Samochod 6 letni diesel sprowadzony z hakiem i taki przebieg. Marzenie
setka do niego dodana to takie minimum. Pochodzenie Francja wiec na 99% dodatkowo mogl byc uszkodzony i to konkretnie
| TURBO DIESEL DW10BTED4 |
Trunk grille:
| WITHOUT BAGAZH.RELSOV ON THE ROOF |
| DIESEL TURBO DW10BTED4 |
FUEL SUPPLY:
| DIRECT EXCHANGE TURBO INJECTION |
DIESEL FILTER WATER DETECTOR:
| DIESEL FUEL |
| EW/DW |
CATALYTIC CONVERTER:
| 2-COMPONENT PLATINUM FILTER CATALYSER |
| MNTG WATER/OIL EXCHANGER ON ENGINE |
COOLING MOTOR:
| RADIATOR TH : 27 - 21 DM2 BRAZED ALUMINIUM |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| "EGR" EXHAUST GAS RECYCLING |
| PARTICLE FILTER |
| 1 AERO 2-SPEED 140W FAN WITHOUT SCOOP |
| SIEMENS ASSEMBLY |
TANK FILTER:
| RESERVOIR FILTER INTERIOR |
| MOTORISED THROTTLE BODY (ENG AIR INTAKE) |
STOP AND START:
| WITHOUT STOP AND START |
| 6-SPEED CONTROLLED MANUAL GEARBOX |
| MCD MANUAL GEARBOX |
| REAR AXLE HYPOID GEARSET 17 X 71 |
SPEEDOMETER DRIVE:
| W/O TACHO TORQUE |
| 17 INCH VOLUBILIS WHEEL |
CLUTCH:
| WITHOUT CLUTCH |
GEARBOX TYPE (TYPE APPROVAL):
| MCD GEARBOX TYPE |
DIFFERENTIAL (GEARBOX):
| W/O GEARBOX DIFF |
| TYRE 215X50X17 W |
| ALLOY WHEEL ASSEMBLY 2 |
| WITHOUT TYRE DEFLATION INDICATOR |
| MC MANUAL GEARBOX |
| FRONT ANTI-ROLL BAR DIAM 23 |
| NORMAL SUSPENSION |
SUSPENSION (ARCHITECTURE TYPE):
| METAL SUSPENSION |
BRAKE ASSOCIATED VARIANT:
| 8 1 BOSCH ESP |
TOWBAR:
| TOWBAR |
HORNS:
| HORN STANDARD |
AERIAL:
| SHORT ROOF AERIAL |
FINISHER (SELF-ADHESIVE):
| DOOR FRAME REAR TRIM |
REAR SPOILER:
| FITTING WITH RR UPPER DEFLECTOR |
| SOLID COLOUR + BODY COLOUR |
SIDE MOULDINGS (DIMENSION):
| THIN SIDE PROTECTORS + SIDE SILL CHROME |
| WITHOUT WHEEL CAP |
SILL ILLUMINATION LAMP:
| SILL ILLUMINATION |
| W/O ENGINE UNDERSHELDING |
| ELECTRICMEMORY FOLDING EXT REAR VIEW MIRROR |
ENGINE BAY SOUNDPROOFING:
| BONNET SOUNDPROOFING |
| W/O HEADLAMP WIPER |
| WITHOUT FRONT BUMPER PLUG |
ROOF GLASS:
| WITHOUT ROOF WINDOW |
REAR TAILGATE GLASS:
| OPENING TAILGATE WINDOW |
LUGGAGE RACK:
| WITHOUT ROOF BARS |
| FRONT FOG LIGHTS |
| REDUCED STEEL WHEEL + NON STD TYRE |
| BODY COLOURED EXT HANDLE+FLAP TRIM+EXT MIRROR |
| CONVEX EXTERIOR MIRROR GLASS |
| FIXED ROOF |
BUMPER TRIM:
| BUMPER WITH CHROME INSERT |
GLASS (APPEARANCE):
| TINTED + MOULDED RR WINDOW GLASS |
REAR QUARTER WINDOW (TYPE):
| FIXED REAR QTR GLASS |
| LAM ATHERM+ACOUS WINDSCREEN + TOUGH REAR SCREEN |
| ANJOU + OMNIREPS "TO" CLOTH |
FRONT HEAD RESTRAINT:
| JOINTED FRONT HEADREST |
| 3 SEPARATE REAR SEATS (3 SLIDING) |
SUPPLEMENTARY SEAT:
| WITHOUT SUPPLEMENTARY SEAT POSITN |
REAR SEAT ARMREST:
| WITHOUT REAR ARMREST |
LUGGAGE COVER:
| SHELF |
FRONT SEATBELT:
| PYROTECHNIC SEAT BELT WITH ALARM |
| TEMPERATE COUNTRIES |
AIR CONDITIONING:
| WITH HEATER MATRIX |
CHILD LOCK:
| ELECTRIC REAR CHILD LOCK |
| GRADUATION KMS/H |
RADIO EQUIPMENT:
| FEED AERIAL RECEIV FRT SPEAKER TWT REAR SPEAKER |
| LEFT HAND DRIVE |
REMOTE CONTROL:
| HEADLAMP ILLUMINATION WITH PLIP |
ADDITIONAL HEATING:
| AUTOMATIC ADDITIONAL HEATING |
BOOT AND LOAD SPACE LIGHTING:
| BOOT + LOAD SPACE + AMV LIGHTING AUTO CONTROL |
| STD FASCIA PANEL EQUIPMENT + PAINTED UPPER VP |
