Witam. Bardzo proszę o ocenę tego auta, rozkodowanie vin i sprawdzenie realnego przebiegu i historii jeśli to możliwe.
otomoto.pl/show?id=C27004135 vin: WVWZZZ9NZ2D020210 Sprawdź ten VIN na autobaza.pl ▸ Z góry wielkie dzięki. |
Auto w tej cenie bez klimy jest trudno sprzedawalne- i bym sie nad tym zastanowił, ustal co to za silnik ( albo wrzuc jego foty ), jak AUA to pewnie nie raz zamarzł w zimie
aua to nawet slychac jak mowi ze go boli
Numer VIN - WVWZZZ9NZ2D020210 Region - Germany Fabryka / Producent - Bratislava Marka - Volkswagen Model - Polo 16v\nRok - 2002 Silnik - 1.40 [55kW] [75HP] [4cyl.] Numer seryjny - 020210 Vehicle identification no. - Wvwzzz9nz2d020210 Model designation - Polo 16v Date of production - 10.01.2002 Model year - 2002 Sales type - 9n10g4 Engine code - AUA Transmission code - FCU Axle drive - 5S Interior trim code - AU Roof color - 8E Exterior color / paint code - 8e / a7w Activated carbon canister - Activated carbon canister Additional body covers, side - Without additional side body covers (stone guard) Additional child seat anchors - Without additional child seat anchor Additional dust seals - Without additional seals outside Additional tires (winter tires) - Without additional tires Additional warning lights - Without additional warning lights Air bag - Air bag for driver and front seat passenger Air cleaner (engine) - Standard air cleaner Air duct, front area - Air duct, standard Antennas - Roof antenna Anti-theft protection system - Electronic vehicle immobilization device Antifreeze - Antifreeze up to -25 degree celsius tolerance up to -30 degree c Automatic transmission indicator light - Without automatic transmission indicator light Backrest release - Backrest release for front seat(s) Base engine - 4-cylinder gasoline engine 1.4 l unit 036.d (aluminum) Batteries - Battery 220 a (44 ah) Body measures - Additional body measures Body style - Hatchback Body treatment - Special body treatment Brackets - Bracket for first aid kit Brake pad wear indicator - Brake pad wear indicator Brake type, front - Front disc brakes with integrated adapter Brake type, rear - Drum brakes, rear Braking systems - Power brake Breakaway interior mirror - Dipping breakaway interior rear view mirror Bumper - Painted bumpers Cd rom/dvd/sd card - Without cd/dvd for navigation Cd changer/cd player - Without cd changer/cd player Carrier frequency for radio remote control - Without carrier frequency Center high-mounted stop light - Center high-mounted stop light Center rear seat belts - Static lap belt, center rear Center sun visor - Without center sun visor Chrome work package - Without aluminum/chrome work package Climatic zones - Standard climatic zones Component part sets with country-specific design requirements - Component parts set without country-specific design requirement Components with special surface appearance - Components without special surface appearance Control number (no pr-family) - Police kosovo Cruise control - Without cruise control system (ccs) Cruise control warning and speed limit system - Without cruise control warning system Cup holder - Without cup holder Dashboard - Standard dashboard Door and lid locking system - Central locking system Door and side trim panels - Door and side trim panel in woven fabric Doors - 2 doors Drawers under front seats - Without drawers under front seats Drive layout - Front wheel drive Electronic map cooling system - Without electronic map cooling system Emission standard - Emission standard eu4 Engine specifications - 4-cyl. gasoline engine 1.4 l/55 kw 16v multi-point injection base engine is t1q/t99/tk0 Equipment levels - Comfort equipment Exhaust tailpipe - Rear exhaust tailpipe (standard) Exterior mirror setting - Exterior mirrors electrically adjustable/heated Exterior noise suppression measures - Additional exterior noise suppression Fire extinguisher - Without fire extinguisher First aid kit / warning triangle - Without first aid kit and warning triangle Floor mats - Without floor mats Foot area lining - Foot area lining without cover Frame forestructure - Long frame forestructure Fresh air intake for passenger compartment (with particulate filter) - Dust and pollen filter Front fog light/additional headlight - Without front fog light Front license plate carrier - License plate carrier front (large) Front stabilizer - Front stabilizer Front underbody guard - Without additional front underbody guard Fuel filler cap/door, locking option - Fuel filler cap Fuel quantity for initial filling - Initial standard fuel filling Fuel systems - Fuel sys. for carburetor gasoline eng. with injector system without fuel return Fuel tank treatment - Fuel tank without special material treatment Gearshift boot/cover - Leatherette gearshift boot Gearshift knob/handle - Plastic gearshift knob/handle General operating permit, alterations - Operating permit, alteration Generators - Alternator 70 a Glove compartment - Standard glove compartment Grab handles at roof frame - Folding grab handles at roof frame Hand brake lever handle - Plastic hand brake lever handle Headlight - Halogen headlight for driving on the right Headlight activation - Without special headlight activation Headlight washer system - Without headlight washer system Headlight-range adjustment - Headlight-range adjustment Headrests - Articulated and height-adjustable headrests for front seats Heat accumulator system/additional heater - without heat accumulator/auxiliary heating Heated door lock cylinder - Without heated door lock cylinder Heated rear window - Heated rear window Heated washer nozzles - Without heated washer nozzles Heating and air conditioning system - Manually controlled heating system Horns - High-sounding