| INJECTION EW7J4 |
Fuel:
| UNLEADED GASOLINE |
| EEC 2000 CLEANING (ENGINE) |
Technical means to protect the environment:
| CARS. With TEH.OCHIST. IFL5 (NAL.LGOT.) |
ABS:
| With ABS brakes |
Steering:
| Power steering |
A dynamic system of sustainability:
| FREE Electronic Stability Program |
Towing system:
| FREE Hook |
Trunk grille:
| WITHOUT BAGAZH.RELSOV ON THE ROOF |
Grading on the odometer:
| Graduations in km / h |
Additional heating system:
| WITHOUT HEATER |
CD:
| FREE CDs |
Rear door window lift:
| REAR WINDOW RUCHN.STEKLOPODEMNIK |
Protection of passengers in the rear seat:
| WITHOUT PROTECTION REAR PASSENGER |
System deactivation of airbags:
| HAND-OFF AIRBAGS |
Cruise Control:
| WITHOUT SPEED CONTROL |
| INJECTION EW7J4 |
DIESEL FILTER WATER DETECTOR:
CYLINDER BLOCK (MATERIAL):
| CRANKCASE ALUMINIUM |
| LEAD FREE PETROL |
| EEC 2000 DEPOLL (ENGINE) |
| EW/DW |
| WITHOUT OIL-WATER DISTR CHAMB |
COOLING MOTOR:
| RADIATOR 27MBA - 21 DM2 - PAS 1.1 |
POWER VARIATION (ENGINE):
| STANDARD POWER |
| "EOBD" AUTO-DIAGNOSTIC WITHOUT ACCELEROMETER |
DEVICE (ANTIPOLLUTION):
| "EGR" + "PULSAIR" AIR INJECTION |
| IFL5 VEHICLE TECHNICAL DEPOLL (TAX INCENTIVE) |
| WITHOUT PARTICLE FILTER |
| 1 3-SPEED 400W FAN WITH DYNA FLAPS |
| MOUNTING SAGEM |
| MANUAL THROTTLE BODY (ENGINE AIR INTAKE) |
| BVM5 |
| BE4-5V MANUAL GEARBOX |
| REAR AXLE HYPOID GEARSET 19 X 77 |
SPEEDOMETER DRIVE:
| TACHO TORQUE 22X18 |
| 15 INCH ESTORIL ALLOY WHEEL |
CLUTCH:
| CABLE CLUTCH TAKING UP OF PLAY |
SEAL, WHEEL END:
| WHEEL-SIDE JOINT DIAM 17 5 |
SEAL, DIFFERENTIAL END:
| AXLE-SIDE JOINT JB2A |
DIFFERENTIAL (GEARBOX):
| STD IMP GEARBOX DIFF |
| 185X65X15 H TYRES |
| ALLOY WHEELS |
| GEARBOX BE4R |
REAR ANTI-ROLL BAR:
| REAR ANTI-ROLL BAR DIAM 21 |
STEERING:
| POWER STEERING |
| FRONT ANTI-ROLL BAR DIAM 21 |
BRAKE TYPE:
| VENTILATED FRONT DISCS/REAR DRUMS |
| NORMAL SUSPENSION |
| WITHOUT ELECTRONIC STABILITY PROGRAM |
TOWBAR:
| WITHOUT TOWBAR |
| WITHOUT WHEEL CAP |
| W/O ENGINE UNDERSHELDING |
| EXT MIRROR ELECTRIC-FOLD BACK |
| SMALL BLANK (LARGE AIR INTAKE) |
LUGGAGE RACK:
| WITHOUT ROOF BARS |
| FRONT FOG LIGHTS |
| PAINTED EXT HANDLES+SIDE MOULDINGS+EXT MIRRORS |
| FIXED ROOF |
BUMPER TRIM:
| BODY COLOUR BUMPER STRIP |
GLASS (APPEARANCE):
| TINTED |
| VELOUR CORINTHIEN "KH" |
| 3 SEPARATE REAR SEATS (3 SLIDING) |
| GRADUATION KMS/H |
CONSOLE:
| WITHOUT CONSOLE |
| LEFT HAND DRIVE |
ADDITIONAL HEATING:
| WITHOUT ADDITIONNAL HEATING |
| CERBE CAPPING + PAINTED FRONT PANEL |
| MOUNTING 4 LOUDSPEAKERS + 2 TWEETERS |
| REMOTE RADIO CONTROL |
FRONT SEAT ARMREST:
| FITTED WITH ARMREST |
| WITHOUT COMPACT DISC |
| WITHOUT NAVIGATION SYSTEM |
| ELECT CNTRL RR WINDOW LIFTR |
| NON HEATED SEAT |
| DOUBLE FRONT LATERAL AIRBAG |
REAR PASSENGER PROTECTION:
| W/O RR PASSENGER PROTECTION |
ADDITIONAL AIR CONDITIONING:
| WITHOUT ADDITIONAL AIR CONDITIONING |
| "RD3" RDS COMPACT DISC AUDIO SYSTEM |
LOAD SPACE STORAGE:
| REMOVABLE LOADING RUNNER |
| GEAR LEVER KNOB CHROME INSERT |
| LEATHER STEERINGWHEEL |
| ALTERNATOR 80 AMP |
| BATTERY L1 300 |
| STARTER MOTOR CL 3 |
| WITHOUT PARTICULAR LIGHT |
MULTIPLEXING:
| WITHOUT MULTIPLEXING |
| STANDARD |
| NORMAL ATMOSPHERE |
SLAVE CONTROL UNIT:
| WITHOUT RELAY UNIT (BSI) |
