Witam wszystkich serdecznie.
Bardzo proszę o pomoc w ocenie tego Auta, ewentualnie o więcej informacji jeśli ktoś był by na tyle uprzejmy. nr VIN: wauzzz8lzva059588 link do aukcji: allegro.pl/piekne-audi-a3-1-6-z-niemiec-...rto-i2066573245.html |
Kolego nie jestem fachowcem od Audi , ale na pierwszy rzut oka znów rzuca mi się wartość przebiegu
Patrząc na zdjęcia od razu zapachniało mi cytrynowym PLAK'iem |
Dekodowanie numeru VIN WAUZZZ8LZVA059588 Sprawdź ten VIN na autobaza.pl ▸ na www.automo.pl
Nazwa dekodera: Dekoder VIN dla Grupy VAG #2 Vehicle Identification No.: WAUZZZ8LZVA059588 Date of production: 25.01.1997 Model year: 1997 Sales type: 8L1044 Engine code: AEH Engine parameters: 4-cylinder, 74 kW (100 p.s.), 1.6 l Transmission code: DLP Interior trim code: DJ Roof color: Q5 Exterior color / paint code: Q5 / Z5L 1E1: Activated carbon canister 3B0: Without additional child seat anchor 2WA: Without additional tires 4UE: Air bag for driver and front seat passenger 7AA: Electronic vehicle immobilization device 1C1: Antifreeze up to -25 degree celsius tolerance up to -30 degree C 3H6: Backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat J1L: Battery 280 A (60 Ah) K8G: Hatchback 1LQ: Front disc brakes with integrated adapter 1KK: Disc brakes, rear 1AC: Anti-lock brake system (ABS) 7A0: Without CD changer/CD player 5D1: Carrier frequency 433.92 MHz-434.42 Mhz 4W0: Without cassette and CD storage unit 8KA: W/o catalytic converter warning light 2D1: Complete cd enhancing underbody panel 6E3: Front center armrest 3C1: Static lap belt, center rear B0A: Component parts set without country-specific design requirement 8T0: Without cruise control system (CCS) 2A5: Delivery equipment (transit coating) with thin seat cover 4K1: Radio remote controlled central locking 0A1: 2 doors 1X0: Front wheel drive 8Z5: Not hot country M63: 4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection and MVEG 2 base engine is T6H A8S: Standard equipment 6XC: Exterior mirrors: electrically adjustable 2B1: Additional exterior noise suppression 1T3: First aid kit with warning triangle 0TD: Front and rear floor mats 6W5: Front license plate bracket 0AG: Front stabilizer 1SA: Without additional engine guard 1Z0: Initial standard fuel filling 0F2: Fuel system for carburetor gasoline engine 2LB: Fuel tank with special material treatment 6R2: Leather gearshift boot 6Q2: Leather gearshift knob/handle C01: Operating permit, alteration 8GL: Alternator 120 A FA0: Control of standard production 8JQ: Twin headlight for driving on the right,with integrated high beam 8K0: Without special headlight activation 8X0: Without headlight washer system 8Q1: Headlight-range adjustment 7E0: W/o heat accumulator/auxiliary heating 9X4: Without heated door lock cylinder with micro switch 9T1: Heated washer nozzles, front 9AK: Climatronic with impact pressure control free of cfc 1EX: Special identification plate for EC for M1 passenger vehicle 0RA: Without ignition/starter switch locking system 2G9: Filler neck module 2 with insert 7CA: Without label for radio remote control 5SL: Left exterior mirror: aspherical 4SD: Left vanity mirror, illuminated 1PC: Wheel bolts with anti-theft protection (unlockable) 7P0: Without lumbar support in seat backrests 6N0: Without mud flaps 9Q0: Without multi-function display/ on-board computer 9Y0: Without outdoor temperature gage 0VC: Information kit in German 5K1: Paint preservative (wax) 4P0: Rear floor panel module, type 