Activated carbon canister:
| Activated carbon canister |
Additional body covers, side:
| Without additional side body covers(stone guard) |
| Child seat anchor forchild seat system ISOFIX |
| Without additional tires |
Additional warning lights:
| Additional reflectors (door area) |
Air bag:
| Driver s and front passenger air bagwith front passenger air bagdeactivation |
Air duct, front area:
| Air duct, standard |
Antennas:
| Antenna for AM/FM reception, diversity |
Anti-theft protection system:
| Electronic vehicle immobilization device |
Antifreeze:
| Antifreeze up to -25 degree celsiustolerance up to -30 degree C |
Auxiliary heating:
Backrest release:
| Without backrest release for front seats |
Base engine:
| 4-cylinder gasoline engine 1.4 Lunit 03C.F (aluminum) |
Batteries:
| Battery 220 A (44 Ah) |
Body measures:
| Without special body measures |
Body style:
| Hatchback |
Brackets:
| Bracket for first aid kit and warningtriangle |
Brake type, front:
| Disc brakes, front (Geomet D) |
Brake type, rear:
| Disc brakes, rear |
Braking systems:
| Anti-lock brake system (ABS) |
Breakaway interior mirror:
| Dipping breakaway interior rear viewmirror |
Bumper:
| Standard bumpers |
CD ROM/DVD/SD card:
| Without CD/DVD for navigation |
CD changer/CD player:
| Without CD changer/CD player |
| Carrier frequency 433.92 MHz-434.42 Mhz |
Center armrest:
| Without center armrest front |
Center rear seat belts:
| 3-point seat belt for center rear seat |
Child seat anchor, front:
| Without child seat anchor front (ISOFIX) |
| Component parts set withoutcountry-specific design requirement |
| Body-colored exterior mirror housings |
Control number (no PR-Family):
| Control (in-plant) |
Controls (steering wheels/steering column):
| Without controls |
Cruise control:
| Without cruise control system (CCS) |
Door and lid locking system:
| Radio remote controlled central lockingoperated from inside and safe securing |
Door and side trim panels:
| Door and side trim panel in foam filmand woven fabric |
Door pockets, front:
| Door pockets without insert mats |
Doors:
| 4 doors |
Drive layout:
| Front wheel drive |
Electronic map cooling system:
| Without electronic map cooling system |
Emission standard:
| Emission standard EU4 |
Engine compartment lighting:
| Without engine compartment lighting |
Engine cooling system:
| Not hot country |
Engine specifications:
| 4-cyl. gasoline engine 1.4 L/66 kW 16Vfuel-stratified injectionbase engine is T74 |
Equipment levels:
| Basic equipment |
Exhaust tailpipe:
| Rear exhaust tailpipe (standard) |
Exterior mirror setting:
| Exterior mirrors electricallyadjustable, separately heated |
Fire extinguisher:
| Without fire extinguisher |
| Without first aid kit and warningtriangle |
Floor mats:
| Without floor mats |
| Without front fog light |
Front license plate carrier:
| License plate carrier front (large) |
Front seat, left:
| Standard seat, front left |
Front seat, right:
| Standard seat, front right |
Front stabilizer:
| Front stabilizer |
Front underbody guard:
| Without additional front underbody guard |
| Initial standard fuel filling |
Fuel systems:
| Fuel system for SI engine with directinjection (FSI) |
Fuel tank treatment:
| Fuel tank without differentiation ofspecial material treatment(fluorination/co-extrusion) |
Gearshift knob/handle:
| Leather gearshift knob/handle |
| Operating permit, alteration |
Generators:
| Alternator 110 A |
Glove compartment:
| Lockable glove compartment door, withlight |
Hand brake lever handle:
| Leather hand brake lever handle |
Headlight:
| Twin-headlight for driving on the right,with integrated high beam |
Headlight activation:
| Without special headlightactivation |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Headlight-range adjustment |
Headrests:
| Articulated and height-adjustableheadrests for front seats |
| W/o heat accumulator/auxiliary heating |
Heated washer nozzles:
| Without heated washer nozzles |
| Climatic air-conditioning system(semi-automatic) |
Horns:
| Single-tone horn |
Identification plates:
| Special identification plate for ECfor M1 passenger vehicle |
| Without ignition/starter switch lockingsystem |
| Filler neck module 1 with insert |
Inserts:
| Without decorative inserts |
Installation differentiation for vehicle components:
| Installation differentiation fortransmission MQ 200vehicle components |
Instrument inserts:
| Instrument insert, km/h speedometer |
Interior light in foot area:
| Without interior light in footwell |
Left exterior mirror:
| Left exterior mirror aspherical |
Left vanity mirror:
| Vanity mirror left |
| Tailgate/trunk lid unlockingfrom outside |
Lockable wheel bolts:
| Standard wheel bolts |
Luggage compartment cover:
| Foldable trunk cover |
Luggage compartment lining:
| Comfort trunk lining with service lid/cover |
Luggage net/pocket on backrest(s):
| Without luggage nets/pocketson backrests |
