Activated carbon canister:
| Activated carbon canister |
| Without additional child seat anchor |
Additional warning lights:
| Additional warning lights (door area) |
Air bag:
| Air bag for driver and front seatpassenger |
Air duct, front area:
| Air duct, standard |
Antennas:
| Roof antenna |
Anti-theft protection system:
| Electronic vehicle immobilization device |
Antifreeze:
| Antifreeze up to -25 degree celsiustolerance up to -30 degree C |
Auxiliary heating:
Backrest release:
| Without backrest release for front seats |
Base engine:
| 4-cylinder gasoline engine 1.6 Lunit 06A.S (aluminum) |
Batteries:
| Battery 280 A (60 Ah) |
Body measures:
| Without special body measures |
Body style:
| Station Wagon Variant/Avant |
Brake pad wear indicator:
| Brake pad wear indicator |
Brake type, front:
| Front disc brakes with integratedadapter |
Brake type, rear:
| Drum brakes, rear |
Braking systems:
| Anti-spin regulation (ABS/ASR/EDL) withelectronic differential lock (EDL) |
Breakaway interior mirror:
| Non-dipping breakaway inside rear viewmirror |
CD ROM/DVD/SD card:
| Without CD/DVD for navigation |
CD changer/CD player:
| Without CD changer/CD player |
| Without carrier frequency |
Cassette and CD storage unit:
| Without cassette and CD storage unit |
Cd enhancing underbody panel:
| Without cd enhancing underbody panel |
Center armrest:
| Without center armrest front |
Center high-mounted stop light:
| Center high-mounted stop light |
Center rear seat belts:
| 3-point seat belt for center rear seat |
Child bench seat:
| Without child bench seat |
Child seats:
| Without child seat |
Chrome work package:
| Without aluminum/chrome work package |
| Component parts set withoutcountry-specific design requirement |
| Body-colored exterior mirror housings |
Controls (steering wheels/steering column):
| Without controls |
Cruise control:
| Without cruise control system (CCS) |
Cruise control warning and speed limit system:
| Without cruise control warning system |
Dashboard:
| Padded dashboard |
Door and lid locking system:
| Central locking system |
Doors:
| 4 doors |
Drive layout:
| Front wheel drive |
Electric safety package:
| Without display and warning tone foropened doors |
Electronic map cooling system:
| Electronic map cooling system |
Emission standard:
| Emission standard EU4 |
Engine cooling system:
| Not hot country |
Engine specifications:
| 4-cylinder gasoline engine 1.6 L/75 kWwith multi-point injectionbase engine is T0B/T53/TC3/TL2 |
Equipment levels:
| Comfort equipment |
Exterior mirror setting:
| Exterior mirrors electricallyadjustable/heated |
Exterior noise suppression measures:
| Additional exterior noise suppression |
Fire extinguisher:
| Without fire extinguisher |
| Without first aid kit and warningtriangle |
Floor mats:
| Without floor mats |
Fresh air intake for passenger compartment (with particulate filter):
| Dust and pollen filter |
| Integrated front fog light |
Front license plate bracket:
| Without license plate bracket front |
Front seats:
| Comfort sports seats, front |
Front stabilizer:
| Front stabilizer |
Front underbody guard:
| Without additional front underbody guard |
Fuel filler cap/door, locking option:
| Fuel filler cap |
| Initial standard fuel filling |
Fuel systems:
| Fuel system for carburetor gasolineengine |
Fuel tank treatment:
| Fuel tank with special materialtreatment |
Gearshift boot/cover:
| Leatherette gearshift boot |
Gearshift knob/handle:
| Plastic gearshift knob/handle |
| Operating permit, initial registration |
Generators:
| Alternator 90A |
Glove compartment:
| Glove compartment door with light |
Hand brake lever handle:
| Plastic hand brake lever handle |
Headlight:
| Halogen headlight for driving on theright |
Headlight activation:
| Separate daytime running lights |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Headlight-range adjustment |
Headrests:
| Articulated and height-adjustableheadrests for front seats |
| W/o heat accumulator/auxiliary heating |
Heated door lock cylinder:
| Without heated door lock cylinder |
Heated washer nozzles:
| Without heated washer nozzles |
| Manually controlled air conditioning |
Horns:
| Two-tone horn |
Identification plates:
| Special identification plate for ECfor M1 passenger vehicle |
| Without ignition/starter switch lockingsystem |
| Filler neck module 2 with insert |
Inserts:
| Without decorative inserts |
Installation differentiation for vehicle components:
| Installation differentiation fortransmission MQ170vehicle components |
Instrument inserts:
| Instrument insert with km/h speedometer,clock, tachometer and trip odometer |
Key for locking system:
| Key with light |
Left exterior mirror:
| Left exterior mirror aspherical,electrically adjustable and heated |
Left vanity mirror:
| Left vanity mirror with cover |
| Tailgate/trunk lid unlockingfrom outside |
