0:
| Drive |
1:
| 3-point seat belts with tensioner and height adjustment, front |
2:
| 3-point seat belts, outer rear with ECE label |
3:
| 4 doors |
4:
| 4 speakers (passive) |
5:
| 4-cylinder gasoline engine 1.6 L unit 06A.S (aluminum) |
6:
| 4-cylinder gasoline engine 1.6 L/75 kW with multi-point injection base engine is T0B/T53/TC3/TL2 |
7:
| 5-speed manual transmission |
8:
| Activated carbon canister |
9:
| Additional exterior noise suppression |
10:
| Additional reflectors (door area) |
11:
| Air duct, standard |
12:
| Alternator 90A |
13:
| Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL) |
14:
| Antifreeze up to -25 degree celsius tolerance up to -30 degree C |
15:
| Articulated and height-adjustable headrests for front seats |
16:
| Axial and vertical adjustable steering column |
17:
| Basic equipment |
18:
| Battery 220 A (44 Ah) |
19:
| Body-colored exterior mirror housings |
20:
| Brake pad wear indicator |
21:
| Carrier frequency 433.92 MHz-434.42 Mhz |
22:
| Center high-mounted stop light |
23:
| Comfort sports seats, front |
24:
| Component parts set, complying with vehicle type for Germany, various parts |
25:
| Display and warning tone f. opened doors |
26:
| Driver s and front passenger air bag with front passenger air bag deactivation |
27:
| Drum brakes, rear |
28:
| Electric throttle actuation |
29:
| Electronic map cooling system |
30:
| Electronic vehicle immobilization device |
31:
| Emission standard EU4 |
32:
| Exterior mirrors electrically adjustable/heated |
33:
| Fabric seat covering |
34:
| Filler neck module 2 with insert |
35:
| Foldable trunk cover |
36:
| Fresh air intake system with activated charcoal canister |
37:
| Front disc brakes with integrated adapter |
38:
| Front shock absorption |
39:
| Front stabilizer |
40:
| Front wheel drive |
41:
| Fuel filler cap |
42:
| Fuel system for carburetor gasoline engine |
43:
| Fuel tank with special material treatment |
44:
| Full wheel covers |
45:
| Gearshift linkage |
46:
| Glove compartment door with light |
47:
| Halogen headlight for driving on the right |
48:
| Hatchback |
49:
| Headlight-range adjustment |
50:
| Increase in initial standard fuel filling |
51:
| Information kit in German |
52:
| Installation differentiation for transmission MQ170 vehicle components |
53:
| Instrument insert with km/h speedometer,clock, tachometer and trip odometer |
54:
| Integrated front fog light |
55:
| Key for locking system with remote control |
56:
| Labels/plates in German and French |
57:
| Leatherette gearshift boot |
58:
| Left exterior mirror aspherical, electrically adjustable and heated |
59:
| Left vanity mirror with cover |
60:
| Left-hand drive vehicle |
61:
| License plate bracket front (large) |
62:
| License plate bracket rear (ECE) |
63:
| Luggage nets/pockets on backrests |
64:
| Manual height adjustment for left front seat |
65:
| Manually adjustable lumbar support in front seats |
66:
| Manually controlled air conditioning |
67:
| Multi-function display/on-board computer |
68:
| Nameplate set in base trim |
69:
| No special purpose vehicle, standard equipment |
70:
| Non-dipping breakaway inside rear view mirror |
71:
| Not hot country |
72:
| Operating permit, initial registration |
73:
| Padded dashboard |
74:
| Paint preservative (wax) |
75:
| Plastic gearshift knob/handle |
76:
| Plastic hand brake lever handle |
77:
| Platform group class 2 |
78:
| Power steering |
79:
| Power windows with comfort operation andcircuit breaker, mechanical window regulators rear |
80:
| Preparation for roof load rack |
81:
| Protective side molding |
82:
| Radiator grille |
83:
| Radio HIGH |
84:
| Radio remote controlled central locking operated from inside and safe securing |
85:
| Rear floor panel module, type 3 |
86:
| Rear fog light for driving on the right |
87:
| Rear headrests |
88:
| Rear seat bench/backrest, split folding |
89:
| Rear shock absorption, basic design 2 |
90:
| Rear stabilizer |
91:
| Rear window wiper and washer system with intermittent control |
92:
| Right exterior mirror convex, electrically adjustable and heated |
93:
| Right vanity mirror with cover |
94:
| Roof antenna |
95:
| Service interval prolongation |
96:
| Side air bag front |
97:
| Side and rear windows in heat-insulatingglass |
98:
| Side turn signal lights |
99:
| Single-tone horn |
100:
| Special identification plate for EC for M1 passenger vehicle |
101:
| Standard bumpers |
102:
| Standard design |
103:
| Standard manufacturing sequence |
104:
| Standard rear axle |
105:
| Standard wheel bolts |
106:
| Static lap belt, center rear |
107:
| Steel spare wheel with original equipment tires |
108:
| Steel wheels 6J x 15 Offset 38 |
109:
| Steering wheel for air bag system |
110:
| Suspension range 17 installation control only, no requirement forecast |
111:
| Tailgate/trunk lid unlocking from outside |
112:
| Taillight assemblies, standard design |
113:
| Tires 195/65 R15 V |
114:
| Tufted trunk floor covering |
115:
| Two reading lights front |
116:
| Type approval Germany |
117:
| Vehicle class differentiation 1U0 |
118:
| Vehicle with standard production scope |
119:
| Windshield in heat-insulating glass |
120:
| Windshield wiper intermittent control with potentiometer (four speeds) |
