tak jak w temacie proszę o sprawdzenie, vin pojazdu WVWZZZ3BZYE281023
Dekodowanie numeru VIN WVWZZZ3BZYE281023 na www.automo.pl
Nazwa dekodera: Dekoder VIN dla Grupy VAG #2 Vehicle Identification No.: WVWZZZ3BZYE281023 Model Designation: passat estate Date of production: 02.02.2000 Model year: 2000 Sales type: 3B53A5 Engine code: ANA Transmission code: DWG Axle drive: 5S Interior trim code: GP Roof color: K1 Exterior color/Paint Code: K1/A5E Activated carbon canister: [1E1] : Activated carbon canister Additional body covers, side: [6EP] : Additional stone guard body covers Additional child seat anchors: [3B4] : Child seat anchor forchild seat system ISOFIX Additional dust seals: [6U0] : Without additional seals outside Additional tires (winter tires): [2XE] : Winter tires 195/65 R 15 91T withsteel wheel 6J x 15, offset 45 (5-hole)without full wheel cover (C0V) Air bag: [4UE] : Air bag for driver and front seatpassenger Alternative drive module: [0K0] : Without alternative drive module Antennas: [8L3] : Roof antenna Anti-theft protection system: [7AB] : Electronic alarm system with vehicleimmobilization device (for RoW) Antifreeze: [1C1] : Antifreeze up to -25 degree celsiustolerance up to -30 degree C Automatic transmission indicator light: [9FA] : Without automatic transmissionindicator light Auxiliary heating: [9M0] : Without auxiliary/parking heater Batteries: [J1P] : Battery 220 A (44 Ah) Body measures: [5C0] : Without special body measures Body style: [K8D] : Station Wagon Variant/Avant Brake type, front: [1ZJ] : Disc brakes, front (Geomet D) Braking systems: [1AT] : Electronic stabilization program (ESP) Breakaway interior mirror: [4L2] : Dipping breakaway interior rear viewmirror Bumper: [2JB] : Standard bumpers CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation CD changer/CD player: [7A2] : CD changer Carrier frequency for radio remote control: [5D1] : Carrier frequency 433.92 MHz-434.42 Mhz Cassette and CD storage unit: [4W0] : Without cassette and CD storage unit Catalytic converter control: [8KA] : W/o catalytic converter warning light Center armrest: [6E3] : Front center armrest Center high-mounted stop light: [8R1] : Center high-mounted stop light Center rear seat belts: [3C3] : Lap belt with retractorfor the center rear seat Climatic zones: [0Y1] : Standard climatic zones Component part sets with country-specific design requirements: [B0A] : Component parts set withoutcountry-specific design requirement Controls (steering wheels/steering column): [4LA] : Without controls Cruise control: [8T0] : Without cruise control system (CCS) Cruise control warning and speed limit system: [6Y0] : Without cruise control warning system Cup holder: [4M6] : Cup holder Door and lid locking system: [4K3] : Radio remote controlled central lockingoperated from inside and safe securing Door and side trim panels: [3LD] : Door and side trim panel Drive layout: [1X0] : Front wheel drive Duty-free tires: [1V0] : Without duty-free and cost-free tires Emission standard: [0GH] : Emission standard D4 Engine cooling system: [8Z5] : Not hot country Engine specifications: [MQ5] : 4-cylinder gasoline engine 1.6 L/74 kWwith multi-point injection and D4base engine is T6U Equipment levels: [A8S] : Standard equipment Exterior mirror setting: [6XN] : Exterior mirrors: electricallyadjustable, separately heated Exterior noise suppression measures: [2B0] : Without additional exterior noisesuppression Fire extinguisher: [6A0] : Without fire extinguisher First aid kit / warning triangle: [1T2] : Warning triangle Flame retardent materials: [4Q0] : No flame retardent materials Floor coverings: [3MQ] : Ibolours floor covering Floor mats: [0TA] : Without floor mats Front fog light/additional headlight: [8WD] : Integrated front fog light Front license plate carrier: [6W1] : License plate carrier front (large) Front underbody guard: [1SA] : Without additional front underbody guard Fuel quantity for initial filling: [1Z0] : Initial standard fuel filling Gearshift boot/cover: [6R1] : Leatherette gearshift boot Gearshift knob/handle: [6Q1] : Plastic gearshift knob/handle General operating permit, alterations: [C13] : Operating permit, alteration Generators: [8GD] : Alternator 90A Hand brake lever handle: [6PA] : Plastic hand brake lever handle Headlight: [8JM] : Twin headlight for driving on the right,with integrated high beam Headlight activation: [8K0] : Without special headlightactivation Headlight washer system: [8X0] : Without headlight washer system Headlight-range adjustment: [8Q1] : Headlight-range adjustment Headrests: [3J7] : Articulated and height-adjustableheadrests for front seats Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating Heated washer nozzles: [9T1] : Heated washer nozzles, front Heating and air conditioning system: [9AB] : Manually controlled air conditioning Identification plates: [1EX] : Special identification plate for ECfor M1 passenger vehicle Ignition/starter switch locking system: [0RA] : Without ignition/starter switch lockingsystem Insert for the filling up of unleaded fuel/fuel type: [2G1] : Insert for the filling up of unleadedfuel Inserts: [5MA] : Decorative inserts Installation parts for engine (engine mount system): [1VG] : Installation parts for four-cylinderengine Interference suppression: [8E2] : Local interference suppression for FM/AMradio reception Left exterior mirror: [5SL] : Left