Data produkcji: 2000-10-12
Data wydania samochodu: 2004-01-30
HISTORII BRAK!
1 0A2 TUE four doors
2 0AL STV front stabilizer
3 0BC STH rear stabilizer
4 0CH AED vehicle class differentiation 1U0
5 0EJ EDF installation differentiation for transmission MQ 250 vehicle components
6 0F3 KRS fuel system for diesel engine
7 0FA FAD standard manufacturing sequence
8 0G4 GES cable gearshift
9 0GD AGM Emissions concept EU2 (MVEG 2)
10 0KA KAE without stickers and badges
11 0L2 GAB electric throttle actuation
12 0N5 HIA standard rear axle
13 0NB SZU nameplate set in base trim
14 0RA ZSS without ignition/starter switch locking system
15 0TA ZFM without floor mats
16 0VT BTA information kit in Polish
17 0YZ GKH without determination of weight categoryfor rear axle
18 1AJ BRS anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
19 1C1 FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
20 1D0 AHV without towing attachment
21 1E0 AKB without activated charcoal canister
22 1FF TYP special identification plate (Poland)
23 1G2 RER steel spare wheel with original equipment tires
24 1H0 BRM without proportioning valve
25 1JD DFH rear shock absorption, basic design 2
26 1KG BAH drum brakes, rear
27 1LS BAV front disc brakes with integrated adapter
28 1MP LRA steering wheel for airbag system
29 1N6 LEN power steering
30 1ND RAA full wheel covers
31 1PA ABR standard wheel bolts
32 1Q0 TGL without mass damper for steering wheel
33 1SA TWU without additional engine guard
34 1T0 VBK Without first aid kit and warning triangle
35 1X0 ATA front wheel drive
36 1Z0 KRM initial standard fuel filling
37 2B3 GRD additional exterior noise suppression (hood, capsule and dash panel)
38 2C5 LSS axial and vertical adjustable steering column
39 2D0 CWV without cd enhancing underbody panel
40 2G8 EBB filler neck module 2 without insert
41 2KP SAU labels/plates in Polish and English
42 2LB KRB fuel tank with special material treatment (fluorination)
43 2UA SWP Without rough-road or sports version
44 2V1 FRI dust and pollen filter
45 2W0 TDA fuel filler cap
46 3AF ASR outer right rear view mirror: convex, powered, heated
47 3B0 ZKV without additional child seat anchor
48 3BS ASL outer left rear view mirror: non-spherical, powered, heated
49 3C1 SHM static lap belt, center rear
50 3CA TRW without partition
51 3FA DEI without roof insert (standard roof)
52 3GA LBH without cargo area
53 3H0 LER without backrest release for front seats
54 3J7 KOV articulated and height-adjustable headrests for front seats
55 3L3 SIE manual height adjustment for front seats
56 3NC HIS rear seat bench/backrest, split folding
57 3Q1 KOH rear headrests
58 3QT RSV 3-point seat belts with tensioner and height adjustment, front
59 3S4 DAR preparation for roof load rack
60 3U1 GPR foldable trunk cover
61 3V0 KSB without child bench seat
62 3X0 DLS without load-through provision
63 3ZB SHA 3-point seat belts, outer rear with ECE label
64 4A0 SIH without seat heater
65 4B1 SSL protective side molding
66 4E0 SDH tailgate/trunk lid unlocking from outside
67 4F1 TKV central locking system
68 4GF WSS windshield, tinted
69 4KC SSH side and rear windows tinted
70 4L0 IRS non-dipping breakaway inside rear view mirror
71 4LA BED without controls
72 4N1 INT padded dashboard
73 4P2 PBH rear floor panel module, type 3
74 4R0 FEH mechanical window regulator
75 4SC MSL left vanity mirror with cover
76 4TC MSR right vanity mirror with cover
77 4U1 GNF luggage nets/pockets on backrests
78 4UE AIB airbag f. driver a. front seat passenger
79 4W0 KBO without cassette and CD storage unit
80 4X0 SAB without side airbag
81 4Z5 HAK glove compartment door with light
82 5C0 KSA without special body measures
83 5D0 TRF without carrier frequency
84 5K0 LAC without paint preservative
85 5TC EIH without decorative inserts
86 6A0 FEU without fire extinguisher
87 6E0 MAS without center armrest front
