Jak pisałeś wcześniej: 94 - Taxi equipment
Numer VIN - WVGZZZ1TZ5W060110
Region - Germany
Fabryka / Producent - Wolfsburg
Marka - Volkswagen
Model - Touran 1.9\nRok - 2004
Silnik - 1.90 [77kW] [105HP] [4cyl.]
Numer seryjny - 060110
Vehicle identification no. - Data are estimates for wvgzzz1tz5w060110
Model designation - Touran 1,9
Model - 1,9
Date of production - 09.2004
Model year - 2005
Engine code - BKC
0 - 3 separate seats
1 - 3-point seat belt for center rear seat
2 - 4 speakers (passive)
3 - 4-cyl. turbo diesel engine 1.9 l/77 kw tdi with pump-jet injection system base engine is t71/tg0/td0/t5x
4 - 4-cylinder diesel engine 1.9 l unit 03g.1
5 - 4-link rear suspension
6 - 6-speed automatic transmission
7 - Additional reflectors (door area)
8 - Additional winter tires
9 - Air duct, type 1
10 - Alternator 140 a
11 - Antenna for am/fm reception, diversity
12 - Antifreeze up to -25 degree celsius tolerance up to -30 degree c
13 - Articulated and height-adjustable headrests for front seats
14 - Automatic transmission indicator light
15 - Auxiliary heater
16 - Battery 380 a (72 ah)
17 - Breakdown set
18 - Carrier frequency 433.92 mhz-434.42 mhz
19 - Climatronic with impact pressure control free of cfc
20 - Comfort equipment
21 - Comfort seat, front left
22 - Comfort seat, front right
23 - Cooled fuel system for diesel engine
24 - Country group central europe f, b, nl, l, ch, a
25 - Cup holder
26 - Decorative inserts
27 - Dipping breakaway interior rear view mirror
28 - Disc brakes, front (geomet d)
29 - Disc brakes, rear
30 - Door and side trim panel in foam film, insert in leatherette
31 - Driver s and front passenger air bag with front passenger air bag deactivation
32 - Electronic stabilization program (esp)
33 - Electronic vehicle immobilization device
34 - Emission standard eu3, diesel with eobd
35 - Exterior mirrors electrically adjustable, separately heated
36 - Front and rear floor mats
37 - Front shock absorption
38 - Front stabilizer
39 - Front wheel drive
40 - Full wheel covers
41 - Headlight washer system
42 - Headlight-range adjustment
43 - Heat-insulating glass (green)
44 - Heated washer nozzles, front
45 - Ignition/starter switch locking system
46 - Information kit in german
47 - Initial standard fuel filling
48 - Installation differentiation for transmission dq250 vehicle components
49 - Instrument insert, km/h speedometer
50 - Integrated front fog light
51 - Labels/plates in german, french, and dutch
52 - Leatherette seat covering
53 - Left exterior mirror aspherical
54 - Left-hand drive vehicle
55 - License plate bracket front (large)
56 - License plate bracket rear (ece)
57 - Local interference suppression for fm/amradio reception
58 - MPV
59 - Manual height adjustment for front seats
60 - Manually adjustable lumbar support in front seats
61 - Mass damper for steering wheel, 26.5hz
62 - Nameplate set tdi
63 - No special edition
64 - Not hot country
65 - Operating permit, alteration
66 - Plastic gearshift knob/handle
67 - Plastic hand brake lever handle
68 - Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
69 - Protective side molding
70 - Radiator grille
71 - Radio preparation
72 - Radio remote controlled central locking operated from inside and safe securing
73 - Radio with cd player
74 - Rear fog light for driving on the right
75 - Rear shock absorption, basic design 1
76 - Right exterior mirror convex
77 - Safety headrest system
78 - Seat heater for front seats separately controlled
79 - Selector lever cover
80 - Service interval prolongation
81 - Side air bag front with curtain air bag
82 - Smoking package, ashtray front and rear
83 - Special identification plate for ec for m1 passenger vehicle
84 - Speed-related variable steering assist (servotronic)
85 - Standard design
86 - Standard glove compartment
87 - Standard wheel bolts
88 - Standard windshield wiper arms/blades
89 - Steel wheels 6j x 15
90 - Steering wheel for air bag system
91 - Suspension range 24 installation control only, no requirement forecast
92 - Tailgate/trunk lid release from inside (electrically)
93 - Taillight assemblies, standard design
94 - Taxi equipment
95 - Tires 195/65 r15 95h xl
96 - Transit coating film with additional transport protection measures
97 - Twin-headlight for driving on the right,with integrated high beam
98 - Two-tone horn
99 - Vehicle class differentiation 1t0
100 - Warning triangle
101 - Washer fluid level indicator
102 - Weight range 2 installation control only, no requirement forecast
103 - Windshield in heat-insulating glass
104 - Windshield wiper intermittent control with potentiometer (four speeds)