exterior mirror: aspherical Left vanity mirror: [4SD] : Left vanity mirror, illuminated Lock operation for tailgate/trunk lid: [4E0] : Tailgate/trunk lid unlockingfrom outside Lockable wheel bolts: [1PA] : Standard wheel bolts Luggage compartment floor covering: [6SL] : Tufted trunk floor covering (cut pile) Luggage net/pocket on backrest(s): [4U5] : Luggage pockets on backrest Lumbar support: [7P4] : Manually adjustable lumbar support infront seats Malfunction display: [9HA] : Without additional malfunction display Manufacturing sequence differentiation: [0FA] : Standard manufacturing sequence Moldings: [4ZE] : Black moldings Multi-function display/trip computer: [9Q1] : Multi-function display/on-board computer Nameplate set: [0NA] : Without nameplate set(without model designation) Navigation device: [7Q0] : Without navigation device Outdoor temperature gage: [9Y1] : Outdoor temperature gage Paint preservative/transit coating: [5K0] : Without surface protection, withadditional transit coating Park distance control: [7X0] : Without park distance control Parking light indicator light: [8NA] : Without parking light warning light Partition: [3CX] : Net partition Platform module floor pan, rear: [4P1] : Rear floor panel module, type 2 Preparation for sound combination for rotating emergency light: [9F0] : Without sound combination for rotatingemergency light and radio antennapreparation Preparation for two-way radio installation: [9D0] : Without preparation for two-way radioinstallation Protective side molding: [4B1] : Protective side molding Radios: [8AD] : Radio "gamma" Reading light: [8S4] : Two reading lights front, two rear Rear cargo area: [3GK] : Without additional lower part forluggage compartment floor Rear fog light: [8TC] : Rear fog light for driving on the right Rear headrests: [3Q1] : Rear headrests Rear seat catch: [6QA] : Rear seat catch Rear seats: [3NW] : Rear seat bench/backrest, split foldingwith center armrest Restraint systems, front: [3QT] : 3-point seat belts with tensioner andheight adjustment, front Right exterior mirror: [5RQ] : Right exterior mirror: convex Right vanity mirror: [4TD] : Right vanity mirror illuminated Roll-up sun screen for rear and side windows: [3Y0] : Without roll-up sun screen Roof insert/convertible top: [3FA] : Without roof insert (standard roof) Roof rails/roof load rack: [3S2] : Black roof rails Safety certificate: [0LA] : Without special plates/stickers/safety certificates Seat adjustment: [3L3] : Manual height adjustment for front seats Seat belt check: [9P0] : Without seat belt reminder Seat covering: [N0U] : Cut pile seat covering Seat heater: [4A3] : Seat heater for front seatsseparately controlled Shock absorption/suspension, chassis: [1BA] : Standard suspension/shock absorption Side air bag: [4X1] : Side air bag front Side lights: [8F2] : Side turn signal lights Ski bag: [3X0] : Without load-through provision Socket: [7B2] : 12-volt socket in luggage boot Spare wheel/breakdown set: [1G2] : Steel spare wheel with originalequipment tires Speaker installation: [8RM] : 8 speakers (passive) Special alarm systems: [9A0] : Without taxi alarm system Special editions: [E0A] : No special edition Special labels/plates: [0SB] : Labels/plates in German Speedometer cable and seal: [8CC] : Speedometer sensor without seal(electronic speedometer sensor) Steering system arrangement: [L0L] : Left-hand drive vehicle Steering wheels: [2PQ] : Steering wheel for air bag system Sticker (customized or special edition): [0KA] : Without stickers and badges Supertone system and tone sequence control: [9J0] : Without supertone system and tonesequence control Taillight assemblies: [8SA] : Taillight assemblies, standard design Telephone/telematics: [9W0] : W/o car phone preparation/installation Throttle actuation: [0L2] : Electric throttle actuation Tire pressure warning light: [7K0] : Without tire pressure warning light Tires: [H6S] : Tires 195/65 R15 V Trailer hitch: [1D0] : Without trailer hitch Transmission shafts: [1WB] : Transmission shafts w/ 100 mm indiameter Transmission shafts, rear axle: [1YA] : Without transmission shafts f. rear axle Transmission specifications: [G0C] : 5-speed manual transmission Transmission types/gearshift mechanisms: [0G1] : Gearshift lever Type approval countries/countries with special requirements: [B01] : Type approval Germany Vehicle class differentiation units/platform components: [0DE] : Installation differentiation for buildstatus of vehicle class B5 (VW Passat) Vehicle specifications: [F0A] : No special purpose vehicle, standardequipment Weight category front axle: [0JD] : Weight category front axleweight range 4 Weight category rear axle: [0YE] : Weight range 5installation control only, norequirement forecast Wheels: [C0V] : Steel wheels 6J x 15 Window regulator: [4R3] : Power windows with comfort operation Windshield glass type: [4GH] : Windshield in heat-insulating glasswith sunshield Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds) Child seats: [QA0] : Without child seat Front seats: [Q2J] : Comfort front seats Service interval prolongation: [QG1] : Service interval prolongation Base engine: [T6U] : 4-cylinder gasoline engine 1.6 lunit 06B.1 (ALU) Instrument inserts: [U0C] : Instrument insert with tachometerclock and km/h speedometer Tire suppliers: [V0A] : Tires w/o specification of tire brand Dekodowanie pochodzi z www.automo.pl |
