Numer VIN - WVWZZZ50ZPK002191
Region - Germany
Fabryka / Producent - Osnabruck
Marka - Volkswagen
Model - Corrado\nRok - 1992
Silnik - 2.00 [100kW] [136HP] [4cyl.]
Numer seryjny - 002191
Vehicle identification no. - Wvwzzz50zpk002191
Model designation - Corrado
Date of production - 02.09.1992
Model year - 1993
Sales type - 509034
Engine code - 9A
Interior trim code - RW
Roof color - J9
Exterior color / paint code - J9 / c5u
Activated carbon canister - Activated carbon canister
Additional dust seals - Without additional seals outside
Additional instruments - Without additional instruments/switches
Anti-theft protection system - Without anti-theft protection system
Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c
Automatic transmission indicator light - Without automatic transmission indicator light
Base engine - 4-cylinder gasoline engine 2.0 l unit 051.3
Batteries - Battery 280 a (60 ah)
Body style - Coupe
Brackets - Without bracket for first aid kit and warning triangle
Brake pad wear indicator - Without brake pad wear indicator
Braking systems - Anti-lock brake system (abs)
Cassette and cd storage unit - Without cassette and cd storage unit
Catalytic converter control - without catalytic converter warning light
Center high-mounted stop light - Without center high-mounted stop light
Child seat anchor, front - Child seat anchor, front left (isofix)
Climatic zones - Standard climatic zones
Component part sets with country-specific design requirements - Component parts set, complying with vehicle type for italy, various parts
Components with special surface appearance - Components without special surface appearance
Cruise control - Without cruise control system (ccs)
Decorative films / emblems - Without decorative films / emblems
Door and lid locking system - Central locking system
Door and side trim panels - Door and side trim panel in foam film and woven fabric with decorative stripes
Electric safety package - without additional electric safety package
Engine specifications - 4-cyl. gasoline engine 2.0 l/100 kw 16v closed-loop catalytic converter base engine is t5j
Equipment levels - Comfort sports equipment
Exterior noise suppression measures - Without additional exterior noise suppression
First aid kit / warning triangle - Without first aid kit and warning triangle
Front fog light/additional headlight - Integrated front fog light
Front license plate carrier - Without license plate carrier front
Front seats - Sports front seats
Front spoiler - Front spoiler
Fuel quantity for initial filling - Initial standard fuel filling
Fuel tank vent line - Fuel tank vent line with gravity valve and pvc breather hose
Gearshift boot/cover - Leatherette gearshift boot
Gearshift knob/handle - Plastic gearshift knob/handle
Generators - Alternator 90a
Hand brake lever handle - Plastic hand brake lever handle
Headlight - Halogen headlight for driving on the right
Headlight activation - Without special headlight activation mode but with coming and leaving home function
Headlight washer system - Without headlight washer system
Headlight-range adjustment - Without headlight-range adjustment
Heated washer nozzles - Heated washer nozzles, front
Heating and air conditioning system - Manually controlled air conditioning
Identification plates - Special identification plate (italy)
Ignition/starter switch locking system - Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type - Insert for the filling up of unleaded fuel
Instrument inserts - Instrument insert with tachometer clock and km/h speedometer
Left exterior mirror - Left exterior mirror flat, electrically adjustable and heated
Lockable wheel bolts - Standard wheel bolts
Malfunction display - Without additional malfunction display
Outer rear seat belts - 3-point seat belts, outer rear with ece label
Paint preservative/transit coating - Paint preservative (wax)
Park distance control - Park distance control, front and rear with rear view camera
Protective side molding - Protective side molding
Radiator grille - Radiator grille
Radios - Without radio
Rear fog light - Rear fog light for driving on the right
Rear license plate carrier - License plate carrier rear (ece)
Rear seats - Rear seat bench unsplit, backrest split folding (three pieces) with center armrest
Restraint systems, front - 3-point seat belts, front
Right exterior mirror - Right exterior mirror convex, electrically adjustable and heated
Roof insert/convertible top - Electric sliding/pop-up sunroof
Seat adjustment - Manual height adjustment for front seats
Seat belt check - Without seat belt reminder
Seat covering - Seat coverings in flat woven fabric
Seat heater - Without seat heater
Shock absorption/suspension, chassis - Standard suspension/shock absorption
Side and rear windows - Side and rear windows in heat-insulating glass
Side lights - Side turn signal lights
Spare wheel/breakdown set - Space-saving spare wheel
Speaker installation - 6 speakers (passive)
Special editions - No special edition
Speedometer cable and seal - Speedometer sensor without seal (electronic speedometer sensor)
Steering column systems - Height adjustable steering column
Steering system arrangement - Left-hand drive vehicle
Steering wheels - Sports steering wheel (hollow rim)
Telephone/telematics - without car phone preparation/installation
Tire suppliers - Tires with o specification of tire brand
Tires - Tires 195/50 r15 v
Towing eyes - One towing eye each side, front and rear
Trailer hitch - Without trailer hitch
Transmission specifications - 5-speed manual transmission
Vehicle class differentiation units/platform components - Vehicle class differentiation -4v0
Wheels - Steel wheels 7.50 x 20 (eight-hole)
Window regulator - Power windows
Windshield glass type - Windshield in heat-insulating glass
