| INJECTION EW10J4S |
Fuel:
| UNLEADED GASOLINE |
| CLEAN ENGINE. IFL5 (NAL.LGOT) |
A dynamic system of sustainability:
| Electronic Stability Program |
Beeps:
| SOUND SIGNALS, Melodic |
Function outside mirrors:
| OUTDOOR. MIRROR with electric. FOLD NO MEMORY |
Windscreen wiper:
| SCHET.STEKLOOCH.LOB.ST. With DAT.DOZHDYA |
Cleaner headlight:
| WIPER / WASHER HEADLAMPS |
Trunk grille:
| WITHOUT BAGAZH.RELSOV ON THE ROOF |
Front fog lamp:
| FRONT FOG LIGHTS |
Luke:
| FIXED ROOF |
Landing and the engine is started without a key:
| Without systems. ACCESS AND START MOTOR. "Hands free" |
Rear seat:
| FOLDING SEPARATE CUSHION AND BACK SEATS |
Tachometer:
| DIGITAL TACHOMETER |
Additional heating system:
| WITHOUT HEATER |
Curtains (curtains, side curtains, sunroof):
| WITHOUT sunshields |
CD:
| SETUP. COMPACT DISCS |
Lamp lights:
| DISCHARGE LAMP |
Rear door window lift:
| WITHOUT REAR Pwr |
Front side airbag:
| BOK.POD.BEZOP. THORAX + ZANAV.BEZOP. |
Airbag on the passenger side:
| Passenger Airbag |
Exterior rear-view mirror (heated):
| NARUZH.ZERKALO ZADN.VIDA HEATED |
System deactivation of airbags:
| HAND-OFF AIRBAGS |
Protecting the front seat:
| CABIN WITHOUT PROTECTIVE PANEL |
The air conditioning system:
| AUTO AIR CONDITIONING |
Cruise Control:
| REGULATORS and speed limiter |
Adjusting the height of the driver's seat:
| PARALLEL Regulus. HEIGHT SIDEN.VODIT. |
The inner rear view mirror:
| INT. REAR VIEW MIRROR DAY / NIGHT |
Airbag driver side:
| Driver Airbag |
Loading platform:
| With cord + Removable Box in the trunk |
Interior Protection:
| WITHOUT INTERNAL SECURITY |
Obstacle detection system:
| DETERMINANTS OBSTACLES, FRONT, REAR RADAR |
Equalizer amplifier:
| An amp EQ |
| Ew10j4s injection |
FUEL SUPPLY:
| Injection |
DIESEL FILTER WATER DETECTOR:
| Without diesel filter water detector |
CYLINDER BLOCK (MATERIAL):
| Crankcase aluminium |
| Lead free petrol |
| Ifl5 engine depollution (tax incentive) |
| Ew/dw |
CAPACITY:
| 2000 cm3 |
CATALYTIC CONVERTER:
| 3-component rhodium+platinum filter catalyser |
| Mntg water/oil exchanger on engine |
COOLING MOTOR:
| Radiator th : 27 - 21 dm2 brazed aluminium |
| W/o heater casing gas circuit |
| "eobd" auto-diagnostic without accelerometer |
| Ifl5 vehicle technical depoll (tax incentive) |
| Without particle filter |
| 2 fans , 2 rates , improved 130waero |
FUEL VAPOUR RETRIEVAL:
| Controlled petrol vapour recuperation |
| Mounting magneti marelli |
TANK FILTER:
| Reservoir filter interior |
| Bvm5 |
| Bvm be4 t |
| Cp 17 x 73 |
| 17 inch resolfen wheel |
CLUTCH:
| Hydraulic clutch |
GEARBOX TYPE (TYPE APPROVAL):
| Gearbox be4/5 t type |
DIFFERENTIAL (GEARBOX):
| Differential 84 |
| 205x50x17 w tyres |
WHEELS FITTED:
| 6,5" rim road wheels |
| Alloy wheel assembly 2 |
| Tyre deflection indicator |
| Gearbox be4r |
REAR ANTI-ROLL BAR:
| Rear anti roll bar diam 27 |
STEERING COLUMN:
| Manually adjusted steering column |
| Front anti-roll bar diam 22 |
POWER STEERING FLUID COOLING SYSTEM:
| Without power steering oil cooling |
| Normal suspension |
| Electronic stability program |
BRAKE ASSOCIATED VARIANT:
| Esp bosch 8 0 |
STEERING (OPERATION):
| Assisted electrohydraulic steering |
PEDAL BRACKET (TYPE):
| Pedal aluminium |
HORNS:
| Horns-harmony |
AERIAL:
| Short roof aerial |
REAR SPOILER:
| Assembly with double tailgate central rr spoiler |
DECORATION (PAINTED):
| Gloss black decor |
| Body colour lateral protectors |
SIDE MOULDINGS (DIMENSION):
| Plastic + chrome side protectors |
| Trompette style |
REVERSING LAMPS:
| With 2 reversing lamps |
SILL ILLUMINATION LAMP:
| Sill illumination |
| W/o engine undershelding |
DRAUGHT EXCLUSION:
| Bonnet without seal |
| Electric folding ext rear view mirror no memory |
EXHAUST TAILPIPE TRIM:
| With exhaust outlet embellisher |
ENGINE BAY SOUNDPROOFING:
| Bonnet soundproofing |
| Front wiper blade with rain sensor |
REAR SCREEN WIPER:
| Rear screen wiper |
| Headlamp washwipe |
| Without front bumper plug |
ROOF GLASS:
| Without roof window |
REAR TAILGATE GLASS:
| Fixed tailgate window |
BUMPER:
| Spc grl body col sport fr bumper body col std rr |
MUDFLAP:
| Without rear mudguard |
NUMBER PLATE:
| Without licence plate |
LUGGAGE RACK:
| Without roof bars |
| Front fog lights |
| Reduced steel wheel + non std tyre |
| Body colour ext handle+rr ctrl+pillar+ mirror |
| Convex exterior mirror glass |
| Fixed roof |
BUMPER TRIM:
| Body colour bumper strip |
GLASS (APPEARANCE):
| Tinted + over-tinted rear |
| Heated & reflec w/screen + side & rr toughened |
| No acces and handsfree starting |
| Leather ’claudia" entire q3 |
| Without theft protection alarm |
CIGAR LIGHTER:
| Front cigar-lighter |
REAR HEAD RESTRAINT:
| Rear headrest adjustable |
FRONT HEAD RESTRAINT:
| Jointed front headrest |
| Sepa folding cushion + sepa folding seat back |
REAR SEAT ARMREST:
| With rear armrest |
| Rear 3-point 3 inertia reel seat belt |
FRONT SEATBELT:
| Pyrotechnic seat belt with alarm |
| Cold countries |
CHILD LOCK:
| Without child lock |
| Graduation kms/h |
TACHOMETER:
| Digital rev counter |
| Left hand drive |
ADDITIONAL HEATING:
| Without additionnal heating |
| Fascia met kurtz low ctrl panel+pen holder painted |
MISC. INT. LAMPS:
| Map reading lamp |
| Digital instrument panel lion grey front panel |
DOOR TRIM:
| Satin chrome door trim decoration |
| 4 fr speakers (2 tw + 2 fr) + 2 rr speakers |
| Remote radio control |
| Without sun visor screen |
| Without front passenger seat height adjustment |
DRIVER SEAT CONTROL:
| Drivers frt seat manual cntrol |
FRONT PASSENGER SEAT CONTROL:
| Passenger frt seat manual cntr |
DRIVER SEAT ADJUSTMENT:
| Driver’s lumbar support |
| Without passenger’s side and lumbar supports |
DRIVER’S SEAT FOLDING:
| With fold driv front seating |
FRONT PASSENGER SEAT FOLDING:
| With fold pass front seating |
FRONT SEAT ARMREST:
| Central armrest |
| Without compact disc |
STOWAGE BIN:
| With setting box |
| Without navigation system |
HEADLAMP BULBS:
| Discharge bulb |
| Without rear glass lift |
TRAFFIC INFORMATION READER:
| Without lateral trajectory monitoring |
| Display (radio+clock,t��,cd) |
COURTESY MIRROR:
| Driver’s + passenger’s concealable with light |
OIL GAUGE:
| Std oil level indicator |
FITTING REAR HEAD RESTRAINT:
| Mount 3 rear head-rest |
| Heated seat |
| Thorax side + curtain airbag |
PASSENGER AIRBAG:
| Passenger airbag |
ELECTRIC WINDOW (OPERATION):
| Driver + passenger electric window auto stop |
EQUIPMENT PACK:
| Without driving school equipment pack |
| Heated door mirror |
| Manual airbag deactivation |
| Soft mistral appearance interior door control |
REAR LOAD FLOOR:
| Without rear load floor |
HEADLAMP HEIGHT ADJUSTER:
| Automatic headlamp adjustment |
FRONT SEAT GUARD:
| Without cab protection panel |
FRONT SUN VISOR:
| Driver’s+passenger’s side without inscription |
STORAGE (DRIVING POSITION):
| Closed side storage compartment + bezel |
| "rd4" rds compact disc audio system |
| Automatic air conditioning |
| Regulator or speed limit |
DRIVER’S SEAT HEIGHT CONTROL:
| Parallel drv height adj |
INTERIOR REAR VIEW MIRROR:
| Day -night inner rear mirror |
CARPET COVER:
| Carpet mat 1 |
DRIVER AIRBAG:
| Drivers air bag |
LOAD SPACE STORAGE:
| With net + removable storage compartment in boot |
CARPET:
| Needled carpet dilour f550 |
TUNER RADIO:
| Mono radio tuner |
INTERIOR PROTECTION:
| Without inner protection |
OBSTACLE DETECTION SYSTEM:
| Front-rear radar obstacle sensor |
LATERAL BLINDS:
| Without side blinds |
| Aluminium gear lever knob + leather gaiter |
FLOOR MAT:
| With carpetmat |
EQUALISER AMPLIFIER:
| Without equaliser amplifier |
| Simple + automatic central locking |
| Standing steering wheel |
| Without interior child monitoring mirror |
| Alternator 150 amp |
| Battery l2 400 |
| Starter motor cl 4 |
| Automatic headlamp illumination |
MULTIPLEXING:
| Multiplexing assembly can can |
| Standard |
| Normal atmosphere |
RADIO HEADPHONE SOCKET:
| With accessories socket |
TRAFFIC SIDE:
| Driving on the right-hand side |
SIDE IMPACTS:
| Door without reinforcement |
SET OF KEYS:
| 1 hf plip key + 1 single main key |
EMERGENCY EQUIPMENT:
| W/o help equipment |
SURFACE CONDITIONS:
| Good terrain |
SLAVE CONTROL UNIT:
| Bsi + com fixed hub steering wheel |
EMERGENCY WARNING TRIANGLE:
| Without warning triangle |
