| TU5JP4 INJECTION |
Fuel:
| UNLEADED GASOLINE |
| Emission standard L5 (ENGINE) |
Technical means to protect the environment:
| CAR with technical cleaning L5 |
ABS:
| With ABS brakes |
Steering:
| Power steering |
Towing system:
| FREE Hook |
Trunk grille:
| WITHOUT BAGAZH.RELSOV ON THE ROOF |
Additional heating system:
| WITHOUT HEATER |
CD:
| FREE CDs |
Protection of passengers in the rear seat:
| WITHOUT PROTECTION REAR PASSENGER |
System deactivation of airbags:
| HAND-OFF AIRBAGS |
| TU5JP4 INJECTION |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE CAST IRON |
| LEAD FREE PETROL |
| TU |
| WITHOUT OIL-WATER DISTR CHAMB |
COOLING MOTOR:
| RADIATOR 27MBA - 21 DM2 - PAS 1.1 |
POWER VARIATION (ENGINE):
| STANDARD POWER |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| WITHOUT ANTI-POLLUTION DEVICE |
| WITHOUT PARTICLE FILTER |
| 140W AERO 2 SPEED FAN |
| MOUNTING MAGNETI MARELLI |
| MOTORISED THROTTLE BODY (ENG AIR INTAKE) |
| BVM5 |
| BE4-5V MANUAL GEARBOX |
| REAR AXLE HYPOID GEARSET 17 X 71 |
| 15 INCH STEEL WHEEL |
CLUTCH:
| HYDRAULIC CLUTCH |
SEAL, WHEEL END:
| WHEEL-SIDE JOINT DIAM 17 5 |
SEAL, DIFFERENTIAL END:
| AXLE-SIDE JOINT JB2A |
DIFFERENTIAL (GEARBOX):
| DIFFERENTIAL 77 |
| 185X65X15 H TYRES |
| STEEL WHEELS |
| GEARBOX BE4R |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 21 |
STEERING:
| POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 21 |
BRAKE TYPE:
| VENTILATED FRONT DISCS/REAR DRUMS |
| NORMAL SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
BRAKE ASSOCIATED VARIANT:
| BOSCH ABS 8 0 |
TOWBAR:
| WITHOUT TOWBAR |
| 15 INCH 16-SPOKE BAYONNE STYLE |
| W/O ENGINE UNDERSHELDING |
| EXT MIRROR MANUAL-FOLD BACK |
| WITHOUT FRONT BUMPER PLUG |
LUGGAGE RACK:
| WITHOUT ROOF BARS |
| FRONT FOG LIGHTS |
| PAINTED EXT HANDLES+SIDE MOULDINGS+EXT MIRRORS |
| FIXED ROOF |
BUMPER TRIM:
| BODY COLOUR BUMPER STRIP |
GLASS (APPEARANCE):
| TINTED |
| REPS + SPOTTED "SV" |
| 3 SEPARATED REAR SEATS (1 SLIDING) |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITHOUT ALARM |
| COLD COUNTRIES |
| GRADUATION KMS/H |
CONSOLE:
| WITHOUT CONSOLE |
| LEFT HAND DRIVE |
ADDITIONAL HEATING:
| WITHOUT ADDITIONNAL HEATING |
| CAPPING V098 + SOLID COLOUR FRONT PANEL |
| MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS |
| REMOTE RADIO CONTROL |
| WITHOUT REAR BLIND |
DRIVER SEAT ADJUSTMENT:
| DRIVER’S LUMBAR SUPPORT |
FRONT SEAT ARMREST:
| FITTED WITH ARMREST |
| WITHOUT COMPACT DISC |
| WITHOUT NAVIGATION SYSTEM |
| MAN CTRL REAR WINDOW LIFTER |
| NON HEATED SEAT |
| DOUBLE FRONT LATERAL AIRBAG |
REAR PASSENGER PROTECTION:
| W/O RR PASSENGER PROTECTION |
ADDITIONAL AIR CONDITIONING:
| WITHOUT ADDITIONAL AIR CONDITIONING |
| HEATED DOOR MIRROR |
| "RD3" RDS COMPACT DISC AUDIO SYSTEM |
| WITHOUT SPEED CONTROL |
LOAD SPACE STORAGE:
| WITHOUT LOADING RUNNER |
OBSTACLE DETECTION SYSTEM:
| WITHOUT OBSTACLE DETECTOR |
| WITHOUT MOULDING ADAPTATION |
| LEATHER STEERINGWHEEL |
| ALTERNATEUR CLASSE 8+ |
| BATTERY L1 300 |
| STARTER MOTOR CL 3 |
| DAYLIGHT RUNNING LIGHTS |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY CAN VAN |
| STANDARD |
| NORMAL ATMOSPHERE |
SLAVE CONTROL UNIT:
| BSI COMM 2000 |
