NoozyMan
Wychodzi na to że wg tego numeru VIN co podałeś to kolor bazowy powinien być GREEN PEARL METALLIC (zielony matalik - perłowy)
Sprawdź czy na pewno masz dobry numer VIN - jeśli tak to by oznaczało że auto zostało przemalowane.
[td]
| RPO | Description | Matches |
| UH8 | CLUSTER-COOL TEMP, TACH, TRIP ODOM GA(UH8) | 85,508 |
| UQ0 | SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL STANDARD RANGE PACKAGE SHELF/QUARTER 4 SPKR SYS(UQ0) | 85,508 |
| U1C | RADIO,AM/FM STEREO,CD PLAYER,ETR, CLOCK STEREO W/CD PLAYER(U1C) | 97,770 |
| U73 | ANTENNA,FIXED FIXED ANT(U73) | 98,608 |
| VM5 | LABEL INFORMATION - CONSUMER, CONTAINS BPR IMP STANDARD FOR FRT 2.5 MPH & RR 2.5 MPH | 76,780 |
| V22 | GRILLE,RADIATOR(CHROME) CHROME GRL(V22) | 53,894 |
| V59 | RAIL ROOF ROOF RAIL(V59) | 95,588 |
| ZV1 | STATEMENT OF ORIGIN - MANUFACTURE | 76,780 |
| ZY1 | COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1) | 98,608 |
| Z05 | COMFORT AND CONVENIENCE PACKAGE COMFORT & CONVENIENCE PKG(Z05)
COMFORT AND CONVENIENCE PACKAGE(MERCHANDISING OPTION) COMFORT & CONVENIENCE PKG(Z05) | 80,522 |
| 1SB | PACKAGE-OPTION 02 (1SB) | 38,934 |
| 17E | TRIM COMBINATION,CLOTH,DK CHARCOAL (17E) | 61,214 |
| 17I | INTERIOR TRIM COLOR - CHARCOAL (17I) | 94,180 |
| 47U | EXTERIOR COLOR,PRIMARY (47U)
EXTERIOR COLOR,PRIMARY,MED DK LICHEN (47U)
EXTERIOR COLOR,PRIMARY,MED GREEN PEARL METALLIC (47U) | 7,710 |
| AJ1 | GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1) | 50,694 |
| AK5 | RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5) | 89,880 |
| AM9 | SEAT,REAR,FOLDING SPLIT BACK FLDG SPLIT BK R/SEAT(AM9) | 85,508 |
| AN4 | RESTRAINT PROVISIONS,CHILD(CANADIAN) CHILD RST PROVISIONS(AN4)(CANADIAN) | 85,508 |
| AR9 | SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) | 98,608 |
| AU0 | LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0) | 80,522 |
| AU3 | LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) | 80,522 |
| A31 | WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31) | 80,522 |
| B1A | PORT OF ENTRY CAMIE PORT OF ENTRY-CAMIE(B1A)
PORT OF ENTRY CAMIE/INGERSOL,ONT.,CANADA (B1A) | 85,508 |
| B58 | COVERING,FLOOR MATS,FRONT AND REAR,CARPETED INSERT CPT INS FLR MATS(B58) | 88,922 |
| B84 | ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84) | 54,512 |
| C25 | WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25) | 98,608 |
| C49 | DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) | 98,608 |
| C60 | AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) | 94,106 |
| DA7 | ARM REST FRT SEAT, LH LH FRT SEAT ARM REST(DA7) | 85,508 |
| DA9 | ARM REST FRT SEAT, RH RH FRT SEAT ARM REST(DA9) | 85,508 |
| DG7 | MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7) | 58,928 |
| DL5 | DECAL ROADSIDE SERVICE INFORMATION ROADSIDE SERVICE INFO DECAL(DL5) | 76,780 |
| FE9 | FEDERAL EMISSION CERTIFICATION FED EMIS(FE9) | 80,202 |
| HC8 | Unk. | 89,760 |
| J41 | BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) | 73,086 |
| K34 | CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) | 76,688 |
| LE8 | ENGINE,2.5L-4, V6, MFI, DOHC (TRACKER) 2.5L-4(LE8) | 41,106 |
| MX0 | TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) | 89,760 |
| M41 | TRANSMISSION AUTO 4 SPD, 2.826 1ST, 0.730 4TH 4-SPD A/TRANS(M41) | 89,760 |
| NF7 | EMISSION SYSTEM FEDERAL, NLEV FEDERAL EMIS NLEV(NF7) | 71,474 |
| NG5 | REGISTRATION EMISSION, CERTIFICATION, FIFTY STATE (50) FIFTY STATE U.S. EMIS(NG5) | 76,780 |
| NX2 | WHEEL SPARE - 15 X 6.0 ALUMINUM | 37,532 |
| N33 | STEERING COLUMN,TILT TYPE TILT STRG COL(N33) | 81,032 |
| N40 | STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) | 98,608 |
| PW8 | WHEEL,15X6,STYLED(ALUMINUM) STYLED AL WHL(PW8) | 25,308 |
| QPK | TIRE ALL P215/70R15/N BL R/PE ST TL ALS 97S TIRE(QPK) | 25,306 |
| TZ2 | Unk. | 94,296 |
| T61 | LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61) | 89,880 |
| T82 | HEADLAMPS,AUTOMATIC ON/OFF CONTROL AUTO HDLP CONT(T82) | 89,880 |