INT. TRIM AND EQUIPMENT VARIATION:
| LEATHER INTEROR EQUIPMENT FITTINGS |
MISC. INT. LAMPS:
| MAP READING LAMP |
WORK TABLE:
| WITH WORK TABLE |
UNDERSEAT STORAGE:
| WITHOUT UNDER SEAT STORAGE |
DOOR TRIM:
| DOOR TRIM PAD WITHOUT DECOR |
| 4 FR SPEAKERS (2 TW + 2 FR) + 2 RR SPEAKERS |
| REMOTE RADIO CONTROL |
| WITHOUT REAR BLIND |
| FRONT PASSENGER SEAT CUSHION HEIGHT ADJUSTMENT PARALLEL ADJUSTMENT |
DRIVER SEAT CONTROL:
| DRIVERS FRT SEAT MANUAL CNTROL |
FRONT PASSENGER SEAT CONTROL:
| PASSENGER FRT SEAT MANUAL CNTR |
DRIVER SEAT ADJUSTMENT:
| RECLINING DRIVER’S SEAT BACK |
| PASSENGER TILTING BACK |
FRONT SEAT ARMREST:
| DRIVER ANT PASSENGER FRONT ARMREST |
| WITHOUT COMPACT DISC |
STOWAGE BIN:
| WITH COOLED STORAGE BOX |
| WITHOUT NAVIGATION SYSTEM |
HEADLAMP BULBS:
| HALOGEN BULB |
| SEQUENTIAL ELECTRIC REAR WINDOW + LOCKING |
TRAFFIC INFORMATION READER:
| WITHOUT LATERAL TRAJECTORY MONITORING |
DRIVER’S WINDOW LIFT:
| SEQUENTIAL DRIVER’S ELECTRIC WINDOW |
PASSENGER’S WINDOW LIFT:
| SEQUEN CONTROL PASSENG FRONT WINDOW LIFTER |
| DISPLAY (NAVIGATION+RADIO+CLOCK, TEMP, CD) |
SUPPLEMENTARY SEAT SEATBELT:
| W/O SUPPLY SEAT SAFETY BELT |
FITTING REAR HEAD RESTRAINT:
| MOUNT 3 REAR HEAD-REST |
| NON HEATED SEAT |
| THORAX SIDE + CURTAIN AIRBAG |
PASSENGER AIRBAG:
| PASSENGER AIRBAG |
ELECTRIC WINDOW (OPERATION):
| DRIVER’S + FRONT/REAR PASSENGER’S ANTI-PINCH |
ADDITIONAL AIR CONDITIONING:
| WITHOUT ADDITIONAL AIR CONDITIONING |
HEADLAMP HEIGHT ADJUSTER:
| REMOTE MANUAL HEADLAMP ADJUSTMENT |
| "RD4/MP3" RDS COMPACT DISC AUDIO SYSTEM |
INTERIOR REAR VIEW MIRROR:
| DAY -NIGHT INNER REAR MIRROR - WITHOUT ELECTROCHRO |
LOAD SPACE STORAGE:
| REMOVABLE LOADING RUNNER |
TUNER RADIO:
| MONO RADIO TUNER |
INTERIOR PROTECTION:
| WITHOUT INNER PROTECTION |
OBSTACLE DETECTION SYSTEM:
| REAR RADAR OBSTACLE SENSOR |
LATERAL BLINDS:
| SIDE BLINDS "ROW 2" |
| WITHOUT MOULDING ADAPTATION |
FLOOR MAT:
| W/O CARPETMAT |
EQUALISER AMPLIFIER:
| WITHOUT EQUALISER AMPLIFIER |
| SIMPLE + AUTOMATIC CENTRAL LOCKING |
| SPORT LEATHER STEERING WHEEL |
DRIVER’S KNEE AIRBAG:
| DRIVER’S KNEE AIRBAG |
REAR VIDEO SCREEN:
| WITHOUT REAR VIDEO SCREEN |
| INTERIOR CHILD MONITORING MIRROR |
SUPPLEMENTARY HEATER:
| WITHOUT ADDITIONAL HEATING |
AUDIO PACK AUXILIARY SOCKET:
| WITHOUT AUDIO PACK AUXILIARY SOCKET |
| ALTERNATOR CLASS 18 180 AMP |
| BATTERY L3 500 |
| STARTER MOTOR CLASS 6+ |
| AUTOMATIC HEADLAMP ILLUMINATION |
CEN. LOCKING REM CONTROL FREQUENCY:
| LOCKING REMOTE CONTROL FREQUENCY 433.92 MHZ HETERODYNE |
MULTIPLEXING:
| MULTIPLEXING ASSEMBLY CAN CAN |
BATTERY CHARGE MEASUREMENT:
| WITH BATTERY CHARGE MEASUREMENT |
RADIO FREQUENCY:
| WESTERN EUROPE RADIO FREQUENCY |
| STANDARD |
| NORMAL ATMOSPHERE |
LABEL:
| WITHOUT LABEL |
RADIO HEADPHONE SOCKET:
| WITH ACCESSORIES SOCKET |
TRAFFIC SIDE:
| DRIVING ON THE RIGHT-HAND SIDE |
SIDE IMPACTS:
| DOOR WITHOUT REINFORCEMENT |
SET OF KEYS:
| 1 HF PLIP KEY + 1 SINGLE MAIN KEY |
EMERGENCY EQUIPMENT:
| W/O HELP EQUIPMENT |
SURFACE CONDITIONS:
| GOOD TERRAIN |
SLAVE CONTROL UNIT:
| BSI + COM FIXED HUB STEERING WHEEL |
EMERGENCY WARNING TRIANGLE:
| WARNING TRIANGLE |
