Activated carbon canister:
| Activated carbon canister |
Additional body covers, side:
| Without additional side body covers(stone guard) |
| Without additional child seat anchor |
| Without additional tires |
Air bag:
| Air bag for driver and front seatpassenger |
Antifreeze:
| Antifreeze up to -25 degree celsiustolerance up to -30 degree C |
Backrest release:
| Backrest release for front seat(s) |
Batteries:
| Battery 280 A (60 Ah) |
Body measures:
| Without special body measures |
Body style:
| Hatchback |
Brake type, front:
| Disc brakes, front |
Brake type, rear:
| Drum brakes, rear |
Braking systems:
| Anti-lock brake system (ABS) |
Bumper:
| Painted bumpers |
Catalytic converter control:
| W/o catalytic converter warning light |
Center high-mounted stop light:
| Center high-mounted stop light |
Center rear seat belts:
| Static lap belt, center rear |
Climatic zones:
| Standard climatic zones |
Clutch actuation:
| Mechanical clutch actuation |
| Component parts set withoutcountry-specific design requirement |
Cruise control warning and speed limit system:
| Without cruise control warning system |
Cup holder:
| Without cup holder |
Dashboard:
| Standard dashboard |
Door and lid locking system:
| Central locking system |
Door and side trim panels:
| Door and side trim panel |
Doors:
| 2 doors |
Duty-free tires:
| Without duty-free and cost-free tires |
Engine specifications:
| 4-cylinder gasoline engine 1.6 L/55 kWw/ MPI, MVEG 2 a. closed-loop cat. conv.base engine is T3N |
Equipment levels:
| Comfort equipment |
Exterior noise suppression measures:
| Additional exterior noise suppression |
| Without first aid kit and warningtriangle |
Flame retardent materials:
| No flame retardent materials |
Floor mats:
| Without floor mats |
Front cargo area:
| Without cargo area front |
| Integrated front fog light |
Front stabilizer:
| Front stabilizer |
Front turn signal lights:
| Yellow turn signal lights |
| Initial standard fuel filling |
Fuel systems:
| Fuel system for carburetor gasolineengine |
Fuel tank treatment:
| Fuel tank with special materialtreatment |
Gearshift boot/cover:
| Rubber gearshift boot |
Gearshift knob/handle:
| Plastic gearshift knob/handle |
| Operating permit, alteration |
Generators:
| Alternator 90A |
Hand brake lever handle:
| Plastic hand brake lever handle |
Headlight:
| Halogen headlightfor driving on the right |
Headlight activation:
| Without special headlightactivation |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Headlight-range adjustment |
| W/o heat accumulator/auxiliary heating |
Heated washer nozzles:
| Heated washer nozzles, front |
| Manually controlled air conditioning |
Identification plates:
| Special identification plate for ECfor M1 passenger vehicle |
| Without ignition/starter switch lockingsystem |
| Insert for the filling up of unleadedfuel |
Interference suppression:
| Local interference suppression for FMradio reception |
Key for locking system:
| Key without LED |
Left exterior mirror:
| Left exterior mirror aspherical,electrically adjustable and heated |
Luggage compartment cover:
| Foldable trunk cover |
Luggage compartment floor covering:
| Flat needle-punched trunk floor covering |
| Wolfsburg manufacturing sequence |
Mud flap:
| Without mud flaps |
Nameplate set:
| Nameplate set in base trim |
Navigation device:
| Without navigation device |
Outer rear seat belts:
| 3-point seat belts, outer rear with ECElabel |
| Without surface protection, withadditional transit coating |
Partition:
| Without partition |
Protective side molding:
| Protective side molding |
Radios:
| Radio alpha Europa |
Rear cargo area:
| Without cargo area |
Rear fog light:
| Rear fog light for driving on the right |
Rear headrests:
| Rear headrests |
Rear seats:
| Rear seat bench/backrest, split folding |
Rear spoiler:
| Rear spoiler |
Rear stabilizer:
| Without rear stabilizer |
Restraint systems, front:
| 3-point seat belts with tensioner andheight adjustment, front |
Right exterior mirror:
| Right exterior mirror convex,electrically adjustable and heated |
Roof insert/convertible top:
| Without roof insert (standard roof) |
Seat adjustment:
| Manual height adjustment for front seats |
Seat belt check:
| Without seat belt reminder |
Seat covering:
| Woven fabric seat covering |
Seat heater:
| Seat heater for front seatsseparately controlled |
Second battery/battery installation:
| Without second battery |
Side air bag:
| Without side air bag |
Side and rear windows:
| Side and rear windows in heat-insulatingglass |
Side lights:
| Side turn signal lights |
Spare wheel/breakdown set:
| Space-saving spare wheel |
Speaker installation:
| 2 speakers (passive) |
Special color trim:
| Without special color trim |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in German |
Speedometer cable and seal:
| Speedometer sensor without seal(electronic speedometer sensor) |
Start/stop system/regenerative braking:
| Without inertia benefit system/deceleration fuel cut-off/idle stopvalve |
Steering:
| Power steering |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Steering wheel for air bag system |
Sticker (customized or special edition):
| Without stickers and badges |
Taillight assemblies:
| Taillight assemblies, standard design |
Tires:
| Tires 235/45 R18 94W(polymer coating) |
Transmission specifications:
| 5-speed manual transmission |
| Type approval Germany |
| Vehicle class differentiation 6N0 |
Vehicle specifications:
| No special purpose vehicle, standardequipment |
Wheel covers:
| Wheel center cover |
Wheels:
| Alloy wheels 6J x 17 |
Window regulator:
| Power windows |
Windshield glass type:
| Windshield in heat-insulating glass |
Front seats:
| Standard front seats with integratedstorage trays |
Base engine:
| 4-cylinder gasoline engine 1.6 Lunit 032.2 |
Instrument inserts:
| Instrument insert with tachometerclock and km/h speedometer |
Tire suppliers:
