Parameter Value
Brand AUDI
Model AUDI A4 AV.QU. 1.8
VIN WAUZZZ8E35A004883
Production date 2004-05-25
Model year 2004
Engine code BEX
Engine volume, L 1.80
Number of cylinders 4
Power, KW 140
Power, PS 190
Colour of body 2S (SILVER: akoya silver metallic)
Colour of roof 2S (SILVER: akoya silver metallic)
Trim QE
Gearbox code HER (6S)
Country of sale 000 ()
Custom options
Parameter Value
E4J Special editions: "S-line"
1PA Lockable wheel bolts: Standard wheel bolts
0CS Vehicle class differentiation units/platform components: Vehicle class differentiation 8E0
0GG Emissions standard: Emission standard EU4
1D0 Trailer hitch: Without trailer hitch
4UF Airbag: Driver's and front passenger air bag with front passenger air bag deactivation
0W2 Label for central electric: Label for central electric English-speaking countries
QE0 Storage compartment package: Without tray areas package/box
6XD Exterior mirror setting: Exterior mirrors: electrically adjustable/heated
5SL Left exterior mirror: Left exterior mirror: aspherical
5RU Right exterior mirror: Right exterior mirror: convex (large viewing field)
1X1 Drive layout: Four wheel drive
A8S Equipment levels: Standard equipment
1KP Brake type in rear: Disc brakes, rear
J0L Batteries: Battery 340 A (70 Ah)
1LT Brake type, front: Disc brakes, front
6FB Components with special surface appearance: Body-colored exterior mirror housings
B0A Component part sets with country-specific design requirements: Component parts set without country-specific design requirement
0VV Owner's manuals: Information kit in Swedish
9T1 Heated washer nozzles: Heated washer nozzles, front
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
C10 General operating permit, alterations: Operating permit, alteration
1BE Shock absorption/suspension, chassis: Sports suspension/shock absorption
3S1 Roof rails/roof load rack: Bright roof rails
2T0 Double-size standard radio/dual-view display: Without double-sized standard (DIN)
3FA Roof insert/convertible top: Without roof insert (standard roof)
3X0 Ski bag: Without load-through provision
2G1 Insert for the filling up of unleaded fuel/fuel type: Insert for the filling up of unleaded fuel
7AA Theft protection system: Electronic vehicle immobilization device
5TG Inserts: Decorative aluminum inserts, dulling
7M8 Scuff plates: Scuff plates in door apertures
7X0 Park distance control: Without park distance control
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
9NX Tachograph/logbook: Without electronic logbook
4R5 Window regulator: Power windows with comfort operation and circuit breaker, mechanical window regulators rear
5NC Hood and trunk stay: Standard tailgate stay
8K1 Headlight control: Separate daytime running lights
2V1 Fresh air intake for passenger compartment (with particulate filter): Dust and pollen filter
1C2 Antifreeze: Antifreeze up to -35 degree celsius tolerance up to -40 degree C
F0A Vehicle specifications: No special purpose vehicle, standard equipment
8GR Alternators: Alternator 150 A
0G1 Transmission types/gearshift mechanisms: Gearshift lever
1YF Transmission shafts, rear axle: Transmission shafts for rear axle diameter 75.5
1WG Transmission shafts: Transmission shafts w/ 88 mm in diameter
0YL Weight category rear axle: Weight range 11 installation control only, no requirement forecast
0JG Weight category front axle: Weight category front axle weight range 7
T0L Base engine: 4-cylinder gasoline engine 1.8 L unit 06B.G
6M0 Tie down straps/net/pocket: Without tie down straps/net/pocket
8T1 Cruise control system: Cruise control system (CCS)
VC0 Garage door opener: W/o remote-controlled garage door opener
G0L Transmission specifications: 6-speed manual transmission for four-wheel drive vehicle
6PC Hand brake lever handle: Leather hand brake lever handle
6V1 Rear trim panel: Rear trim panel (ECE)
5J2 Rear spoiler: Rear spoiler (type 2)
6NJ Molding roof liner: Standard molded headlining
3NZ Rear seats: Rear seat bench unsplit, backrest split folding
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8ED Headlamps: Bi-functional headlight with gas discharge lamp, for driving on the right
FC1 Customized installation: Customized installation
U1A Instrument clusters: Instrument insert with km/h speedometer, clock, tachometer and trip odometer
4N0 Dashboard: Standard dashboard
4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror
K8D Body style: Station Wagon Variant/Avant
6SS Luggage compartment floor covering: Luggage compartment floor covering
4W0 Cassette and CD storage unit: Without cassette and CD storage unit
1W0 Refrigerator: Without refrigerator/glove compartment cooling system
3Q6 Rear head restraints: Three rear headrests
1Z1 Fuel quantity for initial filling: ErhГ¶h.der SerienkraftstofferstbefГјllung um 4 Liter
0F2 Fuel systems: Fuel system for carburetor gasoline engine
5C0 Body measures: Without special body measures
6W5 Front license plate carrier: Front license plate bracket
5K1 Paint preservative/transit coating: Paint preservative (wax)
QQ1 Light package (lighting): With additional lights (interior lighting)
L0L Steering system arrangement: Left-hand drive vehicle
1N1 Steering: Power steering
7P1 Lumbar support: Power adjustable lumbar support in front seats
1ML Steering wheels: Leather trimmed sports steering wheel
9VD Speaker installation: Speaker (active)
8Q3 Headlight range control: Automatic headlight-range adjustment dynamic (self-adjusting while driving)
6E3 Center armrest: Front center armrest
FM0 Versions: Basic equipment variant
9Q2 Multi-function display/trip computer: Multi-function display/on-board computer with check control
8Z5 Engine cooling system: Not hot country
D7E Engine specifications: 4-cyl. gasoline engine 1.8 L/140 kW 20V turbo base engine is T0L/T8C
7Q0 Navigation device: Without navigation device
8TC Rear fog lamp: Rear fog light for driving on the right
4P2 Platform module, luggage compartment floor: Rear floor panel module, type 3
FQ0 Quattro GmbH: Standard production wheels
CL6 Wheels: Leichtmetallräder 7 1/2J x 17 9-Speichen-Design, ET 43
VR0 Impact protection measures: Without impact protection measures
8UD Radios: Radio "concert"
7K0 Direct tire pressure monitoring system: Without tire pressure warning light
H8A Tires: Tires 235/45 R 17 93Y
V0A Tire suppliers: Tires w/o specification of tire brand
1G5 Spare wheel/breakdown kit: Space-saving spare wheel, same size (same rolling circumference) as original equipment tires
PQD S line exterior package (quattro GmbH)
PSS STCC edition for Sweden
PX4 xenon plus
WAX comfort package for Sweden
WQV S line sports package (quattro GmbH)
4X3 Side airbag: Side air bag front with curtain air bag
6Q2 Gearshift knob/handle: Leather gearshift knob/handle
A00 Self-collection / special control: No self-collection
2KA Special labels/plates: Labels/plates in Swedish and English
4E0 Lock operation for tailgate/trunk lid: Tailgate/trunk lid unlocking from outside
2K7 Bumper systems: Reinforced bumpers
9P0 Seat belt check: Without seat belt reminder
3C7 Center rear seat belts: 3-point seat belt for center rear seat
6R2 Gearshift boot/cover: Leather gearshift boot
N2L Seat trim covers: Fabric seat covering "Speed" leather bolsters
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
0LE Safety certificate: Special plates/stickers/ safety certificates for Sweden
S0B Control number (no PR family): Veh. w/ engineering build status of current model year a. vehicle identification no. of next model year
SA8 Control number (no PR family): Inventory control model 3
QH0 Audio-response system/voice control: Without voice control
4KC Side and rear windows: Side and rear windows in heat-insulating glass
3Y0 Roll-up sun screen for rear and side windows: Without roll-up sun screen
7B2 Socket: 12-volt socket in luggage boot
FA0 Handling production and pre-production: Control of standard production
8X1 Headlamp washer system: Headlight washer system
8N4 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with potentiometer (four speeds)
4K4 Door and lid locking system: Radio remote controlled central locking
B07 Type approval countries/countries with special requirements: Type approval Sweden
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
NT1 Transit coating: Transit coating (type 2)
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
1VG Installation parts for engine (engine mount system): Installation parts for four-cylinder engine
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Spezielles Typschild fГјr EG
2Z1 Type sign: Type sign at rear and "Quattro" nameplates respectively
1T2 First aid kit / warning triangle: Warning triangle
Q1D Front seats: Sports front seats
9W0 Telephone / telematics: W/o car phone preparation/installation
4GH Windshield glass type: Windshield in heat-insulating glass with sunshield
2WA Additional tires (snow tires): Without additional tires
0TD Floor mats: Front and rear floor mats
4ZB Decorative trims: Bright moldings
3B9 Additional child seat anchors: Child seat anchor for child seat system ISOFIX front and rear
9M0 Auxiliary heater: Without auxiliary/parking heater