1 9D0: Without preparation for two-way radio installation 1H0: Without proportioning valve 8AD: Radio "gamma" 8S5: Two reading lights front 8TC: Rear fog light for driving on the right 3Q1: Rear headrests 3NC: Rear seat bench/backrest, split folding 0BB: Rear stabilizer 6V1: Rear trim panel (ECE) 8M1: Rear window wiper and washer system with intermittent control 5RQ: Right exterior mirror: convex 4TD: Right vanity mirror illuminated 3FA: Without roof insert (standard roof) 0LW: Special plates/stickers/ safety certificates for Germany 3L3: Manual height adjustment for front seats 9P0: Without seat belt reminder N7H: Alcantara/fabric seat covering 4A0: Without seat heater 1GE: Front shock absorption, basic design 4 1JJ: Rear shock absorption, basic design 4X1: Side air bag front 1G3: Alloy spare wheel with original equipment tires 9VD: Speaker (active) E0A: No special edition 0ST: Labels/plates in German and French 8CC: Speedometer sensor without seal (electronic speedometer sensor) 7L0: Without inertia benefit system/ deceleration fuel cut-off/idle stop valve 1N1: Power steering 2C5: Axial and vertical adjustable steering column L0L: Left-hand drive vehicle 1MR: Leather steering wheel 9W0: W/o car phone preparation/installation H6S: Tires 195/65 R15 V 1D0: Without trailer hitch 1WA: Transmission shafts w/ 90 mm in diameter 1YA: Without transmission shafts f. rear axle G0C: 5-speed manual transmission 0G3: Gearshift linkage B99: Type approval EC 2Z1: Type sign at rear and "Quattro" nameplates respectively 0CJ: Vehicle class differentiation 8L0 F0A: No special purpose vehicle, standard equipment 8W0: Without washer fluid level indicator J02: Suspension range 02 0YZ: Without determination of weight categoryfor rear axle C6X: Cast alloy wheels 6J x 15 twelve-spoke style, offset 38 4R1: Power windows 4GH: Windshield in heat-insulating glass with sunshield Q1A: Standard front seats T6H: 4-cylinder gasoline engine 1.6 L unit 06A.F (aluminum ) S62: Reduced price U1A: Instrument insert with km/h speedometer,clock, tachometer and trip odometer Dekodowanie pochodzi z www.automo.pl |
Dziękuje za odpowiedzi, porównałem kody wyposażenia do tego co faktycznie w aucie jest i wszystko się zgadza, niema nic więcej, ani nic mniej, drobna niejasność z rokiem produkcji w porównaniu do tego co podaje właściciel.
Stan zużycia poszczególnych elementów w aucie nie budzi zastrzeżeń jeśli chodzi o przebieg auta, domyślam się, że nie jest w 100% oryginalny, ale też nie sądze, aby był dużo większy, zużycie pedałów oraz kierownicy w porównaniu do Octavii która jest u mnie w rodzinie z realnym przebiegiem 206kkm zgadza się z tym co jest w audi |
ShaDe napisał:
drobna niejasność z rokiem produkcji w porównaniu do tego co podaje właściciel. autu blizej do 96 niz 98 roku kolego a jak wygladala kiera na zywo? na zdjeciach jest troche zmasakrowana |
zużycie pedałów oraz kierownicy w porównaniu do Octavii która jest u mnie w rodzinie z realnym przebiegiem 206kkm zgadza się z tym co jest w audi Martwi mnie wiek tego auta, ale w końcu powinno się kupować auto nie na wiek czy przebieg, jutro jadę drugi raz, podejdę do tego już z mniejszą dawką emocji, obejrzę auto dokładniej, pojadę na stacje diagnostyczną, mimo wszystko bardzo mi się podoba i poniekąd jest to wymarzony samochód, ze wszystkim co bym chciał aby to auto miało, dodam jeszcze, że w aucie jest zamontowany system BOSE wraz z fabrycznym subwooferem o czym nie jest wspomniane w aukcji |
