TEMAT: Prośba o pomoc AUDI TT
Prośba o pomoc AUDI TT 2012/03/03 13:04 #23063
  • pulpextractor
  • pulpextractor Avatar
Proszę o pomoc w określeniu historii auta. Wiem że niedawno sprowadzone z Włoch,więc tym bardziej trzeba być ostrożnym:)
nr. VIN : TRUZZZ8N041008204 Sprawdź ten VIN na autobaza.pl ▸
Odp: Prośba o pomoc AUDI TT 2012/03/04 16:17 #23128
Dekodowanie numeru VIN TRUZZZ8N041008204 na www.automo.pl
Vehicle Identification No.: TRUZZZ8N041008204
Model Designation: audi tt coupe 1.8 qu.
Model: ATT
Date of production: 14.08.2003
Model year: 2004
Sales type: 8N3069
Engine code: BAM
Transmission code: FZL
Axle drive: 6S
Interior trim code: JN
Roof color: 4Z
Exterior color/Paint Code: 4Z/Z9W
Activated carbon canister: [1E1] : Activated carbon canister
Additional child seat anchors: [3B0] : Without additional child seat anchor
Air bag: [4UF] : Driver's and front passenger air bagwith front passenger air bagdeactivation
Anti-theft protection system: [7AH] : Electronic vehicle immobilization devicewith alarm system, passenger compartmentcontrol and backup horn
Auxiliary heating: [9M0] : Without auxiliary/parking heater
Backrest release: [3H5] : Comfort exit feature for right frontseat
Base engine: [T6B] : 4-cylinder gasoline engine 1.8 Lunit 06A.G
Batteries: [J1L] : Battery 280 A (60 Ah)
Body measures: [5C7] : Additional body measures
Body style: [K8C] : Coupe
Brake pad wear indicator: [9U1] : Brake pad wear indicator
Brake type, front: [1LT] : Disc brakes, front
Brake type, rear: [1KF] : Disc brakes, rear
Braking systems: [1AT] : Electronic stabilization program (ESP)
Breakaway interior mirror: [4L2] : Dipping breakaway interior rear viewmirror
Bumper systems: [2K1] : Reinforced bumpers
CD ROM/DVD/SD card: [7QA] : Without CD/DVD for navigation
CD changer/CD player: [7A2] : CD changer
Cd enhancing underbody panel: [2D1] : Complete cd enhancing underbody panel
Center armrest: [6E0] : Without center armrest front
Child seat anchor, front: [3G0] : Without child seat anchor front (ISOFIX)
Components with special surface appearance: [6FB] : Body-colored exterior mirror housings
Control number (no PR-Family): [SA7] : Inventory control model 2
Cruise control: [8T0] : Without cruise control system (CCS)
Cup holder: [4M0] : Without cup holder
Customized installation: [FC1] : Customized installation
Door and lid locking system: [4K4] : Radio remote controlled central locking
Doors: [0A1] : 2 doors
Drive layout: [1X1] : Four wheel drive
Emission standard: [0GE] : Emission standard EU3
Engine specifications: [MS6] : 4-cyl. turbo gasoline eng. 1.8 L/165 kWmulti-point injection, EU 3base engine is T6B
Equipment levels: [A8S] : Standard equipment
Exterior mirror setting: [6XD] : Exterior mirrors: electricallyadjustable/heated
Exterior noise suppression measures: [2B9] : Additional exterior noise suppression
First aid kit / warning triangle: [1T3] : First aid kit with warning triangle
Fresh air intake for passenger compartment (with particulate filter): [2V5] : Fresh air intake system with activatedcharcoal canister
Front license plate bracket: [6W5] : Front license plate bracket
Front stabilizer: [0AS] : Front stabilizer
Fuel filler cap/door, locking option: [2W0] : Fuel filler cap
Fuel quantity for initial filling: [1Z2] : Increase in initial standard fuelfilling
Fuel systems: [0F2] : Fuel system for carburetor gasolineengine
Fuel tank treatment: [2LB] : Fuel tank with special materialtreatment
Gearshift knob/handle: [6Q7] : Leather gearshift knob with aluminumappearance
General operating permit, alterations: [C12] : Operating permit, alteration
Generators: [8GL] : Alternator 120 A
Hand brake lever handle: [6PA] : Plastic hand brake lever handle
Handling standard production and pre-production series: [FA0] : Control of standard production
Headlight: [8JG] : Headlight with gas discharge lamp fordriving on the right
Headlight washer system: [8X1] : Headlight washer system
Headlight-range adjustment: [8Q2] : Automatic headlight-range adjustmentstatic
Heat accumulator system/additional heater: [7E0] : W/o heat accumulator/auxiliary heating
Heated washer nozzles: [9T1] : Heated washer nozzles, front
Heating and air conditioning system: [9AK] : Climatronic with impact pressurecontrol free of cfc