88 6FB BBO body-colored outer rear view mirror housings
89 6KA KUG radiator grille
90 6M2 GPS load safety net
91 6N1 SZF mud flaps rear
92 6P1 KZH license plate bracket rear (ECE)
93 6PA HBV plastic hand brake lever handle
94 6Q1 SAG plastic gearshift knob/handle
95 6R1 SHV leatherette gearshift boot
96 6SC KBB tufted trunk floor covering
97 6W0 KZV without license plate bracket front
98 6XD ASE outer rear view mirrors: powered, heated
99 6Y0 GWA without cruise control warning system
100 7A0 CDW without CD changer/CD player
101 7AA EDW electronic vehicle immobilization device
102 7E3 WSA sheathed type glow plug heater
103 7N0 ALS without tray on roof liner
104 7P4 LOR manually adjustable lumbar support in front seats
105 7PB PGK platform group class 2
106 7Q0 NAV without navigation device
107 7QA CDR without CD ROM
108 7X0 EPH without park distance control
109 8AA RAO without radio
110 8BN HSW halogen headlight for driving on the right
111 8CC TWP speedometer sensor without seal (electronic speedometer sensor)
112 8F2 SLE side turn signal lights
113 8GL GEN alternator 120A
114 8K0 FLS without special low beam mode
115 8L3 ANT roof antenna
116 8M0 HEW w/o rear window wiper and washer system
117 8N4 SWS windshield wiper intermittent control with potentiometer (four speeds)
118 8NA STK without parking light warning light
119 8Q1 LWR headlight-range adjustment
120 8QC SLR key with light
121 8R1 HBL center high-mounted stop light
122 8RE LSE four loudspeakers (passive)
123 8S5 LEL two reading lights front
124 8SA SBR taillight assemblies, standard design
125 8T0 GRA without cruise control system (CCS)
126 8TC NEL rear fog light for driving on the right
127 8W0 WWA without washer fluid level indicator
128 8WD NES integrated front fog light
129 8X0 SWR without headlight washer system
130 8Y1 SNH two-tone horn
131 8Z5 MKU engine cooling system, type 1
132 9A0 TAA without taxi alarm system
133 9AA HKA manually controlled heating system
134 9BF ESP without display and warning tone for opened doors
135 9D0 VEF without preparation for two-way radio installation
136 9J0 STA without supertone system and tone sequence control
137 9M0 ZUH without auxiliary/parking heater
138 9P1 SGK seat belt warning light, electric contact in buckle
139 9Q1 MFA multi-function indicator/trip computer
140 9T0 BWD without heated washer nozzles
141 9TB WAL additional warning lights (door area)
142 9U0 BVK without brake pad wear indicator
143 9W0 VTV w/o car phone preparation/installation
144 9X0 BTS without heated door lock cylinder
145 A8C AUS comfort equipment
146 AZ0 FAF vehicle with standard production scope
147 B0A BLB component parts set without country-specific design requirement
148 B17 TPL type approval Poland
149 C00 COC operating permit, initial registration
150 C6E RAD steel wheels 6J x 15 offset 38
151 E0A AAU no special edition
152 F0A FZS no special purpose vehicle, standard equipment
153 G0C GSP 5-speed manual transmission
154 G14 DFV front shock absorption
155 H3E REI tires 195/65 R 15 V (black)
156 J0L BAT battery 340 A (70 Ah)
157 K8G KAR hatchback
158 L0L LEA left-hand drive vehicle
159 L16 GKV suspension range 16
160 M0G MOT 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIwith MVEG 2 base engine is T0W
161 N0B SIB fabric seat covering
162 Q4H VOS comfort sports seats, front
163 QA0 KIS without child seat
164 QG0 WIV without service interval prolongation
165 QJ0 CHR without aluminum/chrome work package
166 QS0 KFK without electronic map cooling system
167 QV0 TVE w/o TV reception/digital radio reception
168 SQ9 SNR SKD for Poland
169 T0W GMO 4-cylinder diesel engine 1.9 L unit 038.B
170 U1A INS instrument insert with km/h speedometer,clock, tachometer and trip odometer
171 V0A REL tires w/o specification of tire brand
172 VC0 GRT w/o remote-controlled garage door opener
173 VK0 LFF air duct, standard
174 X4J G national sales program Poland
