
| Rear floor panel module, type 3 |
Radiator grille:
| Radiator grille |
Radios:
| Radio with CD player |
Reading light:
| Without reading light |
Rear axle:
| Heavy-duty rear axle |
Rear fog light:
| Rear fog light for driving on the right |
Rear headrests:
| Three rear headrests |
Rear license plate carrier:
| Without license plate carrier rear |
Rear seats:
| Rear seat bench/backrest, split folding |
Rear spoiler:
| Without rear spoiler |
Rear stabilizer:
| Without rear stabilizer |
Rear window wiper and washer system:
| Rear window wiper and washer system with intermittent control |
Refrigerator:
| Without refrigerator/glove compartment cooling system |
Restraint systems, front:
| 3-point seat belts, front |
Right exterior mirror:
| Right exterior mirror convex |
Right vanity mirror:
| Right vanity mirror with cover |
Roof insert/convertible top:
| Without roof insert (standard roof) |
Roof rails/roof load rack:
| Without roof rails/roof load rack |
Seat adjustment:
| Manual height adjustment for left front seat |
Seat belt check:
| Seat belt reminder, electric contact in buckle |
Seat covering:
| Fabric seat covering |
Seat heater:
| Without seat heater |
Service interval prolongation:
| Without service interval prolongation |
Shock absorption, chassis, front:
| Front shock absorption |
Shock absorption, chassis, rear:
| Rear shock absorption |
Side air bag:
| Side air bag front |
Side and rear windows:
| Side and rear windows in heat-insulating glass |
Smoking/non-smoking package:
| Non-smoking package |
Socket:
| 12-volt socket(s) |
Spare wheel/breakdown set:
| Steel spare wheel with original equipment tires |
Speaker installation:
| 4 speakers (passive) |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in English and French |
Speedometer cable and seal:
| Speedometer sensor without seal (electronic speedometer sensor) |
Start/stop system/regenerative braking:
| Without start/stop system without regenerative braking |
Steering:
| Power steering electro-hydraulic |
Steering column systems:
| Axial and vertical adjustable steering column |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Comfort steering wheel for air bag system |
Sticker (customized or special edition):
| Without stickers and badges |
Taillight assemblies:
| Taillight assemblies, standard design |
Telephone/telematics:
| W/o car phone preparation/installation |
Tire pressure warning light:
| Without tire pressure warning light |
Tire suppliers:
Tires:
| Tires 175/70 R14 84T |
Tool kit and jack:
| Tool kit and jack |
Trailer hitch:
| Without trailer hitch |
Transmission specifications:
| 5-speed manual transmission |
Transmission types/gearshift mechanisms:
| Cable gearshift |
Tray:
| Without tray on roof liner |
Tray areas package:
| Without tray areas package/box |
Trunk sill protection:
| Plastic trunk sill protection |
| Type approval France |
| Vehicle class differentiation 6J0 |
Vehicle specifications:
| No special purpose vehicle, standard equipment |
Vehicle type:
| Vehicle with standard production scope |
Washer fluid level indicator:
| Without washer fluid level indicator |
Weight category front axle:
| Suspension range 60 installation control only, no requirement forecast |
Weight category rear axle:
| Weight range 1 installation control only, no requirement forecast |
Wheel covers:
| Full wheel covers |
Wheels:
| Steel wheels 5J x 14 |
Window regulator:
| Power windows |
Windshield glass type:
| Windshield in heat-insulating glass |
Windshield wiper intermittent control/ light/rain sensor:
| Windshield wiper intermittent control with potentiometer (four speeds) |
