Dekodowanie numeru VIN WVWZZZ3AZSE053790 na www.automo.pl
Vehicle Identification No.: WVWZZZ3AZSE053790
Model Designation: passat gt estate
Date of production: 22.09.1994
Model year: 1995
Sales type: 3A55X5
Engine code: 1Z9
Transmission code: CTN
Axle drive: 5S
Interior trim code: RU
Roof color: J8
Exterior color/Paint Code: J8/N5Y
Activated carbon canister: [1E0] : Without activated charcoal canister
Additional child seat anchors: [3B0] : Without additional child seat anchor
Additional dust seals: [6U0] : Without additional seals outside
Additional instrument for distance measurement: [8U0] : Without additional instruments fordistance measurement
Additional tunnel cover: [4J1] : Floor tray, extension center console
Antennas: [8L3] : Roof antenna
Anti-theft protection system: [7AD] : Anti-theft alarm system and passengercompartment control
Automatic transmission indicator light: [9FA] : Without automatic transmissionindicator light
Backrest release: [3H0] : Without backrest release for front seats
Batteries: [J1D] : Battery 380 A (72 Ah)
Body measures: [5C1] : Body measures for increased safetyrequirements
Body style: [K8D] : Station Wagon Variant/Avant
Brackets: [3P0] : Without bracket for first aid kit andwarning triangle
Brake type, front: [1LB] : Disc brakes, front
Brake type, rear: [1KC] : Drum brakes, rear
Braking systems: [1AC] : Anti-lock brake system (ABS)
Bumper: [2JG] : Body-colored bumpers
CD changer/CD player: [7A0] : Without CD changer/CD player
Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit
Catalytic converter control: [8KA] : W/o catalytic converter warning light
Center high-mounted stop light: [8R0] : Without center high-mounted stop light
Center rear seat belts: [3C1] : Static lap belt, center rear
Chassis: [2E0] : Base chassis
Child bench seat: [3V0] : Without child bench seat
Cigarette lighter: [8V1] : Cigarette lighter
Clutch actuation: [1K2] : Hydraulic clutch actuation
Components with special surface appearance: [6FB] : Body-colored exterior mirror housings
Cruise control: [8T0] : Without cruise control system (CCS)
Door and lid locking system: [4F1] : Central locking system
Door and side pockets, rear: [4YE] : Comfortable stowage boxes rearwith carpet concealed
Door and side trim panels: [3LC] : Door and side trim panel in foam filmand woven fabric
Door pockets, front: [3YG] : Door pockets, front
Drive layout: [1X0] : Front wheel drive
Duty-free tires: [1V0] : Without duty-free and cost-free tires
Electric safety package: [9BA] : W/o additional electric safety package
Engine specifications: [M2K] : 4-cyl. turbo diesel eng. 1.9 L/66 kW TDIand MVEG 2base engine is T2F
Equipment levels: [A8F] : Sports equipment
Exterior noise suppression measures: [2B1] : Additional exterior noise suppression
Flame retardent materials: [4Q0] : No flame retardent materials
Floor coverings: [3MG] : Tufted fine cut pile floor covering
Fresh air intake for passenger compartment (with particulate filter): [2V1] : Dust and pollen filter
Front fog light/additional headlight: [8WD] : Integrated front fog light
Fuel tank vent line: [1TE] : Fuel tank vent line with gravity valveand second vent line with PVC breatherhoses
Gearshift boot/cover: [6R2] : Leather gearshift boot
Gearshift knob/handle: [6Q2] : Leather gearshift knob/handle
Generators: [8GL] : Alternator 120 A
Glove compartment: [4Z0] : Without glove compartment/door, withouttrays
Hand brake lever handle: [6PC] : Leather hand brake lever handle
Headlight: [8BB] : Halogen headlightfor driving on the right
Headlight washer system: [8X0] : Without headlight washer system
Headlight-range adjustment: [8Q1] : Headlight-range adjustment
Heat accumulator system/additional heater: [7E3] : Sheathed type glow plug heater
Heated washer nozzles: [9T0] : Without heated washer nozzles
Heating and air conditioning system: [9AB] : Manually controlled air conditioning
Horns: [8Y1] : Two-tone horn
Identification plates: [1EC] : Special identification plate
