TEMAT: Audi A6 3.0tdi Avant WAUZZZ4F76N136277
Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 11:20 #42914
  • Callogero
  • Callogero Avatar
Witam!
Czy mógłbym prosić o rozkodowanie VINu WAUZZZ4F76N136277 Sprawdź ten VIN na autobaza.pl ▸, interesuje mnie kiedy opuściło fabrykę, wyposażenie i jakieś info na temat serwisowania.
Link do oferty wygasł, jak się pojawi to dodam.
Z góry dziękuje za pomoc.
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 11:24 #42915
  • kprzemo24
  • kprzemo24 Avatar
Data produkcji: 2006-01-23
Data wydania samochodu: 2006-02-03
170 000 km w lipcu 2010
WYPOSAŻENIE:
1 0F3 L KRS Fuel system for diesel engine
2 0G1 L GES Gearshift lever
3 0HP L AED Vehicle class differentiation 4F0
4 0JM L GKV Weight category front axle weight range 12
5 0LU L SIZ Special plates/stickers/ safety certificates for Belgium
6 0M5 L KBV Fuel tank
7 0N5 L HIA Standard rear axle
8 0SZ L SAU Labels/plates in Dutch and French
9 0TD L ZFM Front and rear floor mats
10 0VB E BTA Information kit in French
11 0W1 L AKZ Label for central electric German-speaking countries
12 0YK L GKH Weight range 10 installation control only, no requirement forecast
13 1BA L DAE Standard suspension/shock absorption
14 1C1 L FRO Antifreeze up to -25 degree celsius tolerance up to -30 degree C
15 1D0 L AHV Without trailer hitch
16 1EX L TYP Special identification plate for EC
17 1G8 L RER Breakdown set
18 1KD L BAH Disc brakes, rear
19 1LG L BAV Disc brakes, front
20 1N3 L LEN Speed-related variable steering assist (Servotronic)
21 1PA L ABR Standard wheel bolts
22 1S2 L BOW Tool kit
23 1SA L TWU Without additional engine guard
24 1T2 L VBK Warning triangle
25 1VH L TWL Installation parts for six-cylinder engine
26 1WG L GFW Transmission shafts w/ 88 mm in diameter
27 1X1 L ATA Four wheel drive
28 1YF L GFH Transmission shafts for rear axle diameter 75.5
29 1Z1 L KRM Increase in initial standard fuel filling by 4 liters
30 2C5 L LSS Axial and vertical adjustable steering column
31 2G0 L EBB Without insert for the filling up of fuel
32 2K1 L SFS Reinforced bumpers
33 2WA L ZBR Without additional tires
34 2Z1 L TYZ Type sign at rear and "Quattro" nameplates respectively
35 2ZQ P LRA Leather trimmed multi-function steering wheel for air bag system
36 3B0 L ZKV Without additional child seat anchor
37 3FE E DEI Electric slide/tilt sunroof with sun screen/sunblind
38 3G0 L KSI Without child seat anchor front (ISOFIX)
39 3GD L LBH Plane rear cargo area
40 3L3 L SIE Manual height adjustment for front seats
41 3NZ L HIS Rear seat bench unsplit, backrest split folding
42 3S1 L DAR Bright roof rails
43 3X0 L DLS Without load-through provision
44 3Y0 L SSR Without roll-up sun screen
45 4A3 P SIH Seat heater for front seats separately controlled
46 4D0 L KMS Without seat ventilation/massage seat
47 4E0 L SDH Tailgate/trunk lid unlocking from outside
48 4GH L WSS Windshield in heat-insulating glass with sunshield
49 4H3 L KDS Manual child lock
50 4K4 L TKV Radio remote controlled central locking
51 4KC L SSH Side and rear windows in heat-insulatingglass
52 4L6 P IRS Breakaway interior rear view mirror, automatically dimming
53 4UE L AIB Air bag for driver and front seat passenger
54 4W0 L KBO Without cassette and CD storage unit
55 4X3 L SAB Side air bag front with curtain air bag
56 4Y0 L VSS Without storage compartment/safe box
57 4ZB L ZIE Bright moldings
58 5A5 P GRV Trunk lining, with stowage trays
59 5C0 L KSA Without special body measures
60 5D7 L TRF Carrier frequency 868 MHz without panic button
61 5J0 L HES Without rear spoiler
62 5K5 L LAC Transit protective film (instead of paint preservative)
63 5MG E EIH Decorative inserts, burr-walnut
64 5NC L FHE Standard tailgate stay
65 5RU L ASR Right exterior mirror: convex (large viewing field)
66 5SL L ASL Left exterior mirror: aspherical
67 5XC L SON Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
68 6E3 L MAS Front center armrest
69 6FA L BBO Components without special surface appearance
70 6M1 P GPS Tie down straps
71 6NJ L HIM Standard molded headlining
72 6SJ E KBB Trunk floor covering, reversible mat (rubber/fabric)
73 6U0 L ZTD Without additional seals outside
74 6V1 L HEB Rear trim panel (ECE)
75 6W6 L KZV Front license plate bracket
76 6XE P ASE Exterior mirrors: electrically foldable and electrically adjustable/heated
77 7A2 P CDW CD changer
78 7AA L EDW Electronic vehicle immobilization device
79 7B2 L STD 12-volt socket in luggage boot
80 7F9 L SAG Plastic/leather gearshift knob/handle
81 7GN L AGM Emission standard, EU4, DPF preparation
82 7K0 L RDK Without tire pressure warning light
83 7M1 L EIL Scuff plates in door apertures with metal inserts
84 7P1 P LOR Power adjustable lumbar support in frontseats
85 7Q2 P NAV Navigation system with color screen
86 7QT P CDR CD ROM (Europe)
87 7X1 P EPH Park distance control
88 7Y0 L SPU Without lane change assistant
89 8ED P HSW Bi-functional headlight with gas discharge lamp, for driving on the right
90 8GV L GEN Alternator 180 A
91 8K9 P FLS Separate daytime running lights with low beam assistant and "Coming Home" function
92 8Q3 P LWR Automatic headlight-range adjustment dynamic (self-adjusting while driving)
93 8RY P LSE Speakers with BOSE sound
94 8SK P SBR Taillight assemblies with diodes (LED)
95 8T1 E GRA Cruise control system (CCS)
96 8TF L NEL Rear fog lights, left and right
97 8X1 P SWR Headlight washer system
98 8YQ P RAO Radio "HIGH"
99 8Z5 L MKU Not hot country
100 9AQ L HKA Air conditioning plus
101 9M0 L ZUH Without auxiliary/parking heater
102 9P3 L SGK Seat belt reminder, electric contact in buckle
103 9Q4 P MFA Multi-function display/on-board computerwith check control
104 9W0 L VTV W/o car phone preparation/installation
105 A00 L SAH No self-collection
106 A8S I AUS Standard equipment
107 B02 L TPL Type approval Belgium
108 B0A L BLB Component parts set without country-specific design requirement
109 C11 E COC Operating permit, alteration
110 C5V L RAD Alloy wheels 7.5J x 16 (4F0 601 025 E) offset 45
111 D1V L MOT 6-cyl. turbo dies. eng. 3.0 l/155 kW 24VV6 TDI, common rail Base engine is T41/TF1
112 E0A L AAU No special edition
113 F0A L FZS No special purpose vehicle, standard equipment
114 FA0 L SVO Control of standard production
115 FC0 L IND Without customized installation
116 FM0 L MDS Basic equipment variant
117 FQ0 L QGM Standard production wheels
118 G0L I GSP 6-speed manual transmission for four-wheel drive vehicle
119 GZ0 L EST Manually operated doors
120 HS0 L REI Tires 225/55 R16 99Y x1
121 J0Z P BAT Battery 520 A (110 Ah)
122 K8D I KAR Station Wagon Variant/Avant
123 L0L L LEA Left-hand drive vehicle
124 N0K P SIB Leather seat covering
125 NT0 L TSP Transit coating (type 1)
126 PAC G storage package
127 PBL G BOSE Surround Sound
128 PI4 G driver information system with colour display
129 PS1 G front sports seats
130 Q1D P VOS Sports front seats
131 QE1 P ALG Tray areas package 1
132 QH0 L SPR Without voice control
133 QQ0 L LCP Without add. lights (interior lighting)
134 QV0 L TVE W/o TV reception/digital radio reception
135 T41 I GMO 6-cylinder diesel engine 3.0 L unit 059.D
136 U2A P INS Instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
137 V0A L REL Tires w/o specification of tire brand
138 VC0 L GRT W/o remote-controlled garage door opener
139 WAT G comfort package I for Belgium
140 WKE G comfort package II for Belgium
141 X2A G National sales program Belgium
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 12:35 #42931
wygasly link takze jest dobry.Odzyskamy sobie. Moze byc tez miejscowosc to sobie odnajde sam
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 13:13 #42941
  • Callogero
  • Callogero Avatar
Stary link:
otomoto.pl/audi-a6-3-0-tdi-skora-navigacja-bose-C28785430.html
Mam jeszcze jedno pytanie: czy w systemie Audi możliwe jest wpisanie mniejszego przebiegu ostatniej wizyty niż poprzedniej?
Kolego kprzemo24, masz może info w jakim kraju był zanotowany przebieg o którym mi napisałeś?
I oczywiście bardzo dziękuję za wcześniejszcze info.
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 13:19 #42943
  • kprzemo24
  • kprzemo24 Avatar
Możliwe jest jeśli uprzednio ktoś skręcił licznik. A serwisie wpisują aktualny przebieg z zegarow.
Nie mam pojęcia w jakim to było kraju wpisywane.
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 14:08 #42946
wyszlo by to jak by np mial przeglad przy 150tys a za rok przyjechal na przeglad majac 139tys. Byly juz tu takie przypadki.. ile ma teraz? nie podali
Odp: Audi A6 3.0tdi Avant WAUZZZ4F76N136277 2013/05/02 15:21 #42951
  • Callogero
  • Callogero Avatar
Teraz ma 212tkm
