Activated carbon canister:
| Activated charcoal canister acc. to ORVRand siphoning device for filling up |
Additional body covers, side:
| Without additional side body covers(stone guard) |
| Child seat anchor according toCanadian requirements andchild seat system ISOFIX |
| Without additional tires |
Additional warning lights:
| Additional warning lights (door area) |
Air bag:
| Driver s and front passenger air bag,NAR with front passenger air bagdeactivation (2-stage) |
Air duct, front area:
| Air duct, type 1 |
Antennas:
| Antenna for AM/FM reception, diversity |
Anti-theft protection system:
| Electronic vehicle immobilization devicewith alarm system and backup horn |
Antifreeze:
| Antifreeze up to -35 degree celsiustolerance up to -40 degree C |
Auxiliary heating:
Backrest release:
| Backrest release for right front seat |
Base engine:
| 5-cylinder gasoline engine 2.5 Lunit 07K.1 |
Batteries:
| Battery 380 A (72 Ah) |
Body measures:
| Body measures for increased safetyrequirements |
Body style:
| Notchback |
Brackets:
| Without bracket for first aid kit andwarning triangle |
Brake pad wear indicator:
| Brake pad wear indicator |
Brake type, front:
| Disc brakes, front (Geomet D) |
Brake type, rear:
| Disc brakes, rear |
Braking systems:
| Electronic stabilization program (ESP) |
Breakaway interior mirror:
| Breakaway interior rear view mirror,automatically dimming |
Bumper:
| Comfort bumpers |
CD ROM/DVD/SD card:
| Without CD/DVD for navigation |
CD changer/CD player:
| Without CD changer/CD player |
| Carrier frequency 315 MHz |
Center armrest:
| Front center armrest |
Center rear seat belts:
| 3-point seat belt, center rear with USlabel |
Child seat anchor, front:
| Without child seat anchor front (ISOFIX) |
Compass/traffic sign display:
| With compass |
| Component parts set, complying withvehicle type for USA (withoutCalifornia), various parts |
| Body-colored exterior mirror housingsand various add-on parts |
Control number (no PR-Family):
| Introductory volume |
Controls (steering wheels/steering column):
| Without controls |
Cruise control:
| Cruise control system (CCS)electronic |
Door and lid locking system:
| Radio remote controlled central lockingoperated from inside |
Door and side trim panels:
| Door and side trim panel in foam film,insert in leatherette |
Door pockets, front:
| Door pockets with insert mats |
Doors:
| 4 doors |
Drive layout:
| Front wheel drive |
Electronic map cooling system:
| Without electronic map cooling system |
Emission standard:
| Emission standard ULEV 2 |
Engine compartment lighting:
| Without engine compartment lighting |
Engine cooling system:
| Cold country |
Engine specifications:
| 5-cyl. gasoline engine 2.5 L/110 kW(20V) (R5)base engine is T8K/TQ7 |
Equipment levels:
| US comfort equipment |
Exhaust tailpipe:
| Rear side exhaust tailpipe |
Exterior mirror setting:
| Exterior mirrors electricallyadjustable |
Fire extinguisher:
| Without fire extinguisher |
| Without first aid kit and warningtriangle |
Floor mats:
| Front and rear floor mats |
| Without front fog light |
Front license plate carrier:
| License plate carrier front (small, NAR) |
Front seat, left:
| Comfort seat, front left |
Front seat, right:
| Comfort seat, front right |
Front stabilizer:
| Front stabilizer |
Front underbody guard:
| Without additional front underbody guard |
| Initial standard fuel filling |
Fuel systems:
| Fuel sys. for carburetor gasoline eng.w/ injector system without fuel return |
Fuel tank treatment:
| Fuel tank with special materialtreatment (coextrusion) |
Gearshift knob/handle:
| Plastic gearshift knob/handle |
| Operating permit, alteration |
Generators:
| Alternator 140 A |
Glove compartment:
| Lockable glove compartment door, withlight |
Hand brake lever handle:
| Plastic hand brake lever handle |
Headlight:
| Twin headlight for driving on the right,with integrated high beam (US design) |
Headlight activation:
| Separate daytime running lights withlow beam assistant and Coming Home function |
Headlight washer system:
| Without headlight washer system |
Headlight-range adjustment:
| Without headlight-range adjustment |
Headrests:
| Headrests for front seats, articulatedand height-adjustable with integratedrelease function |
| W/o heat accumulator/auxiliary heating |
Heated washer nozzles:
| Heated washer nozzles, front |
| Climatronic with impact pressurecontrol free of cfc |
Horns:
| Two-tone horn |
Identification plates:
| Without identification plate |
| Ignition/starter switch locking system |
| Filler neck module 1 with insert |
Inserts:
| Decorative inserts |
Installation differentiation for vehicle components:
| Installation differentiation fortransmission AQ250vehicle components |
Instrument inserts:
| Instrument insert, mph speedometerUSA |
Interior light in foot area:
| Interior light in footwell |
Left exterior mirror:
| Left exterior mirror flat (US) |
Left vanity mirror:
| Left vanity mirror illuminated withcover and special mirror imprint (NAR)extractable |
| Tailgate/trunk lid releasefrom inside (electrically) |
Lockable wheel bolts:
| Wheel bolts with anti-theft protection(unlockable) |
Luggage compartment cover:
| Without luggage compartment cover |
Luggage compartment lining:
| Comfort trunk lining with service lid/cover |
Luggage net/pocket on backrest(s):
| Luggage pockets on backrest |
Lumbar support:
| Manually adjustable lumbar support infront seats |
| Mexico manufacturing sequence |
Mass damper for steering wheels:
| Mass damper for steering wheel, 26.5Hz |
| Multi-function display with control |
Nameplate set:
| Nameplate set 2.5 |
Navigation device:
| Without navigation device |
Operating voltage:
| Operating voltage 12V |
Outer rear seat belts:
| 3-point seat belts, outer rear with USlabel |
Owner s manuals:
| Information kit in American English |
Paint coating:
| Standard paint coating |
| Without surface protection, withadditional transit coating |
Park distance control:
| Without park distance control |
Partition:
| Without partition |
Pedal cluster:
| Standard pedal cluster |
Pedestrian protection:
| Standard pedestrian protection measures |
Platform group class:
| Platform group class 1 |
Platform module floor pan, rear:
| Rear floor panel module, type 2 |
Preparation for sound combination for rotating emergency light:
| Without sound combination for rotatingemergency light and radio antennapreparation |
Preparation for two-way radio installation:
| Without preparation for two-way radioinstallation |
Protective side molding:
| Without protective side molding |
Radiator grille:
| Radiator grille |
Radios:
| Radio Premium (double-size standard radio) |
Reading light:
| Two reading lights front, two rear |
Rear fog light:
| Without rear fog light |
Rear headrests:
| Three rear headrests |
Rear license plate carrier:
| License plate carrier, rear (NAR) |
Rear seats:
| Rear seat bench unsplit, backrest splitfolding |
Rear spoiler:
| Without rear spoiler |
Rear stabilizer:
| Rear stabilizer |
Rear window wiper and washer system:
| W/o rear window wiper and washer system |
Refrigerator:
| Glove compartment cooling system |
| W/o remote-controlled garage door opener |
Restraint systems, front:
| 3-point seat belts with tensionerheight adjustment and US label front |
Right exterior mirror:
| Right exterior mirror convex (US) |
Right vanity mirror:
| Right vanity mirror illuminated withcover and special mirror imprint (NAR)extractable |
| Without roll-up sun screen |
Roof insert/convertible top:
| Electric slide/tilt sunroofwith sun screen/sunblind |
Rough-road/sports version:
| Standard design |
Safety headrest system:
| Safety headrest system |
Scuff plates:
| Without protective film for scuff plate |
Seat adjustment:
| Manual height adjustment for frontseats, electric backrest adjustment forleft front seat |
Seat belt check:
| Seat belt reminder, optical and acousticelectric contact in buckle |
Seat covering:
| Leatherette seat covering |
Seat heater:
| Seat heater for front seatsseparately controlled |
Shock absorption, chassis, front:
| Front shock absorption |
Shock absorption, chassis, rear:
| Rear shock absorption, basic design 1 |
Side air bag:
| Side air bag front with curtain air bag |
Side and rear windows:
| Side and rear windows in heat-insulatingglass |
Side lights:
| Side turn signal and marker lights (turnsignal lights with white lens) |
Smoking/non-smoking package:
| Non-smoking package |
Socket:
| 12-volt socket(s) |
Spare wheel/breakdown set:
| Steel spare wheel with originalequipment tires |
Speaker installation:
| Sound system Monsoon |
Special alarm systems:
| Without taxi alarm system |
Special editions:
| No special edition |
Special labels/plates:
| Labels/plates in English and French |
Steering:
| Speed-related variable steering assist(Servotronic) |
Steering system arrangement:
| Left-hand drive vehicle |
Steering wheels:
| Steering wheel |
Supertone system and tone sequence control:
| Without supertone system and tonesequence control |
| W/o TV reception/digital radio reception |
Telephone/telematics:
| W/o car phone preparation/installation |
Tire pressure warning light:
| Without tire pressure warning light |
Tire suppliers:
Tires:
| All-weather tires 205/55 R16 H (NAR) |
Tool kit and jack:
| Tool kit and jack |
Trailer hitch:
| Without trailer hitch |
Transmission specifications:
| 6-speed automatic transmission |
Trunk sill protection:
| Plastic trunk sill protection |
| Legal requirements USA |
| Vehicle class differentiation -1KM-Build status corresponds to productionin Mexico |
Vehicle specifications:
| No special purpose vehicle, standardequipment |
Washer fluid level indicator:
| Washer fluid level indicator |
Weight category front axle:
| Suspension range 14installation control only, norequirement forecast |
Weight category rear axle:
| Weight range 6installation control only, norequirement forecast |
Wheel covers:
| Covers for alloy wheels |
Wheels:
| Alloy wheels 6.5J x 16 |
Window regulator:
| Power windows with comfort operation andcircuit breaker |
Windshield glass type:
| Windshield in heat-insulating glass |
Windshield wiper intermittent control:
| Windshield wiper intermittent controlwith rain sensor |
Child seats:
| Without child seat |
Chrome work package:
| Chrome work package |
Drawers under front seats:
| Without drawers under front seats |
Nameplates for sales name:
| Nameplates for sales name |
Service interval prolongation:
| Without service interval prolongation |