Insert for the filling up of unleaded fuel/fuel type: [2G0] : Without insert for the filling up offuel
Interference suppression: [8E2] : Local interference suppression for FM/AMradio reception
Key for locking system: [8QC] : Key with light
Labels for starting an automatic: [0MA] : Without label for starting an automatic
Left exterior mirror: [3BS] : Left exterior mirror: aspherical,electrically adjustable and heated
Left vanity mirror: [4SA] : Without left vanity mirror
Lock operation for tailgate/trunk lid: [4E0] : Tailgate/trunk lid unlockingfrom outside
Luggage compartment cover: [3U2] : Sliding trunk cover
Luggage compartment floor covering: [6SC] : Tufted trunk floor covering
Luggage compartment lining: [5A8] : Trunk lining (design 2)
Malfunction display: [9HA] : Without additional malfunction display
Multi-function display/trip computer: [9Q1] : Multi-function display/on-board computer
Nameplate set: [2QW] : Nameplate set "GT TDI"
Outer rear seat belts: [3ZB] : 3-point seat belts, outer rear with ECElabel
Paint preservative/transit coating: [5K0] : Without surface protection, withadditional transit coating
Park distance control: [8A0] : Park distance control, front and rearwith rear view camera
Partition: [3CA] : Without partition
Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation
Protective side molding: [4B2] : Body-colored protective side molding
Radios: [8AD] : Radio "gamma"
Reading light: [8S2] : One reading light front, two readinglights rear
Rear cargo area: [3GK] : Without additional lower part forluggage compartment floor
Rear headrests: [3Q1] : Rear headrests
Rear seat catch: [6QA] : Rear seat catch
Rear seats: [3NG] : Separate seat, left
Rear spoiler: [5J0] : Without rear spoiler
Rear trim panel: [6V1] : Rear trim panel (ECE)
Rear window wiper and washer system: [8M1] : Rear window wiper and washer systemwith intermittent control
Right exterior mirror: [3AF] : Right exterior mirror: convex,electrically adjustable and heated
Right vanity mirror: [4TB] : Vanity mirror right
Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen
Roof rails/roof load rack: [3S2] : Black roof rails
Seat covering: [N0N] : Woven fabric seat covering
Seat heater: [4A0] : Without seat heater
Shock absorption/suspension, chassis: [1BA] : Standard suspension/shock absorption
Side lights: [8F2] : Side turn signal lights
Socket: [7B0] : Without socket
Spare wheel/breakdown set: [1G7] : Space-saving spare wheel (radial tire)
Speaker installation: [8RM] : 8 speakers (passive)
Special alarm systems: [9A0] : Without taxi alarm system
Steering: [1N1] : Power steering
Steering column systems: [2C1] : Height adjustable steering column
Steering wheels: [2PH] : Leather steering wheel
Sticker (customized or special edition): [0KA] : Without stickers and badges
Supertone system and tone sequence control: [9J0] : Without supertone system and tonesequence control
Taillight assemblies: [8SB] : Taillight assembly w/ dark colored lens
Tires: [H1V] : Tires 225/45 R17
Transmission specifications: [G0C] : 5-speed manual transmission
Type approval countries/countries with special requirements: [B01] : Type approval Germany
Vehicle class differentiation units/platform components: [0DP] : Installation differentiation for buildstatus of vehicle class B4 (VW Passat)unit components
Wheel covers: [1NL] : Covers for alloy wheels
Wheels: [C5W] : Cast alloy wheels 7J x 15
Window regulator: [4R2] : Power windows front, mechanical windowregulators rear
Windshield glass type: [4GF] : Windshield in heat-insulating glass
Windshield wiper intermittent control: [8N2] : Windshield wiper intermittent controlinfinitely variable
Front seats: [Q3M] : Sports front seats w/ integrated storagetrays and angular adjustment
Base engine: [T2F] : 4-cylinder diesel engine 1.9 Lunit 028.C
Control number (no PR-Family): [S3Y] : 2-door GTI for Hong Kong
Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer
