TEMAT: Citroën Berlingo Spacelight 2.0 HDi - Poznań
Citroën Berlingo Spacelight 2.0 HDi - Poznań 2014/02/04 11:18 #56346
  • thomac
  • thomac Avatar
Citroën Berlingo Spacelight 2.0 HDi - Poznań 2014/02/08 03:34 #56563
nie ma bata zeby byl to przebieg oryginalny
VF7MFRHYB65801941
VF7MFRHYB65801941
France
Citroen
BERLINGO
Van-wagon
Skrzynia biegów:
manual, 5-speed
Diesel Fuel
Vehicle family:
BERLINGO
AS RPO No:
09216 FV 1 0642
Warranty Start Date:
26/04/2002
Engine serial number:
10 DYJP 3029799
Gearbox serial number:
20 TE29 4322484
OPB:
103B
BER:
e2*98/14*0201*05
PRODUCT TYPE:
UTILITY VEHICLE
CITROEN
VEHICLE FAMILY:
BERLINGO
SILHOUETTE:
ESTATE VAN
TRIM LEVEL:
MULTISPACE SLIDING SIDE DOOR
TURBO DIESEL DW10TD
BVM5
DELACROIX CLOTH "LX"
UPHOLSTERY COLOUR:
"FZ"
BE3 L
EW/DW
OTHER BADGE:
WITHOUT FULLER BADGE
OTHER BADGE, " MISC. ":
BERLINGO
BADGE:
HDI
STEERING:
POWER STEERING
SPEEDOMETER DRIVE:
TACHO TORQUE 22X19
TURBO DIESEL DW10TD
EEC 2000 CLEANING (ENGINE)
Standard for emissions of exhaust gases in the atmosphere (as approved):
CLEANING L4 (HOMOLOGATION)
ABS:
WITHOUT ABS brakes
Steering:
Power steering
Suspension:
Front / rear. REINFORCED SUSPENSION
The secondary screen (under the engine):
PROTECTION OF CRANKCASE
Rear window wiper:
Rear window wiper
Rear carrier on the roof:
WITHOUT the sunroof
The rear tailgate:
Sliding LEO. RIGHTS. BOK. DOOR
Bumper:
Two-tone BUMPER
Front fog lamp:
NO FRONT FOG LAMPS
Luke:
FIXED ROOF
Color Trunk:
WITHOUT HOOD
Finishing bumper:
BUMPER WITHOUT chrome inserts
Glass back door (type):
Rear window heated
Glass (exterior):
TOPIROVANNY
Window (type):
ATERMALNOGO WITHOUT WINDSCREEN
Side window (only for commercial vehicles):
2 NAPOL.OTKRYV. WINDOWS EACH SIDE
Anti-theft alarm system:
WITHOUT PROTECTIVE SIGNALING
Headrest Rear Seat:
ADJUSTABLE HEADREST REAR SEAT
Rear seat:
SEPARATE STORAGE. REAR SEAT
Cover for luggage:
With baggage COVER
Additional heating system:
WITHOUT HEATER
A variety of interior lighting lamps:
Backlighting CARD
Adjust the front passenger seat:
BACK PASS. Seats. With Regulus. TILT
Folding front passenger seat:
From the warehouse. FRONT SEAT. PASSENGER
Window Lifter driver's side door:
POSLED.EL.STEKLOPOD.OKNA DRIVER.
Window lift door on the passenger side:
ЭЛЕКТР.СТЕКЛОПОД.ПЕРЕД.ПАССАЖ.ОКНА
Heating element:
SEAT WITHOUT HEATING
The rear sliding panel:
REAR GLASS
Control System headlamp aiming:
REMOTE CONTROL HAND LAMPS
Protecting the front seat:
CABIN WITHOUT PROTECTIVE PANEL
The air conditioning system:
AIR CONDITIONING
Mat:
Flooring 'DILOURS' F330
Switch:
Immobilizer Key
System control block:
SIMPLE central locking
TURBO DIESEL DW10TD
CYLINDER BLOCK (MATERIAL):
CRANKCASE CAST IRON
DIESEL FUEL
EEC 2000 DEPOLL (ENGINE)
PRE-FILTER:
ASSEMBLY WITHOUT PRE-FILTER
EW/DW
CATALYTIC CONVERTER:
3 PARTS CATALYST
MNTG WATER/OIL EXCHANGER ON ENGINE
FUEL SUPPLY IMPROVEMENT:
W/O PETROL FEED IMPROVEMENT
POWER VARIATION (ENGINE):
STANDARD POWER
REGULATION 70/221 (FUEL LEAKS):
WITH ANTI-RETURN VALVE
WITHOUT "EOBD" AUTO-DIAGNOSTIC
L4 VEHICLE TECHNICAL DEPOLLUTION
FUEL VAPOUR RETRIEVAL:
WITHOUT PETROL VAPOUR RECUPERATION
SIEMENS ASSEMBLY
BVM5
BE3 L
REAR AXLE HYPOID GEARSET 19 X 70
SPEEDOMETER DRIVE:
TACHO TORQUE 22X19
BLACK 14 INCH STEEL WHEEL
SEAL, WHEEL END:
WHEEL-SIDE JOINT DIAM 17 5
SEAL, DIFFERENTIAL END:
AXLE-SIDE JOINT JB2A
TYRE 175/70 R14 T NON-REINFORCED
STEEL WHEELS
BE3R MANUAL GEARBOX
REAR ANTI-ROLL BAR:
REAR ANTI-ROLL BAR DIAM 21
STEERING:
POWER STEERING
FRONT ANTI-ROLL BAR DIAM 21
BRAKE TYPE:
VENTILATED FRONT DISCS/REAR DRUMS
NORMAL SUSPENSION
BRAKE ASSOCIATED VARIANT:
ADDITIONAL ABS5 3 BOSCH
TOWBAR:
WITHOUT TOWBAR
BODY COLOUR LATERAL PROTECTORS
ST MALO STYLE 6 HOLES 14 INCHES
THIRD BRAKE LAMP:
WITH EYE LEVEL REAR LIGHTS
W/O ENGINE UNDERSHELDING
REAR SCREEN WIPER:
REAR SCREEN WIPER
W/O HEADLAMP WIPER
REAR ROOF FLAP:
W/O ROOF TRAP
SIDE LOAD DOOR:
SLIDING RH LH SIDE DOOR
BUMPER:
BODY COLOUR BUMPERS WIHTOUT EMBELLISHER
LUGGAGE RACK:
WITHOUT ROOF BARS
NO FRONT FOG LIGHTS
HT EXT RRVW MIRROR MN INT CTR
OUTSIDE PASS RRVIEW MIRROR HEATED ELEC CNTRL
STEEL WHEEL + STANDARD TYRE
C HANDLES/MIRRORS C PLATE LIGHTING C BOOT PROTECT
SPARE WHEEL MOUNTING:
SECURE SPARE WHEEL CARRIER
FIXED ROOF
HOOD COLOUR:
WITHOUT HOOD
BUMPER TRIM:
BUMPER WITHOUT CHROME INSERT
REAR WINDOW (TYPE):
REAR GLASS HEATED
GLASS (APPEARANCE):
TINTED
ATHERMAL WINDSCREEN
SIDE WINDOW (COMM. VEH. ONLY):
2 HALF-OPENING WINDOWS EACH SIDE
WITHOUT THEFT PROTECTION ALARM
REAR HEAD RESTRAINT:
REAR HEADREST ADJUSTABLE
SEPARATE FOLD BACK BENCH SEAT
LUGGAGE COVER:
WITH LUGGAGE COVER
FRONT SEATBELT:
PYROTECHNIC SEAT BELT WITHOUT ALARM
COLD COUNTRIES
AIR CONDITIONING:
WITH AIR RECYCLING
GRADUATION KMS/H
TACHOMETER:
REV COUNTER WITH NEEDLE
LEFT HAND DRIVE
ADDITIONAL HEATING:
WITHOUT ADDITIONNAL HEATING
MISC. INT. LAMPS:
MAP READING LAMP
LOAD SPACE TRIM:
RUBBER MAT LEV C
GRADUATION MAXI 180 K/H OR 110 M/H DIALS BLUE
TACHOMETER (SIGNAL CONNECTION):
REV COUNTER CALC
ASSEMBLY 2 FT SPEAKERS+2 RR SPEAKERS+TWEETERS
DRIVER SEAT CONTROL:
DRIVERS FRT SEAT MANUAL CNTROL
FRONT PASSENGER SEAT CONTROL:
PASSENGER FRT SEAT MANUAL CNTR
PASSENGER TILTING BACK
DRIVER’S SEAT FOLDING:
WITH FOLD DRIV FRONT SEATING
FRONT PASSENGER SEAT FOLDING:
WITH FOLD PASS FRONT SEATING
DRIVER’S WINDOW LIFT:
SEQUENTIAL DRIVER’S ELECTRIC WINDOW
PASSENGER’S WINDOW LIFT:
ELEC CNTRL PASS FRONT WINDOW LIFTER
CLOCK:
NUMERIC CLOCK
COURTESY MIRROR:
PASSENGER SIDE WITHOUT LIGHTING
OIL GAUGE:
OIL LEVEL WARNING INDICATOR
NON HEATED SEAT
PASSENGER AIRBAG:
PASSENGER AIRBAG
MANUAL AIRBAG DEACTIVATION
REAR MOVING PANEL:
REAR WINDOW
HEADLAMP HEIGHT ADJUSTER:
REMOTE MANUAL HEADLAMP ADJUSTMENT
FRONT SEAT GUARD:
WITHOUT CAB PROTECTION PANEL
"RD1" RDS COMPACT DISC AUDIO SYSTEM
AIR CONDITIONING
DRIVER AIRBAG:
DRIVERS AIR BAG
CARPET:
DILOURS CARPET F330
SWITCH:
ELECTRONIC ANTI-THEFT KEY
WATER TEMP INDICATOR:
WATER TEMP INDIC +RED TELLTALE
FLEXIBLE HEAT PARTITION:
W/O SUPPLE THERMIC PANEL
SIMPLE CENTRAL LOCKING
ALTERNATOR 150 AMP
BATTERY (TYPE):
MAINTAINANCE-FREE BATTERY
BATTERY L2 400
CLASS 6 STARTER MOTOR
WITHOUT PARTICULAR LIGHT
CENTRAL LOCKING CONTROL:
CENTR LOCK SYSTM DRIVER’SIDE
ELECTRIC VEHICLE CHARGING PLUG:
WITHOUT VEHICLE LOAD RECOGNITION
NEW FRONTIERS
NORMAL ATMOSPHERE
TRAFFIC SIDE:
DRIVING ON THE RIGHT-HAND SIDE
ADDITIONAL TYPE APPROVAL PLATE:
W/O ADDIT HOMOLOGATION PLATE
SLAVE CONTROL UNIT:
BUILT-IN SYSTEMS INTERFACE (BSI)
GALERIA # 0
