Activated carbon canister:
| Activated carbon canister |
Additional body covers, side:
| Additional stone guard body covers |
| Without additional child seat anchor |
Additional dust seals:
| Without additional seals outside |
| Without additional tires |
Air bag:
| Air bag for driver and front seatpassenger |
Alternative drive module:
| Without alternative drive module |
Anti-theft protection system:
| Electronic alarm system with vehicleimmobilization device (for RoW) |
Antifreeze:
| Antifreeze up to -25 degree celsiustolerance up to -30 degree C |
Automatic transmission indicator light:
| Without automatic transmissionindicator light |
Base engine:
| 4-cylinder gasoline engine 1.8 Lunit 058.B |
Batteries:
| Battery 220 A (44 Ah) |
Body measures:
| Without special body measures |
Body style:
| Station Wagon Variant/Avant |
Brake type, front:
| Front disc brakes, standard ventilation |
Braking systems:
| Anti-lock brake system (ABS) |
Breakaway interior mirror:
| Dipping breakaway interior rear viewmirror |
Bumper:
| Standard bumpers |
CD ROM/DVD/SD card:
| Without CD/DVD for navigation |
CD changer/CD player:
| CD changer |
| Carrier frequency 433.92 MHz-434.42 Mhz |
Cassette and CD storage unit:
| Without cassette and CD storage unit |
Catalytic converter control:
| W/o catalytic converter warning light |
Center armrest:
| Front center armrest |
Center high-mounted stop light:
| Center high-mounted stop light |
Center rear seat belts:
| Lap belt with retractorfor the center rear seat |
Child seats:
| Without child seat |
Climatic zones:
| Standard climatic zones |
| Component parts set withoutcountry-specific design requirement |
Cruise control:
| Without cruise control system (CCS) |
Cruise control warning and speed limit system:
| Without cruise control warning system |
Cup holder:
| Cup holder |
Door and lid locking system:
| Radio remote controlled central lockingoperated from inside and safe securing |
Door and side trim panels:
| Door and side trim panel |
Drive layout:
| Front wheel drive |
Duty-free tires:
| Without duty-free and cost-free tires |
Engine cooling system:
| Not hot country |
Engine specifications:
| 4-cyl. gasoline engine 1.8 L/92 kW 20Vwith MVEG 2base engine is T0V/T5Z |
Equipment levels:
| Standard equipment |
Exterior mirror setting:
| Exterior mirrors electricallyadjustable, separately heated |
Exterior noise suppression measures:
| Additional exterior noise suppression |
| Warning triangle |
Flame retardent materials:
| No flame retardent materials |
Floor coverings:
| Ibolours floor covering |
Floor mats:
| Without floor mats |
| Integrated front fog light |
Front license plate carrier:
| License plate carrier front (large) |
Front underbody guard:
| Without additional front underbody guard |
| Initial standard fuel filling |
Gearshift boot/cover:
| Leatherette gearshift boot |
Gearshift knob/handle:
| Plastic gearshift knob/handle |
| Operating permit, alteration |
Generators:
| Alternator 90A |
Hand brake lever handle:
| Plastic hand brake lever handle |
Headlight:
| Twin headlight for driving on the right,with integrated high beam |
Headlight activation:
| Without special headlightactivation |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Headlight-range adjustment |
Headrests:
| Articulated and height-adjustableheadrests for front seats |
| W/o heat accumulator/auxiliary heating |
Heated washer nozzles:
| Without heated washer nozzles |
| Climatronic with impact pressurecontrol free of cfc |
Identification plates:
| Special identification plate for ECfor M1 passenger vehicle |
| Without ignition/starter switch lockingsystem |
| Insert for the filling up of unleadedfuel |
Inserts:
| Decorative inserts |
Installation parts for engine (engine mount system):
| Installation parts for four-cylinderengine |
Interference suppression:
| Local interference suppression for FM/AMradio reception |
Left exterior mirror:
| Left exterior mirror aspherical |
Left vanity mirror:
| Left vanity mirror, illuminated |
| Tailgate/trunk lid unlockingfrom outside |
Lockable wheel bolts:
| Wheel bolts with anti-theft protection(unlockable) |
Luggage compartment floor covering:
| Tufted trunk floor covering (cut pile) |
Luggage net/pocket on backrest(s):
| Luggage nets/pockets on backrests |
Lumbar support:
| Manually adjustable lumbar support infront seats |
Malfunction display:
| Without additional malfunction display |
| Standard manufacturing sequence |
Moldings:
| Black moldings |
| Multi-function display/on-board computer |
Nameplate set:
| Nameplate set 1.8 |
Navigation device:
| Without navigation device |
Outdoor temperature gage:
| Outdoor temperature gage |
| Paint preservative (wax) |
Park distance control:
| Without park distance control |
Parking light indicator light:
| Without parking light warning light |
Partition:
| Net partition |
Preparation for sound combination for rotating emergency light:
| Without sound combination for rotatingemergency light and radio antennapreparation |
Preparation for two-way radio installation:
| Without preparation for two-way radioinstallation |
Protective side molding:
| Protective side molding |
Radios:
| Radio gamma |
Reading light:
| Two reading lights front, two rear |
Rear cargo area:
| Without additional lower part forluggage compartment floor |
Rear fog light:
| Rear fog light for driving on the right |
Rear headrests:
| Rear headrests |
Rear seat catch:
| Rear seat catch |
Rear seats:
| Rear seat bench/backrest, split foldingwith center armrest |
Restraint systems, front:
| 3-point seat belts with tensioner andheight adjustment, front |
Right exterior mirror:
| Right exterior mirror convex |
Right vanity mirror:
| Right vanity mirror illuminated |
| Without roll-up sun screen |
Roof insert/convertible top:
| Without roof insert (standard roof) |
Roof rails/roof load rack:
| Black roof rails |
Safety certificate:
| Without special plates/stickers/safety certificates |
Seat adjustment:
| Manual height adjustment for front seats |
Seat belt check:
| Without seat belt reminder |
Seat covering:
| Cut pile seat covering |
Seat heater:
| Without seat heater |
Shock absorption/suspension, chassis:
| Standard suspension/shock absorption |
Side air bag:
| Side air bag front |
Side lights:
| Side turn signal lights |
Ski bag:
| Without load-through provision |
Socket:
| 12-volt socket in luggage boot |
Spare wheel/breakdown set:
| Steel spare wheel with originalequipment tires |
Speaker installation:
| 8 speakers (passive) |
Special alarm systems:
| Without taxi alarm system |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in German |
Speedometer cable and seal:
| Speedometer sensor without seal(electronic speedometer sensor) |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Steering wheel for air bag system |
Sticker (customized or special edition):
| Without stickers and badges |
Supertone system and tone sequence control:
| Without supertone system and tonesequence control |
Taillight assemblies:
| Taillight assemblies, standard design |
Telephone/telematics:
| W/o car phone preparation/installation |
Tires:
| Tires 205/60 R15 V |
Trailer hitch:
| Without trailer hitch |
Transmission shafts:
| Transmission shafts w/ 108 mm indiameter |
Transmission shafts, rear axle:
| Without transmission shafts f. rear axle |
Transmission specifications:
| 5-speed manual transmission |
Transmission types/gearshift mechanisms:
| Gearshift lever |
| Type approval Germany |
| Installation differentiation for buildstatus of vehicle class B5 (VW Passat) |
Vehicle specifications:
| No special purpose vehicle, standardequipment |
Weight category front axle:
| Weight category front axleweight range 6 |
Weight category rear axle:
| Weight range 4installation control only, norequirement forecast |
Wheels:
| Alloy wheels 7J x 15 Adelaide offset 45 (five-hole) |
Window regulator:
| Power windows with comfort operation |
Windshield glass type:
| Windshield in heat-insulating glasswith sunshield |
Windshield wiper intermittent control:
| Windshield wiper intermittent controlwith potentiometer (four speeds) |
Front seats:
| Standard front seats |
Control number (no PR-Family):
| Leasing for major customers |
Instrument inserts:
| Instrument insert with tachometerclock and km/h speedometer |
Tire suppliers:
