| Turbocharged diesel engine with FAP DV6TED4 |
Fuel:
| DIESEL FUEL |
| Emission standard L5 (ENGINE) |
Technical means to protect the environment:
| CAR with technical cleaning L5 |
A dynamic system of sustainability:
| Electronic Stability Program |
Trunk grille:
| WITHOUT BAGAZH.RELSOV ON THE ROOF |
Luke:
| FIXED ROOF |
Landing and the engine is started without a key:
| Without systems. ACCESS AND START MOTOR. "Hands free" |
Rear seat:
| FOLDING SEPARATE CUSHION AND BACK SEATS |
Tachometer:
| DIGITAL TACHOMETER |
Additional heating system:
| AUTOMATIC UPDATE. HEAT |
Curtains (curtains, side curtains, sunroof):
| WITHOUT sunshields |
Airbag on the passenger side:
| Passenger Airbag |
System deactivation of airbags:
| HAND-OFF AIRBAGS |
Protecting the front seat:
| CABIN WITHOUT PROTECTIVE PANEL |
Cruise Control:
| REGULATORS and speed limiter |
Airbag driver side:
| Driver Airbag |
Interior Protection:
| WITHOUT INTERNAL SECURITY |
Side-curtain:
| Without side curtains |
| DIESEL TURBO DV6TED4 FAP |
FUEL SUPPLY:
| DIRECT EXCHANGE TURBO INJECTION |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE ALUMINIUM |
| DIESEL FUEL |
| EV/DV |
CAPACITY:
| 1600 CM3 |
CATALYTIC CONVERTER:
| 2-COMPONENT PLATINUM FILTER CATALYSER |
| MNTG WATER/OIL EXCHANGER ON ENGINE |
COOLING MOTOR:
| RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
| PARTICLE FILTER |
| 2 FANS , 2 RATES , IMPROVED 130WAERO |
FUEL VAPOUR RETRIEVAL:
| WITHOUT PETROL VAPOUR RECUPERATION |
| MOUNTING BOSCH |
TANK FILTER:
| RESERVOIR FILTER INTERIOR |
| 6-SPEED CONTROLLED MANUAL GEARBOX |
| MCD MANUAL GEARBOX |
| CP 19 X 71 |
| 16-INCH STEEL WHEEL |
CLUTCH:
| HYDRAULIC CLUTCH |
GEARBOX TYPE (TYPE APPROVAL):
| MCD GEARBOX TYPE |
DIFFERENTIAL (GEARBOX):
| DIFFERENTIAL 77 |
| TYRE 205X55X16 V |
WHEELS FITTED:
| 6,5" RIM ROAD WHEELS |
| MOUNTING LEV 2 STEEL WHEEL |
| WITHOUT TYRE DEFLATION INDICATOR |
| MC MANUAL GEARBOX |
REAR ANTI-ROLL BAR:
| REAR ANTI ROLL BAR DIAM 27 |
STEERING COLUMN:
| MANUALLY ADJUSTED STEERING COLUMN |
| FRONT ANTI-ROLL BAR DIAM 22 |
POWER STEERING FLUID COOLING SYSTEM:
| WITHOUT POWER STEERING OIL COOLING |
| NORMAL SUSPENSION |
BRAKE ASSOCIATED VARIANT:
| ESP BOSCH 8 0 |
STEERING (OPERATION):
| ASSISTED ELECTROHYDRAULIC STEERING |
PEDAL BRACKET (TYPE):
| PEDAL STANDARD |
HORNS:
| HORN STANDARD |
AERIAL:
| SHORT ROOF AERIAL |
REAR SPOILER:
| FITTING WITH RR UPPER DEFLECTOR |
DECORATION (PAINTED):
| SOLID COLOUR DECOR |
| LATERAL PROTECTOR MASS TINTED |
SIDE MOULDINGS (DIMENSION):
| WITHOUT LATERAL PROTECTORS |
| 16 INCH 8-SPOKE AZZANA STYLE |
REVERSING LAMPS:
| WITH 1 REVERSING LAMP |
SILL ILLUMINATION LAMP:
| WITHOUT SILL ILLUMINATION |
| W/O ENGINE UNDERSHELDING |
DRAUGHT EXCLUSION:
| BONNET WITHOUT SEAL |
| EXT MIRROR MANUAL-FOLD BACK |
EXHAUST TAILPIPE TRIM:
| W/O EXHAUST OUTLET EMBELLISHER |
ENGINE BAY SOUNDPROOFING:
| BONNET SOUNDPROOFING |
REAR SCREEN WIPER:
| REAR SCREEN WIPER |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
ROOF GLASS:
| WITHOUT ROOF WINDOW |
REAR TAILGATE GLASS:
| FIXED TAILGATE WINDOW |
BUMPER:
| BODY COLOUR STANDARD FRONT/REAR BUMPER |
MUDFLAP:
| WITHOUT REAR MUDGUARD |
NUMBER PLATE:
| WITHOUT LICENCE PLATE |
LUGGAGE RACK:
| WITHOUT ROOF BARS |
| FRONT FOG LIGHTS |
| REDUCED STEEL WHEEL + NON STD TYRE |
| BODY COLOUR EXT HANDLE+RR CTRL+PILLAR+ MIRROR |
| CONVEX EXTERIOR MIRROR GLASS |
| FIXED ROOF |
BUMPER TRIM:
| BODY COLOUR BUMPER STRIP |
GLASS (APPEARANCE):
| TINTED |
| HEATED & REFLEC W/SCREEN + SIDE & RR TOUGHENED |
| NO ACCES AND HANDSFREE STARTING |
| VELOUR SOUNDTRACK + TABRE "SS" |
CIGAR LIGHTER:
| FRONT CIGAR-LIGHTER |
REAR HEAD RESTRAINT:
| REAR HEADREST ADJUSTABLE |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| SEPA FOLDING CUSHION + SEPA FOLDING SEAT BACK |
REAR SEAT ARMREST:
| WITH REAR ARMREST |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITH ALARM |
| COLD COUNTRIES |
CHILD LOCK:
| ELECTRIC REAR CHILD LOCK |
| GRADUATION KMS/H |
TACHOMETER:
| DIGITAL REV COUNTER |
| LEFT HAND DRIVE |
ADDITIONAL HEATING:
| AUTOMATIC ADDITIONAL HEATING |
| FASCIA BOMBAY BROWN LOW CTRL PAN+PEN HOLDER PAINT |
MISC. INT. LAMPS:
| 3-POSITION FR COURTESY LAMP |
| DIGITAL INSTRUMENT PANEL LION GREY FRONT PANEL |
DOOR TRIM:
| DOOR PANEL WITHOUT WOOD DECOR |
| 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| REMOTE RADIO CONTROL |
PASSENGER COMPARTMENT SOUNDPROOFING:
| 6 KG BULKHEAD SOUNDPR |
| WITHOUT SUN VISOR SCREEN |
| WITHOUT FRONT PASSENGER SEAT HEIGHT ADJUSTMENT |
DRIVER SEAT CONTROL:
| DRIVERS FRT SEAT MANUAL CNTROL |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT MANUAL CNTR |
DRIVER SEAT ADJUSTMENT:
| DRIVER’S LUMBAR SUPPORT |
| WITHOUT PASSENGER’S SIDE AND LUMBAR SUPPORTS |
DRIVER’S SEAT FOLDING:
| W/O FOLDING DRIV FRONT SEATING |
FRONT PASSENGER SEAT FOLDING:
| W/O FOLDING PASS FRONT SEATING |
FRONT SEAT ARMREST:
| CENTRAL ARMREST |
| WITHOUT COMPACT DISC |
STOWAGE BIN:
| WITHOUT SETTING BOX |
| WITHOUT NAVIGATION SYSTEM |
HEADLAMP BULBS:
| HALOGEN BULB |
| SEQENT CONTR RR WINDOW LIFTER |
TRAFFIC INFORMATION READER:
| WITHOUT LATERAL TRAJECTORY MONITORING |
| DISPLAY (NAVIGATION+RADIO+CLOCK, TEMP, CD) |
COURTESY MIRROR:
| DRIV OCCULT+PASS OCCULT W/O LIGHT |
OIL GAUGE:
| STD OIL LEVEL INDICATOR |
FITTING REAR HEAD RESTRAINT:
| MOUNT 3 REAR HEAD-REST |
| NON HEATED SEAT |
| THORAX SIDE + CURTAIN AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
EQUIPMENT PACK:
| WITHOUT DRIVING SCHOOL EQUIPMENT PACK |
| HEATED DOOR MIRROR |
| BOMBAY BROWN APPEARANCE INTERIOR DOOR CONTROL |
REAR LOAD FLOOR:
| WITHOUT REAR LOAD FLOOR |
HEADLAMP HEIGHT ADJUSTER:
| REMOTE MANUAL HEADLAMP ADJUSTMENT |
FRONT SEAT GUARD:
| WITHOUT CAB PROTECTION PANEL |
FRONT SUN VISOR:
| DRIVER’S+PASSENGER’S SIDE WITHOUT INSCRIPTION |
STORAGE (DRIVING POSITION):
| CLOSED SIDE STORAGE COMPARTMENT + BEZEL |
| "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM |
| REGULATOR OR SPEED LIMIT |
DRIVER’S SEAT HEIGHT CONTROL:
| PARALLEL DRV HEIGHT ADJ |
INTERIOR REAR VIEW MIRROR:
CARPET COVER:
| W/O CARPETMAT |
DRIVER AIRBAG:
| DRIVERS AIR BAG |
LOAD SPACE STORAGE:
| WITH NET + REMOVABLE STORAGE COMPARTMENT IN BOOT |
CARPET:
| VELOUR CARPET SOMTEX F470 |
TUNER RADIO:
| DUAL RADIO TUNER |
INTERIOR PROTECTION:
| WITHOUT INNER PROTECTION |
OBSTACLE DETECTION SYSTEM:
| REAR RADAR OBSTACLE SENSOR |
LATERAL BLINDS:
| WITHOUT SIDE BLINDS |
| GEAR LEVER KNOB CHROME INSERT |
FLOOR MAT:
| W/O CARPETMAT |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| SIMPLE + AUTOMATIC CENTRAL LOCKING |
| SPORT STEERING WHEEL |
| WITHOUT INTERIOR CHILD MONITORING MIRROR |
| ALTERNATOR 150 AMP |
| BATTERY L3 450 |
| CLASS 6 STARTER MOTOR |
| AUTOMATIC HEADLAMP ILLUMINATION |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY CAN CAN |
| STANDARD |
| NORMAL ATMOSPHERE |
RADIO HEADPHONE SOCKET:
| WITH ACCESSORIES SOCKET |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SET OF KEYS:
| 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
EMERGENCY EQUIPMENT:
| W/O HELP EQUIPMENT |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SLAVE CONTROL UNIT:
| BSI + COM FIXED HUB STEERING WHEEL |
EMERGENCY WARNING TRIANGLE:
| WITHOUT WARNING TRIANGLE |
