Witam.
Zależy mi bardzo na sprawdzeniu przebiegu w polo 9N VIN: WVWZZZ9NZ2Y068754 Sprawdź ten VIN na autobaza.pl ▸ Proszę o pomoc Pozdrawiam |
a link do aukcji? zapoznaj sie z regulaminem
Samochodu nie ma niestety jeszcze na allegro. Dopiero jest w trakcie sprowadzania.
Na liczniku podobno 125tys. Chciałbym poporstu wiedzieć czy jest sens sie tym interesowac czy odrazu odpuscic |
Numer VIN - WVWZZZ9NZ2Y068754
Region - Germany Fabryka / Producent - Pamplona Marka - Volkswagen Model - Polo 16v\nRok - 2002 Silnik - 1.40 [55kW] [75HP] [4cyl.] Numer seryjny - 068754 Vehicle identification no. - Wvwzzz9nz2y068754 Model designation - Polo 16v Date of production - 05.03.2002 Model year - 2002 Sales type - 9n12g4 Engine code - BBY Transmission code - FVT Axle drive - 5S Interior trim code - BE Roof color - Z4 Exterior color/paint code - Z4/c9z Activated carbon canister - Activated carbon canister Additional body covers, side - Without additional body covers, but withadd. paint Additional child seat anchors - Without additional child seat anchor Additional dust seals - Without additional seals outside Additional tires (winter tires) - Without additional tires Additional warning lights - Additional warning lights (door area)front Air bag - Driver s and front passenger air bagwith front passenger air bagdeactivation Air cleaner (engine) - Standard air cleaner Antennas - Roof antenna Anti-theft protection system - Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn Antifreeze - Antifreeze up to -25 degree celsiustolerance up to -30 degree c Automatic transmission indicator light - Without automatic transmissionindicator light Backrest release - Backrest release for front seat(s) Batteries - Battery 280 a (60 ah) Body measures - Additional body measures Body style - Hatchback Body treatment - Special body treatment Brackets - Bracket for first aid kit and warningtriangle Brake pad wear indicator - Brake pad wear indicator Brake type, front - Front disc brakes with integratedadapter Brake type, rear - Disc brakes, rear Braking systems - Anti-lock brake system (abs) Breakaway interior mirror - Dipping breakaway interior rear viewmirror Bumper - Body-colored bumpers Cd rom/dvd/sd card - Without cd/dvd for navigation Cd changer/cd player - Without cd changer/cd player Carrier frequency for radio remote control - Carrier frequency 433.92 mhz-434.42 mhz Center high-mounted stop light - Center high-mounted stop light Center rear seat belts - 3-point seat belt for center rear seat Center sun visor - Center sun visor Climatic zones - Standard climatic zones Component part sets with country-specific design requirements - Component parts set withoutcountry-specific design requirement Components with special surface appearance - Body-colored exterior mirror housingsand various add-on parts Cruise control - Without cruise control system (ccs) Cruise control warning and speed limit system - Without cruise control warning system Cup holder - Cup holder Dashboard - Standard dashboard Door and lid locking system - Radio remote controlled central lockingoperated from inside and safe securing Door and side trim panels - Door and side trim panel in foam filmand woven fabric Doors - 2 doors Drive layout - Front wheel drive Emission standard - Emission standard eu4 Engine specifications - 4-cyl. gasoline engine 1.4 l/55 kw 16vmulti-point injectionbase engine is t1q/t99/tk0 Equipment levels - Sports comfort equipment Exhaust tailpipe - Rear exhaust tailpipe (standard) Exterior mirror setting - Exterior mirrors electricallyadjustable/heated Exterior noise suppression measures - Additional exterior noise suppression Fire extinguisher - Without fire extinguisher First aid kit / warning triangle - Without first aid kit and warningtriangle Floor mats - Front and rear floor mats Frame forestructure - Long frame forestructure Fresh air intake for passenger compartment (with particulate filter) - Dust and pollen filter Front fog light/additional headlight - Integrated front fog light Front license plate bracket - License plate bracket front (large) Front stabilizer - Front stabilizer Front underbody guard - Without additional front underbody guard Fuel filler cap/door, locking option - Fuel filler cap Fuel quantity for initial filling - Initial standard fuel filling Fuel systems - Fuel sys. for carburetor gasoline eng.w/ injector system without fuel return Fuel tank treatment - Fuel tank without special materialtreatment Gearshift boot/cover - Leatherette gearshift boot Gearshift knob/handle - Plastic gearshift knob/handle General operating permit, alterations - Operating permit, alteration Generators - Alternator 90a Glove compartment - Standard glove compartment Grab handles at roof frame - Folding grab handles at roof framesoft fold-away Hand brake lever handle - Plastic hand brake lever handle Headlight - Halogen headlightfor driving on the right Headlight activation - Without special headlightactivation Headlight washer system - Without headlight washer system Headlight-range adjustment - Headlight-range adjustment Headrests - Articulated and height-adjustableheadrests for front seats Heat accumulator system/additional heater - without heat accumulator/auxiliary heating Heated door lock cylinder - Without heated door lock cylinder Heated rear window - Heated rear window Heated washer nozzles - Without heated washer nozzles Heating and air conditioning system - Climatic air-conditioning system(semi-automatic) Horns - Two-tone horn Identification plates - Special identification plate for ecfor m1 passenger vehicle Ignition/starter switch locking