Dane samochodu
Marka: A Nr identyfikacyjny samochodu: WAUZZZ8LZ1A004719 Kod kraju: DEU
Rok modelowy: 2001 Opis: A3 TDI 1.9 I4 96 M6S Region: 133
Typ handlowy: 8L1BGC Data produkcji: 2000-08-18 Nr partnera: 36668
MKB: ASZ Data wydania samochodu: 2000-09-06 Leasing:
GKB: DRW Nr homologacji typu:
Kolor wyposażenia Typ Kod barwny Nr lakieru (nr KD lakieru) Opis
z zewnštrz (nadwozie/dach) 4Z/4Z Ebony Black, pearl effect/Ebony Black, pearl effect
wewnštrz EG black/black/black/light grey
Numery PR Nr identyfikacyjny Nr Pochodzenie Grupa Opis
1 0A1 L TUE two doors
2 0AL L STV front stabilizer
3 0BB L STH rear stabilizer
4 0CJ L AED vehicle class differentiation 8L0
5 0F9 L KRS cooled fuel system for diesel engine
6 0FA L FAD standard manufacturing sequence
7 0G4 L GES cable gearshift
8 0GE L AGM emissions concept EU 3
9 0L2 L GAB electric throttle actuation
10 0LW L SIZ special plates/stickers/ safety certificates for Germany
11 0N1 L HIA standard rear axle
12 0RA L ZSS without ignition/starter switch locking system
13 0ST L SAU labels/plates in German and French
14 0TD L ZFM front and rear floor mats
15 0VC L BTA information kit in German
16 0W1 L AKZ label for central electric German-speaking countries
17 0YZ L GKH without determination of weight categoryfor rear axle
18 1AT L BRS electronic stabilization program (ESP)
19 1C1 L FRO antifreeze up to -25 degree celsius tolerance up to -30 degree C
20 1D0 L AHV without towing attachment
21 1E0 L AKB without activated charcoal canister
22 1EX L TYP special identification plate for EC
23 1G3 L RER alloy spare wheel with original equipment tires
24 1H0 L BRM without proportioning valve
25 1JK L DFH rear shock absorption, sports design
26 1KK L BAH disc brakes, rear
27 1LE L BAV disc brakes, front
28 1N6 L LEN power steering
29 1PC L ABR wheel bolts with anti-theft protection (unlockable)
30 1SA L TWU without additional engine guard
31 1T3 L VBK First aid kit with warning triangle
32 1X0 L ATA front wheel drive
33 1Z2 E KRM increase in initial standard fuel filling
34 2A5 L UEA delivery equipment (transit coating) with thin seat cover
35 2B3 L GRD additional exterior noise suppression (hood, capsule and dash panel)
36 2C5 L LSS axial and vertical adjustable steering column
37 2D1 L CWV complete cd enhancing underbody panel
38 2G8 L EBB filler neck module 2 without insert
39 2JB L STF standard bumpers
40 2LB L KRB fuel tank with special material treatment (fluorination)
41 2PV L LRA leather trimmed sports steering wheel
42 2UA L SWP Without rough-road or sports version
43 2V5 L FRI fresh air intake system with activated charcoal canister
44 2W0 L TDA fuel filler cap
45 2WA L ZBR without additional tires
46 2Z1 L TYZ type sign at rear and "Quattro" nameplates respectively
47 3B0 L ZKV without additional child seat anchor
48 3C1 L SHM static lap belt, center rear
49 3FA L DEI without roof insert (standard roof)
50 3H6 L LER backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
51 3L3 L SIE manual height adjustment for front seats
52 3NC L HIS rear seat bench/backrest, split folding
53 3Q1 L KOH rear headrests
54 4A0 L SIH without seat heater
55 4E0 L SDH tailgate/trunk lid unlocking from outside
56 4GH L WSS windshield tinted with windshield sunshield
57 4K4 P TKV radio remote controlled central locking operated from inside and separate trunk release
58 4L2 L IRS dipping breakaway inside rear view mirror
59 4P0 L PBH rear floor panel module, type 1
60 4R1 L FEH power windows
61 4UE L AIB airbag f. driver a. front seat passenger
62 4X3 E SAB side airbag front with curtain airbag
63 5C0 L KSA without special body measures
64 5D1 P TRF carrier frequency 433.92 MHz
65 5E1 L SAA without sill top with door cover
66 5J0 L HES without rear spoiler
67 5K1 L LAC paint preservative (wax)
68 5RU L ASR outer right rear view mirror: convex (large viewing field)
69 5SL L ASL outer left rear view mirror: non-spherical
70 5TC L EIH without decorative inserts
71 6A0 L FEU without fire extinguisher
72 6E3 E MAS center armrest front
