Około 150 000 km w 2008 roku
Skrzynia niestety nie ma zbyt pochlebnych opinii...
1 0CS L AED Vehicle class differentiation 8E0
2 0F3 L KRS Fuel system for diesel engine
3 0FA L FAD Standard manufacturing sequence
4 0G7 L GES Tiptronic
5 0GZ L AGM Emission concept EU3, diesel with EOBD
6 0JJ L GKV Weight category front axle weight range 9
7 0LW L SIZ Special plates/stickers/ safety certificates for Germany
8 0TC L ZFM Front floor mats
9 0VC L BTA Information kit in German
10 0W1 L AKZ Label for central electric German-speaking countries
11 0YK L GKH Weight range 10 installation control only, no requirement forecast
12 1BA L DAE Standard suspension/shock absorption
13 1C1 L FRO Antifreeze up to -25 degree celsius tolerance up to -30 degree C
14 1D2 P AHV Trailer hitch, removable and lockable
15 1EX L TYP Special identification plate for EC
16 1G8 L RER Breakdown set
17 1KD L BAH Disc brakes, rear
18 1LB L BAV Disc brakes, front
19 1N1 L LEN Power steering
20 1PA L ABR Standard wheel bolts
21 1SA L TWU Without additional engine guard
22 1T3 L VBK First aid kit with warning triangle
23 1VG L TWL Installation parts for four-cylinder engine
24 1W0 L KBX Without refrigerator/glove compartment cooling system
25 1WG L GFW Transmission shafts w/ 88 mm in diameter
26 1X0 L ATA Front wheel drive
27 1YA L GFH Without transmission shafts f. rear axle
28 1Z0 L KRM Initial standard fuel filling
29 2G0 L EBB Without insert for the filling up of fuel
30 2KR L SAU Labels/plates in English and German
31 2PV P LRA Leather trimmed sports steering wheel
32 2T0 L DAT Without double-sized standard (DIN)
33 2V1 L FRI Dust and pollen filter
34 2WA L ZBR Without additional tires
35 2Z0 E TYZ Deletion of model designation
36 3B0 L ZKV Without additional child seat anchor
37 3C7 L SHM 3-point seat belt for center rear seat
38 3FA L DEI Without roof insert (standard roof)
39 3L3 L SIE Manual height adjustment for front seats
40 3NZ L HIS Rear seat bench unsplit, backrest split folding
41 3Q6 L KOH Three rear headrests
42 3S1 L DAR Bright roof rails
43 3X0 L DLS Without load-through provision
44 3Y0 L SSR Without roll-up sun screen
45 4A3 P SIH Seat heater for front seats separately controlled
46 4E0 L SDH Tailgate/trunk lid unlocking from outside
47 4GH L WSS Windshield in heat-insulating glass with sunshield
48 4K4 L TKV Radio remote controlled central locking
49 4KC L SSH Side and rear windows in heat-insulatingglass
50 4L2 L IRS Dipping breakaway interior mirror
51 4N0 L INT Standard dashboard
52 4P2 L PBH Rear floor panel module, type 3
53 4R5 L FEH Power windows with comfort operation andcircuit breaker, mechanical window regulators rear
54 4UE L AIB Air bag for driver and front seat passenger
55 4W0 L KBO Without cassette and CD storage unit
56 4X3 L SAB Side air bag front with curtain air bag
57 4ZE L ZIE Black moldings
58 5C0 L KSA Without special body measures
59 5D1 L TRF Carrier frequency 433.92 MHz-434.42 Mhz
60 5J0 L HES Without rear spoiler
61 5K1 L LAC Paint preservative (wax)
62 5MA L EIH Decorative inserts
63 5NF L FHE Interstop gas prop for tailgate
64 5RU L ASR Right exterior mirror: convex (large viewing field)
65 5SL L ASL Left exterior mirror: aspherical
66 6E3 P MAS Front center armrest
67 6FB L BBO Body-colored exterior mirror housings