horn Identification plates - Special identification plate (poland) Ignition/starter switch locking system - Without ignition/starter switch locking system Insert for the filling up of unleaded fuel/fuel type - Filler neck module 1 with insert Inserts - Without decorative inserts Installation differentiation for vehicle components - Installation differentiation for transmission mq 200 vehicle components Instrument inserts - Instrument insert with tachometer clock and km/h speedometer Interior light in driver compartment - Interior light with door pillar switches Key for locking system - Key with light Left exterior mirror - Left exterior mirror aspherical Left vanity mirror - Left vanity mirror with cover Lock operation for tailgate/trunk lid - Tailgate/trunk lid unlocking frnm outsidd Locj`bld vheel bolts - Standard wheel bolts Luggage compartment cover - Foldable trunk cover Luggage compartment floor covering - Tufted trunk floor covering Luggage compartment lighting - Without trunk lighting Luggage compartment lining - Full fleece trunk lining Luggage net/pocket on backrest(s) - Without luggage nets/pockets on backrests Manufacturing sequence differentiation - Bratislava manufacturing sequence Mass damper for steering wheels - Without mass damper for steering wheel Molding roof liner - Unsplit molding roof liner Multi-function display/trip computer - Without multi-function display/ on-board computer Nameplate set - Nameplate set 1.4 Navigation device - Without navigation device Outer rear seat belts - 3-point seat belts, outer rear with ece label Owner s manuals - Information kit in german Paint preservative/transit coating - Without surface protection, with additional transit coating Park distance control - Without park distance control Partition - Without partition Pillar lining - Exterior pillar lining Platform group class - Platform group class 1 Platform module floor pan, rear - Rear floor panel module, type 3 Protective side molding - Protective side molding Radiator grille - Radiator grille Radios - Without radio Rear axle - Heavy-duty rear axle Rear fog light - Rear fog light for driving on the right Rear headrests - Rear headrests Rear license plate carrier - License plate carrier rear (ece) Rear seats - Rear seat bench/backrest, completely folding Rear window wiper and washer system - Rear window wiper and washer system with intermittent control Restraint systems, front - 3-point seat belts with electric tensioner and height adjustment, front Right exterior mirror - Right exterior mirror convex Right vanity mirror - Right vanity mirror with cover Roof insert/convertible top - Without roof insert (standard roof) Seat adjustment - Without special seat adjustment Seat belt check - Without seat belt reminder Seat covering - Fabric seat covering Seat heater - Without seat heater Service interval prolongation - Service interval prolongation Shock absorption, chassis, front - Front shock absorption Shock absorption, chassis, rear - Rear shock absorption Side air bag - Side air bag front Side and rear windows - Side and rear windows in heat-insulating glass Side lights - Side turn signal lights (white) Smoking/non-smoking package - Smoking package, ashtray front Socket - Without socket Spare wheel/breakdown set - Steel spare wheel with original equipment tires Speaker installation - Without speakers Special editions - No special edition Special labels/plates - Without special labels/plates Speedometer cable and seal - Speedometer sensor without seal (electronic speedometer sensor) Steering - Power steering electro-hydraulic Steering column systems - Axial and vertical adjustable steering column Steering system arrangement - Left-hand drive vehicle Steering wheels - Steering wheel for air bag system Sticker (customized or special edition) - Without stickers and badges Taillight assemblies - Standard taillight assemblies (type 2) Telephone/telematics - without car phone preparation/installation Tire suppliers - Tires with o specification of tire brand Tires - Tires 165/70 r14 81t Tool kit and jack - Tool kit and aluminum jack Trailer hitch - Without trailer hitch Transmission specifications - 5-speed manual transmission Transmission types/gearshift mechanisms - Cable gearshift Trunk sill protection - Plastic trunk sill protection Type approval countries/countries with special requirements - Type approval poland Vehicle class differentiation units/platform components - Vehicle class differentiation 6q0- for build status europe Vehicle specifications - No special purpose vehicle, standard equipment Vehicle type - Vehicle with standard production scope Washer fluid level indicator - Without washer fluid level indicator Weight category front axle - Suspension range 02 installation control only, no requirement forecast Weight category rear axle - Weight range 1 installation control only, no requirement forecast Wheel covers - Full wheel covers Wheels - Steel wheels 5j x 14 Window regulator - Power windows Windshield glass type - Windshield in heat-insulating glass Windshield wiper arms/blades - Windshield wiper arms/blades with spoiler wiper blade Windshield wiper intermittent control/ light/rain sensor - Windshield wiper intermittent control with potentiometer (four speeds) Child seats - Without child seat Front seats - Standard front seats |
To mi wystarczy, właśnie czytałem o tym silniku i juz wiem ze trzeba go unikać. Dzięki za wszystko.
ale co za porazka ;D ja sie dowiedzialem teraz o tym.. masakra
abc1234xx napisał:
ale co za porazka ;D ja sie dowiedzialem teraz o tym.. masakra BBY jest ok, ale do 05.2002r 1.4 16V- nie ważne jakie oznaczenie silnika i jaki model grupy vag - nie na polskie warunki |
A historii Panowie i tak nie ma