Lockable wheel bolts:
| Standard wheel bolts |
Luggage compartment cover:
| Sliding trunk cover |
Luggage compartment floor covering:
| Tufted trunk floor covering |
Luggage net/pocket on backrest(s):
| Luggage nets/pockets on backrests |
Lumbar support:
| Manually adjustable lumbar support infront seats |
| Standard manufacturing sequence |
Mass damper for steering wheels:
| Without mass damper for steering wheel |
Mud flap:
| Mud flaps rear |
| Multi-function display/on-board computer |
Nameplate set:
| Nameplate set in base trim |
Navigation device:
| Without navigation device |
Outer rear seat belts:
| 3-point seat belts, outer rear withheight adjustment |
Owner s manuals:
| Information kit in Danish |
| Paint preservative (wax) |
Park distance control:
| Without park distance control |
Parking light indicator light:
| Without parking light warning light |
Partition:
| Without partition |
Platform group class:
| Platform group class 2 |
Platform module floor pan, rear:
| Rear floor panel module, type 3 |
Preparation for two-way radio installation:
| Without preparation for two-way radioinstallation |
Proportioning valve:
| Without proportioning valve |
Protective side molding:
| Protective side molding |
Radiator grille:
| Radiator grille |
Radios:
| Without radio |
Reading light:
| Two reading lights front |
Rear axle:
| Standard rear axle |
Rear cargo area:
| Without cargo area |
Rear fog light:
| Rear fog light for driving on the right |
Rear headrests:
| Three rear headrests |
Rear license plate bracket:
| License plate bracket rear (ECE) |
Rear seats:
| Rear seat bench/backrest, split folding |
Rear stabilizer:
| Rear stabilizer |
Rear window wiper and washer system:
| Rear window wiper and washer systemwith intermittent control |
| W/o remote-controlled garage door opener |
Restraint systems, front:
| 3-point seat belts with tensioner andheight adjustment, front |
Right exterior mirror:
| Right exterior mirror convex,electrically adjustable and heated |
Right vanity mirror:
| Right vanity mirror with cover |
Roof insert/convertible top:
| Without roof insert (standard roof) |
Roof rails/roof load rack:
| Without roof rails/roof load rack |
Rough-road/sports version:
| Standard design |
Seat adjustment:
| Manual height adjustment for front seats |
Seat belt check:
| Seat belt reminder, electriccontact in buckle |
Seat covering:
| Fabric seat covering |
Seat heater:
| Without seat heater |
Service interval prolongation:
| Service interval prolongation |
Shock absorption, chassis, front:
| Front shock absorption |
Shock absorption, chassis, rear:
| Rear shock absorption |
Side air bag:
| Side air bag front |
Side and rear windows:
| Side and rear windows in heat-insulatingglass |
Side lights:
| Side turn signal lights |
Ski bag:
| Without load-through provision |
Spare wheel/breakdown set:
| Steel spare wheel with originalequipment tires |
Speaker installation:
| 8 speakers (passive) |
Special alarm systems:
| Without taxi alarm system |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in Danish and English |
Speedometer cable and seal:
| Speedometer sensor without seal(electronic speedometer sensor) |
Steering:
| Power steering |
Steering column systems:
| Axial and vertical adjustable steeringcolumn |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Steering wheel for air bag system |
Sticker (customized or special edition):
| Without stickers and badges |
Supertone system and tone sequence control:
| Without supertone system and tonesequence control |
| W/o TV reception/digital radio reception |
Taillight assemblies:
| Taillight assemblies, standard design |
Telephone/telematics:
| W/o car phone preparation/installation |
Throttle actuation:
| Electric throttle actuation |
Tie down straps/net/pocket:
| Load safety net |
Tire suppliers:
Tires:
| Tires 195/65 R15 V |
Trailer hitch:
| Without trailer hitch |
Transmission specifications:
| 5-speed manual transmission |
Transmission types/gearshift mechanisms:
| Gearshift linkage |
Tray:
| Without tray on roof liner |
| Type approval Denmark |
| Vehicle class differentiation 1U0 |
Vehicle specifications:
| No special purpose vehicle, standardequipment |
Vehicle type:
| Vehicle with standard production scope |
Washer fluid level indicator:
| Without washer fluid level indicator |
Weight category front axle:
| Suspension range 04installation control only, norequirement forecast |
Weight category rear axle:
| Without determination of weight categoryfor rear axle |
Wheel covers:
| Full wheel covers |
Wheels:
| Steel wheels 6J x 15Offset 38 |
Window regulator:
| Power windows with comfort operation andcircuit breaker |
Windshield glass type:
| Windshield in heat-insulating glass |
Windshield wiper intermittent control:
| Windshield wiper intermittent controlwith potentiometer (four speeds) |