system - Without ignition/starter switch lockingsystem Insert for the filling up of unleaded fuel/fuel type - Filler neck module 1 with insert Inserts - Without decorative inserts Installation differentiation for vehicle components - Installation differentiation fortransmission mq 200vehicle components Interior light in driver compartment - Interior light with door pillar switches Key for locking system - Key for locking systemwith remote control Left exterior mirror - Left exterior mirror aspherical Left vanity mirror - Left vanity mirror, illuminated Lock operation for tailgate/trunk lid - Tailgate/trunk lid unlockingfrom outside Lockable wheel bolts - Standard wheel bolts Luggage compartment cover - Foldable trunk cover Luggage compartment floor covering - Tufted trunk floor covering Luggage compartment lighting - Luggage compartment lighting Luggage compartment lining - Full fleece trunk lining Luggage net/pocket on backrest(s) - Without luggage nets/pocketson backrests Manufacturing sequence differentiation - Pamplona manufacturing sequence Mass damper for steering wheels - Without mass damper for steering wheel Molding roof liner - Comfort molding roof liner unsplit Multi-function display/trip computer - Multi-function display/on-board computer Nameplate set - Nameplate set 1.4 Navigation device - Without navigation device Outer rear seat belts - 3-point seat belts, outer rear with ecelabel Owner s manuals - Information kit in french Paint preservative/transit coating - Without surface protection, withadditional transit coating Park distance control - Without park distance control Partition - Without partition Pillar lining - Exterior pillar liningdesign 2 Platform group class - Platform group class 1 Platform module floor pan, rear - Rear floor panel module, type 3 Protective side molding - Body-colored protective side molding Radiator grille - Radiator grille Radios - Without radio Rear axle - Heavy-duty rear axle Rear fog light - Rear fog light for driving on the right Rear headrests - Three rear headrests Rear license plate bracket - License plate bracket rear (ece) Rear seats - Rear seat bench/backrest, split folding Rear window wiper and washer system - Rear window wiper and washer systemwith intermittent control Restraint systems, front - 3-point seat belts with electrictensioner and height adjustment, front Right exterior mirror - Right exterior mirror convex Right vanity mirror - Right vanity mirror illuminated Roof insert/convertible top - Without roof insert (standard roof) Seat adjustment - Manual height adjustment for front seats Seat belt check - Without seat belt reminder Seat covering - Fabric seat coverings Seat heater - Without seat heater Shock absorption, chassis, front - Front shock absorption Shock absorption, chassis, rear - Rear shock absorption Side air bag - Side air bag front Side and rear windows - Side and rear windows in heat-insulatingglass Side lights - Side turn signal lights (white) Smoking/non-smoking package - Smoking package, ashtray front Socket - Without socket Spare wheel/breakdown set - Steel spare wheel with originalequipment tires Speaker installation - 4 speakers (passive) Special editions - No special edition Special labels/plates - Labels/plates in french Speedometer cable and seal - Speedometer sensor without seal(electronic speedometer sensor) Steering - Power steeringelectro-hydraulic Steering column systems - Axial and vertical adjustable steeringcolumn Steering system arrangement - Left-hand drive vehicle Steering wheels - Steering wheel for air bag system Sticker (customized or special edition) - Without stickers and badges Taillight assemblies - Standard taillight assemblies (type 2) Telephone/telematics - without car phone preparation/installation Tires - Tires 185/60 r14 t Tool kit and jack - Tool kit and aluminum jack Trailer hitch - Without trailer hitch Transmission specifications - 5-speed manual transmission Transmission types/gearshift mechanisms - Cable gearshift Trunk sill protection - Plastic trunk sill protection Type approval countries/countries with special requirements - Type approval france Vehicle class differentiation units/platform components - Vehicle class differentiation 6q0-for build status europe Vehicle specifications - No special purpose vehicle, standardequipment Vehicle type - Vehicle with standard production scope Washer fluid level indicator - Without washer fluid level indicator Weight category front axle - Suspension range 04installation control only, norequirement forecast Weight category rear axle - Weight range 1installation control only, norequirement forecast Wheel covers - Full wheel covers Wheels - Steel wheels 6j x 14offset 43 (5-hole) Window regulator - Power windows Windshield glass type - Windshield in heat-insulating glass Windshield wiper arms/blades - Windshield wiper arms/bladeswith spoiler wiper blade Windshield wiper intermittent control - Windshield wiper intermittent controlwith potentiometer (four speeds) Air duct, front area - Air duct, standard Base engine - 4-cylinder gasoline engine 1.4 lunit 036.d (aluminum) Child seats - Without child seat Chrome work package - Chrome work package Drawers under front seats - Drawers under front seats Electronic map cooling system - Without electronic map cooling system Foot area lining - Foot area lining without cover Front seats - Comfort sports seats, front Instrument inserts - Instrument insert with tachometerclock and km/h speedometer Service interval prolongation - Service interval prolongation Tire suppliers - Tires with o specification of tire brand |