Lumbar support:
| Without lumbar supportin seat backrests |
| Standard manufacturing sequence |
Mass damper for steering wheels:
| Without mass damper for steering wheel |
| Multi-function display/on-board computer |
Nameplate set:
| Nameplate set FSI |
Navigation device:
| Without navigation device |
Operating voltage:
| Operating voltage 12V |
Outer rear seat belts:
| 3-point seat belts, outer rear with ECElabel |
Owner s manuals:
| Information kit in Polish |
Paint coating:
| Standard paint coating |
| Without surface protection, withadditional transit coating |
Park distance control:
| Without park distance control |
Partition:
| Without partition |
Pedal cluster:
| Standard pedal cluster |
Pedestrian protection:
| Extended pedestrian protection measures |
Platform group class:
| Platform group class 1 |
Platform module floor pan, rear:
| Rear floor panel module, type 1 |
Preparation for sound combination for rotating emergency light:
| Without sound combination for rotatingemergency light and radio antennapreparation |
Preparation for two-way radio installation:
| Without preparation for two-way radioinstallation |
Protective side molding:
| Protective side molding |
Radiator grille:
| Radiator grille |
Radios:
| Without radio |
Reading light:
| Reading light front |
Rear fog light:
| Rear fog light for driving on the right |
Rear headrests:
| Three rear headrests |
Rear license plate carrier:
| License plate carrier rear (ECE) |
Rear seats:
| Rear seat bench unsplit, backrest splitfolding |
Rear stabilizer:
| Rear stabilizer |
Rear window wiper and washer system:
| Rear window wiper and washer systemwith intermittent control |
Refrigerator:
| Glove compartment cooling system |
| W/o remote-controlled garage door opener |
Restraint systems, front:
| 3-point seat belts with tensioner andheight adjustment, front |
Right exterior mirror:
| Right exterior mirror convex |
Right vanity mirror:
| Vanity mirror right |
| Without roll-up sun screen |
Roof insert/convertible top:
| Without roof insert (standard roof) |
Rough-road/sports version:
| Standard design |
Safety headrest system:
| Safety headrest system |
Scuff plates:
| Plastic scuff plates in door apertures |
Seat adjustment:
| Manual height adjustment for left frontseat |
Seat belt check:
| Seat belt reminder, electric contact inbuckle |
Seat covering:
| Fabric seat covering |
Seat heater:
| Without seat heater |
Shock absorption, chassis, front:
| Front shock absorption |
Shock absorption, chassis, rear:
| Rear shock absorption, basic design 1 |
Side air bag:
| Side air bag front with curtain air bag |
Side and rear windows:
| Side and rear windows in heat-insulatingglass |
Side lights:
| Side turn signal lights (white) |
Smoking/non-smoking package:
| Smoking package, ashtray front and rear |
Socket:
| Without socket |
Spare wheel/breakdown set:
| Space-saving spare wheel for temporaryuse, radial tire(5-hole) |
Speaker installation:
| 10 speakers (passive) |
Special alarm systems:
| Without taxi alarm system |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in German |
Steering:
| Speed-related variable steering assist(Servotronic) |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Leather steering wheel |
Supertone system and tone sequence control:
| Without supertone system and tonesequence control |
Telephone/telematics:
| W/o car phone preparation/installation |
Tire pressure warning light:
| Without tire pressure warning light |
Tires:
| Tires 195/65 R15 T |
Tool kit and jack:
| Tool kit and jack |
Trailer hitch:
| Without trailer hitch |
Transmission specifications:
| 5-speed manual transmission |
Trunk sill protection:
| Plastic trunk sill protection |
| Type approval Poland |
| Vehicle class differentiation 1K0/5K0 |
Vehicle specifications:
| No special purpose vehicle, standardequipment |
Washer fluid level indicator:
| Without washer fluid level indicator |
Weight category front axle:
| Suspension range 01installation control only, norequirement forecast |
Weight category rear axle:
| Weight range 2installation control only, norequirement forecast |
Wheel covers:
| Full wheel covers |
Wheels:
| Steel wheels 6J x 15 |
Window regulator:
| Power windows with comfort operation andcircuit breaker |
Windshield glass type:
| Windshield in heat-insulating glass |
Windshield wiper intermittent control:
| Windshield wiper intermittent controlwith potentiometer (four speeds) |
Child seats:
| Without child seat |
Chrome work package:
| Without aluminum/chrome work package |
Compass/traffic sign display:
| Without compass/traffic sign display/traffic signs recognition |
Drawers under front seats:
| Without drawers under front seats |
Nameplates for sales name:
| Nameplates for sales name |
Service interval prolongation:
| Service interval prolongation |
| W/o TV reception/digital radio reception |
Tire suppliers:
