Nr vin: WVWZZZ3CZ6E029047 - passat B6
I przy okazji by nie zakładać drugiego tematu: Passat B5 nr VIN: WVWZZZ3BZYP446173 |
Na prawdę nikt nic nie ma o tych autach?
Dekodowanie numeru VIN WVWZZZ3CZ6E029047 na www.automo.pl
Nazwa dekodera: Dekoder VIN dla Grupy VAG #2 Vehicle Identification No.: WVWZZZ3CZ6E029047 Date of production: 28.04.2005 Model year: 2006 Sales type: 3C2111 Engine code: BKC Engine parameters: 4-cylinder, 77 kW (105 p.s.), 1.9 l Transmission code: HNV Interior trim code: UP Roof color: 2T Exterior color / paint code: 2T / C9X 9WC: Without "Multimedia" in vehicle 1E0: Without activated charcoal canister 3B4: Child seat anchor for child seat system ISOFIX 2WA: Without additional tires 9TC: Additional reflectors (door area) 4UE: Air bag for driver and front seat passenger 8ZH: Antenna for AM/FM reception, "diversity" 7AA: Electronic vehicle immobilization device 9M5: Auxiliary heater 3H0: Without backrest release for front seats J1D: Battery 380 A (72 Ah) 5C0: Without special body measures K8B: Notchback 3P0: Without bracket for first aid kit and warning triangle 1LJ: Disc brakes, front 1KU: Disc brakes, rear 1AT: Electronic stabilization program (ESP) 4L6: Breakaway interior rear view mirror, automatically dimming 2JC: Comfort bumpers 7QA: Without CD/DVD for navigation 7A0: Without CD changer/CD player 5D1: Carrier frequency 433.92 MHz-434.42 Mhz 4W0: Without cassette and CD storage unit 6E3: Front center armrest 3D3: Center console 3C7: 3-point seat belt for center rear seat 0Y1: Standard climatic zones QR0: Without compass/traffic sign display/ traffic signs recognition B0A: Component parts set without country-specific design requirement FE0: Without country code (no DVD player in vehicle) 8T2: Cruise control system (CCS) electronic 6Y9: W/o cruise control speed limit system 4M5: Cup holder FC0: Without customized installation 4K3: Radio remote controlled central locking operated from inside and safe securing 3LD: Door and side trim panel 1X0: Front wheel drive QS0: Without electronic map cooling system 0GG: Emission standard EU4 8Z5: Not hot country D3W: 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X A8C: Comfort equipment 6XP: Exterior mirrors: electrically folding, electrically adjustable, separately heated 2B0: Without additional exterior noise suppression 6A0: Without fire extinguisher 1T0: Without first aid kit and warning triangle 0TD: Front and rear floor mats 8WD: Integrated front fog light 6W1: License plate bracket front (large) 3TF: Comfort seat, front left 3SF: Comfort seat, front right 1SA: Without additional engine guard 1Z0: Initial standard fuel filling 0F9: Cooled fuel system for diesel engine 6Q2: Leather gearshift knob/handle C02: Operating permit, alteration 8GU: Alternator 140 A 8BG: Twin-headlight for driving on the right,with integrated high beam 8K8: Low beam assistant with "Coming Home" function 8X0: Without headlight washer system 8Q1: Headlight-range adjustment 8MA: Without headphone port rear 7E0: W/o heat accumulator/auxiliary heating 9T0: Without heated washer nozzles 9AK: Climatronic with impact pressure control free of cfc 1EX: Special identification plate for EC for M1 passenger vehicle 2G0: Without insert for the filling up of fuel 5MA: Decorative inserts 0EJ: Installation differentiation for transmission MQ 250 vehicle components 1VG: Installation parts for four-cylinder engine 6T0: Without interior light in footwell 5SL: Left exterior mirror: aspherical 4SG: Left vanity mirror illuminated extractable sun visor 4E2: Tailgate/trunk lid release from inside (electrically) 1PC: Wheel bolts with anti-theft protection (unlockable) 6SE: Flat needle-punched trunk floor covering 7P7: Electrically adjustable lumbar support for left front seat 0FA: Standard manufacturing sequence 1Q0: Without mass damper for steering wheel 4ZB: Bright moldings 9Q2: Multi-function display/on-board computerwith check control 1DG: Nameplate set "TDI" 7Q0: Without navigation device 9Z3: Operating voltage 12 V plus 230 inverter 3ZB: 3-point seat belts, outer rear with ECE label 0VB: Information kit in French FB0: Standard paint coating 5K1: Paint preservative (wax) 7X0: Without park distance control 3CA: Without partition 9F0: Without sound combination for rotating emergency light and radio antenna preparation 9D0: Without preparation for two-way radio installation 4B4: Protective side molding 6KA: Radiator grille 8YL: Radio with CD player 8S7: Two reading lights front 3GA: Without cargo area 8TC: Rear fog light for driving on the right 6P1: License plate bracket rear (ECE) 3NU: Rear seat bench unsplit, backrest split folding with center armrest 3QT: 3-point seat belts with tensioner and height adjustment, front 5RQ: Right exterior mirror: convex 4TL: Vanity mirror, right, illuminated extractable sun visor 3Y0: Without roll-up sun screen 3FA: Without roof insert (standard roof) 3S0: Without roof rails/roof load rack 7M0: Plastic scuff plates in door apertures 3L3: Manual height adjustment for front seats 9P1: Seat belt reminder, electric contact in buckle N0U: Cut pile seat covering 4A0: Without seat heater 4D0: Without seat ventilation/massage seat 8FA: Without second battery G07: Front shock absorption 1JA: Rear shock absorption, basic design 1 4X3: Side air bag front with curtain air bag 4KC: Side and rear windows in heat-insulatingglass 7R3: Side turn signal lights (white) 3X2: Load-through provision 9JA: Non-smoking package 7B5: 12-volt socket(s) 1G2: Steel spare wheel with original equipment tires 8RE: 4 speakers (passive) 9A0: Without taxi alarm system E0A: No special edition 0SS: Labels/plates in English and French 1N3: Speed-related variable steering assist (Servotronic) L0L: Left-hand drive vehicle 2ZB: Leather multi-function steering wheel QV0: W/o TV reception/digital radio reception 8SK: Taillight assemblies with diodes (LED) 9W0: W/o car phone preparation/installation 6M0: Without tie down straps/net/pocket 7K0: Without tire pressure warning light HJ7: Tires 215/55 R16 97W x1 1S1: Tool kit and jack 1D0: Without trailer hitch NT0: Transit coating (type 1) G0C: 5-speed manual transmission 0G4: Cable gearshift 2P1: Plastic trunk sill protection B08: Type approval France NS0: Without umbrella(s) 0HG: Vehicle class differentiation 3C0 F0A: No special purpose vehicle, standard equipment L02: Suspension range 02 installation control only, no requirement forecast 0YC: Weight range 3 installation control only, no requirement forecast 1NL: Covers for alloy wheels CN8: Alloy wheels 7J x 16 H2 offset 45 (3C0 601 025) 4R4: Power windows with comfort operation andcircuit breaker 4GF: Windshield in heat-insulating glass 8N3: Windshield wiper intermittent control with rain sensor QH0: Without voice control QA0: Without child seat QG1: Service interval prolongation QE2: Storage box T71: 4-cylinder diesel engine 1.9 L unit 03G.1 U5A: Instrument insert, km/h speedometer UH1: Parking brake VL1: Extended pedestrian protection measures VC0: W/o remote-controlled garage door opener V0A: Tires w/o specification of tire brand Dekodowanie pochodzi z www.automo.pl |
Dekodowanie numeru VIN WVWZZZ3BZYP446173 na www.automo.pl
Nazwa dekodera: Dekoder VIN dla Grupy VAG #2 Vehicle Identification No.: WVWZZZ3BZYP446173 Model Designation: passat saloon Model: PA Date of production: 26.05.2000 Model year: 2000 Sales type: 3B237A Engine code: ATJ Transmission code: ELN Axle drive: 6S Interior trim code: HX Roof color: X1 Exterior color/Paint Code: X1/B7Z Activated carbon canister: [1E0] : Without activated charcoal canister Additional body covers, side: [6EP] : Additional stone guard body covers Additional child seat anchors: [3B4] : Child seat anchor forchild seat system ISOFIX Additional dust seals: [6U0] : Without additional seals outside Additional tires (winter tires): [2WA] : Without additional tires Air bag: [4UE] : Air bag for driver and front seatpassenger Alternative drive module: [0K0] : Without alternative drive module Antennas: [8L3] : Roof antenna Anti-theft protection system: [7AB] : Electronic alarm system with vehicleimmobilization device (for RoW) Antifreeze: [1C1] : Antifreeze up to -25 degree celsiustolerance up to -30 degree C Automatic transmission indicator light: [9FA] : Without automatic transmissionindicator light Auxiliary heating: [9M0] : Without auxiliary/parking heater Batteries: [J0R] : Battery 380 A (80 Ah) Body measures: [5C0] : Without special body measures Body style: [K8B] : Notchback Brake type, front: [1ZC] : Disc brakes, front (Geomet D) Braking systems: [1AJ] : Anti-spin regulation (ABS/ASR/EDL) withelectronic differential lock (EDL) Breakaway interior mirror: [4L2] : Dipping breakaway interior rear viewmirror Bumper: [2JB] : Standard bumpers CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation CD changer/CD player: [7A0] : Without CD changer/CD player Carrier frequency for radio remote control: [5D1] : Carrier frequency 433.92 MHz-434.42 Mhz Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit Catalytic converter control: [8KA] : W/o catalytic converter warning light Center armrest: [6E3] : Front center armrest Center high-mounted stop light: [8R1] : Center high-mounted stop light Center rear seat belts: [3C7] : 3-point seat belt for center rear seat Climatic zones: [0Y1] : Standard climatic zones Component part sets with country-specific design requirements: [B0K] : Component parts set, complying withvehicle type for France, various parts Controls (steering wheels/steering column): [4LA] : Without controls Cruise control: [8T0] : Without cruise control system (CCS) Cruise control warning and speed limit system: [6Y0] : Without cruise control warning system Cup holder: [4M6] : Cup holder Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing Door and side trim panels: [3LC] : Door and side trim panel in foam filmand woven fabric Drive layout: [1X0] : Front wheel drive Duty-free tires: [1V0] : Without duty-free and cost-free tires Emission standard: [0GE] : Emission standard EU3 Engine cooling system: [8Z5] : Not hot country Engine specifications: [M3L] : 4-cyl. turbo diesel engine 1.9 L/85 kWTDI with pump-jet injection systembase engine is T4N/TD0 Equipment levels: [A8S] : Standard equipment Exterior mirror setting: [6XN] : Exterior mirrors: electricallyadjustable, separately heated Exterior noise suppression measures: [2B1] : Additional exterior noise suppression Fire extinguisher: [6A0] : Without fire extinguisher First aid kit / warning triangle: [1T2] : Warning triangle Flame retardent materials: [4Q0] : No flame retardent materials Floor coverings: [3MQ] : Ibolours floor covering Floor mats: [0TA] : Without floor mats Front fog light/additional headlight: [8WD] : Integrated front fog light Front license plate bracket: [6W1] : License plate bracket front (large) Front underbody guard: [1SA] : Without additional front underbody guard Fuel quantity for initial filling: [1Z0] : Initial standard fuel filling Gearshift boot/cover: [6R2] : Leather gearshift boot Gearshift knob/handle: [6Q2] : Leather gearshift knob/handle General operating permit, alterations: [C14] : Operating permit, alteration Generators: [8GL] : Alternator 120 A Hand brake lever handle: [6PC] : Leather hand brake lever handle Headlight: [8JM] : Twin headlight for driving on the right,with integrated high beam Headlight activation: [8K0] : Without special headlightactivation Headlight washer system: [8X0] : Without headlight washer system Headlight-range adjustment: [8Q1] : Headlight-range adjustment Headrests: [3J7] : Articulated and height-adjustableheadrests for front seats Heat accumulator system/additional heater: [7E3] : Sheathed type glow plug heater Heated washer nozzles: [9T0] : Without heated washer nozzles Heating and air conditioning system: [9AK] : Climatronic with impact pressurecontrol free of cfc Identification plates: [1EX] : Special identification plate for ECfor M1 passenger vehicle Ignition/starter switch locking system: [0RA] : Without ignition/starter switch lockingsystem Insert for the filling up of unleaded fuel/fuel type: [2G0] : Without insert for the filling up offuel Inserts: [5MD] : Decorative aluminum inserts Installation parts for engine (engine mount system): [1VG] : Installation parts for four-cylinderengine Interference suppression: [8E2] : Local interference suppression for FM/AMradio reception Left exterior mirror: [5SL] : Left exterior mirror: aspherical Left vanity mirror: [4SD] : Left vanity mirror, illuminated Lock operation for tailgate/trunk lid: [4E0] : Tailgate/trunk lid unlockingfrom outside Lockable wheel bolts: [1PC] : Wheel bolts with anti-theft protection(unlockable) Luggage compartment floor covering: [6SD] : Tufted trunk floor covering(dimensionally stable) Luggage net/pocket on backrest(s): [4U5] : Luggage pockets on backrest Lumbar support: [7P4] : Manually adjustable lumbar support infront seats Malfunction display: [9HA] : Without additional malfunction display Manufacturing sequence differentiation: [0FG] : Mosel manufacturing sequence Moldings: [4ZE] : Black moldings Multi-function display/trip computer: [9Q1] : Multi-function display/on-board computer Nameplate set: [1DG] : Nameplate set "TDI" Navigation device: [7Q0] : Without navigation device Outdoor temperature gage: [9Y1] : Outdoor temperature gage Paint preservative/transit coating: [5K1] : Paint preservative (wax) Park distance control: [7X0] : Without park distance control Parking light indicator light: [8NA] : Without parking light warning light Partition: [3CA] : Without partition Platform module floor pan, rear: [4P1] : Rear floor panel module, type 2 Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation Preparation for two-way radio installation: [9D0] : Without preparation for two-way radioinstallation Protective side molding: [4B1] : Protective side molding Radios: [8AR] : Radio "gamma"with removable operating panel Reading light: [8S4] : Two reading lights front, two rear Rear cargo area: [3GK] : Without additional lower part forluggage compartment floor Rear fog light: [8TC] : Rear fog light for driving on the right Rear headrests: [3Q6] : Three rear headrests Rear seat catch: [6QB] : Locking rear seat catch Rear seats: [3NN] : Rear seat bench unsplit, backrest splitfolding Restraint systems, front: [3QT] : 3-point seat belts with tensioner andheight adjustment, front Right exterior mirror: [5RQ] : Right exterior mirror: convex Right vanity mirror: [4TD] : Right vanity mirror illuminated Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen Roof insert/convertible top: [3FA] : Without roof insert (standard roof) Roof rails/roof load rack: [3S0] : Without roof rails/roof load rack Safety certificate: [0LJ] : Special plates/stickers/safety certificates for France Seat adjustment: [3L3] : Manual height adjustment for front seats Seat belt check: [9P0] : Without seat belt reminder Seat covering: [N0N] : Woven fabric seat covering Seat heater: [4A0] : Without seat heater Shock absorption/suspension, chassis: [1BE] : Sports suspension/shock absorption Side air bag: [4X1] : Side air bag front Side lights: [8F2] : Side turn signal lights Ski bag: [3X0] : Without load-through provision Socket: [7B2] : 12-volt socket in luggage boot Spare wheel/breakdown set: [1G2] : Steel spare wheel with originalequipment tires Speaker installation: [8RM] : 8 speakers (passive) Special alarm systems: [9A0] : Without taxi alarm system Special editions: [E0A] : No special edition Special labels/plates: [0SG] : Labels/plates in French Speedometer cable and seal: [8CC] : Speedometer sensor without seal(electronic speedometer sensor) Steering system arrangement: [L0L] : Left-hand drive vehicle Steering wheels: [2PA] : Leather steering wheel for air bagsystem with mass damper Sticker (customized or special edition): [0KA] : Without stickers and badges Supertone system and tone sequence control: [9J0] : Without supertone system and tonesequence control Taillight assemblies: [8SA] : Taillight assemblies, standard design Telephone/telematics: [9W0] : W/o car phone preparation/installation Throttle actuation: [0L2] : Electric throttle actuation Tire pressure warning light: [7K0] : Without tire pressure warning light Tires: [H6U] : Tires 205/55 R16 91W Trailer hitch: [1D0] : Without trailer hitch Transmission shafts: [1WD] : Transmission shaft for tripod joints Transmission shafts, rear axle: [1YA] : Without transmission shafts f. rear axle Transmission specifications: [G0K] : 6-speed manual transmission Transmission types/gearshift mechanisms: [0G1] : Gearshift lever Type approval countries/countries with special requirements: [B08] : Type approval France Vehicle class differentiation units/platform components: [0DE] : Installation differentiation for buildstatus of vehicle class B5 (VW Passat) Vehicle specifications: [F0A] : No special purpose vehicle, standardequipment Weight category front axle: [0JG] : Weight category front axleweight range 7 Weight category rear axle: [0YB] : Weight range 2installation control only, norequirement forecast Wheels: [C0J] : Alloy wheels 8J x 18 Window regulator: [4R3] : Power windows with comfort operation Windshield glass type: [4GH] : Windshield in heat-insulating glasswith sunshield Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds) Base engine: [T4N] : 4-cylinder diesel engine 1.9 Lunit 038.A Child seats: [QA0] : Without child seat Front seats: [Q4H] : Comfort sports seats, front Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer Service interval prolongation: [QG2] : No possibility of activating serviceinterval prolongation Control number (no PR-Family): [S12] : Fashion Tire suppliers: [V0A] : Tires w/o specification of tire brand Dekodowanie pochodzi z www.automo.pl |