Horns: [8Y1] : Two-tone horn
Insert for the filling up of unleaded fuel/fuel type: [2G9] : Filler neck module 2 with insert
Installation differentiation for vehicle components: [0EN] : Installation differentiation fortransmission MQ 350vehicle components
Instrument inserts: [U2A] : Instrument insert with km/h speedometer,radio-controlled clock, tachometer andtrip odometer
Label for central electric: [0W1] : Label for central electricGerman-speaking countries
Left vanity mirror: [4SD] : Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid: [4E6] : Sensor-controlled luggage compartmentopening
Lockable wheel bolts: [1PA] : Standard wheel bolts
Lumbar support: [7P0] : Without lumbar supportin seat backrests
Multi-function display/trip computer: [9Q2] : Multi-function display/on-board computerwith check control
Outdoor temperature gage: [9Y1] : Outdoor temperature gage
Owner's manuals: [0VC] : Information kit in German
Paint preservative/transit coating: [5K3] : Liquid film sealant
Platform group class: [7PF] : Platform group class 6
Platform module floor pan, rear: [4P0] : Rear floor panel module, type 1
Proportioning valve: [1H0] : Without proportioning valve
Quattro GmbH: [FQ1] : Wheels of Quattro GmbH
Radios: [8UD] : Radio "concert"
Rear axle: [0N5] : Standard rear axle
Rear spoiler: [5J1] : Rear spoiler
Rear stabilizer: [0BH] : Rear stabilizer
Rear trim panel: [6V1] : Rear trim panel (ECE)
Rear window wiper and washer system: [8M0] : W/o rear window wiper and washer system
Remote-controlled garage door opener: [VC0] : W/o remote-controlled garage door opener
Right exterior mirror: [5RU] : Right exterior mirror: convex(large viewing field)
Right vanity mirror: [4TD] : Right vanity mirror illuminated
Rough-road/sports version: [2UA] : Standard design
Safety certificate: [0LW] : Special plates/stickers/safety certificates for Germany
Scuff plates: [7M1] : Scuff plates in door apertures withmetal inserts
Seat covering: [N3Q] : Fine napa leather seat covering
Self-collection / special control: [A00] : No self-collection
Service interval prolongation: [QG1] : Service interval prolongation
Shock absorption, chassis, front: [G98] : Front shock absorption
Shock absorption, chassis, rear: [UA5] : Rear shock absorption
Side air bag: [4X1] : Side air bag front
Spare wheel/breakdown set: [1G9] : Space-saving spare wheel for temporaryuse, radial tire(5-hole)
Speaker installation: [8RY] : Speakers with BOSE sound
Special labels/plates: [0ST] : Labels/plates in German and French
Steering: [1N4] : Power steering
Steering column systems: [2C5] : Axial and vertical adjustable steeringcolumn
Steering wheels: [2ZN] : Leather trimmed sports steering wheelwith aluminum appearance
TV reception/digital radio reception: [QV0] : W/o TV reception/digital radio reception
Tachograph/logbook: [9NX] : Without electronic logbook
Telephone/telematics: [9W0] : W/o car phone preparation/installation
Throttle actuation: [0L2] : Electric throttle actuation
Tie down straps/net/pocket: [6M0] : Without tie down straps/net/pocket
Tires: [H3L] : Tires 235/60 R18 ??? fronttires 255/55 R18 ??? rear
Transit coating: [NT0] : Transit coating (type 1)
Transmission specifications: [G0L] : 6-speed manual transmission forfour-wheel drive vehicle
Transmission types/gearshift mechanisms: [0G4] : Cable gearshift
Type approval countries/countries with special requirements: [B01] : Type approval Germany
Type sign: [2Z1] : Type sign at rearand "Quattro" nameplates respectively
Vehicle class differentiation units/platform components: [0CV] : Vehicle class differentiation 8N0
Versions: [FM0] : Basic equipment variant
Washer fluid level indicator: [8W1] : Washer fluid level indicator
Weight category front axle: [L62] : Suspension range 62installation control only, norequirement forecast
Weight category rear axle: [0YP] : Weight range 14installation control only, norequirement forecast
Wheels: [C1Q] : Alloy wheels 8J x 18
Wind blocker: [7S0] : Without wind blocker
Window regulator: [4R1] : Power windows
Windshield glass type: [4GH] : Windshield in heat-insulating glasswith sunshield
Windshield wiper intermittent control: [8N4] : Windshield wiper intermittent controlwith potentiometer (four speeds)
Front seats: [Q1D] : Sports front seats