73 6FB L BBO body-colored outer rear view mirror housings
74 6M0 L GPS without tie down straps/luggage net
75 6N0 L SZF without mud flaps
76 6PA L HBV plastic hand brake lever handle
77 6Q2 L SAG leather gearshift knob/handle
78 6R2 L SHV leather gearshift boot
79 6U0 L ZTD without additional seals outside
80 6V1 L HEB rear trim panel (ECE)
81 6W5 L KZV front license plate bracket
82 6XC L ASE outer rear view mirrors: powered
83 7A0 L CDW without CD changer/CD player
84 7AA L EDW electronic vehicle immobilization device
85 7CA L AKF without label for radio remote control
86 7E3 L WSA sheathed type glow plug heater
87 7M0 L EIL plastic scuff plates in door apertures
88 7P0 L LOR without lumbar support in front and rear seats
89 7PE L PGK platform group class 5
90 7Q0 L NAV without navigation device
91 7QA L CDR without CD ROM
92 7R3 L SLE side turn signal lights (white)
93 7X0 L EPH without park distance control
94 8GL L GEN alternator 120A
95 8JG P HSW headlight with gas discharge lamp for driving on the right
96 8K0 L FLS without special low beam mode
97 8KA L KUE w/o catalytic converter warning light
98 8M1 L HEW rear window wiper and washer system with intermittent control
99 8N4 L SWS windshield wiper intermittent control with potentiometer (four speeds)
100 8Q2 P LWR automatic headlight-range adjustment static
101 8RY P LSE speakers with BOSE sound
102 8T0 L GRA without cruise control system (CCS)
103 8TC L NEL rear fog light for driving on the right
104 8UM P RAO radio "symphony" (ECE)
105 8W1 P WWA washer fluid level indicator
106 8WB E NES front fog lights
107 8X1 P SWR headlight washer system
108 8Y1 L SNH two-tone horn
109 8Z5 L MKU engine cooling system, type 1
110 9AK P HKA "Climatronic" with impact pressure control free of cfc
111 9D0 L VEF without preparation for two-way radio installation
112 9M0 L ZUH without auxiliary/parking heater
113 9NX L FAS without electronic logbook
114 9P0 L SGK without seat belt warning light
115 9Q2 P MFA multi-function indicator/on-board computer with check control
116 9T1 L BWD heated washer nozzles, front
117 9U1 L BVK brake pad wear indicator
118 9W0 L VTV w/o car phone preparation/installation
119 9X4 L BTS without heated door lock cylinder with micro switch
120 9Y1 P ATE outdoor temperature gage
121 A00 L SAH no self-collection
122 A9D I AUS "Ambition" equipment
123 AZ0 L FAF vehicle with standard production scope
124 B0A L BLB component parts set without country-specific design requirement
125 B99 L TPL type approval EC
126 C14 E COC operating permit, alteration 14
127 C3F P RAD cast alloy wheels 6 1/2J x 16 5-arm style, offset 42
128 D3E L MOT 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3base engine is T9J
129 E0A L AAU no special edition
130 F0A L FZS no special purpose vehicle, standard equipment
131 FA0 L SVO control of standard production
132 FC0 L IND without customized installation
133 G03 L DFV front shock absorption
134 G0K I GSP 6-speed manual transmission
135 H6U P REI tires 205/55 R 16 91W
136 J0L L BAT battery 340 A (70 Ah)
137 K8G I KAR hatchback
138 L0L L LEA left-hand drive vehicle
139 L21 L GKV suspension range 21
140 N0E L SIB woven fabric seat covering
141 PFA G remote control for central locking
142 PH5 G automatic air conditioning, sun-positioncontrolled
143 PI1 G Driver Information System (DIS)
144 PR1 G Aluminium Gu~r{der 6,5Jx16 im 5-Arm-Design mit Reifen 205/55 R 16 W
145 PX1 G xenon headlights
146 Q1D L VOS sports front seats
147 QG1 L WIV service interval prolongation
148 QQ0 L LCP without add. lights (interior lighting)
149 QS0 L KFK without electronic map cooling system
150 QV0 L TVE w/o TV reception/digital radio reception
151 RSM G "symphony" radio with BOSE sound system
152 S0C E SNR introductory volume
153 SA9 E SNR inventory control model 4
154 T9J I GMO 4-cylinder diesel engine 1.9 L unit 038.K
155 U2A L INS instrument insert with km/h speedometer,radio-controlled clock, tachometer and trip odometer
156 V0G P REL MICHELIN tires
157 X0A G national sales program Germany