68 6M0 L GPS Without tie down straps/net/pocket
69 6NJ L HIM Standard molded headlining
70 6PC P HBV Leatherette hand brake lever handle
71 6Q2 P SAG Leather gearshift knob/handle
72 6R0 L SHV Selector lever cover
73 6SS L KBB Luggage compartment floor covering
74 6V1 L HEB Rear trim panel (ECE)
75 6W5 L KZV Front license plate bracket
76 6XC L ASE Exterior mirrors: electrically adjustable
77 7A0 L CDW Without CD changer/CD player
78 7AA L EDW Electronic vehicle immobilization device
79 7B2 L STD 12-volt socket in luggage boot
80 7K0 L RDK Without tire pressure warning light
81 7M0 L EIL Plastic scuff plates in door apertures
82 7P1 P LOR Power adjustable lumbar support in frontseats
83 7Q0 L NAV Without navigation device
84 7QA L CDR Without CD/DVD for navigation
85 7X0 L EPH Without park distance control
86 8GU L GEN Alternator 140 A
87 8JH L HSW Ellipsoidal headlight for driving on the right
88 8K0 L FLS Without special low beam mode
89 8N4 L SWS Windshield wiper intermittent control with potentiometer (four speeds)
90 8Q1 L LWR Headlight-range adjustment
91 8T0 L GRA Without cruise control system (CCS)
92 8TC L NEL Rear fog light for driving on the right
93 8UD P RAO Radio "concert"
94 8X0 L SWR Without headlight washer system
95 8Z5 L MKU Not hot country
96 9AK L HKA Climatronic with impact pressure control free of cfc
97 9M0 L ZUH Without auxiliary/parking heater
98 9NX L FAS Without electronic logbook
99 9P0 L SGK Without seat belt warning light
100 9Q3 L MFA Multi-function display, without on-boardcomputer and check control
101 9T0 L BWD Without heated washer nozzles
102 9VD P LSE Speaker (active)
103 9ZF P VTV Mobile phone preparation with hands-freespeaking system
104 A00 L SAH No self-collection
105 A8S I AUS Standard equipment
106 B01 L TPL Type approval Germany
107 B0A L BLB Component parts set without country-specific design requirement
108 C09 E COC Operating permit, alteration 9
109 CB1 L RAD Alloy wheels 7J x 16 Alu-4, offset 42
110 D3E L MOT 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
111 E0A L AAU No special edition
112 F0A L FZS No special purpose vehicle, standard equipment
113 FA0 L SVO Control of standard production
114 FC0 L IND Without customized installation
115 FM0 L MDS Basic equipment variant
116 FQ0 L QGM Standard production wheels
117 G0Z I GSP Variable gearing ratio
118 H6U L REI Tires 205/55 R16 91W
119 J1D L BAT Battery 380 A (72 Ah)
120 K8D I KAR Station Wagon Variant/Avant
121 L0L L LEA Left-hand drive vehicle
122 N3A L SIB Fabric seat covering
123 NT0 L TSP Transit coating (type 1)
124 P16 G leather-covered sports steering wheel, 3-spoke
125 PAA G trailer towing hitch
126 Q1D E VOS Sports front seats
127 QE0 L ALG Without tray areas package/box
128 QH0 L SPR Without voice control
129 QQ0 L LCP Without add. lights (interior lighting)
130 QV0 L TVE W/o TV reception/digital radio reception
131 T9J I GMO 4-cylinder diesel engine 1.9 L unit 038.K
132 U1A L INS Instrument insert with km/h speedometer,clock, tachometer and trip odometer
133 V0A L REL Tires w/o specification of tire brand
134 VC0 L GRT W/o remote-controlled garage door opener
135 VJ1 L SFS Reinforced bumpers
136 VR0 L RAM Without impact protection measures
137 WKQ G business package for key accounts
